Yeti SB115- Mtbr.com
Results 1 to 108 of 108
Thread: Yeti SB115
    Jun 2018
    Yeti SB115
    May 2012
    Yew! Just lobbed in my Inbox. Looks nice.
    Scandinavian
    Looks nice, and with the capabilities of my SB100 this must be very good.
    Is it a completely new frame or is the front the same as SB100?
    Sent fra min SM-G973F via Tapatalk
    May 2012
    Hard to know. It hasn't appeared on PinkBike or MTBR.com as yet so they may know more details. I only saw it when it first lobbed because I am in Australia and it's the afternoon of June 30 here already. Be interesting to find out about the background of it/why Yeti went this way and what differences there are.
    Jun 2018
    May 2012
    Sweet!
    Reputation: Dagonger's Avatar
    Dec 2011
    Same frame as Sb100..
    Sent from my GM1915 using Tapatalk
    Instagram/Youtube- Dagonger
    Yeti Cycles sb45c/sb150
    ejj
    ejj is offline
    YepóI may have read incorrectly, but this is the same frame with a new rocker link and shock.
    So this is essentially the SB100 LR, with more travel eked out of same frame, bigger fork, and bigger brakes.
    Jun 2015
    Sounds like they tweaked the si link, not sure what or how, but more importantly are any of these changes adaptable to the sb100.
    17j
    17j is offline
    I'd like to know why it specifically says 130 fork but in geo says 120mm of travel. Also, wonder if SI is improved as that was a problem for certain. Don't generally love when a company just adds travel to a frame as seat tube is too slack etc but looks nice
    Jun 2015
    Quote Originally Posted by 17j View Post
    As with most bikes you can run different lengths of fork travel. According the FAQ, This sb115 is designed for 120/130mm of travel.
    17j
    17j is offline
    The spec on the 130 version says fork travel: 120.4 - That was what my post refers to...interesting. Naturally a 120 will work too and may actually be ideal for this bike to make more XC and steeper seat tube
    Reputation: jboyd122's Avatar
    Quote Originally Posted by junior77 View Post
    My thoughts exactly. Iíve gone through the 3 stages of the SI ďfixesĒ on my SB100. While the most recent nylock bolts have not come lose the revisions for the SB115 certainly look a lot more stout. It would be cool to see a retrofit for the SB100.
    Worldwide has a nice closeup of the SB100 and SB115 SI units side by side in their initial review of the SB115.
    I wonder how a 140 fork would work with this frame? Would it be similar to how a 130 performs on the SB 100? I think this bike hits a big market of people who wanted a "do it all". Filling a big void where the 4.5 was prior, in my opinion. The 4.5 may not have been the best XC bike but it got the job done..
    Jul 2013
    The SI unit appears to be updated. If you go to the manual instructions, the SI stanchions are now threaded on the inside and have new mounting hardware and new torque instructiions.
    This is a huge improvement imo, as someone who has the old linkage and I think this should finally fix the issue with this configuration of the SI link.
    Feb 2016
    The build kit options in terms of groupsets are pretty interesting too. I know most will probably get at least a Turq T1 or above build, but the C1 build is equipped with Shimano SLX. On the SB100, the C1 build comes with SRAM GX, which is now the C2 SB115 build.
    On that note, can we talk about pricing? As per the Yeti site currently (as of 9:30am pacific time), the SB100 starts at $5,099 USD for a C1 build. The SB115 starts at $4,700 for a C1 build (with SLX). If you want the "equivalent" SB115 C2 GX build to the SB100, even then it's $4,900. So for essentially the same frame, updated linkage, longer travel fork, longer shock, and the updated GX group, the new SB115 comes out $200 less than the "older" SB100.
    The pricing gets a bit more blurred as you progress up the Turq builds though.
    Dec 2016
    Anybody notice that the yeti website shows ride footage of the sb115 with a pike fork and what appears to be a RS superdeluxe? Are we thinking rear travel can be stretched to 120? Given that the 2021 dpx2 is available aftermarket in 190x45, could present some interesting build options.
    Reputation: mfa81's Avatar
    Quote Originally Posted by fryeguy View Post
    maybe, but the rider is a sram/rockshox ambassador so they can easily have access to modified shocks.
    ejj
    ejj is offline
    Quote Originally Posted by localn8ve View Post
    I typically like their build options. I think the SLX build should be popularóa decent value for a good bike from a decent builder. If you compare the two C builds to offerings from Pivot, SC, Ibis, etc they are right in the mix.
    Weíll see if they offer the 100 in the futureóor if the 130 adopts similar build kits.
    Sep 2014
    Quote Originally Posted by Udyr View Post
    I thought this was fixed the last time? Is the Tribe finally admitting there was a problem with the SB100 SI? When I complained about mine, both versions, I got crucified for being a hater and not knowing what I was doing. I sincerely hope they got rid of the issue, it was a great bike other than that. But WITH that, I couldn't wait to get rid of it.
    Ibis Ripmo V2
    Ibis Ripley V4
    Pivot Mach 4SL
    Pivot LES SS
    A road bike
    Reputation: skinnybex's Avatar
    Aug 2015
    Quote Originally Posted by BmanInTheD View Post
    IMHO the last revision Yeti implemented which was the nylock bolts was only a band-aide for what was a reocuuring problem for some owners in regards to loosening and having movement and play in the rear triangle. This new update seems to be the proper fix to what would have been appropriate last year.
    I love the bike so much because of the firm and lively feel of the suspension and how snappy and quick handling the bike is. With that said I'd like the update free of charge for my SB100 to make it bombproof and I feel thats what all owners of the SB100 deserve.
    Yeti 2020 SB165
    Yeti 2019 SB150
    Yeti 2019 SB130 AXS
    Yeti 2018 SB100 AXS
    Which wheels are being offered for the carbon wheels? I can't find that info on the Yeti web page.
    It looks ridable, follow me....................
    Dec 2016
    Quote Originally Posted by skinnybex View Post
    Agree
    As an SB100 owner, canít help but feel kicked in the crouch by Yeti. SB115 seems like more of a Maintenance release that features a proper fix for the SI system, new link and longer shock. yeti marketing materials than play up how stiff the 115 is, ya think? Iím skeptical SB100 owners will ever have access to the new link/SI kit, itís about selling new bikes not properly fixing old ones.
    Mar 2019
    In theory you could get 130mm of travel, by swapping the 190x45 for a 190x51
    Went to the local Yeti emporium yesterday and they had a medium T2 on the floor. Looks really nice and felt good in the parking lot.
    They had 18 already on order when I got there and 19 when I left.
    Reputation: Gobstopper's Avatar
    Yeti posted on Instagram that there really isn't a simple upgrade / conversion for the 100 due to the SI assembly, hardware, etc. Be interested to see if that's truly the case or if a link/shock would do the trick.
    When I asked Yeti about retrofitting the SB115 SI onto the SB100 they said that the bolt interface on the front triangle for the SB115 is different. They will be coming out with a kit in a couple months for the SB100 that includes bolts to fit the front triangle.
    Dec 2011
    Official word from Yeti regarding updating Sb100 to SB115..
    Itís a bit more involved than just a link, really you need a new switch assembly, new master rebuild kit hardware, the shock (overall can size is different along with stroke) and fork.
    At this time we havenít planned a to make a retro kit available, we have seen the demand and may take the Tribes suggestion for the future. Right now though we are working to keep up with demand and do not have excess parts available to sell.
    Reputation: jon123's Avatar
    Quote Originally Posted by Dagonger View Post
    I'm not convinced the new switch assembly is necessary. No doubt it's improved, though mine has been without any problems. But necessary I doubt.
    I bet it's simply the new link and associated hardware, plus shock and fork of course.
    Aug 2015
    The last revision to the SI assembly which was the Nylock bolts is a fail. I checked mine today before my ride and 1 really loose and the other slightly loose on the drive side.
    Yeti 2020 SB165
    Yeti 2019 SB150
    Yeti 2019 SB130 AXS
    Yeti 2018 SB100 AXS
    Jun 2020
    I gotta say, I was dead set on an SB100, then considered the 115 as I started to hear those rumors. But the SI issues have definitely planted some doubt in my mind, seems farily wide spread.
    Strongly considering either the Transition Spur or Revel Ranger. I probably won't buy until end of summer or fall, and continue to slog up my 30+ mile rides on my Aluminum Troy until then.
    Nov 2019
    The Blue Loctite isn't strong enough and the Red is perfect until you want to upgrade to the new Gen 3 switch infinity hardware.
    Jun 2016
    Quote Originally Posted by sethde View Post
    Looks very interesting and good for my trials. And don't need to take out a second mortgage for the SLX or GX option.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Agree
    The SI link is a more complicated way to do what dual links can do, none of this should be a surprise. There are significant engineering difficulties and yes, often with enough time and $$$ most can be designed around, but you are starting at a big disadvantage from an engineering perspective when you choose to do this. There is no advantage to doing it this way.
    Feb 2006
    Here are some thoughts on the SB115 after spending a few hours on it during the last three days.
    I've built up a turq frame with SRAM XO and We Are One wheels on King hubs. The frame looks the same as the 100, but the difference in stiffness is immediately noticeable (I was one of the owners of a 100 that experienced many problems with the Switch link). Though the 115 may look like the 100, the differences are really significant. I'm fortunate to work at a shop and have been able to ride every model from Yeti. The marketing copy that says the 115 feels like a 130 is no exaggerationóit's stiff and efficient climbing, and it descends more capably than you think it should. The suspension is more responsive than that of the 100, and it definitely feels like a 130. I live on Vancouver Island and have been able to do some longer climbs as well as some tough descending. On the climbs it was fast and efficient, and descending it really was capable on some challenging trails. It was quiet, creak-free, with that solid, planted feel. I was a reluctant but hopeful buyer, and am really pleased and impressed thus far. I'm keeping my fingers crossed that the dreaded rear end problems don't resurface...
    Reputation: chase2wheels's Avatar
    Oct 2003
    How youíd pickup the frame so quick? Competitive Cyclist wonít have the frame only option for another few weeks. I plan on picking one up when theyíre available.
    Great to hear your ride impressions. Thanks for sharing.
    Bikes are my time machines.
    Feb 2006
    I ordered as soon as the information was released to Yeti dealers (I think Yeti shipped it June 25).
    17j
    17j is offline
    I see the crank size was size specific for sb 100 but looks like all 115 come with 170cranks
    Jun 2018
    Quote Originally Posted by tyberius_77 View Post
    Not going to lie...that's exactly what I want to hear as I patiently wait for my 115. If this thing punches closer to the 130 than the 100 I will be a happy...happy man! Might have a 130 for sale and look at even slightly bigger bike to takes it's spot.
    Oct 2016
    Ugh. Not sure what to do about sizing for this bike. I am 6'1" with a 34" inseam and normally feel most comfortable on bikes that have somewhere in the 470-480 reach range. I am currently on a Large SB150 that fits really well at that 480 mark. The Large on this one is way down to 450 and the numbers overall seem very small for me. The XL is very close in most respects, reach, bike length etc. But Yeti is saying that is for huge people up to 6'7" but gets me on the low side of that frame size.
    I had a 4.5C years back and I found the Large there felt small and always wished I had gone XL on that one. Perhaps that is my answer?
    Feb 2016
    Since the SB115 is pretty similar to the SB100, I'd start by going through the SB100 thread on here for sizing advice.
    For what it's worth, I'm 5'6" and in between sizes on the Yeti size chart (Small and Medium). After demoing them both, I ended up with the medium and very satisfied with that decision. I haven't tried out a SB150, but the SB130 in small fits me well.
    I am Walt
    Reputation: waltaz's Avatar
    Quote Originally Posted by brennenhuff View Post
    I'm 5'10" on a Large SB100, and it fits me perfectly. I would go XL, for sure.
    Ride more; post less...
    Dec 2011
    I'm 6'4 with 34 inseam so I easily do XL. My input would be go to a XL since your large felt small. I also own a Sb45c. The sb115 comes fitted with a 50mm stem so you have some options to shorten if you need to. I think you will find the longer bike more stable on the downs...
    Dec 2011
    Check out Yeti Instagram
    Iíd go XL. Iím 6í5Ē and have had a 130 and 150 in XL. I picked up a 100 this year and the XL is tiny, wish there would have been a bigger size or updated reach. Iím had to size up to a 80mm stem to get remotely comfortable. Iíd imagine if you went large, youíd have similar concerns. Itís good with the longer stem but with the stock 50, I was all out of sorts.
    Jun 2015
    Quote Originally Posted by Gobstopper View Post
    Well at 6í5Ē itís a no brained....probably would like a XXL if they made one.
    At 6í is where the debate between L and XL comes into play. Stem lengths are typically required to lengthen or shorten the reach.
    Reputation: smartyiak's Avatar
    What this guy says. The geometry is small for almost anyone over 6'2" (compared to the "new" geo of GG, Transition, Mondraker, etc.); Yeti SB115 needs an XXL.
    Dec 2016
    Same size as you, very comfortable on XL SB 100
    Dec 2016
    Brian,
    Is Graves rocking a new line of yeti branded saddles? Says itís a SM Pro, so I donít think itís new old stock. Understand if you canít say.
    Dec 2011
    Brian,
    One of his picture shows old stock model "turq" highlights....I think World Wide Cyclery may have some still.. The all black is based on a new current Ergon saddle but haven't seen it for sale tbh.....I'll hit up my Ergon contact about it...
    Jun 2020
    I'm in the market for a new bike, and have narrowed it down to the Ranger, Spur and 115. I would run the SID 120 fork on the Ranger or Spur, would that be a good fit for the 115 as well, or would it make the head angle too steep?
    I think any of these bikes will probably suit my needs, I am looking for a light bike that is still fun, I live in the CO front range and mostly ride longer, intermediate trails, every once in a while I will ride something steep and chunky, but it's not really my jam. I like to go fast up and down, and at least one of my rides each week I am trying to set a PR. Going to enter a couple of races next year, including the Leadville 100. I want to perform well in these races but not at the cost of having fun going down and riding the occasional rowdy trail.
    The only MTB I have owned is my Devinci Troy, which is 150 both front and back and weights around 34 pounds, I'm sure the Ranger, Spur or 115 will be a lot easier going up! Possible I would keep the Troy and have a 2 bike set up but would prefer to sell it.
    Aug 2018
    I'm considering similar bikes right now but it's hard to get demo's and Transition told me the Spur is sold out until October. If you want to run the SID 120, why not look at the SB100? Assuming the linkage updates are available if you experience anything coming loose, it sounds like a good fit for the type of riding you're describing.
    Jun 2020
    Quote Originally Posted by yagr68 View Post
    I was dead set on the SB100 until all these new bikes started coming out. Two things have changed my mind:
    1) As I have been following the posts on this site, it seems like I see a lot of people with linkage issues. And some of these people say they have tried to address them several times only to see them come loose again. I don't want to have to deal with that or worry about it.
    2) This isn't based on anything factual, but I am anticipating the Ranger, Spur, and possibly even the 115 will be just as fast going up, while being a little more capable going down.
    Having said that I am still open to the 100.
    I am Walt
    Quote Originally Posted by APDuncan27 View Post
    FWIW, Strava says I have 2,372 miles on my SB100 in the last year, and I haven't had any issues. Have serviced the SI link twice...no issues. To me, it's the perfect bike for endurance XC, with good trail capability. I just ordered an SB130 LR as my "big bike", so don't need the 100 to cover that end of the spectrum.
    Jun 2020
    Quote Originally Posted by waltaz View Post
    That's good to hear, and I am guessing those with the issues are a small minority, but it still has my attention. That's a lot of miles on your SB100, nice!
    I am Walt
    That bike just eats up the miles...
    Reputation: stonedead's Avatar
    I own a sb4.5 and have long thought about upgrading it. Any opinions on how the sb115 compares? On paper they seem pretty similar.
    Dec 2011
    Quote Originally Posted by stonedead View Post
    Think modern sb45c update.
    Check out Geoff Kabush IG TV. Graves refers to the Sb45c vs sb115
    17j
    17j is offline
    5-9 what size?
    Oct 2003
    5-9 what size?
    Iím 5í8Ē and am on a medium. Perfect fit.
    Dec 2014
    Pretty much the same bike as the 4.5. If you're cool with loosing 10mm up front but gaining a sleeker SI and better internal cable routing (hate those damn 4.5 grommets), then I say upgrade.
    ** BB would be to high and seat tube to slack with a 140mm fork on SB115
    Nov 2019
    Hello all,
    Iím in the market for a new bike that can handle about any trail in San Francisco/Bay Area.
    The type of rider I am- I love climbing as long as thereís an amazing descend, so I need a bike that can handle going downhill. Iím not into jumping or hitting drops unless they are in my way. Yet, this will be my only bike so preferably I want a bike thatís dependable and can do it all.
    With this said, please let me know if the SB115 can possibly be a bike for me.
    My previous bike was a Stumpjumper with a 150mm fork and 140mm of rear travel.
    The SB115 does not disappoint!
    The SB115 does not disappoint! I am coming off of an SB150 in size XL- I loved the SB150 but I am not in a position to afford two Yetiís-ha! I sold the SB150 (a very, very tough thing to do) and ordered a SB115 frame in size XL. This was my first frame-up build and I went with a Pike Ultimate 140mm travel fork, Roval Traverse Carbon wheels, the latest generation of SRAM GX Eagle drivetrain, SRAM G2 RCS brakes w/180mm rotors f&r, X-Fusion Manic dropper post (it was all that was available at the time) Raceface Next Carbon bars (760mm) and 60mm Raceface Turbine R stem- Diety Lockjaw Grips, WTB Volt Ti-Rail saddle and Butcher 2.3 front tire and Ground Control 2.3 Grid rear tire- Shimano XT clipless pedals-
    I havenít weighed the bike but it is much lighter than the SB150 of course! I live in Western Colorado and have about 150 miles on the bike so far- This thing rips! Most of those miles are on the Lunch Loop Trail system and a couple of Front Range rides- Apex/Chimney Gulch out and backs two days in a row. Climbing is as it should be and I have not noticed any drawbacks to the 140mm fork going up and the bikeís shorter wheelbase (compared to the 150), light weight and great suspension all combine to make a bike that easily cleans the nastiest, steepest stuff I can throw at it. I KOMíd a tough local climb that is very steep, loose and rough- none of this should come as a surprise as this bike should climb well! I am most impressed by the way this bike descends! I was obviously spoiled with the 150, but I havenít shied away from anything or any line that I had normally taken on the 150. In fact, I was only one second off my PR on a descent that includes the main Gunny Loop descent at the Lunch Loop Trail system (a descent I have been doing on many, many bikes for many, many years). I have also PRíd a lot of stuff out at the Kokopelli Trail system on this bike! I decided on the SB115 for a few reasons; I have an entry into the Breck Epic that was deferred due to COVID- (I was going to race a hardtail) and I am fit enough to be competitive in my age group so I wanted to up my arsenal bike-wise, I demoed a LG SB100 just prior to ordering the 115 as it was all the shop had available- I took it on a portion of the Colorado Trail and did a 45 mile ride with about 7,000 feet of climbing- the SB100 was a blast, despite being too small and it also impressed me on the descents. I knew the SB115 in an XL was the bike for me after that demo- some folks have an issue with the geometry- I would encourage anyone who is interested in this bike to ride it first and any concerns you might have will be negated- there isnít a trail around Western Colorado that I wouldnít ride on the SB115!
    Last edited by spintheblackcircle; 1 Week Ago at 07:44 AM. Reason: Posted before I was finished
    It's really a great bike. I have a couple Yeti's and haven't touched them after getting the 115. I built it with a 140 Pike and it is amazing! It climbs like a beast and descends great too. This would be my choice, if I only had one.
    Aug 2020
    Quote Originally Posted by Stumprider29 View Post
    Iím in the market for a new bike that can handle about any trail in San Francisco/Bay Area. I love climbing as long as thereís an amazing descend, so I need a bike that can handle going downhill. Iím not into jumping or hitting drops unless they are in my way. Yet, this will be my only bike so preferably I want a bike thatís dependable and can do it all.
    It sounds like a short-travel trail bike would be a good match for you. Besides the SB115, you should also consider the Ibis Ripley and Transition Spur. All three bikes are well suited for Bay Area trails (when they aren't on fire).
    In terms of dependability, the SB115 and Spur are new so the jury is still out on them. Yeti has had its share of problems with the SI design on the SB100, which the SB115 inherited. And Spur owners are complaining about problems with the SID Ultimate fork. In contrast, you won't read about many issues with the Ripley in mtbr forums.
    Nov 2019
    Thank you all. At 5í6 should I go with a Medium? Do they run small.
  67. #67
    Jul 2020
    Hello all,
    Where are you able to get a SB115 locally in the Bay?
  68. #68
    Nov 2019
    Bike Rhythmin in Oakland and Bike Tam In Mill Valley have a few.
  69. #69
    Got my large T2 a couple of weeks ago. Upgraded to Reynolds tr309 wheels.
    I am 6'1" with a pretty good wing span and the large felt much better to me than the XL.
    Spent the first two rides adjusting the suspension and it is almost there. This bike climbs so well. It just rolls up and over rocky climbs. It is very different to the horst link bikes I owned in the past. No hanging up on square edged rocks. It just makes them disappear. Even at walking speeds uphill it is stable. No vagueness or wandering, but still responsive to input.
    Descending is great. It rolls far faster than my last bikes. Very stable, yet very nimble or easy to change direction with out any twitchiness of the 70 degree head angles of the past.
    I feel more like I am sitting in the bike than all of my other 29ers.
    Like others have said, if you only go by what is on the geo chart, you are selling the bike short. It has to be ridden to understand how well it works. It just goes!
  70. #70
    Dec 2014
    Nice!! I just got my anthracite frame today, 2021 forks are on backorder, hopeful to have it by end of month. Coming off an sb100 so very intrigued by how much difference there is between the two models.
  71. #71
    Apr 2020
    Although this is not a helpful response, probably best to demo at least a small or a medium. I'm 5'6" (or 5'5.5" to be precise) so I can go either way with Yeti bikes. My SB140 I went with a small, but it is a long bike to start with. Since the standover does not increase on the SB115 you can choose based on reach and wheelbase. The medium would make the geo pretty close to the Small Revel Ranger (biggest difference being the slacker seatpost on the SB115) -- https://geometrygeeks.bike/compare/r...sb115-2021-md/ -- but a small would give you more of a cross-country maneuverable feeling bike. Just my thoughts at least.
  72. #72
    Aug 2020
    How is the sizing? According to the charts, I'm solidly a L at just over 6' tall....but the geometry charts show the reach as being real short?
    Am I missing something, or does it fit better than it looks like it should?
  73. #73
    Dec 2011
    Quote Originally Posted by Chrispy1974 View Post
    Large is your size. I am 6'4 and demo'd a large. It was rideable but to small...
    As many reviews and owner testimonies, and also my experience is that the geo numbers on paper don't tell the whole story..
  74. #74
    Aug 2020
    Thanks for the feedback.... I'm currently between the Evil Following V3 (now), SB115 (in stock in a couple months), YT Izzo (probably wait for the 2021 hoping they change the lockout)...
    I hear great things about the Yeti...and then will hear stories of flexing and frame damage...I'm pushing 240 and between odd geo charts and people posting pics of their busted up frames (mostly 130s) it has me overthinking...
  75. #75
    Dec 2011
    Been as heavy as that and have owned 7 Yetis and not a single issue #truestory
    #8 just arrived
  76. #76
    Aug 2020
    Forget the SB115...talk to me about that Bourbon!
    #8 just arrived
  77. #77
    Dec 2011
    Given to Yeti dealers from Yeti
  78. #78
    Aug 2020
    That's worth bonus points on its own! lol
  79. #79
    120mm Fork on SB115?
    120mm Fork on the SB115?
    I have a SB130 Lunch Ride and am looking for a short travel, lightweight bike to add to the mix. I've been eyeing the SB100 for a while, but with so many complaints of creaks and flex with the SI, I've held off. The 115 looks rad, but I'd like to keep the bike as light as reasonable with sharp handling. Some SB115 reviews also comment on the front end feeling tall...combined with a rather slackish seat tube angle...not ideal. Seems like running a step cast or the new SID at 120mm could be the perfect balance....lower the front end for improved climbing, shed some weight, and still have the extra 5mm in the rear with the improvements to the SI link hardware.
    Any opinions?
  80. #80
    Dec 2011
    https://youtu.be/AsR6PivUa_0
    Plenty of reviews on youtube now
  81. #81
    Dec 2014
    I put a 130 on my sb100 and did not notice much difference. Just lowered the bars a little more. The Sb130 climbing position is very nice but the long wheelbase is annoying for my area.
    I have a like new medium sb100 frame and SC fork I may be selling if the 115 Iím building up is a noticeable improvement. If I canít tell much if a difference Iíll be selling the 115 frame as I can get more out of it.
    The sb100 has the 2021 fox rear shock and the most updated SI hardware. Stiff AF
  82. #82
    Dec 2014
    Reviews are fun but letís be honest, most people have an agenda with their reviews / media outlets. One minute youíre watching a review and then next youíll be ordering 10 cases of coco joy coconut water and using code yumyum at check out @ competitive cyclist.
  83. #83
    Dec 2011
    Go to the Yeti Bikes Facebook group. Owners are posting their findings
  84. #84
    Dec 2011
    My friend and youtuber mtbsavant owns a Spur and demo the 115. He said he would be curious to put a SID 120mm and see how the 115 feels.
    He may do a video on it in the future
  85. #85
    Jul 2020
    #8 just arrived
    Lol... I figured you were going to get that frame. When I talked to them earlier in the week they didn't have bikes only the one XL white frame.
  86. #86
    Dec 2011
    Quote Originally Posted by addxyz View Post
    This was ordered for me just need to pick it up
  87. #87
    Jul 2020
    I was really thinking hard about the Arc they had but I think I'll get the 115 instead...
    Sent from my Pixel 2 XL using Tapatalk
  88. #88
    Dec 2011
    I can save you some $$ on either. DM me
  89. #89
    Aug 2020
    How close is the cockpit feel to the 100? I don't think there is a 115 demo available locally...but I may be able to sneak out on a 100?
  90. #90
    Dec 2011
    Feels the same. It's the same triangle and rear.
  91. #91
    Aug 2020
    Thank you...that's what I thought...but the numbers don't always tell the whole story...
  92. #92
    Having spent 2 years on an SB100 and now a month of riding on the SB115 they do feel very similar. The SB115 is noticeably taller on the front end. If you raise the stem 1cm on the SB100 youíll get a sense of the riding position on the SB115. I had 1cm of spacers under the stem of my SB100 and my shop setup my SB115 the same way. After a couple rides I slammed the stem and the riding position was nearly identical. Climbing with the Fit4 fork and shock in the middle position I canít tell the difference between the 2 bikes. With the suspension open the SB115 is noticeably squishier. The SB115 descends like a whole nother animal though. Where the SB100 would feel a little steep and twitchy the SB115 with the bigger fork can track better and feels much more stable. Itís amazing to me how the small difference between the two bikes create such a large difference in this area.
  93. #93
    Jun 2020
    Hello to all owners of Yeti Sb 115. Sorry in advance for my language but I use a translator. Please have a question ... is your bike quiet when driving downhill?
    I own an SB 115 and when driving off-road, especially when going downhill, I hear a "knocking" of the bowden cable or maybe a brake hose from inside the frame.
    I'm disappointed, I know that's what the testers met
    https://enduro-mtb.com/en/yeti-sb115-t1-review-2021/
    Please do not have advice on how to solve the problem?
    Thanks for any advice
  94. #94
    Mine did.
    My dropper post cable was the worst of the three cables running in the frame.
    My solution was to use some length .070 weed eater line and feed it down thru the hole in the frame where the cables enter the frame by the head tube. I put some bends or kinks along the length of the line so it would take up the space between the cable sheath and the inner dia of the frame inner tube. I also put a 90 degree at the top end so it would not slip inside the frame tube.
    There is also a small boss or loop in the frame where the shifter and rear brake cables exit at the botton of the down tube meant for securing the cables with a tywrap. The tywrap on mine was missing, so I installed one to keep the cable stationary in the inside of the frame and help to prevent rattles and also chaffing.
    Only two rides so far and it is very quiet now.
  95. #95
    Aug 2020
    Quote Originally Posted by Threesticks View Post
    I'm rather surprised that the cables are exiting below the BB as opposed to contained and running above like the other models?
  96. #96
    Reputation: Rom3n's Avatar
    Jan 2014
    The SB115 rides great. I had a SB100 and I prefer the 115 for trail riding. The added travel makes the bike more capable for sure and the frame has an overall stiffer feel. I currently have a V3 Following and Spur and I don't think anyone should dismiss the 115 in this category.
  97. #97
    Danglers
    The SB100 also had the cable and hose exiting the bottom of the down tube just ahead of the BB. Not my favorite feature of the bike, but I haven't heard any negatives from anyone here or else where on the webs.
  98. #98
    Reputation: RRauzer's Avatar
    Jul 2019
    Quote Originally Posted by Rom3n View Post
    Dig your N+1 life. How do you delineate when to use the Spur or the 115 for a ride?
  99. #99
    Jun 2020
    Thank you very much for your answer, I will try to go the same way
  100. #100
    Wouldn't the SB115 and Spur overlap too much to have both? I would be interested in hearing your comparison of the two. If you had to keep one, which? Why?
    BTW, that color is sick!
  101. #101
    Jan 2014
    Quote Originally Posted by stom_m3 View Post
    They do. If you are riding steeper trails the spur for allout speed, If you are riding tight slower terrain the 115. The 115 pedals a better IMO.
  102. #102
    Dec 2014
    I donít get the spur craze. Single pivot flex stays, no thanks. Get the SB130 instead and build it up light. Much better pedaling platform.
  103. #103
    Jan 2014
    Quote Originally Posted by kumquat View Post
    It is a super fun bike to ride. Not everyone's taste but if you are used to riding big slack bikes and you want a short travel fun bike and you have some steep local trails it's a good option.
  104. #104
    Aug 2020
    Took a Large SB100 out to test the cockpit feel and a Med SB130 for the suspension/pedal feel...
    The SB100 was a rocket ship (T2 build with carbon wheels) compared to the SB130 C2 build... (I was shocked at how much heavier the 130 felt compared to the 100...much more so than the numbers would indicate)
    The Specialized Evo Expert felt even livelier for pedal feel/acceleration...but the Yeti was just SO MUCH more comfortable... I think that I've at least ruled out the Specialized...unfortunately, now instead of a C1 build, I'm trying to find a way to sell wifey on the need to step up to a T1 build instead....lol
  105. #105
    Dec 2014
    I own both sb100 and sb130 turq x01 builds. If I place the same wheels and tires on both bikes the Sb130 climbs damn near the same as sb100. Itís just when the trail gets tight, does the sb130 start feeling clumsy and a little slow.
    I absolutely love the sb130 but my sb100 is more fun on my local trails. Building up a 115 with the idea I can sale both my 100 and 130.
  106. #106
    Dec 2016
    Hi folks, anybody have any rear tire clearance issues? Iím stunned that yeti says in the FAQ section that max tire size is 2.3 (after the Line that says it has great tire clearance). Iím running my SB100 wheelset on my 115 (forekaster 2.35 on 26iw rims), but planning a 2.4 dissector on a 30iw rim, am I asking for trouble?
  107. #107
    Dec 2011
    It's the same as the sb100. Maybe search the sb100 thread for your answer...
  108. #108
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    I have 2.4 DHFís on mine (sb100), no problems at all. But we donít ride when itís muddy here.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Thrill Bikers Unite!
  1. A Happy Yeti is a Dirty Yeti
    By bear in forum Yeti
    Last Post: 03-19-2014, 04:50 PM
  2. Replies: 2
    Last Post: 08-27-2013, 05:31 AM
  3. Replies: 6
    Last Post: 08-01-2013, 01:11 PM
  4. Yeti-man's Yeti Pro FRO disc version
    By digilux in forum Vintage, Retro, Classic
    Last Post: 07-11-2011, 07:56 AM
  5. Yeti 575 vs. Yeti ASR 5C for Grass Valley/Tahoe
    By schweisd in forum California - Norcal
    Last Post: 05-09-2011, 12:41 PM
Members who have read this thread: 416
