Yeti SB150 Ride, Performance and Build talk. - Page 7- Mtbr.com
Page 7 of 7 FirstFirst ... 34567
Results 601 to 632 of 632
  1. #601
    Nov 2015
    Quote Originally Posted by Druster View Post
    Thanks, all good now
    Sent from my SM-G965F using Tapatalk
    Hey, how did you solve the problem ? i still have a gap with my DropSet
  2. #602
    Jun 2005
    Just bought a SB150 frame and going to be swapping parts from a SB5.5 over to the new frame. I know that the seat post diameter is different but does anyone know what else is different? Looks like the BB will swap over but what about the headset? Anything else I might not be considering?
  3. #603
    Reputation: skinnybex's Avatar
    Aug 2015
    Quote Originally Posted by TtotheJ View Post
    You can just use a problem solvers shim thatíll allow your 30.9Ē Dropper to size up to 31.6Ē
    Youíll need a new headset as well, Iím using the CK dropset 1
    Everything else should be good to go.
  4. #604
    Reputation: Dagonger's Avatar
    Dec 2011
    Quote Originally Posted by skinnybex View Post
    Fork offset is differrent on sb150 vs sb55c
    Sent from my SM-G930T using Tapatalk
  5. #605
    Anyone running a rs lyrik on this thread?
    10 S-works Enduro
    09 Tricross comp
    08 Enduro Pro
    06 Tarmac Expert
    04 S-works Enduro
  6. #606
    Sep 2017
    I have four rides on my SB150 and freaking love it! I have been experimenting with suspension and was gonna ask if anybody has recommendations for an aggressive 160 lb rider. I had two tokens up front, stock two in the rear but I just put in an extra on both ends and will try that hopefully this weekend. Running high speed rebound in the rear two clicks slower than recommended, LSC up front is 2-3 clicks firmer than recommended with LSC in the rear being about 1 click firmer.
  7. #607
    Quote Originally Posted by JCordell View Post
    Check out the Fox website. They have some good starting point recs for both the fork and shock. Also check out the Vorsprung website if you really want to geek out and get a better understanding of HSC/LSC and HSR/LSR.
  8. #608
    Quote Originally Posted by Crit Rat View Post
    Yeti had problems with the initial rubber guard peeling off so they redesigned it. Controversial design as the new design has all these triangles cut out of it, presumably to allow some flex or curve however that also left holes where there is no protection.
    I'll solve it by cutting out some triangle of Mastic tape to protect those areas but as has said it seems like it was designed with aesthetics in mind not protection.
    My rubber guard is starting to peel -- will Yeti replace this? Or how much is the new DT guard?
  9. #609
    Dec 2011
    Quote Originally Posted by ross86 View Post
    Just email info@yeticycles.com and then will send you the updated one free of charge.
  10. #610
    Aug 2015
    Just fyi oneup has their 31.6x170 dropper on sale for $170, looks like they have a newer model coming out so old one is on sale. I bought one for my sb150 (large, orange, on the way) as the fox post I wanted wasn't available. I'll still get the Fox post, but this was a great deal for a 31.6 dropper.
  11. #611
    250 miles in, about 35k of vert so far, about 25 rides. The SB150 is working very well, no issues. Itís a monster that likes rough trail, but it still does just fine on all trail. First race of the season is next weekend and will be a relay XC race at Philís World, near Cortez, CO. Iíll put an Ardent EXO 2.4 in the front and an Ikon EXO 2.35 in the rear, add a few PSI to the fork and shock, add a few clicks of compression dampening and voila, an XC race bike! After that itíll be enduro racing for the rest of the season. 😂
  12. #612
    Quote Originally Posted by Dagonger View Post
    Ty -- shooting them an email now.
  13. #613
    Aug 2015
    It's here!Yeti SB150 Ride, Performance and Build talk.-img_20190510_165446.jpg
  14. #614
    Long time since Iíve posted on here, finally changed up from my SB6 to the SB150
    Full build video on the youtubes:
    https://youtu.be/py3lQa2JD_w
    Ill try and remember how to post some pictures
    No. 22: Yeti SB6c (now chopped in for No. 23)
    No. 23 Yeti SB150
  15. #615
    Feb 2016
    Just finished three days of shuttling in Nesbyen, Norway. What a bike! This thing rips on the descents
    Skickat frŚn min iPad med Tapatalk
  16. #616
    Mar 2019
    Quote Originally Posted by Yeti83 View Post
    Sweet ride man, I've got my orange sb150 ordered too!
    Just wondering what wheels are those? I don't recognise the decals
  17. #617
    Dec 2011
  18. #618
    Feb 2016
    Quote Originally Posted by Buzznz View Post
    Light Bicycle with self made decals, H83 CHENVE
  19. #619
    Oct 2018
    Speeder1 I agree with all that you posted. I have about 300 miles and 27,000 feet climbing (Utah spring has been tough to get any real climbing in) and the bike is great. I am going to steal your XC tire combo for a ride at the end of summer. Thanks! Good luck with your XC race.
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-dc47d771-e17b-4470-bfb8-3a82461e2397.jpg
  20. #620
    Quote Originally Posted by WillNick View Post
    The bike worked just fine for the XC race and if there is any tech in there you can just hang on and send it straight through with your HR pinned. 😜 The fast rolling tires make a huge difference. My team won the geezer class for the second year in a row!
    2.5 EXO DHF front and 2.5 DD Aggressor rear went back on today, back to Enduro mode.
    Iím also giving a 50mm stem a try. Cockpit feels a little more roomy. I like it on lower angle descents, for climbing, and cornering does not seem negatively impacted. Itís not quite as confidence inspiring as the 40 on steep descents, especially those with hucks and drops mid way down, but thats to be expected. It was a good choice for the XC race and Iíll probably leave it on for a while.
    In typical Yeti fashion, the harder you push this thing the better it works. Itís a race bike. It holds a line and hooks up through mid corner rocks and rough stuff really well if you keep leaning, keep the weight on it and trust it.
  21. #621
    Mar 2019
    Just picked up my new frame
    Noticed the paint is chipped on the bottom of the head tube
    Would you guys think this acceptable for a premium frame? Had the same thing happen on my road bike, and it just started flaking off over time
    I've emailed the dealer, just waiting for their response
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-20190515_141346.jpg
  22. #622
    Dec 2011
    Looks like shipping damage. I wouldnt accept it..
  23. #623
    Reputation: scooby8272's Avatar
    Sep 2016
    My SB150
    Just finished building my dream build SB150
    Push Coil front and rear
    Ive come from a Trek Slash 9.9 2019 and WOW the Yeti is unreal.
    I used to have an SB6 and missed Yeti ownership.
    Thought I'd do this build justice
  24. #624
    Reputation: mfa81's Avatar
    Quote Originally Posted by scooby8272 View Post
    list the parts, Iím curious on what you went with...
  25. #625
    Dec 2011
    Nice..
  26. #626
    Fierce!!
  27. #627
    Sep 2016
    Enve M730 Wheels DT Swiss 350 hubs (54T engagement)
    Enve M7 Bars
    Hope 35mm Stem and hope Headset (no gap new fitment)
    Push ElevenSix SS Shock
    Push Acs3 Coil conversion fox 36 Factory grip 2
    X01 carbon cranks X01 eagle Derailleur and shifter
    XX1 eagle cassette and Chain
    Hope V4 brakes and 203mm Rotors front and rear
    Michelin wild Enduro tyres
    Shimano Saint SPD 's
  28. #628
    Sep 2016
    Quote Originally Posted by mfa81 View Post
    Below sorry
  29. #629
    Reputation: jimarin's Avatar
    Mar 2005
    Thatís the bike I came from too, also on a full coil 150. It blows the trek away.
  30. #630
    Jan 2019
    Enve M7 Bars
    how do you like those push shocks? im running a vorsprung in my fox 36's (sb5.5c) and i love it.
  31. #631
    Aug 2015
    After riding the sb5.5 this morning, spent 20 minutes starting my build. I realized that my xtr 12 shifter is i-spec ev, which I ordered with the appropriate xtr brake lever. However, i bought some magura brakes to go on this build so pondering my options, like using my saint brakes on this bike with the xtr lever or putting the xtr 12 on my sb5.5 and moving my eagle stuff over to the sb150. The latter was my original plan, but just involved more work. I'm still waiting on some parts, so have time to think. The stem is the same as the one I'll use(deity copperhead), except I have an orange one on order. Fork is my mrp ribbon coil 160mm which the reconfigured to a 41 offset(44 wasn't an option). A 170mm Lyrik ultimate is on order(should be another 4 weeks). That aside, should be riding by end of week. The sb5.5 will continue to be my trail bike. This I'm building for park and big DH shuttle rides.
  32. #632
    Jan 2019
    fork offset
  1. Replies: 1832
    Last Post: 1 Day Ago, 09:03 AM
  2. New Yeti SB150 sneak peak!
    By svinyard in forum 29er Bikes
    Last Post: 08-27-2018, 12:54 PM
  3. Replies: 22
    Last Post: 02-25-2016, 04:44 AM
  4. Replies: 10
    Last Post: 09-04-2013, 05:54 PM
  5. Full build pictures of Yeti SS and Yeti FR bike
    By ryan_daugherty in forum Downhill - Freeride
    Last Post: 04-22-2008, 03:23 PM
Members who have read this thread: 609
