Yeti SB150 Ride, Performance and Build talk. - Page 6- Mtbr.com
Page 6 of 6 FirstFirst ... 23456
Results 1,001 to 1,191 of 1191
  1. #1001
    May 2014
    Im tempted, these guys in the UK stock them.
    https://www.bikeandspanner.co.uk/m3b...haft-2-5mm-TLG
    Has anyone running 65mm stroke actually made tire and seatpost contact?
  2. #1002
    Reputation: jimarin's Avatar
    Mar 2005
    Iím running 65 with an offset bushing to give it a little more clearance. I think contact without the offset would be close and subject to what tire youíre running. Add some mud in the mix and itís a little too tight for my taste.
  3. #1003
    Shamisen Appreciator
    Quote Originally Posted by B Rabbit View Post
    I modified my 65 to get 63mm of stroke. In my tests with the 65, with Assegai 2.5WT, they hit the ST at full compression
    Sean Chaney :: Owner/Builder :: Vertigo Cycles
  4. #1004
    Reputation: Bradical's Avatar
    Feb 2013
    Cool, so sounds like increasing stroke by 2.5mm to 62.5 overall will work.
    I will be able to confirm when my new 2021 Fox Float X2 arrives at 230x57.5 , my local Suspension Co. is going to machine down the spacers to go from 57.5 to 62.5.
    The shock should be arriving early to mid May....Iíll report back.
  5. #1005
    Reputation: fan_f1's Avatar
    That is exactly what YETI FOX Team rider Richie Rude does too.
    He is 5'10', and rode a 5.5 in size Large
    Now, in the SB150, he sized down to a Medium
    He felt the 'feel' was his decision maker
    With his access to any frame size and components, probably the most honest feedback and opinion you can gather...
    Quote Originally Posted by doodooboi View Post
    Hey Fulltrucker,
    I was kinda feeling the same way with my bike. Quick few questions what size frame are you running and how tall are you?
    I'm 5'10" went with the Medium, was on a Large Sb6. On paper they were literally the same geo.
    But I felt the same twitchy-ness of the front end but it had teh 50mm already. Secondly I feel like the bike pushes you forward and I feel way too forward to as how much tucked the offset of the fork is.
  6. #1006
    Jan 2018
    I'm 5'10 as well. I debated the large SB150 frame size- so glad I went with the medium, it's perfect. Was it on this thread I saw that post from Jared graves on how too many people are riding too big a frame these days? I think he's spot on.
  7. #1007
    Aug 2015
    Quote Originally Posted by jasonHMB View Post
    Taking a pro downhiller's opinion on bike size should be be put in to context of how many of them start in disciplines like bmx where you're on a smaller bike. I'd venture most of us are on longer bikes than we were 5 years ago. I certainly can't imagine going back to a large with a 445mm reach like I had in 2014.
  8. #1008
    Reputation: Radical_53's Avatar
    Nov 2006
    Thereís a difference though: Ąlargeď bike in absolute terms or Ąlargeď as per manufacturerís recommendation?
    Up to a certain point, you can get used to a Ąwrongď size anyhow as long as you can still handle the bike somehow.
    By the way, any Ąkey aspectsď to the size apart from nimbleness for the smaller and stability for the larger frame?
    Gesendet von iPhone mit Tapatalk Pro
  9. #1009
    Has anyone here been able to fit a fidlock with a 600 mil bottle on a medium sized bike?
  10. #1010
    Nov 2006
    ...whereís the connection to this topic?
  11. #1011
    SB150 Build talk. Get it? Or just had a bad morning?
  12. #1012
    May 2018
    Just ordered a gx build sb150 should be here in 2-3 weeks. Super excited will be sad to say goodbye to the reign though.
  13. #1013
    ban
    ban is offline
    Sorry to bring this back but I can't find any of hacks you are referring to... could you please share a link to these hacks if possible? cheers!!
    Quote Originally Posted by Dagonger View Post
    Early when 2019 sb150 was released there were some cable port hacks that you could get from the internet to use....
    Probably need to do a bit of a search here in this forum or fb...
    Sent from my GM1915 using Tapatalk
  14. #1014
    ban
    ban is offline
    ok, now I found it.... on Seth's youtube vid, simply use some black tape around the cable to stop it from rubbing the frame....I thought it would be something more sophisticated ....
    Quote Originally Posted by ban View Post
  15. #1015
    May 2018
    Does the sb150 come with the clear protective frame kit or do you have to purchase it separately.
  16. #1016
    ban
    ban is offline
    mine did, although it's not very thick so I added some extra layers in some spots on the frame...
    Quote Originally Posted by alsoran View Post
  17. #1017
    May 2018
    May 2014
    I see Cascade components have a new link on the way to add 5mm additional travel and extra progression to the SB150.
  19. #1019
    Jun 2015
    Does the Oneup 210mm dropper fit all the way in the frame on a size large? Thoughts and experience is welcomed.
    Evil Insurgent Yeti SB5.5 Evil Wreckoning Pivot Switchblade Pivot Mach 5.5 Yeti SB150
  20. #1020
    Quote Originally Posted by Snowsed341 View Post
    Sure does!
    Sent from my SM-G975U using Tapatalk
  21. #1021
    Mar 2019
    Very interesting, do you have any idea when it will be available? I've just had a look on their site and couldn't find much
  22. #1022
    May 2018
    Late next month at the earliest looking to cost around 250
  23. #1023
    ban
    ban is offline
    Will the Cascade link change the geo of the bike?
  24. #1024
    Mar 2019
    Sent from my SM-G950F using tiny.cc/Mtbr_android_app
  25. #1025
    Reputation: Dagonger's Avatar
    Dec 2011
    Increased rear travel by 5mm. Closer leverage progression to sb165 so would make it better suited to run a coil.
    Instagram/Youtube- Dagonger
    Yeti Cycles sb45c/sb150
  26. #1026
    Feb 2013
    Iím running a 62.5 mm stroke shock to get 157mm travel.
    Clearance is more than fine.
    I will also end up trying the cascade link
  27. #1027
    Jul 2016
    Anyone know whether Yeti will spec the 150 with the new Fox 38 or 36? And what the timeline could be for the new Fox gear being sent out with new bikes?
  28. #1028
    Reputation: Gobstopper's Avatar
    I was looking at grabbing a 150 a month or so ago and reached out to Yeti. More or less said they didnít have any idea because there were major delays and lack of supply for the 21í Fox stuff. Iím holding out until mid-summer to see. Didnít indicate 36 or 38.
  29. #1029
    May 2018
    I've just ordered a c1 build sb150 it comes with the dt Swiss 1900 wheels can anybody tell me if the discs are 6 bolt or centre lock please
  30. #1030
    Dec 2011
    I believe it's 6 bolt
  31. #1031
    Mine were 6 bolt
  32. #1032
    May 2018
    Apr 2019
    Quote Originally Posted by Bradical View Post
    Excited to be back on a SB150, Iíve sized up and love it, go figure?
    Iím 5í8Ē and and right at home on a Large.
    Wondering if anyone has tried a 230x62.5 shock, I feel like the extra 2.5mm of stroke will work and thus increase the rear travel from 150mm to 157mm.
    Anyone give this a try yet?
    Thanks for any input and everyone stay healthy.
    Wow! Talk to me! I'm 5'9 (5'10 with shoes) and ordered a 2019 Large SB150 a few weeks ago. Expecting delivery in a week. Pondered the sizing charts and geo, but I've ridden all frames Large and felt great. What year is your rig?
  34. #1034
    Feb 2013
    Quote Originally Posted by Sadistic View Post
    Iím on a 2020, all SB150 are the same expect for paint and build kits.
    I got used to my Specialized Enduro 2020 S3 that has a 1248 wheel base but less reach.
    However I got to thinking that the large SB150 is worth a try being that the seat tube on the Yeti is so steep and fights off sag thanks to the switch infinity.
    Iím glad I did...I sold my Enduro and am in love with the bigger SB150.
    Iím a wanna-be semi serious enduro racer and this bigger bike has made me a better rider overall.
  35. #1035
    Reputation: skinnybex's Avatar
    Aug 2015
    I have exactly the same as you. Currently I've been home in Colombia for the past 7 weeks avoiding all the stupidity back in the USA and I have a 2020 Enduro S3 for my riding in Manizales but back in the States I have a Large SB150 for the past 18 months and The SB150 just does everything slightly better for me although the Enduro really does excel in Chunky terrain with it's active kinematics but damn the bike feels like a heavy pig compared to my SB150 which really gets up to speed quickly out of the saddle or just laying down the watts.
    20' SB165
    19' SB150
    19' SB130
    21' Sworks Enduro
    21' Sworks Stumpy
    21' Epic HT
    Pinarello F10
  36. #1036
    Dec 2011
    I miss you...lol
  37. #1037
    Aug 2015
    I miss you...lol
    Likewise Dagonger....I'll be back stateside June 4
    20' SB165
    19' SB150
    19' SB130
    21' Sworks Enduro
    21' Sworks Stumpy
    21' Epic HT
    Pinarello F10
  38. #1038
    May 2014
    Cascade Components have their SB150 link available for pre-order. Im sorta tempted, works out to about $450aud in Australia delivered, not a small sum, but not too bad. I wonder if it will provide too much ramp up with a progressive coil?
    But I am tempted to get better small bump and some extra travel, not sure how the 63mm stroke im running will go with this link tho, might make contact.
    155 mm of travel
    Increased to 26% progressive compared to 15% with stock link
    Slackens bike 0.5 degrees and lowers BB 7 mm
    Sealed Enduro MAX bearings
    CNCíd out of 6061-T6 aluminum in the USA
    Colors: Black, silver, orange
  39. #1039
    On the fence about this too. Iím not overly excited about the drop in BB as the bike has always felt low to me. The additional spring rate required is pretty high too, I run a 550 now and would need a 600/650 which isnít available in SLS.
  40. #1040
    May 2014
    Wouldn't the increase in progression mean you could keep, or possibly drop down your current spring rate?
  41. #1041
    Dec 2011
    155 mm of travel
    I specifically asked them which coil would work better.. progressive vs linear and they said linear
  42. #1042
    May 2018
    Anybody running a to chain guide on their sb150 if so which one fits best?
  43. #1043
    Dec 2011
    Any iscg 5 spec one will work.
    I use oneup's
  44. #1044
    They'll all fit but some might have nicer features than others. I had an MRP but now have a OneUP which I find easier to install, space out the guide and to remove the crank occasionally to switch chainrings. I'd definitely go OneUP again.
  45. #1045
    because they have increased the initial leverage ratio. If you keep the same spring, your bike would sag more. It looks like the biggest progression rate change is in the last ~15mm of travel and the rate of the first 140mm looks roughly the same as stock, but with higher leverage.
  46. #1046
    May 2014
    ^ Cheers, makes sense
    So, forgive me if I get this wrong. Im currently running a Canecreek 400-488 progressive spring and weigh about 78kg, the small bump is great and it ramps up nicely at the end. With this link I'll get better small bump, but have to go up to a 500ish linear spring to get the correct sag, but then that increased spring weight will decrease small bump so I'll probably just be at the same place if I just ran my progressive spring? Minus the lower BB and .5 slacker head angle of course. Seems like 1 step forward, 1 step back.
    Im still sorted tempted to give it a go to see if it helps other ride characteristics.
  47. #1047
    I wrote a rather wordy response to this yesterday but it didn't want to post. If your current setup is working for you, it doesn't seem to me that swapping to a stronger spring and getting the new link would turn out to be a huge advantage. The change in the leverage ratio with the new link seems to suggest that a 500lb spring would be a little harsher in the initial stroke than what you already have. Personally, I see the BB drop as being the big negative for the new link, but I know it wouldn't be the case for everyone...I did some riding down in Santa Cruz last year and rock strikes were a non-issue. The trails I like up here are a lot rockier and to get some sneaky pedal strokes in, I need a little more clearance.
  48. #1048
    Dec 2011
    Quote Originally Posted by smudge View Post
    the link benefits the use of a coil shock vs X2 and with a linear spring vs a progressive spring..is how I interpret it.
  49. #1049
    Reputation: CascadeComponents's Avatar
    Aug 2019
    We gave a prototype link to a local Yeti dealer and here is what they had to say of it. Make what you want of it, but point is the link is not only for coil springs.
    "Just had a solid ride on the 150 link. It's amazing. I rode it with same pressure and volume spacers as I usually do which is 4 spacers and 212psi and usually have a pretty easy time bottoming it out. And the new link gave me 3-5 millimetres on the stroke short of bottoming which is perfect. Much better small sharp bump sensitivity, and then gave me so much more support in the 60-80% travel range. Really really stoked on it. "
  50. #1050
    Jan 2018
    Stoked on the new ride.
    Push, XTR, Reserve / I9 Wheels, Ewings Cranks. Coming from a 130LR that was a little too long for my liking excited for the Large frame and extra squish for the spicey bits.
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-img_0772.jpg
  51. #1051
    Nov 2006
    Nice ride! The color looks so fresh
    So you went from a XL LR 130 to a 150 L?
  52. #1052
    Jan 2018
    Quote Originally Posted by Radical_53 View Post
    Yup. 130 XL felt like a limo. Rode it for a year or so and on the wide-open straight bits it felt so good but much of what I ride is tight singletrack and it always felt a bit too long in tight spots. I am 6'1 so probably should have been on a L to begin with but tested both and decided on the XL. I think what it was was when I tested out the 130 I wasn't accustomed to the steeper seat tube and felt cramped while climbing so immediately assumed I needed an XL, oh well, I loved the 130LR all the same!
    I think my new 150 is actually lighter than the 130 even with the Push. Probably a combo of carbon rims, titanium cranks, smaller frame, XTR, etc. Took it out last weekend for its maiden voyage on my local steep tech and man it felt good! Excited to put many more miles on this bike over the next few years.
  53. #1053
    Oct 2013
    Lots of great info on this thread, I read a bunch of it while I was shopping bikes! I did not end up going with the SB150, mostly due to price and sales at the time, but wanted to put this link here for anyone else interested in in-depth suspension analysis on the Switch Infinity and how it stacks up to other popular bikes. Hope you enjoy!
    https://mtbsr.com/yeti-sb150/
  54. #1054
    May 2015
    Hello fellas, wondering if anyone here running an extra short stem in the 150. Specifically the Pacenti PDent which system uses a 20mm stem.
  55. #1055
    hello here,
    Just to inform you that the Scott Ransom chainstay protector fit perfectly without any mod on the SB150. just stick it and go.
    I try to figure out to post a photo on the thread ASAP.
  56. #1056
  57. #1057
    need a color matching on the 38! Anyway, after 3 rides, this fork seems promising (needs to be tweak a bit with volume spacers)
  58. #1058
    Mar 2019
    Looks good and thanks for posting. What are the advantages of using this, does it offer more protection, quieter???
  59. #1059
    Quote Originally Posted by ambition>ability View Post
    Protection : I don't know!!
    Qieter : for sure yes! The yeti has a flat hard rubber coumpound chainstay! The Scott one (or Santa cruz HT, Nukeproof reaktor) will prevent chain slapping with material and design (dents).
    You can also DIY with scotch 2228, but most of the time, the result is ugly!
  60. #1060
    Mar 2019
    Cheers, will give it a go when I get a chance
  61. #1061
    May 2018
    Just bought a new sb150 after 2 years on a 2017 giant reign 1. Having trouble finding front end traction. I have changed the stem to a 40mm length and fitted a 12mm riser bar from the start. Was thinking of trying a higher rise bar and or a longer stem. Any suggestions welcome from your experiences. Thanks
  62. #1062
    I had the same issue with my medium size 130, I couldnít go any longer than a 40mm without feeling too stretched out and found the bike hard to control at times. When I bought my 150 I went with the small and run a 50mm stem and itís perfect, Iím between sizes though. Iíd give a 50mm stem a go if you can fit with it.
  63. #1063
    May 2018
    Quote Originally Posted by OU812 View Post
    I'm 6ft without shoes and got the large think the medium would have been too small. Will see if I can borrow a 50mm stem and give it a try.
  64. #1064
    Aug 2015
    Try lowering your bar....Slam the bar and put all your spacers above. Also going 10-20mm longer on your stem will naturally pull your Torso over the front end especially when in the attack position.
    These bikes will hand you your ass if your used to keeping your rear end behind the saddle and BB. Once you actually make the adjustments needed you'll never go back to riding rear biased again.
    Watch Kyle Warner Youtube video's on body positioning on the bike. That guy is the very best at conveying what you should be doing to become a better rider.
    20' SB165
    19' SB150
    19' SB130
    21' Sworks Enduro
    21' Sworks Stumpy
    21' Epic HT
    Pinarello F10
  65. #1065
    Dec 2011
    Quote Originally Posted by skinnybex View Post
    That's a good video..I watched it and applied things these last 2weeks of riding.
  66. #1066
    Oct 2019
    I have a 2019 SB150 GX build in medium. I really like it a lot, but it is a bit of a pig at times.
    So far I have installed a Luftkappe kit and a Grip 2 cartridge in the fork. I switched to a Raceface 75mm stem and Yeti 760mm carbon bar. I changed to a 28t Absolute Black front chainring as the stock one was killing my old knees.
    I live in San Diego and ride mostly Penasquitos Canyon and Lake Hodges. I had plans of some trips but Covid stopped it for now. I would like to make the bike a little more XC friendly.
    I'm considering some lighter wheels. The DT Swiss M1900 wheels on the bike are over 2,000 grams. I've looked at a lot of different prebuilt wheels and custom building a set. 1,500 grams would be nice.
    Less inertia and un-sprung weight is a good thing. Spending $1,500.00 to $2,500.00 is a big expense for bicycle wheels.
    My questions:
    1, How light can you reasonably get a big wheelset like this?
    2, Would there be a noteworthy pedaling difference in a lighter wheelset?
    3, Is the cost VS performance worth the money?
  67. #1067
    Reputation: LaCostaClydesdale's Avatar
    Aug 2013
    My experience...lighter tires will reduce your wheel weight the most. Carbon wheels with 30mm width won't be noticeably lighter than Aluminum of the same width. So you might look at an alum XC wheelset with lighter duty tires for more climbing oriented days. DT Swiss M1900 2019g Santa Cruz Reserve Carbon 30's are 1,943g so 4% lighter, 76g. Minion DHR II 60 TPI 29x2.4 is 955g, Aggressor 2.3 60 TPI is 900g (as an example) that is 55g savings on the rear tire. Aggressor has better rolling resistance than DHRII also. You are in SD and it is now "chalk" season (dust). You could go Minion SS Silkworm on the rear and that is 810g.
    I also found that if I drank 30% less beer, that savings pays for tires in about 3 weeks! And I lose 5 lbs. and am slightly more fit so I climb better.
    2019 Yeti SB130 LR XL
    2018 YT Capra CF Pro 29er XXL - sold
    2016 Yeti SB5.5c XL - sold
    SW Washington
  68. #1068
    Nov 2006
    Body weight is totally different and feels different.
    All rotational/unsprung mass reduction is good usually.
    Tires too light can feel weird, as the dampening is lower usually, but a tubeless setup and light carbon rims do really help.
    Last time I got new wheels my rims got ~80g lighter per piece and that was very noticeable, especially as the carbon wheels are so much more direct.
  69. #1069
    Aug 2015
    For a 150/170 bike I'd not be looking at "light carbon" but probably carbon that was more or less the same weight as an alloy wheel, like the m730 by enve. I ride alloy and have DT rims for trail and another set of DT rims for park or anything that justifies using them... And corresponding tire casings.
  70. #1070
    May 2019
    Has anyone tried the cascade linkage? I want to hear your experience.
  71. #1071
    Nov 2006
    Quote Originally Posted by foggnm View Post
    If you want to extend the bandwidth of the bike, a second set of wheels is probably the easiest solution.
    For lighter use Iíd get a lighter (carbon) set to make the difference count, same width as the standard wheels perhaps. Save some weight there, probably give it some rubber with less rolling resistance and the money will be well spent.
  72. #1072
    Aug 2019
    Cascade link early feelings here:
    Those guys just took the one small complaint about the 150 and smashed it!
    Small bump and square edge hang up at speed has been a thing, but I have been able to tune it out with a faster HSR setting. Have had my bike feeling pretty great the last dozen rides or so without the link (float X2 btw).
    Installed Cascade link and rode a few trails that have a decent mix of high speed rough rock gardens and roots, and some little air-in chutes for good measure.
    The bike now skips across the tips of rough ground instead of getting bogged down in them and carries more speed through fast rough terrain. Insane actually. It doesnít plow, it floats. Not like a gooey squish bike but like a greased up slick rocket. Iím in love with it. Made this bike hands down the best enduro rig Iíve ridden.
    The added OTT suppleness is there, but not quite like jumping over to a coil.
    I find bottom less, but it has not been harsh and is much more pillow-like, and is exactly what I want when I get into a big one hit. Havenít felt it pack up to bottom yet and the added support in the mid stroke is noticeable. Airing into a steep root or rock chute finds the bike feeling planted and ready for action. Sticks and carries on. This is pretty rad and not to be understated. It just floats in the golden zone and gives you the support you want to keep charging through
    Unreal job by the Cascade Components team. Unlocked a new level on this bike.
  73. #1073
    Jul 2013
    Quote Originally Posted by Getup2getdown View Post
    Have you noticed the lower BB and slacker head angle having an effect on handling?
    2021 - ARc T1
    Previous bikes:
    SB75
    SB5
    SB4.5
    SB150
    SB100
  74. #1074
    New owner of a sb150 C1. It was a budget stretch but so happy I bought it. I'm 5'11 1/2, 32" inseam and went with a large. The fit is perfect.
    I ride some really rocky terrain and decided to make a protector for the seat stay/behind the infinity link. This is made with Kydex. Its a mouldable plastic that you heat in the oven. Took a long time to get right as I didn't want to place the hot Kydex right on the Carbon frame. Just lots of trial & error. But only had to use one piece. Used a heat gun for small tweaks. Should really help with small rock hits on the paint. I've got 3M film on other parts of the bike.
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-20200702_185934.jpg
  75. #1075
    Aug 2019
    Bike handles great, still. Slightly slacker sta, hta, and lower bb are intuitive and do not change the overall intent of the bike. A shreddy bike staying shreddy. Ride her hard and she will thank you
  76. #1076
    Mar 2012
    51mm offset VS. 44mm offset.
    Is anybody running a 51mm offset on their 150 instead of the 44mm offset? What am I losing or aging if I stick with my Fox 36 170 with the 51mm offset? I would prefer to not buy a fork quite yet.
  77. #1077
    Quote Originally Posted by madbomber99 View Post
    it'll be fine. I've been running one for the past year. More stable at speed, not quite as nimble in slower tech.
  78. #1078
    Mar 2014
    Am I misunderstanding, or are you saying that 51 is more stable at speed and less nimble in slow tech? That's seems to be opposite of the conventional wisdom
    Sent from my moto g(7) power using Tapatalk
  79. #1079
    Mar 2012
    I am hoping you are correct. I struggle more in slow tech areas then I do at being stable at speed.
  80. #1080
    Aug 2019
    Either fork is fine. Run what u brung.
    If you struggle with slower tech moves, try being more active on the bike and looking for opportunities to ďopenĒ the trail and unweight your wheels. Practice flat ground skills like stoppies and manuals so you can move the big bike around more. Long bikes like the 150 need a different approach to slow tech, but they work great once you incorporate that into your riding habits as there is a TON of bike in front of you to push on.
    If you just want a piece of kit as a bandaid, look at something less slack or dropping the fork to 160mm...might help a little with reeling in the front end.
  81. #1081
    Quote Originally Posted by GT87 View Post
    That's what I felt but I'm open to being wrong and trying it out again. I've got the 44mm crown hanging in my shop.
  82. #1082
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    Took my 150 to Angelfire last weekend and it crushed everything. I have always taken a dh bike there and felt that I would have actually been slower and more tired on that bike. I have a 35mm rise bar and some good stack under it but ordered a 180mm spring to test strictly for the bike park. The x2 handled everything with ease there. Very impressed! I also have a dhx2 with cane creek progressive spring that I didn't even try out since the X2 performed so well but I intend to soon. Anyone running 180mm up front or the fox 38 180mm and have some feedback on it? Thanks!
    Bender to AZDog: I'm not the best person to give advice on not riding!
  83. #1083
    For those of us considering getting this frame now, the option for the 170 mm is a Fox 38 with added stiffness and weight, I wonder how this will affect the dynamics of the bike
  84. #1084
    Aug 2019
    Perfect fork for the 150
  85. #1085
    Aug 2019
    Iíll elaborate to be more helpful...
    The 38 has a notch up in stiffness, no doubt. This is nice when tossing your chips in and working to the other side of the rough as it tracks great.
    Most noticeable is the higher ride height resulting from the new air spring, which preserves geo without feeling harsh off the top. The 38 is a great fork for the sb150, which begs to be ridden aggressively. The fork brings to the front end the confidence that already exists in the rear.
  86. #1086
    Thanks, I wonder if they'll be releasing update to the frame soon
  87. #1087
    May 2018
    Finally found the sweets spot in the cockpit department after testing varying setups. Now running 30mm riser bars with a 40mm stem and no spacers. Steering now feels perfect and has transformed the bike. No more feeling like the front end is going to wash out.
  88. #1088
    I'm sure I read something in this topic over the past few days about drive side chain stay clearance and how some people are dishing their wheels to the non drive side to rectify it. I thought I'd share something I just learned about my own bike.
    My back end is crooked.
    I was on a ride yesterday and had a new squeak. It turned out to be the main pivot bolt, but while I was looking down trying to recreate it on the trail, I notice that my tire had worn into the stay more than it has in the past. I'm sure that the loose pivot had everything to do with the extra wear, but while I had the bike in the stand to deal with the axle and doing a little IS maintenance, I made a gauge to check the wheel alignment. The front of the rim is 6mm to the drive side. The dish on the rim is within 0.25mm BTW. So I extended the feeler out to the dropout and learned that the dropouts are 11mm different (so 5.5mm off center.) Now I don't know what Yetis specs are when it comes to rear end alignment tolerance, it may be 1/4" and my bike would be within that, but there's no doubt that my back end is crooked. It's not just off center, it's off axis.
    It's also fair to say that I'm not bothered by the alignment issue on its own. My own bikes are 0.020" or less but I understand the nature of manufacturing and don't expect to see that kind of tolerance out of a mass manufacturer. The other interesting thing to note is that the off-axis swingarm actually has nothing to do with the tire clearance and in my case, if I dish my wheel 3mm to the non-drive side, it fixes the problem I'm having (abrasion on the stay) when having a swingarm aligned perfectly would not.
  89. #1089
    May 2018
    Anybody fitted a 200mm rotor to the rear of their sb150 if so what mount did you use???
  90. #1090
    I put on a 203 with a Shimano mount. I think it would be a 20mm pm adapter for Sram. Yeti SB150 Ride, Performance and Build talk.-20200712_185516.jpg
  91. #1091
    May 2018
    Put my gx build on the scales this morning knew it was a bit heavy but wasn't expecting the best part of 37lb.
  92. #1092
    I'm at 38.6 on my gx build but I have push coil front and rear, Enduro casing tires with cushcore, one up pump and kit and porky wheels.
  93. #1093
    May 2018
    Rain164845 what's the coil conversion like on the front been looking into this the last week or so also looking at the smash pot.
  94. #1094
    Aug 2015
    I have run 51, 42, and 46 offsets (my current set up, bought a CSU separately and installed on Lyrik). I'd say in slower tech the 51 feels less like it will fold over and surprise you. I used to think the 51 felt more stable at speed but the more time I've spent on short offset it doesn't seem that way. I'd say the short offset feels good at high speed because it slows the steering a bit. But the 51 can make the bike feel a little more grounded at high speeds. I went with a 46 because it feels very neutral and doesn't penalize turning the bars like my 42 offset does (it wants to lean, not turn). With any of the offsets I think you get used to it and make small riding adjustments. Overall, I'd say the 51 is the most forgiving in most situations.
  95. #1095
    Aug 2015
    Wink
    Did you remove the box?
    I've never weighed mine, because I don't want it to take away any of my deep love for this bike! One year in and still in love!
  96. #1096
    The conversion is really incredible but I found that I needed more damping once so much friction was removed from the action. I ended up having to get the push damper to make it work. But now it is on another level.
  97. #1097
    Mar 2012
    37?
    I run GX on mine and it isn't quite 33 pounds. 37 lbs is crazy.
  98. #1098
    Yeah, you gotta keep adding stuff till you get there!
  99. #1099
    May 2018
    The weight of it is quite disappointing
  100. #1100
    Mar 2012
    37 lb?
    I don't even know what I could add to make it 37 lbs. Maybe downgrade to NX? Buy a heavier wheelset? Iron water bottle holders? heaviest rear shock I could find? Or all of the above?
  101. #1101
    May 2018
    Here's my build, bought a gx complete so the slightly heavier frame, hunt trail wide wheels, wild enduro front tire, rim pact tyre insert in rear, gamut cilios 40mm stem, Pro tharsis bars, xt shifter, xt mech, bergtec penthouse mk4 pedals, 4x volume spacers in the rear 2 in the front and tubeless sealant. I weighed the bike on two different sets of scales and both approximately the same. My old aluminium reign with a coil shock was lighter. Not taking anything away from the bike it rides awesome no where near the claimed weight on the yeti website though.
  102. #1102
    Jul 2020
    How did you fix your headset gap
    Quote Originally Posted by Druster View Post
    Yup, all good now. Stem is on a negative on purpose due to too high of a stack height to my liking.
    Sent from my SM-G965F using Tapatalk
    Hi, I've been scouring all over the place trying to find someone with the same issue as I've had - and yours looks pretty much the same. I'm running a steel frame, but looks like the same Chris King headset with the same gap.
    How did you get rid of it?
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-img_20200727_125954.jpg
  103. #1103
    Reputation: Gman086's Avatar
    Quote Originally Posted by itsumishi View Post
    That looks like one of the old CK headsets that all the XC geeks were in love with (because of their nice bearings) but were JUNK for those of us that were into DH/FR; first big drop and it was toast. CK waited until the patent ran out on Cane Creek's upper bearing top cover assembly with integrated split washer that finally fixed it (allows the cap to come all the way down on the bearing). Little known story that a lot of CK fanboys don't even know about. I have never bought another CK product since and never will either... their own pride was worth more than their customer's satisfaction, SMH. Anyone who thinks CK is the gold standard for headsets simply doesn't know THE REST OF THE STORY as Paul Harvey would say...
    Have FUN!
    G MAN
    PS - I'll take it a step further... Cane Creek started as Dia-Compe who invented the threadless headset. They have LITERALLY developed every component of the modern day headset. Chris King has done JACK SHEIT when it comes to engineering other than come up with nice bearings. I'm shocked at how many think they are the gold standard when all they really are is a bunch of pirating copycat yahoos. I like to buy from and defend local companies (Portland, OR) but I simply cannot get on board with CK anything. But hey, they have all those kewl colors, LMAO! CK is marketing at it's finest.
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
  104. #1104
    Nov 2006
    Where did they get their hub design from?
    The headset sounds like the iPhone. Take other peopleís ideas and combine it to be something better.
  105. #1105
    That would be DT Swiss' ring drive mechanism... and yeah, I'll give you that one as theirs is probably better than DT's version which cannot get that high of POE. Chris King reminds me a lot of Toyota who copies everything that's successful and tries to make them better.
    Have FUN!
    G MAN
  106. #1106
    Nov 2006
    Thanks. Are you sure about DT Swiss? They have a star ratchet, which (as far as I understand) works differently. DT and I9 are built the same way I thought?
  107. #1107
    I'm very sure... King's is a bigger version which engages the outer wall better as an additional point of contact vs DT's outer teeth. I9 is still a pawl system but their latest is essentially a hybrid with what King does in how it interacts under tension with more surface area. I was put off by my old I9's and all the bearing problems and drag but honestly their new hubs are the best engineered I've yet seen. I don't think you can go wrong with any of them quite honestly.
    Have FUN!
    G MAN
  108. #1108
    Nov 2006
    Thanks! I ran King for the best part of the last two decades so I might just stick with then.
    The i9 approach sounds interesting, Iíll have to look into that. DT would probably be my first pick for a hassle-free, lightweight build.
  109. #1109
    Quote Originally Posted by Gman086 View Post
    Have FUN!
    G MAN
    After using King hubs for decades, I switched to some I9 torch hubs on my SB6 solely because I wanted CenterLock rotors and have nothing negative to say other than they require more maintenance than the Kings. When I built up my 150, I went with Hydra hubs and think that they're great but the extra engagement really accentuates pedal kickback on tech climbs.
  110. #1110
    Mar 2020
    Quote Originally Posted by OLDMOTO View Post
    My questions:
    On my sb130LR I switched from the 1700's to the new I9 315c wheels- we are one carbon rims 31 wide, with I9 hydra hubs and their alu spokes, dropped almost a full pound. new wheels are stiffer, lighter, faster and stronger. You could go down to a 28 spoke and less serious rim.
    Other options- DT swiss 180 hubs front and back with lightish but strong 28h carbon rims- that would save another 100+g or more with sapin cxray spokes.
  111. #1111
    Dec 2014
    Hi everyone,
    Quick question regarding sizing and manoeuvrability of SB150.
    Starting from the beginning, I'm 6feet (184cm) tall with 34 inches in side leg and just sold my Transition Sentinel Large due to not connecting with the bike. Riding Sentinel I couldn't make tight corners as quick and easy as I would like. My question is how SB150 copes with tight stuff, any riders in the UK. Next question is regarding sizing, should I go for Large or get a Medium SB150. Due to broken collarbone, I can't ride for next month and can't demo anything. The main issue is with sizing, go smaller which should feel better in tight or go L if SB150 feel good in tight anyway. Last though, sacked the SB150 idea and go for SB140 Thanks
  112. #1112
    May 2018
    I was in a pretty similar situation as yourself regarding sizing just a slightly shorter leg length. I went for a large, I think you could go with either when descending but for climbing the top tube length on the medium was too short. I found it also quite a big bike to get around tight switchbacks but after trying numerous bar rises, stem rises, stem lengths spacers under the stem I am now in a good place and am matching previous times if not bettering them on most tracks.
  113. #1113
    Dec 2014
    So with what did you end up, stem, bars and spacers wise?? Thanks
  114. #1114
    May 2018
    No spacers under the stem 30mm rise bars. Was running a 40mm stem with 0 degree rise and felt good, have done 1 ride with a 50mm stem and 6degree rise didn't feel as direct going to give it one more try but most probably go back to the 40mm.
  115. #1115
    Reputation: jboyd122's Avatar
    Putting the SB150 on a diet for a road trip to Copper Harbor. Removed my DHF/Aggressor tires and putting an Ardent Race 2.35 I have sitting around on the rear and a Rekon 2.4WT on the front for a more pedal friendly feel. Power meter installed with 170mm cranks which meant removing my One UP bash guard/chain guide combo. The Quarq was rubbing on the bash guard, womp. I was surprised how much leverage I lost with the 170mm cranks vs the 175mm ones. I raised up my seat a little which helped but it was noticeably harder to sustain higher watts on the SB150 with 170mm cranks vs my XC bike with 175mm cranks. Taking it out on a 40 mile ride tomorrow so I'll see how she does at distance.
  116. #1116
    Mar 2020
    Quote Originally Posted by jboyd122 View Post
    https://www.trainingpeaks.com/blog/t...-crank-length/
  117. #1117
    Awesome article. I think the seat height was playing a huge factor for me. With a half cm shortened extension I wasnít driving as much power through my legs. Also it was my first ride on the shorter cranks so obviously there is some muscle memory to work through. Iím optimistic about the results on my ride tomorrow.
  118. #1118
    Feb 2013
    If anyone is interested in long-shocking their Yeti SB150 I have a 2019 (just serviced) Fox Float X2 for sale. Its stroke has been changed from 60 to 62.5 giving you an increased travel of 157mm .
    PM if your interested.
    May 2019
    Has anyone tried an EXT Storia on a SB150? How does it compare to other coil suspension?
  120. #1120
    May 2018
    First ride out this morning with the storia fitted. Amazing shock also had one fitted to my previous reign. Will come back with a report after the weekend. Would post a pic up but got no clue how to do it.
  121. #1121
    May 2019
    What Storia do you have? LOK V3 or Arma?
  122. #1122
    May 2018
    Lok v3
  123. #1123
    HOLY SHEEP SAUCE BATMAN, that new color hurts me eyes!
    https://www.competitivecyclist.com/y...A6MTozOlNCMTUw
    Have FUN!
    G MAN
    PS - Who has an orange Med frame for sale?!
  124. #1124
    Jul 2019
    Have FUN!
    G MAN
    Iíve got a med turquoise for sale if youíre interested
  125. #1125
    Oct 2019
    I have a 2019 Medium GX in orange I'm considering selling. Its in perfect condition. I'm in San Diego.
  126. #1126
    May 2019
    Lok v3
    Did you also order the hardware kit from EXT?
  127. #1127
    May 2018
    Had 3 days of riding now on the storia and what a shock. How a shock can be so supple yet supportive is insane has totally transformed the bike but I did also have the v2 storia on my old reign. As for the hardware I had the shock fitted at mojo rising who are the UK dealers. They fit the shock get you to have a ride around in their grounds and then advise on a few changes to the bike if they need to made. Big shout out to them immense customer service highly recommended. All mounting hardware included.
  128. #1128
    May 2019
    How is the frame and suspension clearance? I've seen a picture of an SB150 with Lok V3 and it has a very tight clearance. What frame size do you have?
  129. #1129
    Have FUN!
    G MAN
    PSS - Looks like they took the pic down before the official release... IAC it IS MOST DEFINITELY a neon green/yellow color!!! Not to my liking, one of those fad colors. No more orange, still have turq and anthracite or new smoke? (yuck).
  130. #1130
    Dec 2011
    Raw is back!
  131. #1131
    May 2018
    I'm on a large the shock does sit slightly closer to the frame but plenty of room.
  132. #1132
    Sep 2017
    just pre ordered my sb150 21 t2 bike .
    Cant wait to get it expected mid sept
  133. #1133
    Sep 2015
    Ordered mine a couple of weeks ago. They said mid-October then. I talked to them today and they said yeti will often give a longer time frame. They are seeing 21 show up. Not to get hopes up but hopefully it shows up sooner rather than later.
  134. #1134
    May 2014
    Any more reviews of the Cascade Link?
  135. #1135
    May 2018
    Think I worked out how to upload pics so here's one of the whip
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-img_20200808_132041_830.jpg
  136. #1136
    May 2019
    Nice! Already ordered mine last week. Excited to try out once it arrives.
  137. #1137
    what rear fender do you guys recommend?
    2020 yeti sb165 t2
  138. #1138
    Fork travel
    Hi all, I measured my fork today and noticed it sits at 180mm. The fork is stock, and when I look up the code on fox's website it shows its 170. It's a fox performance 36 fork. I've only had Rockshox suspension before and they always sit at their travel amount.
    Does anyone know if I put a 180 air spring in if it will actually raise the fork up to 190 or if it will just use the rest of the stansion travel? If the latter, then it shouldn't change the bike geo...I did email fox about this, but may be a while before they get back to me.
    *Edit* after doing some more research, doesn't look like Fox makes a 180 spring for 29er forks. But maybe a 180 38 fork, or a 180 Zeb actually sits at 180 stanchion length...
  139. #1139
    Quote Originally Posted by 4g63pwr View Post
    Fox 36's have 10 extra mm of dead stanchion space so... you fork is a 170mm.
    Have FUN!
    G MAN
  140. #1140
    Thanks👍
    Was just curious because my old 170 Lyrik measured 170 at the stanchion.
  141. #1141
    Finished my first ride a little while ago with the Cascade link. It was interesting
    Prior to installing the link, I've swapped back and forth about a dozen times between the DHX2 and X2, deciding every time that I like the initial compliance of the DHX2 but not the linear rate and that I love the progressive nature of the X2 but hate the blocky small bump response especially in chunky corners.
    With the Cascade link and X2 installed, I set my pressure about 15psi higher than I would typically run it (that got me to 30% sag), added a couple of clicks of rebound damping...it wasn't enough. Though the beginning stroke brought it much closer to a coil like feel, the bike sat way too low and I was hitting my pedals everywhere. It was expected to some extent when pedaling through rocky sections, but where it really surprised me was hanging an outside pedal in corners and catching embedded rocks. The other big surprise came in a high speed section of bench cut where I normally pop off of a root to clear the section just beyond and I got bucked hard. It was a bit of a pucker but I stayed upright. Lower down in the trail system, we hit a small jump line and it was more of the same...getting bucked off the lips. I'll have to play around with the damping on the next few rides.
    it will be interesting to see of the eyelet can be pulled on the X2 like I did on the DHX2 to add a puck under the shaft to extend the eye to eye and what effect it'll have on the stroke of the shock. The lower BB of the Cascade link is a problem for me, but once I can get the damping setup to behave off lippy jumps and pops, it'll be really nice.
  142. #1142
    Sep 2015
    Anybody got a 2021 yet?
  143. #1143
    Mar 2019
    Finished my first ride a little while ago with the Cascade link.* It was interesting
    With the Cascade link and X2 installed, I set my pressure about 15psi higher than I would typically run it (that got me to 30% sag), added a couple of clicks of rebound damping...it wasn't enough.* Though the beginning stroke brought it much closer to a coil like feel, the bike sat way too low and I was hitting my pedals everywhere.* It was expected to some extent when pedaling through rocky sections, but where it really surprised me was hanging an outside pedal in corners and catching embedded rocks.* The other big surprise came in a high speed section of bench cut where I normally pop off of a root to clear the section just beyond and I got bucked hard.* It was a bit of a pucker but I stayed upright.* Lower down in the trail system, we hit a small jump line and it was more of the same...getting bucked off the lips.* I'll have to play around with the damping on the next few rides.
    it will be interesting to see of the eyelet can be pulled on the X2 like I did on he DHX2 to add a puck under the shaft to extend the eye to eye and what effect it'll have on the stroke of the shock.* The lower BB of the Cascade link is a problem for me, but once I can get the damping setup to behave off lippy jumps and pops, it'll be really nice.
    Interesting feedback, be keen to hear if you can get set-up to your liking. You really should give a progressive spring on your DHX2 a try though, awesome small bump while still having some bottom out resistance. Well I found it so much better than a standard spring anyway... Have you tried the Cascade with the DHX2?
    I've also been experimenting with some other changes, I'm back on the 29 rear wheel (after trying with a 27.5), running a 3mm puck in the eyelet of the DHX2 and have put in one of those new 9point8 Slack-r anglesets in. This has slackened the HA out to 63.5' (according to my phone), and theoretically will have steepened the ST angle a little. Wheelbase has stretched out to 1264mm. I haven't measured the BB height yet, but guessing at an increase of maybe 6mm. Only done 2 very small rides on it so far, super stable as expected and seems to have more pedal clearance, need a few more rides to be sure on that.
  144. #1144
    Aug 2020
    Try removing volume spacers from the X2, adding more air, and more rebound damping.
    You are currently way too progressive.
  145. #1145
    Jan 2016
    Cascade link after a week of riding
    After installing my cascade link, I noticed that the bike was way more willing to pop off of stuff. I am getting way more air on jumps and I really enjoy it.
    Super plush off the top. Added a volume spacer (total of 4) anyway just because I like to huck to flat a lot. Leaves me with about 3 mills of extra travel after a good drop
    Definitely more harsher in the mid stroke with the volume spacer. Probably adds to the poppy feeling as well
    Climbing is as easy as it was, if not easier. The handling felt more nimble.
    Pedal strikes are about the same, sometimes It misses even though I had a good feeling of it striking.
    I started off with 20 clicks (from closed) HSC, 18 clicks LSC, 18 clicks LSR and 17 clicks HSR. Kept leaving the ground when I didint want to on multiple successive whops. Very chattery.
    I settled with 17 HSC, 17 LSC, 16 LSR and 15 HSR.
    I can now stay on the ground when I want to, and pop when I want to. Seems to control the high-speed chatter better, but it's still there.
    I'm running 145 psi and weigh around 145 with gear. I get about 27% sag.
    My original link had one siezed bearing so my experience with the link may be different compared to others.
  146. #1146
    I haven't tried it with the DHX2 because I'll need a new spring. If I can get it dialed with the X2, I may not feel like I need to try the DHX2 at all, or if I get too curious to resist, at least I'll have a better idea what spring rate I'll need. There's no way the 550lb spring I have now would work well with this setup and I think that's the heaviest SLS spring they make. It would be nice to stick with the air shock if I can get the corner traction I'm after.
    The other notable observation that I don't think I mentioned is pedal kickback. It's a lot more noticeable on techy climbs. Certainly the I9 hydra isn't helping.
    With the amount of time being spent at home thanks to Covid and the dark and rainy months ahead here in the PNW, I may have to try to machine a link to mullet the bike without messing with the geometry or suspension too much.
    Quote Originally Posted by Chuck Johnson View Post
    I haven't pulled the can to check the spacer situation, but it may be that I already removed them all. More HSR is definitely going to happen.
  147. #1147
    Sep 2015
    Iím considering getting a cascade link whenever my bike comes. Iím on a nomad v3 with an 11-6 and 175 cranks. Looks like the nomad bb is lower than stock 150. Do yíall think the link drops the bb too much? Iím pretty used to pedal strikes with my current set up. Although, the 11-6 helps with that. I plan on running the x2 and feel like the cascade link will help it feel a little more like a coil. Is that an accurate assumption or am I going to miss my coil?
  148. #1148
    Aug 2019
    Keep in mind the SB150 isn't an especially low bike to begin with. It sits at around 348 mm. Throw the link on and it's at around 340 mm, which happens to be the same as a Hightower in the low setting (the HT is intended to be run in the low setting). If anyone is having issues with mashing pedals into the ground it would be worthwhile double checking sag a few times. It should be between 16 and 18 mm at the shock and this should be measured while seated.
    Unfortunately this can't be done with the link without messing up the kinematics. The dimension that raises the BB/pushes the wheel further down is directly tied to progression. If you tweak it to push the wheel about 20 mm down (the necessary amount to correct for a 27.5" wheel) it does very bad things. The progression becomes -11% AKA digressive which is the last thing you want out of your suspension.
  149. #1149
    Dec 2011
    My understanding is cascade link works best with a linear coil spring if going coil but benefits the X2 more so. I have seen feedback that it seems to be more beneficial on a sb130 vs 150.
    I run a stock link with dhx2 and CC progressive vault spring and really like it..
  150. #1150
    Jan 2013
    Quote Originally Posted by cubebiker View Post
    Curious as well.
    Just switched over to SB150 from Knolly Warden Carbon.
    Finding already that the water bottle in a standard side pull cage already doesn't fit right and the bottom of the bottle hits the seat tube before it's all the way into the cage.
    Also, looking at the best way to store other stuff while enduro racing. I have the tube strapped into the triangle just in front of front shock mount. EDC tool in the steerer. Wish I could utilize the lower triangle for tiny dynaplug tool, levers, tiny CO2 head.
    Has anyone found any of the water bottle + tool storage combo things that work on a medium SB150? Thanks.
  151. #1151
    Sep 2018
    Quote Originally Posted by Whiteroom_Guardian View Post
    Curious as well.
    The Specialized Zee cage helps with the bottle hitting the seat tube before being all the way in.
  152. #1152
    Jul 2019
    Curious as well.
    I use a specialized zee cage and one up pump/edc tool off the side. I canít use the full size bottle though, but the with the slightly shorter bottom I donít rub the seat tube. On cooler days and about 2hr rides I donít need anything else
    side note does anyone know if a fidlock water bottle fits in a medium frame?
  153. #1153
    Sep 2017
    should be taking delivery of my sb150 t2 over the next few weeks and there are a few questions i have .
    I want to change the stock 30t chainring for a 32 or 34 . Is it best to stick with the sram rings or are there any aftermarket rings that do the same job for less ?
    For a water bottle cage was looking at the fidlock set up . does anyone know what size fits the medium frame ?
    are you all running the stock 20mm rise bar or running something a little higher ?
    help appreciated
    dan
  154. #1154
    Quote Originally Posted by daniel366940 View Post
    help appreciated
    dan
    I put an AbsoluteBlack 32t oval on my SB150- it worked great and I have been running AbsoluteBlack ovals on all my bikes since 2015. People can say what they will but the oval rings from AbsoluteBlack reduce climbing fatigue and allow you to pedal more smoothly through chunky, chundery trails and build speed!
    I was on an XL frame and had no issues with a right side Specialized Zee Cage and full sized bottle.
    20mm riser bars were all I ran and was super happy with them at 800mm width- (Yeti brand bars) again, I am 6'2" and believe that bar width for taller guys helps handling and fatigue.
  155. #1155
    Sep 2017
    just recieved the news that my sb150 has been delayed untill mid december now .
    I am gutted as was supposed to be getting it next week
  156. #1156
    Sep 2015
    What size did you order?
  157. #1157
    Sep 2017
    a medium t2 build turquoise
  158. #1158
    Mar 2018
    Here are my findings on the Cascade Components link.
    For a frame of reference, I'm ~79kg/175lbs without the kit. 177cm/5.8" tall on a SB150 2019 Medium.
    I've been riding the SB150 with the original Yeti performance DPX2, a DHX2 prepped by Avalanche for my previous Slayer 2018 (I machined a spacer to reduce the stroke to 60mm), a stock Yeti-tuned X2. I set the SAG to 33% as per Yeti's recommendation. Running a Fox 36 Factory 170mm up front at 20% SAG (and also a Fox 36 170mm Push ACS3 + Ava cartridge at 22% SAG).
    Assegai DH MaxxGrip with tubolito up front at around 23psi, Aggressor DD with Vittoria AirLiner at around 27psi out back.
    I ride rocky and rooty natural trails with some jumps (nothing big) and drops up to 1.5m high. I rank about middle at the regional enduro races, so not very good but not very bad either. I use a SussMyBike unit to tune the shock on timed runs on the same test trails.
    I alternate rides between the SB150 and a steel hardtail Pipedream Moxie to remember what it feels like not having a shock.
    Before the Cascade Link with X2: 190psi 5 spacers, using 100% of the travel, bottoming it out on drops (never harsh though), using a bit too much travel too fast for my liking, feeling like it sits a bit too much on the back end/too low in the travel when riding. Granted, I could have added a bit more air and removed some spacers to run a 30% SAG instead of 33% and that might have solved some of the above issues while making the rear end a bit less confortable.
    With the Cascade Link and X2: 210psi 3 spacers, using up to 95% of the travel on the same trails, feels like sitting at "the right height" in the travel when riding, feels a touch more supportive, a touch more supple of the top, bike feels more planted on the back, more traction. Only slight drawback: a touch more pedal strikes but you quickly get used to level the feet more. Wrt pedalling: without being huge, now the shock lockout makes more of a difference than before on long fireroad climbs (so for 30min-45min sustained climbs I lock the shock). Finally, I turned out to be significantly faster on average on my timed runs.
    Still a lot of stuff to try, but got to take a break after I slammed myself to the ground and have a quite sore wrist (rear end can feel sometimes a bit too flexy when pushing harder and got thrown off line in an off-camber turn that I probably rode 300 times in the course of the last 4 years - however most likely my own fault).
    HTH
  159. #1159
    Sep 2015
    I ordered an anthracite xl t2 in July. Iím still assuming mine will show up mid October but not holding my breath. Sounds like production and shipping is getting back to normal but there is a lot of catch up.
  160. #1160
    I recently ordered a large 2021 turq frame and was told end of October in Switzerland.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Switchblade V2
    Pivot Vault
    Santa Cruz Tallboy V4
    Orbea Alma
  161. #1161
    Sep 2015
    Iím in the states. I guess there is really no way of knowing an exact date. Hope itís soon for everyone waiting. The weather is super good right now.
  162. #1162
    Jan 2016
    Alloy Port Insert kit
    Got the Alloy port Insert kit from my LBS.
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-f03f9e54-bab7-402d-9311-281a8f0adad4.jpg
  163. #1163
    Mar 2012
    2021 Frame
    It only took a week to get my 2021 SB150 Frame. But that was in July.Yeti SB150 Ride, Performance and Build talk.-sb150.jpg
  164. #1164
    Mar 2016
    Where did you get that amazing wrap done?!??
    Quote Originally Posted by Ob917 View Post
    My new sb150 build. This bike really is a hoot to ride where I live. I also have a 5.5.
    Grip 2
    Dhx2
    175 dropper in a med frame size
    Rsc brakes
    Assegai 2.5 front
    Trusty DHR 2.4 rear
    SRAM XX1 axs, I love this stuff.
    Xtr trail pedals
    Renthal bars and stem
    The yellow is a wrap I did.
    Hey that wrap you had done is outstanding!
    Foolishly I did not wrap my 150 when I got it and now it has severe wear marks on the top tube from my pads. I would like to find a place that will produce a coloured wrap so I can refresh the cosmetics and protect at the same time. Thinking about just a straight Teal, but your Yellow wrap does look banger!
    Appreciate a supplier name or advice on how to go about doing it!
  165. #1165
    May 2014
    Hi
    Has anybody tried an Ųhlins ttx 22 air in a yeti sb150?
    Stefan
    P.S. Hereís mine
    Attached Thumbnails Attached Thumbnails Yeti SB150 Ride, Performance and Build talk.-64de8f23-baa8-41d5-86c4-e449eba16a2b.jpg
  166. #1166
    Dec 2011
    Yes I have...video impressions on my Instagram TV
  167. #1167
    Mar 2020
    Does anyone know is there any volume spacer pre-assembled in the X2 shock by YETI?
  168. #1168
    Quote Originally Posted by stuart24 View Post
    Funny you should ask, I had mine apart for the first time 2 days ago. The 2020 X2 had 2 spacers.
  169. #1169
    Quote Originally Posted by ifly3Dallday View Post
    What does this do? I can't seem to find it on their site, or anywhere else for that matter.
  170. #1170
    Mar 2020
    Quote Originally Posted by rain164845 View Post
    Hope my 2021 version also come with 2
  171. #1171
    Sep 2015
    I hope my 2021 comes at all
  172. #1172
    Sep 2017
    mine is in the parcel depot and delivery down for tomorrow
    Very happy as the last date i got for delivery was mid december
  173. #1173
    Sep 2015
    Nice! What size did you order?
  174. #1174
    Sep 2017
    medium t2 build
  175. #1175
    I $uck, but MY BIKE Rules
    Reputation: SparkyAlumni's Avatar
    My 1st Yeti - 2021 SB150 (Medium) - My Thoughts.
    I posted this a few days ago on a FB Forum, but, thought I'd share here too.
    For reference, I'm 5'9", 180lbs, and ride super rocky, steep, gnarly trails full of square edge rocks (Phoenix, AZ). I recently sold a 2018 Intense Tracer 275 w/Push 11-6 shock and custom valved Lyrik; and a 2018 Intense M16 DH bike. This Yeti SB150 is to be my one and only do-it-all bike.
    For anyone wanting to get a 2021 build, but, hesitant b/c you think you NEED to spend the extra cash on a "T" level build (trying to avoid Fox's "Performance" Fork & Shock on the "C" builds), fear not, Fox's 2021 Performance suspension is no less than amazing!!! I'm truly blown away with the "entry level" suspension on my C2 build... it's stable, planted, with good/smooth mid-stroke support without being harsh, has a great pedaling platform and has all around DH inspiring characteristics.
    Now, I will say that i have an Avy tuned Zoch CR coil shock coming (I ordered it before i got my bike) and if you have the extra cash, cool, go ahead and get the suspension with more tunability, but, don't feel like you have to avoid the "C" level builds b/c the Performance Fork/Shocks aren't any good... I'm so impressed with my Performance X2, i may just keep it (was going to sell it b/c i have the coil shock coming).
    I think I've dialed in my suspension to what i feel is my base tune (will probably still play with the settings a click or two here and there, but, I'm delighted with my bike with the following settings).
    SHOCK (Float X2 Performance): 195psi [Yeti recommended 202psi], LSC 11 clicks (from fully closed), Rebound 10 clicks (from fully closed) [Yeti recommended 12 LSC & 9 Rebound]
    FORK (38 Performance): 80psi [Yeti recommended 101psi, but, I wasn't getting into the bottom half of the travel], LSC 3 clicks (from fully open), Rebound 10 clicks (from fully closed) [Yeti recommended 1 LSC & 9 Rebound].
    To date, here is my 2021 SB150 C2 Build with the following upgrades:
    * Ergon seat (custom paint job)
    * Shimano SLX Quad piston brakes
    * Invisiframe
    * Crank boot covers
    * OneUp bashguard & chain guide
    * 30T Absolute Black Oval chainring
    * Rockguardz (downtube protector)
    * I9 Hydra Hubs w/Stan's Flow EX3 rims
    Special shoutout to
    doodooboi
    azdog
    for all their help/advice!
    [email protected]: luis_salazar_j316
    I Hate when the trail trips my bike! :skep:
  176. #1176
    Sep 2015
    Just picked my xl t2 up! Got the call right after posting on here.
    Yeti SB150 Ride, Performance and Build talk.-999e8b4e-27cb-4bef-a5b7-c6da82aa70cd.jpg
    Sorry. Need to figure out how to rotate it
  177. #1177
    Jul 2017
    I no longer like to party. But I like the idea of it.
  178. #1178
    Trail Ninja
    Reputation: Varaxis's Avatar
    Quote Originally Posted by almazing View Post
    Surprised it's taking so long for this to catch on. In my experience demo'ing bikes in M and L sizes back-to-back, I've consistently found that one size felt simply more balanced and intuitive than the other in corners and on bumpy rolling terrain. Can just stay centered on the bike and let go; my control of the bike took relatively less effort on the balanced & intuitive bike. The SB150 was one bike that I clearly noted where the medium handled more effortlessly than the L. It was an exception from the norm. Almost every other bike felt more intuitive and balanced in size L, including the SB130. I had presumed that sizing-up was what you did to go faster, but that article echoed my beliefs that it was something else based on these exceptions. I just don't know how to word it to explain it clearly to others...
    People have tried and failed to convince others that it's about how long the CS is, in relation to the wheelbase or front end length. My spin on it would be to relate it to how a high end sports car (designed for competitively fast track times) might choose to place its weight to get a certain weight balance, such as a mid or rear engine to get more on the rear. This contrasts the cars designed for everyday commuting that have a lot of weight up front, with the belief that it's safer for unskilled drivers. It would be akin to moving the weight of a rider back on a bike, by moving the cranks more rearward closer to the rear wheel. If the crank can't be moved back any more, can move the front wheel forward for a similar effect.
    "The challenge is not in developing new ideas, but in escaping old ideas."
  179. #1179
    Mar 2020
    Does it have to remove the original rubber guard while installing the ROCKGUARDZ? I'm also intested in the carbon guard since the rubber one seems to provide weak protection.
  180. #1180
    Dec 2011
    No. You apply the Rockguardz over the stock one.
  181. #1181
    Mar 2020
    Thanks, that's ideal!
  182. #1182
    Apr 2014
    I left the tribe after I sold my SB66. I rolled around out in the wilderness on a v2 Bronson, a Slash 9.8, a Pedalhead, a Chameleon, but Iím back on a Yeti. Grabbed my C2 SB150 on Tuesday....feels real nice.
  183. #1183
    M^X
    M^X is offline
    Aug 2020
    Hey everyone
    Iím looking to install a Bearing Kit on the Fox X2 on my SB150.
    Have the feeling this must have been discussed before, but I canít find anything specific on the endless MTB forumsí threads.
    Does anyone have a RWC Needle Bearing Kit installed on the top eyelet of the shock of a SB150? If yes, is it worth upgrading to?
    Thanks,
    Max
  184. #1184
    Nov 2015
    Quote Originally Posted by Costigan View Post
    What do you think of the 150 compared to the Bronson v2? Am looking at making the same switch or going with the 140.
  185. #1185
    Apr 2014
    Quote Originally Posted by wagonmaster87 View Post
    Mmmm.....the SB150 is unforgiving in the race bike sense of ďunforgivingĒ. Like all of the reviews say you have to be on it. The SB150 doesnít reward chill. I felt that today on my first crack at my local rowdy spot. I wasnít slow, but I didnít always feel in control. My 2017 Slash 9.8 was the shit. I do miss that bike, but I suspect Iíll unlock the SB 150 in another few rides.....it does climb better than my old Slash.
    If I didnít have a bike Park in my back yard I would have bought the SB130.
    The V2 Bronson was special....the new one kinda sucks.
  186. #1186
    Quote Originally Posted by M^X View Post
    Hey everyone
    Thanks,
    Max
    Don't bother... the RWC kits are great for shock eyelets that see a lot of rotation like with the top eyelets of bikes with vertically mounted rear shocks. The relatively straight push thru of Yeti's rear triangle to the rear shock makes that a moot point and your best bet is to stick with the Fox Igus OEM bushings from my experience as they work well, are cheap, and last a long time.
    Have FUN!
    G MAN
  187. #1187
    M^X
    M^X is offline
    Aug 2020
    Thanks for the reply. Makes sense as some of those bikes with vertically mounted shocks have around 20degrees of rotation, but I thought it would be beneficial anyway as the SB150 has about 7degrees of rotation on the top eyelet, which is not nearly as much but still something. If I could, Iíd definitely install a spherical bearing...
    Max
  188. #1188
    Mar 2020
    Max
    Hi, do you know which product of RWC fit the SB150, I'm also interested in it but I have no idea about the mounting size.
  189. #1189
    M^X
    M^X is offline
    Aug 2020
    Hey
    The shock mount should be around 36mm wide, but I was recommended to measure my frame specifically. Iíd advise you to do the same and double check the mount spacing on your frame.
  190. #1190
    Sep 2017
    I also do not see how the SB150 would measurably benefit from a front eyelet needle bearing. You'd be better off holding off that money and putting it into suspension upgrades down the road. There's so little front eyelet rotation. Just use a fox eyelet hardwear, or something expensive like PUSH bushings with little wear I could sell you cheap.
    Also even though Yeti Manual states it uses 36x8mm for the front shock mount, they really use 35.6x8mm which is a more standard size. I have confirmed this with Yeti in a website chat. They said for the manual they rounded up. This is what I have been using for a year or two as well.
  191. #1191
    Reputation: Junersun's Avatar
    Jun 2014
    Just picked up a sb150. Really digging the ride. Question and Iím sorry if this has been covered before but has anyone come up with a clever switch infinity cover or protector?
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    2019 Kona Rove NRB DL
    2020 Banshee Paradox
Page 6 of 6 FirstFirst ... 23456
  1. Replies: 2401
    Last Post: 1 Week Ago, 10:31 AM
  2. New Yeti SB150 sneak peak!
    By svinyard in forum 29er Bikes
    Last Post: 08-27-2018, 12:54 PM
  3. Replies: 22
    Last Post: 02-25-2016, 04:44 AM
  4. Replies: 10
    Last Post: 09-04-2013, 05:54 PM
  5. Full build pictures of Yeti SS and Yeti FR bike
    By ryan_daugherty in forum Downhill - Freeride
    Last Post: 04-22-2008, 03:23 PM
Members who have read this thread: 393
