Yeti SB130 Discussion, Performance and Build - Page 11- Mtbr.com
Page 11 of 11 FirstFirst ... 7891011
Results 2,001 to 2,153 of 2153
  1. #2001
    Reputation: MJW75's Avatar
    Jul 2018
    We the people ...
    Quote Originally Posted by stolenteg View Post
    I'm no wizard at setting up suspension, still trying to get my grip2 160mm fork to feel *plush* in rocks garden.
    I am about 160-165 riding weight atm
    I am the same weight also with a 160mm Grip2 36. I also had issues with getting my fork plush. It seems the Grip 2 works better with heavier riders. A key thing to check is that you are running 30% sag as per Yeti's recommendation (not 15-20% that Fox say). I was, but it still wasn't plush.
    I started by cleaning excess grease from the air side to stop any getting in the port between negative and positive air spring (there are a fair bit there). This seemed to help a little, but not much. I then fitted a Luftkappe, which fixed the issue. The fork is much better now.
    I'm running 50psi with no volume spacers (the Luftkappe actually counts as 1 spacer). This gets me bang on 30% sag and my ShockWiz seems to think everything is near perfect. It certainly feels a lot better than from factory.
    Yeti SB130LR Turq Series Custom Build
  2. #2002
    Reputation: mstrkrft69's Avatar
    Jan 2018
    I just acquired an SB130LR. My original plan was to get a straight 130 but the LR came up on PB with carbon wheels at a good price. So I went for it. I thought it was a stock build but I noticed the stem is shorter than spec'd which I'm cool with since I'd likely swap it out anyway. So it looks like a build up.
    Bigger issue, it came with a 170mm grip2 fork. Wow, wasn't expecting that. I know (I think) I can swap the air shaft to 160 or even 150. Q is what should I expect with the 170mm?
    I haven't ridden it yet, because it just came yesterday. I'm still putting it together. I'm mostly a technical trail rider in Marin county California. I'll definitely get up to the mountains occasionally and get to the bike park and ride some gnarlier stuff. So I'm sure the 170 will be great for that. But I'm wondering for straight trail riding if I should downsize it?
    Sent from my Pixel 2 XL using Tapatalk
  3. #2003
    Aug 2017
    Are you sure it's a 170mm. A 160mm will have stanchion of 170mm btw.
    Better way to check is let all the air out and measure how much it actually compresses.
  4. #2004
    Reputation: mfa81's Avatar
    also why not ask the seller? 170mm fork will increase bb height, likely not ideal for climbing, your front wheel might feel a little vague, I'd not be running a 170 in this bike
  5. #2005
    Mar 2019
    Agreed! You値l keep loosing the front in corners.
  6. #2006
    Oct 2007
    Is anyone running their sb130 with the rear long shocked, but with a 150mm fork? How do you like it?
  7. #2007
    Reputation: Lpcunity's Avatar
    Jun 2010
    Advise please.
    I知 an owner of a SB6 and love it. I want to try the 29er game. I知 considering the 130 TLR but also thinking of the 150. I知 a Golden CO native and now live in Hong Kong. The trails here are chunky with a bit of XC feel. There are shuttle options out here that are chunky and steep. I値l only be shuttling about 30% of the time. I知 wondering if anyone has come off the SB6 to the 130 LR and felt under gunned. 70% of my riding will be short tech climbs with tech DH. I知 not sure if I should go 150 or 130LR. I知 not racing but enjoy having a bike that will make up for my mistakes. The riding here in Hong Kong is not like the front range. It痴 not 1500 up and bomb down. More short climbs and around 10 miles for a loop. I want a bike that will inspire me on the DH like the SB6, but I keep reading the 150 is mostly for chargers going Mach with climbing as an after thought. Anyone think the 130 TLR will be a good replacement for my SB6 or should I go for the 150?
  8. #2008
    Mar 2019
    Had the SB6, thought I was fast on it ... then moved on to the SB5.5 (even faster) ... and again to the SB130 ... totally stocked! Go for the 130 you can do everything on it and it rips.
  9. #2009
    Jan 2018
    I pulled the code off the back and emailed it to Fox. They told me it's a 170. Although when I compress and measure it only goes 155.
  10. #2010
    Jan 2018
    Quote Originally Posted by mfa81 View Post
    Yeah I'll do that. So the question is do I go down to 160 or 150
  11. #2011
    Aug 2017
    I dont see why anyone would put a 170 on a 130. I bet you it may be a 170 and reduce to 160 if it only compress 155 max. Even though it should compress 160 and have 10 exposed left
  12. #2012
    Jan 2018
    Fully extended it measures 170 edge to edge on the crown and stanchion.. When I compress it all the way down It may go to 160. But there's a little bit of spring at the end so I had to push pretty hard on it even with all the air out
  13. #2013
    Jun 2018
    hoping that someone can save me some time here as i am sure it has already been asked at some point....
    how does the 130 do with the x2 shock?
    anyone have the true weight of an XX1 equipped, XL 130 tlr? With either the aluminum or carbon wheels...
  14. #2014
    Oct 2007
    Quote Originally Posted by ironpeddler View Post
    There's a few posts above with people on the X2.
    Here are a few good videos on the differences between the X2 and DPX2 (also the DPS)
    https://www.youtube.com/watch?v=K94N7fTOLMQ
    https://www.youtube.com/watch?v=4rPun6VBrag
  15. #2015
    Reputation: DesertVelo's Avatar
    Sep 2018
    Quote Originally Posted by Dave1078 View Post
    I am running the stock 150mm Fox 36 but I ended up replacing my Factory DPX2 52.5mm with a Cane Creek DBCoilIL 55mm - the same stroke as the SB130LR. While not exactly a direct comparison from a stock setup, the 6mm increase of travel (130mm to 136mm) is negligible. As far as sag is concerned, 30% of 2.5 mm (52.5mm to 55mm stroke) translates to a .75mm increase.
    Not much to report for the "long" shock and the 150mm fork combination other than it rides as expected (great!). However, the coil shock is definitely an improvement. Getting settings dialed for my weight and style.
    Sent from the singletrack...
  16. #2016
    Mar 2019
    Quote Originally Posted by DesertVelo View Post
    I am running the stock 150mm Fox 36 but I ended up replacing my Factory DPX2 52.5mm with a Cane Creek DBCoilIL 55mm ...
    That shock rules! Do you know the settings you池e using?! LSC/LSR/HSC/HSR
  17. #2017
    Yeti specs the 2020 130 with a 50mm stem, but last year all new 130's came equipped with 40mm stems. Interesting that they would decide to change that....
    I know stem length preference is different for every rider, but any experiences or thoughts on running both 40 and 50 back-to-back on a "stock" build (150mm Fork)? Just curious.
  18. #2018
    Reputation: skinnybex's Avatar
    Aug 2015
    Quote Originally Posted by JasonHH View Post
    That choice was likely based on putting more of a riders weight over the front end to help with ease of adjusting to the more forward body position benefit with the longer front center and reduced offset forks of the new Geo bikes.
    Yeti SB165
    Yeti SB150
    Yeti SB130 AXS
    Yeti SB100
    Yeti SB5.5
    Orbea Rallon
    Devinci Spartan
    Devinci Troy
  19. #2019
    Quote Originally Posted by skinnybex View Post
    that's true... also a lot of people are feeling in between sizes feeling too cramped while climbing seated but comfortable with the longer reach in one size or comfortable while climbing seated but thinking reach is too long if they size up, a longer stem reduces this gap a little, even though it also increases the reach it's more noticeable when you are seated
  20. #2020
    Sep 2018
    Quote Originally Posted by digev View Post
    Ageed! I need a little more time to adjust the settings but I started with the neutral base (stock). From there, I added 1 click to the LSC/LSR to take care of pedal feel. I increased the HSR +1/2 and left the HSC alone for now.
    For my 70.9kg/156lb rider weight (fully kitted out)
    LSC 8 clicks
    LSR 11 clicks
    HSR 2.5 turns
    HSC 2 turns
    Last weekend's ride was mostly climbing so I need to ride other terrain to get the rest of it dialed in. I am using the 2.25x450 VALT spring about 28% sag.
    Definitely a different feel than the Factory DPX2, which is a great shock.
  21. #2021
    Sep 2018
    Totally agree; however, I ended up using a 44mm stem on my 2019 model after experimenting with a 50mm. Yeti must have received feedback from riders with a focus on handling to make the change. All things for the better, hopefully, but it is still a personal preference. I like how the 2020 models are using 170mm cranks throughout the line.
  22. #2022
    Jul 2014
    Hi skinnybex.
    Rallon R5 VS SB130 ?
    Thank you
  23. #2023
    Jun 2018
    they have a rallon r5? what's a rallon r5?
  24. #2024
    Aug 2015
    Quote Originally Posted by Uzzy View Post
    Hi skinnybex.
    Thank you
    For a do everything bike that checks every single box as far as fun factor and capability I'd say SB130 with a 160mm fork and the limiter removed on the rear shock giving you 136mm travel.
    If your a smasher and ride Bike Park as much as general trail riding then the Rallon with the new rear linkage is Damn near perfect giving you 170/160mm and more progresivity but the Rallon slightly less rewarding to ride in general as the SB130.
    Tradeoffs to both since the Yeti will have less rear tire clearance and need a bit more maintenece for the SI but the bike climbs amazingly and is lively and nimble on all types of trails whereas the Rallon is a big mountain smasher that still is fun to ride on tamer terrain
    SB130 !!!!!
    Yeti SB165
    Yeti SB150
    Yeti SB130 AXS
    Yeti SB100
    Yeti SB5.5
    Orbea Rallon
    Devinci Spartan
    Devinci Troy
  25. #2025
    Jul 2014
    Last year I bought a Orbea Rallon 2018 and I am happy with it because it ascends very well, it descends very well but it is dry and insipid.
    I think the Yeti sb130 can be more fun than the Rallon. My intention is to configure it 130/150 because in my area there are not many rocks and I think that 136/160 are not necessary here, although I think that in the future I will make the change ....
  26. #2026
    Hisforever
    Reputation: SHAHEEB's Avatar
    Dec 2004
    Hi.
    I have had many Santa Cruz. Last year I bought a Orbea Rallon 2018 and I am happy with it because it ascends very well, it descends very well but it is dry and insipid . I was waiting for the new bicycles of Santa Cruz, but I am disappointed with the STA. Now I like the yeti sb130 in the 130/150 configuration. Who has had the rallon 2018 .... what important differences exist? (Rallon vs Sb130).
    Thank you.
    Regards
    Uzzy, i can comment on the rallon vs 130 or 150. it basically splits the difference b/w these two. i felt like my rallon was a ripper every time i rode it. the rallon feels slightly shorter and slightly more upright/ ie higher bb. this is just my observation, specs may say otherwise... i may actually prefer the rallon that i sold for its quicker handling. however i felt the rallon too linear(new linkage could remedy this). nothing seems to climb as well as the yeti's(referring to seating position and supsension going up). maybe the ripmo.
    overall maybe the yeti could be summed up more like a speedy racer, rallon more of a capable trail / all mtn bike? little nuances, both are killer. I just sold the rallon mainly b/c of fear that it would be hard to sell later, look at the orbea forum...crickets. the rallon is very very good for how unpopular it seems.
    PipedreamMoxie
    M 5.5
    Yeti
    Evil
    Yz 250x braap
  27. #2027
    Jul 2018
    Quote Originally Posted by mstrkrft69 View Post
    Was it a custom build? Are the forks orange?
    Mine is a custom build and the orange 36 with reduced offset only come in 170mm.
    So the previous owner probably changed the air spring, but looking up on the Fox website will obviously give you spec from factory.
  28. #2028
    Jul 2014
    Quote Originally Posted by SHAHEEB View Post
    Thank you.
  29. #2029
    Jan 2018
    Quote Originally Posted by MJW75 View Post
    I asked the previous owner. Looks like a sb150 kit dropped on an sb130 frame. The fork is neutral black. Specs say 170. Just trying to figure out if it's stroked down to 160. I'll probly drop it down to 150mm for trail riding.
    What I don't know is if that will lower the BB
  30. #2030
    Jun 2018
    when you order a tlr 130 edition and you want to get the axs and carbon wheel upgrade. What axs does it upgrade to...the xx1 axs or x01 axs? It does not specify on their website which one it is, it just says "AXS" and nothing else.
    And if you get the dt swiss 1200 carbon wheel upgrade what hubs does it come with? I am assuming dt swiss 240 hubs but again it does not specify on their website.
  31. #2031
    Jul 2017
    The Swedish shop I just ordered a TLR AXS through had it down as XX1 AXS.
  32. #2032
    Jul 2017
    Btw, not sure those DT hoops are that solid, considering they池e on the beefed up version of the 130, believe they池e marketed more as XC/trail. I壇 spend that money on other carbon wheels if I where u, like Nobl/Santa CRUZ.
  33. #2033
    Sep 2017
    If the fork has 170mm exposed its a 170mm fork. Its likely got some tokens installed which is why you can't compress it all the way even without air in it.
  34. #2034
    Jul 2014
    Hi.
    I can't find any sb130 Turq Series 2019 frame size L new in stock in Europe.
    Can any European help me?
  35. #2035
    Mar 2019
    Hi.
    Try these guys!
    TST Trading GmbH
    Eiweg 10
    CH-4460 Gelterkinden
    +41 61 985 50 85
    [email protected]
    OR
    +44 1246 566 555
    [email protected]
  36. #2036
    Aug 2015
    Quote Originally Posted by Lpcunity View Post
    Advise please.
    I知 an owner of a SB6 and love it....I want a bike that will inspire me on the DH like the SB6, but I keep reading the 150 is mostly for chargers going Mach with climbing as an after thought. Anyone think the 130 TLR will be a good replacement for my SB6 or should I go for the 150?
    I have an sb150 and 130. If I had to choose one I'd probably go with the 150. It climbs very well and can be made into a faster bike by tire choice, lighter wheels, and even dropping the fork down to 160. If you have an sb6 (which I've never tried), I'd think the 130 might feel less plush/forgiving. However, the 130 is likely to be faster due to the 29 wheels and will suit your hk trails well. Guess it comes down to this...would you trade your sb6 for an sb5? Also depends on how long your rides are. If you go out for 2 hours or 4 hours, may influence the long vs medium travel choice. You are right that the sb150 loves to go fast in steep terrain, but it is not a one trick pony.
  37. #2037
    Jun 2018
    I was kind of hoping that the LR 130 would be more like the 150 than the regular 130. With a grip2 160mm instead of the fit4 150mm in the front and it has a slightly larger rear shock 210x55mm compared to 210x52.5mm, the 130 should be able to handle the more burly stuff better like the 150 does while still being a better climber and faster on the flatter trails. Or maybe i am just dreaming
  38. #2038
    Reputation: Gman086's Avatar
    Correct - 240 straightpull hubs with 6 bolt flanges (NOT centerlocks which I would have preferred). DT Swiss knows how to make wheels and those 30mm IW hoops are stronger than most so... I wouldn't worry about them unless you run crazy low tire pressures.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
  39. #2039
    Sep 2017
    Quote Originally Posted by nortonwhis View Post
    My 2020 HSLC has a 160mm airshaft and about 170mm of exposed stanchion...I forget the exact number. I'm no suspension expert, but I investigated when it first arrived and learned that it's normal for this fork to have quite a bit of unused stanchion.
    Sent from my SM-G960U using Tapatalk
  40. #2040
    Sep 2017
    Well, I've only ridden the 130LR, so I wont be able to give you the comparison...but it's extremely capable. Unless you spend most of your time in park and smashing big rock gardens, I cant imagine needing a SB150. There's a local trail with a couple big/painful drop-to-flat I use to test suspension...the 130 LR handled these equal to my Wreckoning. Overall I feel like the suspension and leverage curve uses/gives up a lot of its travel quite regularly, making it ride bigger than it is...and happy to say, this does not seem to translate into harsh bottom-outs. For another reference, I did a couple demo days on the Rallon...I found the 130LR to be more capable in every regard.
    I dropped a grand on an extra rear wheel and cassette so I could a 2.5 Aggressor with cushcore so I could run lower pressures in the back to make up for the lack of travel...that was pretty much wasted money.
  41. #2041
    Sep 2017
    Anybody better versed than I in BB standards able to tell me if this "thread-together" Pressfit BB from Wheels Manufacturing would be the right size for our Yeti? (This style BB eliminates creaking for me on my last couple bikes, and sure enough starting to hear some slight creaking creep in)
    https://wheelsmfg.com/bottom-brackets/bbrighttm-outboard-abec-3-bb-for-29mm-sram-dub-cranks-black.html
  42. #2042
    Aug 2015
    Quote Originally Posted by RAG2 View Post
    I can't tell from your photo, but the wheels mfg bb you'll need for the yeti is dependent upon the cranks you have. But they have a PF BB92 for shimano and sram and sram dub. Go to https://wheelsmfg.com/bottom-brackets.html and on the left side click bb86/92. Then you'll see your options. They are very good bottom brackets, but I've had no issues with $30 Shimano press fit BBs. But if I was going to buy something nice, it would be a wheels mfg. And if you're still not sure, call their number at the bottom of the web page, they are a good company, easy to deal with.
  43. #2043
    Jul 2014
    Try these guys!
    TST Trading GmbH
    Eiweg 10
    +41 61 985 50 85
    [email protected]
    OR
    +44 1246 566 555
    [email protected]
    Thank you.
    I have not been able to buy outside my country.
    I have finally bought a turquoise 2020 frame.
    I currently have a fox 36 RC2 fork and it works fine. Maybe the Nate Hills videos have caused me to want to install a red 2020 Lyrik Ultimate fork on my turquoise SB130 but there are few Lyrik Ultimate forks out there. Do you know what the reason may be? Are those forks working badly?
    Greetings.
  44. #2044
    https://wheelsmfg.com/bottom-bracket...nks-black.html
    https://wheelsmfg.com/bottom-bracket...m-bracket.html
    this is what you need for DUB cranks. You can only use thread together for shimano or gxp cranks no space in the bb shell for dub or 30mm spindle.
  45. #2045
    Sep 2017
    Ahh, that explains it then. Thank you
  46. #2046
    May 2012
    Hi.
    Silverfish UK are the UK distributors:
    https://www.silverfish-uk.com/manufacturer/Yeti-Cycles
  47. #2047
    Finally got my new build dialed in. Thought I'd post some photos of the new 2020 color and some personal touches.
    Turq 2 XO1 build. I've run two bikes for the last 5+ years (short and long travel) and for the first time I really think this one bike covers all my needs.
    Running the Enve wheelset in the photos with Hans Damf and Nobby Nic for lighter duty trail riding. Build weight as shown is just over 28 lbs. I've got a set of Santa Cruz Reserve 30's with 2.5 Assegai and 2.5 Aggressor for bigger trails and considering getting a coil shock to compliment. As expected, the much grippier/heavier rubber completely changes the character of the bike. I've truly never ridden a bike that can climb so well and also handle steep, long descents so well.
    Little things.....Syncro mud guard is pretty slick integrated with the Fox 36, had the bike swapped for 175 cranks (170 cranks just tweak my knees and I haven't had any issues with low BB at all), 150mm fork feels perfect..no interest in up-forking to 160mm, slapped on some custom Fox decals on suspension.
    Attached Thumbnails Attached Thumbnails Yeti SB130 Discussion, Performance and Build-img_9512.jpg
  48. #2048
    Jul 2014
    Quote Originally Posted by kingofbiscuits View Post
    Thank you.
    I will finally buy the latest 2020 version in Spain.
    Regards
  49. #2049
    Oct 2007
    I really like the Storm color this year. Looks nice. Are you running 2.6 schwalbes?
  50. #2050
    Running 2.35 Schwalbe's. I'm really a fan of 2.35-2.5 tires. I've tried the 2.6's and they just felt too high volume and kind of vague for my personal preference.
  51. #2051
    Oct 2007
    Gotcha. The 2.35 Schwalbes (Magic Mary, HD2, Nobby nic, & Rock Razor) I've tried all measured 2.4" or bigger.
  52. #2052
    Jul 2018
    Is the AXS upgrade for the XO build and XX1 build always the XX AXS?
    Wonder if you buy the 2020 T2 kit with the AXS upgrade, is it the XX AXS kit? Just sold my SB6 and ordered the 2020, T2 kit with AXS but I don't recall if the upgrade is XX AXS or XO AXS. I still have my SB4.5 but will be moving some bling parts over before I sell it. This is my current SB4.5.
    Attached Thumbnails Attached Thumbnails Yeti SB130 Discussion, Performance and Build-img_5783.jpg
  53. #2053
    Aug 2015
    Quote Originally Posted by TXMTBMonkey View Post
    The Eagle AXS upgrade option includes The XX AXS Rear Derailleur and an XX AXS controller and 1 battery and charger.
    All the other group components stay unchanged and are the exact same as listed on the spec sheet.
    Yeti SB165
    Yeti SB150
    Yeti SB130 AXS
    Yeti SB100
    Yeti SB5.5
    Orbea Rallon
    Devinci Spartan
    Devinci Troy
  54. #2054
    Oct 2014
    Just put a deposit down on a 2020 sb130 medium turquoise t1 build through bikeco.com! Stoked for the bike, and the new xt groupset. bikeco.com has been super easy to work with, even offered a small discount on the bike! Slapping on the frame protector kit, shuttle guard, and chainguide/bash guard. Should have it within a few weeks. Now I just need to sell my 4.5.
  55. #2055
    Oct 2014
    Does anyone know what dropper lever they are spec-ing with 2020 models? Thanks!
  56. #2056
    Quote Originally Posted by roaringfork View Post
    fox transfer
  57. #2057
    Oct 2014
    fox transfer
    Bummer. Will definitely switch my wolftooth over to the new bike. The fox lever might be the worst bike part I've ever used. Broke 2 collars torqued to spec.
  58. #2058
    Jul 2018
    I ordered mine on 9/10 from my local Yeti dealer. He said it would arrive in a week which would be 9/17. I called yesterday and he said that Yeti is back ordered on rear shocks and wheels? So, now he is saying next Wednesday. He is going to swap out the fork for the shinney orange Fox. I am planning on moving some of my orange parts over to the new bike as soon as I get it, then put my 4.5 back to stock and then for sale. It's like Christmas, the waiting is killing me!
  59. #2059
    Oct 2014
    Just got word they will have my bike built and shipped by next Friday. Sweet!
    The dropper remote lever included is race face turbine, not the fox transfer.
  60. #2060
    Jul 2019
    Just want to say thanks to everyone who's contributed to this thread. The amount of information to hand is frankly ridiculous, and has been a huge help in whittling down what kind of build I wanted to go for. Picked it up last week (the day before an enduro race!) and could not be happier. Fox factory front & rear, Turq frame and Hunt Trailwide wheels.
    Cheers!
    Attached Thumbnails Attached Thumbnails Yeti SB130 Discussion, Performance and Build-yeti_sb130.jpg
  61. #2061
    They are based in the UK, prices are in 」
    The go-to custom decals shop for bikes in Europe and they make most of the stickers for EWS teams
    https://www.instagram.com/slikgraphics/
    https://www.slikgraphics.com
    Quote Originally Posted by LaCostaClydesdale View Post
    mfa81...slik graphics makes these. They have standard color combos or you can request custom. Mine was custom: Yeti Turquoise and Fox Orange. I did the shock too. They are great to work with. I think based in Sweden
    Quote Originally Posted by uberscott View Post
    Cheers!
    the 2020 almost non existent graphics is so nice! really like the stealth looks! beautiful bike!
  62. #2062
    Jul 2019
    Thanks man!
    In my experience Slik Graphics are excellent to deal with - I got a set of blue Fox decals for the fork lowers, but now I'm torn as I rather like the orange ones! I'll leave them on until they get damaged. At this point it's more about getting out and riding the damn thing anyway
  63. #2063
    Jan 2018
    I just acquired a used sb130lr. When I got it I ran the fork code thru Fox's website and it came back as a 170mm Grip2. The LR comes stock with a 160mm. So I'm 10mm over the base model. On the Yeti website they have a full tuning guide for HSC, LSC, etc...
    Q1- should I use the same numbers for the 170 fork? Would stroke even effect this?
    Q2- since I'm mostly a trail rider, I'll likely put in a 150mm airshaft and reserve the 170 for when I head up to Tahoe and the bike park. Same Question. Should I stick to the yeti specs for my baseline?
  64. #2064
    Jul 2019
    I just used the SB140 as my initial setup guide as it's got the same travel front & rear. Haven't had much of a chance to tinker with the setup yet but from initial rides it's a great starting place.
  65. #2065
    Jul 2019
    Sorry, just read your post again and realised you've got a 170 not a 160. As it happens I also checked the recommended settings for the SB150. Comparing the 170 fork to the 160 fork, the settings are pretty much the same. Pressure is 2psi higher in the 170, but all the compression and rebound settings are the same.
  66. #2066
    Jan 2018
  67. #2067
    Aug 2015
    Quality of light this time of year is awesome...Yeti SB130 Discussion, Performance and Build-img_20190908_185236.jpg
  68. #2068
    Jul 2018
    Is it a stock build or custom build? I have the orange Fox 36 and they only come in 170mm, so I needed to change the air shaft to 160mm (after going 150mm first). Checking the serial number obviously brings up the spec the fork left the factory.
    I would check the travel before assuming you do have 170mm. Just deflate the fork and check how much actual travel you have. Don't measure the stanshion as some of it isn't used (unlike Rockshox forks). Personally, I'd go with 160mm. It seems great on mine and I had 150mm before on the bike for 4 months.
  69. #2069
    Jan 2018
    Not completely sure on the build. I think it's custom but very close to stock. 780mm bars instead of 800. 30mm stem instead of 50mm. Both the same model as stock. Everything else appears to be stock.
    I did let the air out of the shock and compressed it. There appeared to be a little bit of pressure in it I couldn't "push" out at the bottom of the travel. So measuring that number accurately feels a little vague.
    So maybe it's been restroked to 160mm. I'll have to inspect it a little closer.
    How did you like it at 150mm? Think I may try it out for a while since it's a pretty cheap part to acquire and seems pretty easy to swap.
  70. #2070
    Jul 2018
    150mm was fine, but I prefer 160mm. It doesn't make the bike any less capable on flats and climbs (that I could tell), but it made a good difference descending.
  71. #2071
    May 2019
    2020 models are coming with a Raceface turbine dropper lever, not the Fox as the 2019 had.
    edit: just noticed you already found this out!
  72. #2072
    Aug 2017
    This is a 210x55 inline coil with a 2.25 400lbs spring.
    Do you guys think a longer spring like 2.5 or even 2.75 is better? Quite a bit of thread left on the coil.
  73. #2073
    Mar 2019
    You could go with a 2.5 but the 2.25 is good too and even lighter. Technically it doesn稚 change anything.
  74. #2074
    Mar 2019
    Are you sure it痴 a 400x2.25?
    Mine is only 7mm shorter than a 450x2.25 VALT ... so visually it should be longer than what you have on the picture!
  75. #2075
    Aug 2017
    Yup 400 x 2.25. I was surprised how short it is on the coil.Yeti SB130 Discussion, Performance and Build-20190924_103803.jpg
  76. #2076
    Mar 2019
    Mine is 119mm (free length). What about yours?!
  77. #2077
    Reputation: Apexit's Avatar
    Yup 400 x 2.25. I was surprised how short it is on the coil.Click image for larger version.
    I like that Fox SLS with the Cane Creek IL. Does anyone know if the SLS is lighter than the Valt spring since the coils are not as tightly wound?
    SB165
    SB150
    SB130
    SB100
    FollowingV2
    SB5
    SB55
    SB45
    Farley 9.8
  78. #2078
    Aug 2017
    The spring is around the same lenght as yours
    Is it my coil? BAD1742 part # 210x55
  79. #2079
    Mar 2019
    Hmmm. Strange! mine is the #BAD2394 but I don稚 think it would make a difference.
    The VALT 450x2.25 free length is 126mm and I get about 21mm of exposed thread bellow the preload.
  80. #2080
    Aug 2015
    Did you call cane creek and ask their recommendations? I think they'd probably say do the 2.5 or 2.75 (not all weights are available in a given length). You want something longer than the stroke length 55/25.4=2.16 (which the 2.25 is) and no larger than a size that the manufacturer will specify. Generally the size recommended is not the size closest to the stroke length.
  81. #2081
    Mar 2019
    It might be a silly question but you don稚 have too many turns of preload on that spring, right?!
  82. #2082
    Aug 2017
    Thats with maybe 1 1/2 turn of preload
    this is my first coil set up. i follow earlier post suggesting a 2.25 spring for this bike
  83. #2083
    Sep 2018
    I am running the same 210x55 shock (BAD1857) with a 2.25x450 spring. I ordered my shock directly from Cane Creek and spent some time reviewing the spring weight/length. After an internal discussion with their suspension technicians, Cane Creek recommended the the 2.25 spring.
    Since the CC springs are a linear rate (versus variable rate springs), you will will not gain any "performance" going to a longer spring. The key is the spring "weight" that will affect sag/feel/support of your ride.
    I believe Fox's SLS spring is a linear rate spring - and light weight (Super Lightweight Spring) compared to a conventional steel spring. I am noticing that you have more exposed thread that I do (measured from the front eyelet) - I have 2.5 turns for preload which about in the middle. The spring length is 126mm which @digev had mentioned.
  84. #2084
    Aug 2017
    My coil lenght is 115mm with 2 1/2 turn of preload. Took it for a 15 miles ride and everything feel ok so dont know why the sls spring is so short
  85. #2085
    Mar 2019
    That means your coil is about 10mm shorter that ours. When it doesn稚 change anything, I'll see if I can exchange it if I was you ... while it痴 still new.
    How do you like the coil compared to the DPX2?
  86. #2086
    Hisforever
    Dec 2004
    how would you sum up the change from air to coil on this frame? Did it improve certain ride characteristics that you noticed?
    Fox coil $
    CC inline $
    Bomber CR value
    DVO $?
    Avalanche $$
    11/6 too $$$
    RS ?
    which one would be the best for ride quality but not too $$
    PipedreamMoxie
    M 5.5
    Yeti
    Evil
    Yz 250x braap
  87. #2087
    Mar 2019
    Fox coil $
    CC inline $
    Bomber CR value
    DVO $?
    Avalanche $$
    11/6 too $$$
    RS ?
    - The CCIL coil is great and cheap (4 ways + climb switch) and by far the lightest
    - The Bomber CR is meant to be really good once tuned (by yourself or Avalanche) cheap too. No CS and only 2 ways (LSC/RBD)
    With a coil you値l get insane grip in corners and off camber and more confidence in the rough because it痴 a lot more supple / compliant. The mid stroke is superior to air shocks without having to compromise your settings.
    I really think smaller travel bikes such as the 130 greatly benefit from a coil shock because they can punch way above their weight! (The stumpy is another great example of how a "small" bike can rip with a coil shock)
  88. #2088
    Mar 2019
    I almost forgot. They climb better too because the rear wheel can track the ground without skipping any bumps, holes or roots. I honestly don稚 see any flip side to it. (After 3 years of use on 3 different bikes)
  89. #2089
    Mar 2012
    in pedaling do you feel difference? does it move so much? and if you get up on the pedals? the dpx2 is practically stopped
  90. #2090
    Mar 2019
    The only time I use the climb switch is on the road ... otherwise on singletracks you leave it open and keep it open, so yes it moves a little but it痴 good for traction and confort ... it痴 not wallowing or bouncing ... it痴 a firm plush if you will, the bike keeps its dynamic.
    It reacts to the ground but not to the riders' input.
  91. #2091
    Mar 2019
  92. #2092
    Aug 2015
    I bought a CC db coil IL just because it was over 50% off. I wouldn't have bought it otherwise. I think with coil suspension you can debate the best damper/shock but really it is just that coil gives a much different ride quality. That being said, my aim will eventually be to put an X2 on my sb130. I've had that shock on 4 different bikes and love it. I feel like the middle of the travel gives something extra that shocks like the dpx2 do not. I would like to try the new RS super deluxe ultimate as well. But the X2 is really a great piece of equipment. The only downside is it is not something that you can service at home (takes a lot of special tools, etc), so you end up sending it to Fox for $150/year to get it serviced for the season.
  93. #2093
    Nice, thanks!
    SB165
    SB150
    SB130
    SB100
    FollowingV2
    SB5
    SB55
    SB45
    Farley 9.8
  94. #2094
    Aug 2017
    Seem like the 2.25 sls spring is 120mm in lenght, mine was 115 mm with 2 1/2 of preload so seem about right?
    I didnt check to see what the lenght of the cc vault spring are.
  95. #2095
    Aug 2015
    I think you just proved why there is no reason to buy a valt spring over the standard CC steel spring. If weight is your concern, a fox or other options would be the way to go.
  96. #2096
    Aug 2017
    Well the vault spring is half the price of a sls but almost double weight
  97. #2097
    Aug 2015
    Quote Originally Posted by fryeguy View Post
    Hi guys, I致e got an opportunity for a set of Enve wheels at a steep discount.
    Did you try speaking with Enve directly? It looks like the 730 rims are about 100g more carbon per rim than the 630s and still are only just over 500g per rim which is very light for a 29" rim. Plus 32 spokes is a plus in my book. The main difference I see other than a little weight is that the 730s use that rim strip thing that is supposed to help prevent flats/burps. I guess you could see that as a positive (reduced chance for flats, rim protection) or a negative (something else to mess with). But I agree with mfa81 that your riding would say M630 to me. They will probably be more forgiving/less stiff and be better for all around trail riding. Another way to look at it is, get the M630s as your 'fast' wheels and then build a set of strong alloy wheels for days when you're going to put on the full face helmet.
  98. #2098
    Moderator Moderator
    Reputation: 5k bike 50cent legs's Avatar
    Oct 2016
    Just did my first SI grease service. Zerk fittings make it so easy. I do wish they would design the housing so that both fittings are exposed on the SB130 without taking out the main pivot bolt.
  99. #2099
    Mar 2012
    Quote Originally Posted by foggnm View Post
    50 off? where?
  100. #2100
    Mar 2019
    Quote Originally Posted by mastralbe View Post
    The SB130 has one of the best anti-squat in its category, so coil or air ... the kinematic takes care of it (before the shock)... in short, no bobbing allowed going up or when force is applied to the pedals. Thanks Yeti!
    Talking about all that, there is a new website to analyse any bike痴 suspension kinematics. Pretty good to skip all the marketing acronyms and BS and go straight to point. Does it pedal well going uphill? Are the brakes impacting the suspensions? What痴 the best SAG for this bike? Is it better to use an air shock or a coil?
    Source: https://www.mbr.co.uk/news/andre-xtr-391055
    If anyone wants to order a full SB130 analysis and be a hero ... feel free
  101. #2101
    anybody riding a small to confirm what size water bottle you fit in the frame?
    wondering if even a 20oz would fit, a 24oz definitely didn稚 fit on a demo bike but I didn稚 have another smaller bottle to try
  102. #2102
    there are short and long 20oz/24oz Bottles on the Market....
    the High of the Bottle should not exceed 21.5cm(8.46)...
    Measured with "Birzman Uncage" Bottlecage...
  103. #2103
    Oct 2010
    ergowave
    my new sqlab 611 ergowave feels like a lounge chair
    in a dream castle
    on the rocks
    a really nice saddle. no more cracking with the nivo seatpost.
  104. #2104
    Oct 2010
    Quote Originally Posted by zweigelt View Post
    the 24 oz bottles of fabric fit perfectly in a large frame. see above.
    its a very lightwight but sturdy solution with a maximum of volume to carry with.
    drinking in the saddle is possible, but I would not do so.
  105. #2105
    Aug 2016
    I could fit fidlock 600ml bottle
  106. #2106
    Oct 2017
    So I致e pulled a trigger and placed a deposit at my LBS to order a 2020 Yeti SB130 Large Grey Frame.
    I知 planning on swapping most of components from my existing highest end custom built 2019 Yeti SB100.
    I had a chance to take a demo 2020 SB130 T1 build in Large size (same size as all of my previous Yeti bikes) on two 20 mile rides. First one was more of XC ride. Second one was on single Black Diamond 3 mile trail and a 4 mile long hand built flow trail with total of 3 fire road 1,000 elev climbs.
    On the descends when the suspension is fully open with Fox 36 Fit4 150mm and DPX2 rear shock the simply blew my mind how capable it is. My previous bike was 2017 Yeti SB6 with 160mm Lyrik and Fox X2 rear shock. I felt like the SB130 was DEFINITELY much faster, supper easy thru chatter areas, incredibly nimble, maybe just 5% less stable than the SB6.
    But if was racing down that single black Dimond trail and had an option to choose between SB6 or SB130, I would not even hesitate and pick the SB130.
    I was very impressed how the bike changes once I locked both suspensions on long fire road climbs. It almost felt like I知 on an E-Bike. Even though the demo bike came at 30.5 lbs with pedals, it was just as easy for me climb on it as on my 24 lbs Yeti SB100.
    I have a strong feeling that the questions that I have to you guys as owners of SB130 has already been asked before. But I would really appreciate your opinion and input for my next custom built of SB130.
    So I知 firm on building this bike with a 150mm Fox 36 fork.
    What route would you recommend me to go with and an additional comment why, would be very helpful.
    (1) Fox 36 Fit4 150mm with Vorsprung Luftkappe air piston
    (2) Fox 36 Grip2 150mm
    (3) Fox 36 Grip2 150mm with Vorsprung Luftkappe air piston
    And the options for rear suspension:
    (1) Stock Fox DPX2 210x52.5
    (2) Fox X2 210x52.5
    (3) Fox X2 210x55 (Lunch Ride 136.2mm Travel)
    As an additional note. I値l be selling my SB100 frame and will satay with one bike only which will be the SB130. Potentially in the near future I値l add a Transition Vanquish 29er Hardtail with 120mm Fox 34 SC fork as a fun bike.
    I値l be riding this bike on all possible trails around the Bay Area from long XC days on the saddle with 40 miles and 5,000 - 6,000 ft of elevation gain to riding all day on descends (approx 25-30 miles) with self climbing back to the top. And I might be able to escape once a year to ride something like Downieville.
    Please vote and add a comment if possible.
    Cheers!
  107. #2107
    Sep 2017
    Quote Originally Posted by iErnest85 View Post
    (2) Fox X2 210x52.5
    Cheers!
    Doesn稚 the Grip2 only come in 160mm and up?
  108. #2108
    Oct 2017
    Quote Originally Posted by lagerboy View Post
    Stock Fox 36 does.
    But there are 2 ways to bypass it.
    The more expensive way is to get a Fox 36 Fit4 with 150mm travel and then upgrade the Charger Damper to Grip2 which is like $350 + LBS Labor.
    The cheaper way is to get a Fox 36 Grip2 with 160mm and replace the Air Shaft to 150mm which is about $45 + LBS Labor.
  109. #2109
    Mar 2019
    Grip2 + Luftkape + X2 (55mm)
    They are the best options!
  110. #2110
    Reputation: Dagonger's Avatar
    Dec 2011
    I'm in the Bay Area...
    Grip 2 plus luftkappe or Fit4 with vorsprung tractive tuning plus luftkappe.
    Your riding weight may help determine which shock dpx2 or X2. Stroke increase 6mm is negligible.
    I recommend Michael at Fullflow Suspension in Auburn to help get you sorted.
    Curious what LBS are you using?
    Sent from my GM1915 using Tapatalk
    Instagram/Youtube- Dagonger
    Yeti Cycles sb45c/sb150
  111. #2111
    Oct 2017
    Quote Originally Posted by Dagonger View Post
    Have not heard of Vorsprung *Fractive, but already looked it up. Looks very interesting.
    I'm about 185 lbs with all of my riding gear.
    Been using Rhytm Bikes in Oakland for a few years now. By far the best shop compared to over 20 other shops I've been before.
  112. #2112
    Dec 2011
    Chad is a great guy and shop owner.
    Your weight is on the border of the dpx2. I would recommend riding it first. If you aren't happy with it for certain reasons due to your weight impacting it's tuning parameters, then a X2 or ohlins ttx air might be better options.
  113. #2113
    Jun 2015
    I am not following this statement are you saying at 185 hes to heavy for the dpx2?
    Evil Insurgent Yeti SB5.5 Evil Wreckoning Pivot Switchblade Pivot Mach 5.5 Yeti SB150
  114. #2114
    Jan 2016
    Does the X2 come in the same size (210 x 52.5)? I didn稚 think so...
  115. #2115
    Dec 2011
    Quote Originally Posted by Snowsed341 View Post
    Heavier riders can bottom out shocks like a dpx2. To remedy that most put in bigger spacers to add progression and more air psi. This remedy's the bottom out and blow thru on travel, but negatively affects begining stroke aka small bump. Often rebound damping isn't enough to keep it from being to fast at increase progression and psi...
    X2 and ttx air or coil can help overcome those factors for some riders in some cases....
  116. #2116
    Vorsprung Fractive Tuning system for Fit4 forks provides BETTER damping than the Grip2 dampers at a fraction of the price ($120 CAN vs. $300+ for Grip2 damper). That one is a no-brainer if you buy a complete bike with the Fit4 damper fork.
    The Luftkape is a bandaid fix that jacks up the negative air volume, sucks down the fork travel and still doesn't provide enough mid-stroke support for really aggro riders. Enter the RUNT from Diaz Suspension to fix the 36's air spring problem. A more expensive but more effective fix.
    The only thing I'll agree with in your post is the 55mm stroke X2 BUT an Avy tuned DPX2 with Craig's SSD mod and HSB adjuster will give more than adequate performance for 99% of riders at a fraction of that cost (and Craig will take out the silly spacer to make it 55mm stroke anyway so... for $289 the best option IMHO).
    Have FUN!
    G MAN
  117. #2117
    Mar 2019
    Quote Originally Posted by Gman086 View Post
    Vorsprung Fractive Tuning system for Fit 4 forks provides BETTER damping than the Grip2 dampers at a fraction of the price ($120 CAN vs. $300+ for Grip2 damper). That one is a no-brainer if you buy the complete bike with the Fit4 damper.
    The only thing I'll agree with in your post is the 55mm stroke X2.
    Have FUN!
    G MAN
    That wasn稚 part of the options listed above, so what痴 the point of having a list if you pick stuff outside of it. Otherwise there痴 even better options ... yep, agreed!
  118. #2118
    Nov 2007
    Hi All,
    I am doubting between the Yeti SB130 and Occam as my new ride to replace my current Orbea Rallon.
    The only real downside for the yeti is the PF BB, or should I not worry about this?
    Then Two questions for which I was looking for an answer in this thread:
    - I am 1.70 and was aiming to pick a medium (seattube on S would be very short) and putting a 35 mm stem on it. Still the reach increases ~2.5 cm compared to my current bike. Does the length gets countered by the much steeper seattube, what are the general experiences with the progressive geometry?
    - second question, I want to put a RS Lyrik or Pike on the frame. But see this guy is offered in 37 ,44 or 46 mm offset where Yeti recommens 44. Would it be pushing the boundaries too much when putting a 37 offset fork?
  119. #2119
    Oct 2007
    Quote Originally Posted by K2-man View Post
    Hi All,
    The one time I had an issue with a PF bottom bracket was due to an improper installation. I only have a few hundred miles now on my 130 but haven't had any problems with the BB.
    1. For sizing, it seems like you'd be on a small, especially if you have longer legs for your height. For proper fit, you'd end up moving the saddle back to compensate for the steeper STA. Not everyone follows that, but I like it when my knees are pain free. The extra reach out of the saddle is to help with being more forward on the bike instead of hanging off the back of it. It does require a little more weight on the bars around turns to keep good front wheel traction. I've had some close calls a couple of times when I got lazy. Lowering the stack helped too.
    2. You'd probably want to stick to as close to the 44mm offset as possible for the fork. It's a good blend of low speed turning for the switchbacks and not twitchy at high speeds. 37mm might feel too sluggish.
  120. #2120
    Nov 2007
    Thanks for your reply, I feel that if I go with the small I would not make optimal use of the new Geo by sliding the saddle to the back. But I guess I should really try to find a test bike before making the decision :-)
  121. #2121
    Aug 2016
    Hi All,
    First, I never ride Orbea Rallon/Occam thus no comment on that.
    No problem with PF BB. Where I come from - humid, wet and muddy no issue on the BB. I transferred the CK from my previous SB4.5C to the SB130 and I think >1k miles on the previous bike.
    1. I am 1.69 and riding size S with 35mm stem. Saddle bang in the middle. Feel centered on the bike.
    2. Ran 42 offset Lyrik few weeks and I didnt feel much of a different. Yeah i think u need to stay close to 44 offset recommended by Yeti.
    Happy trails!
  122. #2122
    for rockshoxs forks get a 42mm offset! they only come in 42mm or 51mm offset for 29 wheels
  123. #2123
    Mar 2019
    FYI
    Hot tip for @ridefoxbike grip2 owners-don稚 run your high-speed compression more than about 18 clicks out from the closed/hard stop position, your compression shims will be floating off the piston completely!
    Source: https://www.instagram.com/p/Bzb8xyFHXxc/?hl=en
  124. #2124
    Jul 2014
    Hi.
    The frame arrives soon.
    Ligth headset 41/52?
    I read:
    -Chris King 150 gr
    -Cane Creek 100 gr
    -Hope ソ?ソ?ソ
  125. #2125
    Mar 2019
    Good call, that痴 where you値l save the most weight.
  126. #2126
    Jul 2014
    Why install a 150 gr headset if it works the same as a 100 gr headset?
    50 + 50 + 50 + 50 + 50 +.......
  127. #2127
    Mar 2019
    Absolutely
  128. #2128
    Oct 2017
    Hi.
    I read:
    -Chris King 150 gr
    -Cane Creek 100 gr
    -Hope ソ?ソ?ソ
    Lightest Headset I've found was Cane Creek AER Series II.
    https://www.canecreek.com/product/aer-series-ii/
    I've installed it on my 24 lbs Yeti SB100 and this week same one going to be installed on 2020 SB130 frame that has just arrived yesterday.
    Here's the part # that will fit SB130:
    Top w/ Short Cover: IS41/28.6/H9 - Black - BAA0957K
    Top w/ Tall Cover: IS41/28.6/H15 - Black - BAA0956K
    Bottom: IS52/40 - BAA1044
    Actual Scaled Weight for Top w/ Short Cover + Bottom: 67g
    AER Spacers also will be lighter even then the carbon ones.
    Cheers!
  129. #2129
    Oct 2017
    I've just opened up today my 2020 SB130 Frame in Anthracite (Grey) color / Size Large.
    Actual weight of the frame with stock DPX2 shock, rear axle, and seat clamp is 3280g (7.231 lbs)
    Not a superlight frame.
    My SB100 in Black (Raw) / Size Large is 2,682g.
    My 2017 SB6c Green / Size Large was 3,165g.
    It was obvious that the SB130 will be heavier than SB100, but I did not expect it to be even heavier than the SB6c.
  130. #2130
    Jul 2014
    The weights I wrote yesterday are incorrect
    Real weights headset:
    Chris King = 108 gr
    CC Forty = 104 gr
    CC Hellbender = 91,20 gr
    CC 110 = 87,30 gr
    CC Aer = 67 gr
    Regards
  131. #2131
    Jul 2014
    Chris King - Cane Creek AER = 43 gr.......
  132. #2132
    Jul 2014
    Cheers!
    Thank you, I bought CC AER
  133. #2133
    Hisforever
    Dec 2004
    Can you guys running x2's post your weight and settings, just bought a used one off a ripmo! aggro 165lb rider dude asking.
    thanks!
    PipedreamMoxie
    M 5.5
    Yeti
    Evil
    Yz 250x braap
  134. #2134
    Mar 2019
    thanks!
    You should also ask for the 4 digit code, because the compression/rebound stack might be different. So the same settings might not give the same results
    Ex: DL2Q >> https://www.ridefox.com/fox17/help.p...ref=findbycode
    2018 Factory Series FLOAT X2
    2018, FLOAT X2, F-S, K, 2pos-Adj, Ibis, Ripmo, 210, 55, 0.3 Spacer x2, CM, Neutral, STD Logo
  135. #2135
    Jul 2017
    Looking at perhaps picking up an SB130 T1 eventually. Does anyone know if the Fox 36 Fit4 damper is the newly updated 2020 Fit4 with the 8mm damper shaft? Or the previous generation still?
    I no longer like to party. But I like the idea of it.
  136. #2136
    Aug 2019
    I had a fall and skipped paint on the fram. Do you know pantone code or where to get paint to repair?
    Enviado desde mi SM-G950F mediante Tapatalk
  137. #2137
    yeti has touch up paint on their website
  138. #2138
    Oct 2017
    Quote Originally Posted by kirkom View Post
    You can purchase Touch Up Paint directly from Yeti's website:
    https://www.yeticycles.com/gear/parts?filters=13&page=1
    Good Luck!
  139. #2139
    Oct 2017
    Quote Originally Posted by almazing View Post
    Not 100% sure if it's the 2019 or the 2020 fork...
    But if you have a good relationship with your LBS and they're reasonable, you can build a custom bike with all of the parts that you want and it'll be cheaper for you than getting a complete kit from Yeti.
    My LBS starting to build my 2020 SB130 with Fox 36 Grip2 with 150mm Air Shaft instead of the stock 160mm. And they're charging me 15% less than the stock 2020 Fox 36 Fit4.
  140. #2140
    Aug 2019
    Good Luck!
    I had already seen it, but, with shipping to Spain it costs 45$ !!!
    Other option?
  141. #2141
    Jul 2017
    Eh, I just buy build kits to make things easier. And I can sell my old bike complete, which is easier than selling just a frame most of the time. The closest Yeti dealer to me is 3 hours away. So I just order online. Even though they 'build and tune' the bikes, I still do a once over to make sure everything is torqued to spec and brakes are bled properly. Often times, I have to completely re-tune the derailleurs and retorque bolts because it's too tight or too loose. I just wish they'd assemble and send it out to me. I can do the job of their 'bike builders' at home properly.
    The T1 Turq has everything I want, really. Shimano 12S XT. I really, really wanna try out the Shimano 12S. Only changes I'm going to make are the saddle, 203 rotors front and rear, and carbon wheels and tougher tires, which I already have.. The Fit4 is a pretty good fork. But if it comes with the newly updated one, it'd be nice to see if I can tell any difference.
  142. #2142
    Jan 2018
    Looking to replace my QR rear axle with non-QR
    Having a little trouble figuring out what I need. The axle that's in it is 172mm. Can't find that length in non-QR
    What I think will work:
    12 x 148 E-thru 170mm
    Am I right?
    Looking at the Maxle Stealth from SRAM or similar.
    Sent from my Pixel 3a XL using Tapatalk
  143. #2143
    yeti sell axles, I知 surprised yours is a qr you need a 12mm x 172 mm x 1.5 thread
    robert axle makes one, ibis shimano axle is another option but the yeti one costs only $20 that痴 what I壇 buy
  144. #2144
    Oct 2017
    Am I right?
    The one you're looking for called Shimano E-Thru 148x12mm
    There's a very light one made by Carbon-Ti Brand. It's only 32g.
    Rear Axles Bike E-Thru
    That's what I currently have on my SB100 and I just moved it from my SB100 to my new SB130 frame.
    I purchased mine from Fair Wheel Bikes website:
    https://fairwheelbikes.com/carbon-ti...ear-thru-axle/
    Cheers!
  145. #2145
    Oct 2017
    SB130 T1 was the one I had as a demo from my LBS. Had a chance get on 2 rides on it with a total of 38 miles and 5,000 elev.
    In general I'm not a huge fan of Shimano products, but not a hater either. And the T1 kit comes with XT 4 piston brakes and XT 1-12 Drivetrain. But still, I really enjoyed the bike and Shimano stuff did not bother. On my last 3 bikes I've installed SRAM Eagle drivetrain and I find it a bit smoother on the shifting and a bit more precise compared to Shimano 1x12. But there's one significant advantage on Shimano 1x12 drivetrain that I've noticed, is that you can still shift pretty easy under heavy load of pedaling and that's not something that Eagle can do.
    Large frame that I demoed came at 30 lbs before pedals, but the bike climbed maybe 10% slower than my 24 lbs SB100 and descending on it was just an enormous FUN compared to my SB100. So, SO SO MUCH Confidence Inspiring !!!
    Fox 36 Fit4 that came on the 2020 SB130 Demo was phenomenal with zero complains, but my LBS recomened me to go with Grip2 for the same price.
    The biggest thing I loved about this bike is how comfortable and not exhausting at all it was on long fire road climbs and 10+ min descends.
    I'm going to throw 34mm internal NEXTIE Carbon wheels with i9 Hydra hubs on mine as well. 180mm Front and Rear SRAM Centerline X rotors should be plenty for me, since I'm about 185lbs with all of my gear and I'll be installing SRAM Code RSC brakes on mine. Will be rolling on Maxxis Dissectors 29x2.4 Front and Rear as well. Ones I tried these tires I could confedntly say "Bye, Bye DHR II". Dissector rolls faster than DHR II, Grip, Break and Corner better than DHR II.
    I strongly beleive that the Assegai will replace the DHF on all Enduro bikes and some trail bikes. When the Dissector will replace the DHR II and Aggressor on Trail and Enduro bikes.
    Also I recall that JensonUSA and Fanatik Bikes fully assemble the bikes and they ship it with just the front wheel not attached. But you should double check that.
    Ether way T1 is an awesome kit and SB130 phenomenal bike !!! So you can't go wrong.
    Cheers
  146. #2146
    Hisforever
    Dec 2004
    This is exactly the code on the shock I have DL2Q. IS that bad or good?
    PipedreamMoxie
    M 5.5
    Yeti
    Evil
    Yz 250x braap
  147. #2147
    Mar 2019
    It痴 good
  148. #2148
    Mar 2019
    3rd day in Finale Ligure with the SB130, the bike is coping great no matter the track. For those who know, you could come with your DH bike and be happy ... very fast, loose, super rocky, jumps, compressions! Even ォDH menサ feels great ... You gotta love this "trail" bike hahaha
  149. #2149
    Jul 2017
    Cheers
    Thanks for the insight! I much prefer Shimano over SRAM. I do have the XO1 Race kit on my SB100 I don't have any real complains. I just dislike that the feel of the upshift lever gets lighter and lighter as you go down the cassette, while Shimano feels the same all the time. As far as brakes, I'll always have 4 pistons from now on. I put Guide Ultimates on my SB100 and put 180/180 rotors and that's been perfect for it. I'm excited to try out the new generation XT brakes, but if it's not up to snuff, I'll replace the calipers with Saints, which is something people have been doing for a long time. $200+ for 2 Saint calipers and banjo bolts is a lot cheaper than Code RSCs front and rear. I've got a set of Crank Bros Synthesis E11s with Hydra hubs going on the SB130. Tires will be WTB Verdict front, and WTB Judge rear. Not the lightest of tires, but I know they grip amazingly and are nearly indestructible.
    Riding my SB100 always puts a smile on my face. It just 'feels' like a special bike. I'm really hoping that the SB130 feels the same. And I feel that the T1 Turq build represents the best value for Yeti builds, as they don't skimp on parts spec. You get a full XT groupset and brakes. I mean, Yetis aren't exactly teeming with value, but Turq builds are better this year. What I dislike about this year's builds are the lower spec wheelsets and the move to 170mm cranks. The XM1501s are phenomenal wheels. I have a set of E1700s and M1700s myself, and they are great wheels. But XM1501s are lighter and stronger. I prefer longer cranks due to the extra leverage they provide. Not that big of a deal. But the BBs are so low that I see why Yeti chose to go with shorter cranks.
    Can't wait to get my bike. I'm hoping to get it by Friday at the earliest.
  150. #2150
    Quick ride report and question/advice needed....apologies for a long post.
    I rode Captain Ahab in Moab for the first time on the SB130 today. I致e ridden this trail 25 plus times over the years on a Yeti 95c, Yeti SB5, Gen 3 Nomad, and most recently a SB 5.5. Was really excited to see how the 130 stacked up.
    First off...I just swapped my stock 50mm stem that came on a 2020 T1 build for a 40mm stem and I really prefer the shorter stem. This was the standard length on the original builds and I feel that Yeti truly designed the bike around this stem length.
    Climbing...the 130 climbs better than any other bike I致e owned and motored right up the ledges and chunk of Ahab. Low bb takes some timing, but I知 adjusting. I知 not willing to go to 170mm cranks....I致e tried and they hurt my knees and I prefer the leverage with 175mm.
    Descending...the bike did great, but not the best I致e ridden on this trail. I have to disagree that this bike does everything better than the Yeti 5.5. My 5.5 had a little bit more smash and go personality on the ledges, drops, and steep slabs of Ahab. The 130 did fine, but I had to be a little more selective in picking lines and it wasn稚 quite the autopilot feeling my 5.5 had. It wasn稚 huge, but maybe a roughly 10% decrease in downhill confidence. What really surprised me was the feeling in steep slabs and successive steep ledge drops...the 130 is pretty damn slack, but I still felt just a bit too far over the front. I know the new forward-centric geo helps to weight the front-end better, but there is a time and place where that can feel a little sketch. This front-planted geo and steep seat tube also makes this bike a little harder to pop the front end up. Manuels off ledges take more work and timing...Anyone else having more difficulty popping wheelies on large wheelbase and steep seat tubed bikes?
    My 5.5 had offset bushings, 160 mm fork and X2 in the rear. My 130 is the stock 150mm fork and dpx2 130mm.
    So, my question. Can I get the 130 to have that same unflappable feeling on fast chunky trails like Ahab? I知 tossing around a few scenarios:
    1) Maybe I need to spend more time tuning the front end to provide more support and keep me higher in travel....countering that too far forward feeling on steeps.
    2) Maybe I need to 斗unch ride the bike and go to 160mm front to really compare to my old 5.5 and unlock a more aggressive downhill demeanor. Maybe run a coil shock.
    3) Maybe it痴 just a 130mm trail bike through and through. You can only change the character of a bike like this so much. If I really want that total smasher feel, I should look to a bigger bike.
    Thoughts or advise would be awesome. All in all...combining up and down, the bike is killer. Just missing a little of that extra confidence on the steeper tracks.
  151. #2151
    Aug 2015
    I have a 160 front with push coils and cushcore. That wouldve been perfect for the trail that youre riding
    Sent from my SM-G973U using Tapatalk
  152. #2152
    Mar 2019
    Bumping the fork to 160 and swapping the shock for a more capable one will definitely help you bring the 5.5 feel/confidence back.
    You can also play with spacers under the stem.
  153. #2153
    Hisforever
    Dec 2004
    mullet setup rips pretty good, it put some party back into the bike as the ride felt a little bland honestly, think the HA is around 64.5? about to try x2.
    tires make a big difference
    fun little ride
    PipedreamMoxie
    M 5.5
    Yeti
    Evil
    Yz 250x braap
  1. Replies: 2056
    Last Post: 2 Days Ago, 07:01 PM
  2. SB130 vs SB150, opinions wanted!
    By propulsionclimbing in forum Yeti
    Last Post: 09-02-2019, 07:48 PM
  3. SB130 is Live (again)
    By softbatch in forum Yeti
    Last Post: 09-10-2018, 12:19 AM
  4. A Discussion of Tire Width, Weight, and Performance
    By The Boz in forum Wheels and Tires
    Last Post: 01-04-2012, 02:13 PM
Members who have read this thread: 947
