Yeti SB100 Discussion, Performance and build- Mtbr.com
Page 1 of 12 1234511 ... LastLast
Results 1 to 200 of 2392
    Reputation: skinnybex's Avatar
    Aug 2015
    Let's kick this new bike off with its own discussion thread.
    Yeti 2020 SB165
    Yeti 2019 SB150
    Yeti 2019 SB130 AXS
    Yeti 2018 SB100 AXS
    Oct 2015
    Are you planning on adding one to the fleet Skinnybex?
    Aug 2015
    Quote Originally Posted by GarthMci View Post
    Not sure. Iím really happy with my SB4.5 so Iím going to Demo one at Yeti HQ in May so I can feel the difference myself. Iím pretty intrigued how short travel switch infinity will improve on the ASRc in regards to 100mm travel and I loved my ASRc
    Yeti 2020 SB165
    Yeti 2019 SB150
    Yeti 2019 SB130 AXS
    Yeti 2018 SB100 AXS
    Reputation: tom tom's Avatar
    I have a medium in the garage that I am building tonight and the frame is 2640 grams.
    Here it is hanging on the scale with only the rear axle in the seat post clamp
    Attached Thumbnails Attached Thumbnails Yeti SB100 Discussion, Performance and build-20180413_175218.jpg
    Reputation: slider_phil's Avatar
    Aug 2014
    Looks like the website is pretty accurate. And also re-enforces the fact that every scale is going to read a little bit differently when you're trying to measure things to the gram.
    Checked again without axle and seat post clamp and it's only 2535 grams. 5.588 pounds. The new Blur I built weighed 2165 with DUB BB still in frame also with axle and seat post clamp and it was a large.
    Aug 2014
    Roughly a pound or 15% heavier. I'm going to assume most of the weight comes with the switch infinity system over carbon weight. Pretty keen to throw a leg over one.
    Anyone know if Yeti demo bikes all the way down in Aus?
    Reputation: Dagonger's Avatar
    Dec 2011
    Im going to beat you to that demo ride!! lol Im in CO on Sunday for the week
    Oct 2015
    Quote Originally Posted by slider_phil View Post
    Noop, no demo Yetis. If youíre in Sydney though, go see the guys at Summit Cycles. Theyíll like the be the first in the country with one on the shop floor. There seems to be a strong correlation between cool new bikes coming into the floor in L and the store manager also being a large
    Oct 2015
    Quote Originally Posted by skinnybex View Post
    Fair enough, keen to hear how you find it.
    Iím in the same boat about the 4.5, currently my only MTB and wondering if the 100 is going to be that more racey/fast that Iíd want one
    Aug 2015
    I'm interested to hear your impressions of the the SB 100 compared to the 4.5 and ASR. I demoed a 4.5 in small and loved it, was the first time I'd ever gotten on a bike and felt like it fit just perfect! It rode beautifully, but I did prefer the snappiness when climbing of my ASR. (beti 27.5 version) If the SB 100 climbs pretty much the same, is a bit more forgiving on the downs, and feels similar in fit/geo to the 4.5, then I'm in! I'm wanting to move to bigger wheels, and the 4.5 is a little more bike than what I want. I'm hoping to get a chance to demo one in the next few months
    Aug 2015
    Quote Originally Posted by yeti575inCA View Post
    Awesome, I look forward to your thoughts after you have your demo on Enchanted/ Apex.
    Yeti 2020 SB165
    Yeti 2019 SB150
    Yeti 2019 SB130 AXS
    Yeti 2018 SB100 AXS
    So, I have a 2017 SB4.5 that I like a lot.
    I feel that climbing very steep stuff is a bit challenging (front wheel lift).
    I am 5'9, ride a M with a 80 mm stem with no spacer.
    If I get the SB100 frame and I keep my fox 34 (140) and swap the components, how will the 140 mm fork affect climbing ?
    Maybe a better route would be to sell the 4.5 and get the SB100 (with the proper fork)
    Quote Originally Posted by fabe View Post
    I think 140 would be stretching it, in terms of it riding anything remotely like the designers intended, AND you'd still have the front wheel lift challenge you have now.
    Better might be to buy a ~$50 airshaft for your fork in 120 mm. Easy to install (or cheap for your LBS -- certainly less than an hour).
    Whining is not a strategy.
    Oct 2013
    Subscribed, I'm eyeing one as my race-ish XC bike to replace the Trek. Would be my first Yeti, hope the pedal efficiency is similar/ better than the Trek Re:aktiv
    Yeti SB100
    Commencal META HT AM
    Thanks Kosmo, this makes sense.
    I also got a 10mm rise 35/760 raceface bar (mine has a 20 mm rise) and got a 90 mm stem. This plus an airshaft will probably do the trick.
    Aug 2014
    Quote Originally Posted by mevnet View Post
    Same boat, never owned a Yeti but looking for a new endurance race bike. I haven't ridden the Trek reactive stuff but I've heard good things.
    I'm curious to hear how the rear works compared to the JS tuned VPP I'm currently on with my Primer.
    Oct 2013
    One thing I found out today is that the rear brake hose can only go in the opening on the non drive/ left side. So if you're using moto style brakes you end up with a sharp J bend on the left side, might look ok but it's not ideal.
    Also that same hose is internal so you have to disconnect/ trim it first.
    Yeti SB100
    Aug 2014
    That kinda sucks. All my bikes (plus a lot of other countries standards) are Moto style. Something to think about anyway.
    Reputation: mfa81's Avatar
    is any other bike with internal tubing routing different? any idea how's the new ripmo or sb5? I'm guessing if they mold internal tubes for routing there is no way around this...
    Aug 2014
    Quote Originally Posted by mfa81 View Post
    Honestly every other bike I've owned with internal routing hasn't been tube routing so I'm not to sure. Noise hasn't been an issue in my Primer and routing was pretty straight forward and easy being able to choose any hole. My old Evil Following had tube routing for the dropper and that was it.
    I like the idea of tube routing everything but I guess as a company you have to pick a side with the brake line and Yeti chose the non drive side. I'm sure it's not a deal breaker for most but I'm a bit pedantic with my cable routing
    Jul 2013
    Hopefully picking up my frame tomorrow!
    Reputation: wooly88's Avatar
    Posted this in the 2019 XC thread but thought Iíd post here with more detail. Just picked this up last night.
    Build is medium with xx1 Eagle, We Are One Insider wheels laced to Project 321 silent hubs with Sapim Race spokes, 2.35 Nobby Nic Addix tires set up with Orange Seal, SDG Bel Air saddle, 150 Transfer dropper (waiting for backordered Kashima post), 50mm Turbine stem (waiting for a 60 and 70 to fine tune fit), yeti bars, Guide RSC brands with 180 rotors front and back and XT Trail pedals. All in 26.5 lbs on the shops scale.
    ejh
    ejh is offline
    Quote Originally Posted by wooly88 View Post
    Build is xx1 Eagle, We Are One Insider wheels laced to Project 321 silent hubs with Sapim Race spokes, 2.35 Nobby Nic Addix tires set up with Orange Seal, SDG Bel Air saddle, 150 Transfer dropper (waiting for backordered Kashima post), 50mm Turbine stem (waiting for a 60 and 70 to fine tune fit), yeti bars, Guide RSC brands with 180 rotors front and back and XT Trail pedals. All in 26.5 lbs on the shops scale.
    that is dope!!
    Quote Originally Posted by ejh View Post
    that is dope!!
    Thanks. Stepped out of my box and went a little more bling than normal.
    Apr 2015
    Have you at least ridden in the parking lot?
    Sent from my SM-G955U using Tapatalk
    Quote Originally Posted by bogeydog View Post
    I demoíd one this week and rode this one around my neighborhood. Thatís about it. My wife is out of town this weekend so no riding for me.
    Jul 2013
    Picked up my frame today. Need to order a headset and hope to have it built up within the next few weeks.
    Double checked the bottle cage and it clears the larger size standard bottle without touching the shock. Frame weight as claimed.
    Aug 2015
    Beautiful bike and build. I also commend your choice on wheels as they are the most happening and cool company to come around in a while and the wheels look flawless.
    Yeti 2020 SB165
    Yeti 2019 SB150
    Yeti 2019 SB130 AXS
    Yeti 2018 SB100 AXS
    Apr 2015
    Quote Originally Posted by Udyr View Post
    Whatfork are you using? I am tempted to try a 130mm first since the new SC34 isnt available yet. Formula makes a 35 fork that's very light and really adjustable and 44mm offset. Reviewers like it but I haven't found any real world reviews. I also don't know is it is available in boost.
    Jul 2013
    I'm swapping on my 120mm standard 34 with 51mm offset. I'll try and source some uppers in 44mm eventually for when annual service rolls around. Might go to 130mm later on depending on how it goes.
    Dec 2011
    I saw this frame and bike in person at Sea Otter today, and pics just dont do the lines justice!! Breath taking!!
    Sent from my SM-G930T using Tapatalk
    Instagram/Youtube- Dagonger
    Yeti Cycles sb45c/sb150
    That orange 34 step cast is the cats meow. Wish I couldíve found one!
    Jul 2013
    One thing I noticed when I cycled the suspension with all of the air out is that the bottom out stops probably 6mm short of the end. I don't want to speculate or cause someone to make some rash decisions, but someone might want to check the tire clearance at full bottom out. There might be a few extra mm of travel that we may be able to squeak out of this thing!
    My frame arrived last saturday but I am in MN working. Will be back home, Puerto Rico, on Friday. I am super pumped to get the build going. I currently own an Asrc. Will swamp most of the part from the ASRC in the meantime. We dont have super steep or gnarly trail back home so I will keep me dt swiss team race fork until I find a buyer and then will swap to a fox 34.
    Attached Thumbnails Attached Thumbnails Yeti SB100 Discussion, Performance and build-932944dd-cb6a-4f46-bc9f-5a9c4733f9bd.jpg
    Jul 2013
    The fact that people were running chain guides at Fort Ord makes me highly likely to get one. I've only dropped a chain once with Eagle (oddly enough it was while climbing), but given you can run a really lightweight one on the Sb100, why not right?
    I ran a chainguide/taco bash on my HD3 and it was great.
    Might need to talk me off the ledge here. I'm thinking about selling my favorite bike, sb4.5, to get this. I find myself doing more and more endurance events and I think this would be a little better due to efficiency, slight weight advantage, and the bottle holder. I just don't hydrate well using a backpack, because I can't see how much I'm consuming. Then I ride my hardtail on courses that would be better suited for FS. One bottle on the bike and one in my jersey pocket would work fine though. If I don't lose much fun factor or versatility it might be the ticket. Part of me thinks this is totally irrational though.
    Quote Originally Posted by dgregorie View Post
    As I just eluded to in another thread, there is nothing rational about the ledge you are standing on.
    I'm trying to figure out how to swing a SB100 (full pimp build of course), just because I think my already super dialed current ride, is over-kill for 50% of my riding (yet perfectly acceptable).
    The basement needs to get finished, kids college funds are on the low side, and what retirement fund... There is no argument I can make to justify it adding to the fleet, but will do it anyway.
    Quote Originally Posted by NS-NV View Post
    Clearly, if we lived in the same place we would be friends
    Mainly a lurker but Iíd join that club.
    Jul 2013
    Taking her out for tuning tomorrow. The quick pedal from the shop to my apartment was illuminating though (in a good way). I'm not going to go into a lot of detail until I have done about a weeks worth of riding, and then I'll post up a proper review.
    Yeti SB100 Discussion, Performance and build-31945588_10106194565612685_2827498806294085632_n.jpg
    Looks great. Iíve had mine for a week and gotten in 3 rides. Iím out of shape but it makes the hurting fun. Enjoy.
    If in Golden CO, my garage is always open.
    If youíre in Golden CO, my garage is always open...
    Likewise, if you're ever in Chattanooga, TN
    Jul 2013
    One thing to be advised, the Stages 2nd gen GXP power meter doesn't clear the chainstay. I have a Power2Max NGEco on the way to replace it.
    probably not only gxp, I saw Jonathan Lee mentioning something about stages clearance with the chainstays, maybe there is a problem with dub or bb30 as well
    Jul 2016
    A perfect bike for my local trails
    Yeti SB100 Discussion, Performance and build-20180503_152521_resized.jpgYeti SB100 Discussion, Performance and build-20180503_183107_resized.jpgYeti SB100 Discussion, Performance and build-20180503_183111_resized.jpgYeti SB100 Discussion, Performance and build-20180505_065046_resized.jpg
    Can't say enough positive things about this bike. I have a 2018 SB5LR, 2018 SB6, had a 2017 ASR. I could actually sell the other 2, keep this one, and would be perfectly happy. Yeti does it again! It feels better, smoother and the cockpit is more comfortable than the ASR. I do not race XC, so I can't notice the extra pound everyone's whining about. I couldn't be happier with Yeti's decision to produce this sweet machine. It's like it was custom made for me.
    Apr 2015
    Quote Originally Posted by 46isgood View Post
ID:	1196622Click image for larger version.
ID:	1196623Click image for larger version.
ID:	1196624Click image for larger version.
    Tell us about where and how you ride. Also how it is in different types of terrain. What bikes you could replace and why.
    Jul 2016
    I live in San Diego and ride all the local trails here with a mixed terrain of techy rocky sections, ruts, smooth singletrack, hardpack with loose dirt on top, punchy climbs, etc etc. It's hard for me to put into words and I want to do a good job so give me some time to put it together and I will respond with as much detail as I can. I am not a racer but I do put in 70-100 miles a week in my local canyons. What I can say is that the bike feels like it has way more travel than 100mm, I beat 2 of my SB6 downhill times which actually aggravates me because I feel I didn't push the SB6 to it's limits or hard enough. I"m not sure if it's the 29" wheels or what but I felt more secure on the SB100, weird right? For arguments sake and for you to get a feel of how I ride based on Strava data on the same segement: On my SB6 last week my time was 1:09 which ranked me 120/1657, this morning on the SB100 I did 1:06 which ranked me 52/1657. Of course this is GPS/Garmin Fenix 5 and not official pro times but you can get the idea. The bike just feels good to me. Could be the placebo effect, not sure, only time will tell. PM me and I will share my Strava data or name if you are interested in San Diego rides/riding and how I ride. I am an aggressive rider.
    Apr 2015
    Thanks. I am easy coast rooty and rocky singletrack with punchy climbs and short downs. We have rock gardens which can be up or downs. Techy climbs with roots and rocks. Not many drops, but do have successive rocks and onstacles to pedal up on or down.
    Jul 2016
    Sounds like you found yourself a match. I haven't had a pedal strike yet. Trust me, you will not be disappointed. The bike tracked/tracks extremely well through the rough for me, I could probably do it blind folded if I kept a little speed going. Kidding
    Reputation: Dpca10's Avatar
    Sep 2012
    I havenít heard much in the way of pedal strikes. Anyone with one of these been smacking rocks? Not that Iím worried, I prefer 170mm or even 165mm cranks but all the builds that are available now in large have 175mm cranks. I am fully capable of adjusting my technique or ratcheting but nothing beats smoothly powering through a tech climb.
    seems like Nate Hills was 2nd in the Endurocup in Moab with his sb100, he built it for trail riding and seems to be working for him!
    Reputation: chiburi's Avatar
    May 2016
    Too funny! I think most of us go through the same thought progression looking for reasons or holes where a nice new bike will fit nicely! I just picked up a used 2016 asrc and love it. My evil wreckoning has been collecting dust but canít bring myself to sell it considering itís a tank on the DH.
    Chib
    Test ride complete. Quick first impressions.
    1) excellent small bump sensitivity. Amazing actually. Had the suspension open nearly the whole ride.
    2) slacker head angle then asr, similar to 4.5, but the wheel feels more tucked under the bike for quicker steering response. Not twitchy at all. Better tight trail handling then the 4.5. Similar on flatfish rolling terrain compared to the asr.
    3) descending- better than the asr, but to be fair asr does not have a dropper. The slacker head angle definitely felt good on the descent. Maybe not as charge happy as the 4.5? Front fork air pressure needs to be dialed.
    4) technical climbing blew me away. The traction, plus rear wheel staying glued allowed me to climb a tech section 2x in a row that I only make 30% of the time. Either the maxxis aggressor tire is amazing or the supple suspension with great mid stroke support is just that good. Likely the combo. I was impressed. Bike did not feel floppy at all on climbs.
    For all around Colorado riding, it is a great bike. It would be very interesting to try it with 2.35 fast rolling tires like an ardent race or vittoria mezcal. The aggressor and minion that come stock are very grippy. It was my first time riding this combo.
    Quote Originally Posted by rianclay View Post
    Which fork rake did your test bike have?
    Jul 2013
    Jun 2015
    I hate reading these....new Bike disease starts kicking in and makes me want to swap out my ASR for a new SB100. Financially, that would be hard to swallow...primarily thanks to boost wheels and new 46mm offset Fork!
    Quote Originally Posted by junior77 View Post
    Udyr and others think the 46mm isn't "necessary" on the SB100. It has more to do with Yeti's volume buying from Fox as it relates to the 4.5 redesign and/or it's a fad. A Yeti pro, Lee, races with a 51 rake.
    I have not ridden either back to back on the SB100.
    Reputation: jfkbike2's Avatar
    Feb 2005
    Quote Originally Posted by Dpca10 View Post
    I picked up an XL from Jensen and it has 170mm cranks. I'll trade you for your 175's
    Dec 2017
    I just ordered one and excited to pick it up ~Monday, looking forward to it !
    Quote Originally Posted by westin View Post
    right now 44 vs 51 offset is something that no matter which direction they choose it's going to be questioned. I'm guessing going 44 was more like Yeti wanting to go with what everybody is going (even tough though they don't like to say that) than anything else! but take that with a huge grain of salt since I haven't hidden the bike yet
    Jul 2013
    Nate Hills is also on a 51mm Pike. I havenít ridden a 44, so I have nothing to compare it to. Iíll prob hop on a demo at some point to compare but itís not a priority because the bike handles well in all the terrain Iíve been riding.
  67. #67
    The new step cast
  68. #68
    My review is up: Yeti SB100 ride impressions (with comparisons to Kona Hei Hei
    I hear you. I have a very nicely built asr and 4.5. Iíd take a big loss on selling either.
  69. #69
    Reputation: Stalkerfiveo's Avatar
    Feb 2015
    Not bad considering you could easily drop 1 lb with different tires and pedals alone.
    In serving the wicked, expect no reward, and be thankful if you escape injury for your pains.
  70. #70
    Freezer
    Reputation: mlloyd007's Avatar
    Dec 2009
    Went for a demo ride last night, and going for a long ride today. I'm comparing to the lightweight (22.7 lb. with the 34 fork I have on it now) Pivot 429SL I recently built up to see if I swap out frames. The reach on the Pivot is feeling a bit short for me, and the longer reach and modern geometry on the SB100 is very appealing.
    First ride quick impressions relative to the Pivot: Feels a bit taller in the saddle, the stack is definitely higher, reach feels better, slacker head tube and steering feels fine and I got used to it pretty quickly, pedaling efficiency seems similar to the DW link on the Pivot. The SB100 weights in at 27.2 lb, so it's 4.5 lb. more than my Pivot, and I can definitely feel that climbing. If I swap out the frame and fork, I'd probably net out about the same weight as the Pivot is now, so that would be a wash. More impressions after the ride today.Yeti SB100 Discussion, Performance and build-img_1533.jpgYeti SB100 Discussion, Performance and build-pivot-5-5-.jpg
  71. #71
    Dec 2004
    Quote Originally Posted by mlloyd007 View Post
    First ride quick impressions relative to the Pivot: Feels a bit taller in the saddle, the stack is definitely higher, reach feels better, slacker head tube and steering feels fine and I got used to it pretty quickly, pedaling efficiency seems similar to the DW link on the Pivot. The SB100 weights in at 27.2 lb, so it's 4.5 lb. more than my Pivot, and I can definitely feel that climbing. If I swap out the frame and fork, I'd probably net out about the same weight as the Pivot is now, so that would be a wash. More impressions after the ride today.Click image for larger version.
ID:	1197540Click image for larger version.
Name:	Pivot (5 of 5).jpg
    Cant wait for that. I have Spark 900RC and Mach 429SL at home and prefer Spark for ability to adjust suspension on handlebar. That is the main reason. Otherwise Pivot is more comfortable ride and more capable on tricky sections but reaching for levers on shock and fork on uphill is not my game. As I had back surgery comfort when seated and pedaling is main thing where I look for improvement on Spark which is hurting my back after 1 hour in saddle.
    Keep us informed!
  72. #72
    Freezer
    Dec 2009
    I got in another 2-hour ride on the SB100 today, then did a back-to-back comparison of the 429SL and SB100 on the same 20 minute course. As I mentioned in my earlier post, there is a 4.5 lb. difference in weight (22.7 lb. Pivot vs. 27.2 lb. Yeti), so clearly some of my impressions are a function of the better/lighter build on the Pivot, but Iíve tried not to conflate the riding characteristics of the frame with differences in alloy vs. carbon wheels, tires, brakes etc. In addition, my Pivot is a Medium, and the Yeti I demoed is a Large, so some of the differences are a function of different sizes. Here are some of my impressions in no particular order.
    Geometry: The Yeti geometry feels very nice, and I do like it better than the Pivot. The longer front end and somewhat shorter chainstays of the Yeti feel very comfortable for climbing, descending and on the flats. The increased head tube angle of the Yeti is mitigated somewhat by the 44mm offset, and while the Yeti is bit slower steering going uphill, I didnít feel like it was an issue, and it is a benefit in descending. The stack is noticeably higher on the Yeti, and while I do prefer an XC body position, I got used to the bar height quickly and did notice less lower back fatigue when climbing for extended periods. Overall, Yetiís interpretation of modern geometry is quite good.
    Climbing/ SI vs DW Link: Some quick background on shock setup for each bike. The Pivotís shock tune requires pretty low pressure for the proper sag. Iím 170lb, and around 100psi gives me proper sag. I climb on the trail in the middle setting on the shock lever, and descend with the shock wide open. The Yeti requires about 200psi for proper sag, and the manual recommends keeping the shock wide open all the time except for riding on the road. All this said, the Yeti is noticeably less plush than the Pivot, although the pedaling efficiency when climbing seems to be about the same between the bikes. Both bikes have a slight effect on the shock when grinding hard uphill, but the Yeti seems to compress the shock under load while the Pivot seems to extend the shock. I assume this is a difference in the anti-squat profile. The bottom line for me here is that the Pivot is noticeably more plush at about the same climbing efficiency as the Yeti.
    Descending: The Yetiís longer wheelbase and slacker steering makes it more stable when descending relatively smooth/fast terrain than the Pivot. As the descent becomes rockier/more chunky, the Pivotís plushness and resultant controllability becomes an increasingly important factor relative to the Yetiís better geometry. As an aside, the build (SRAM XO) on the Yeti didnít help things. First, itís pretty noisy from rattling cables, loud brakes (not squealing, but a damn loud grinding which I assume is from sintered pads), and lastly from the DT Swiss hubs which buzz a lot (Iíve gotten used to the golden silence of Project 321 hubs). Second, in my humble opinion, the Maxxis tires are pretty sketchy and produced a feeling of unstable oversteer on fast hardpack compared to the Racing Ralphs Iím used to. Lastly, I did feel like the Yetiís rear end moved around more when descending through technical sections, especially when cornering. This could be a function of alloy hoops compared to the Pivotís carbon rims, the difference in tires, or the Yetiís somewhat less laterally stiff rear triangle (more on that below). I did, however, find the Yeti better to jump, with really stable takeoffs and landings.
    Miscellaneous: I tried to get a feel for the Yetiís frame stiffness by trying to move the rear wheel laterally, and found the rear triangle to have a noticeable amount more lateral flexibility than that of the Pivot. Some of what I noticed clearly is from the less-stiff alloy rims, but I could also see the rear triangle flexing a bit. The Pivotís rear triangle by comparison is like rock.
    Build-specific items include the XT dual caliper brakes which are insanely powerful (much stronger than the XTR single caliper brakes), and require some finesse not to lock up; the WTB Volt saddle which is really comfortable (more so than the WTB Silverado on my Pivot); and the 34SC fork which felt identical in all respects to the regular 34 fork.
    The bottom line for me when comparing the SB100 to the 429SL is that the Yetiís geometry feels better, the pedaling efficiency is about the same between the bikes, and the Pivot is noticeably more plush. And to state the obvious, the Yeti is a gorgeous bike, while Iíd characterize the Pivotís looks charitably as functional.
  73. #73
    Oct 2013
    I got in another 2-hour ride on the SB100 today....
    Hey there, thanks for sharing. What sag did you have on the Yeti? The 32% recommended?
    BTW tires make a huge difference in the way the bike feels. RaRa rear is good but I prefer the Thunder Burt, front is sketchy at best.
    Yeti SB100
  74. #74
    Freezer
    Dec 2009
    Hey there, thanks for sharing. What sag did you have on the Yeti? The 32% recommended?.
    Yes, I ran the 32% sag which is 12mm
  75. #75
    Wheels and tires play such a big role in how a bike feels. Any chance to swap and review?
  76. #76
    BLAH BLAH
    Last piece to my puzzle on my SB100 build.
    44mm Offset Standard Fox 34
    or
    51mm Offset Fox 34 Step Cast
    Whats this line for?
  77. #77
    Freezer
    Dec 2009
    For what it's worth, I compared the twisting flex in the 34SC with the 34 standard by pinning the front wheel between my legs and twisting the bar. I could definitely discern more flex in the 34SC than in the 34 standard. Not nearly as much as with the 32SC which I started with on my Pivot, but it is noticeable. If I were you, I'd go with the 44mm offset; I'm sure Yeti spec'd that offset for a good reason.
  78. #78
    Reputation: Projectnortheast's Avatar
    Mar 2011
    For what it's worth I appreciate the comparison... but yet not. It's kindof absolutely absurd to compare a bike built with trail bike wheels and tires etc. vs a bike clearly built for XC racing set up. My asr was a noodle with alum wheels but stiffened right up with a set of nox wheels. To say the pivot is flexless compared to the yeti with the 2 very different wheelsets is not apples to apples.
    I owned and raced both a pivot 429sl and a yeti asrc and hands down the Yeti was better at everything and had a similar feel on shock set up, and similar pressure, both would BLOW through travel on drops without a volume spacer. As far as suspension did you notice the SB100 bottoming out harshly on drops? As compared to the 429SL? As I think that's just about the ONLY thing that you compared that would be anywhere near worth reading considering the VASTLY different builds you have going on is the basic suspension characteristics...
    I would be VERY interested in an indepth review of the same build on both bikes, but otherwise feel like we are just throwing around useless data on the internet
  79. #79
    Dec 2017
    Quote Originally Posted by manchvegas View Post
    Wow that seems like a totally dickish thing to say, the guy spent a chunk of time writing up his thoughts and you just pooped all over them...
  80. #80
    Mar 2011
    Quote Originally Posted by bobhoppy View Post
    Really? Dickish? Come on! Lets list the differences
    dropper post on pivot
    no dropper yeti
    1800ish g wheelset with 1000g front tire 800g rear tire on yeti
    1400ish g wheelset with 700ish g tires front and rear
    pivot wheelset A-symmetrical carbon hoops basically 0 flex
    yeti wheelset aluminum fairly stiff for alum wheelset but still floppy as hell when compared
    Crankset on pivot next SL
    crankset on yeti X0 another 100g heavier
    JUST the wheels and tires make up roughly 2lbs! of rotational weight difference between these 2 bikes, there is no way to objectively compare with that much difference. These 2 frames only have a .3lb difference between them but yet the builds are 4.5lbs different and totally changes the character of any bike. I'm not trying to be a dick I'm just trying to say, it's not an objective comparison and I think it will mislead people.
  81. #81
    Jul 2013
    @manchvegas my review is comparing two exact same builds: http://forums.mtbr.com/yeti/yeti-sb1...i-1077779.html
  82. #82
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Well, the time he used comparing the two was not well spent. Thatís the truth.
    ďGee, these two bikes that are only alike in frame travel ride differently.Ē
    If you donít attempt to normalize differences between the two (wheels, tires), of course they are going to ride differently, and no, you wonít be able to say those differences are solely due to the frame. Thatís the truth.
    Death from Below.
  83. #83
    Mar 2011
    Thanks Udyr I read your write up and kindof more along what I was thinking it should be when comparing this bike with similar build to other bikes in it's class. With that said, I'm still trying to be objective and not just drink the Kool-aid as a yeti fan in general, but to give real impressions of how this bike is going to perform as a racer. Yeah yeah, Yeti didn't stock it as an xc race bike, but lets be honest, that's what ALOT of weekend warrior racers are looking at this bike as... So comparing stock builds on MTBR VS an obvious custom built xc race bike is misleading to what this bike's potential really is.
    With that said, I'm hopeful the reviewer above changes wheelsets to the NOX with race tires and gives another review... and then slaps the wheelset with the minion etc. on the Pivot and see how it feels!
  84. #84
    Jul 2013
    I feel pretty comfortable giving the following advice:
    #1. If you self-identify as primarily an XC racer, you probably shouldn't buy the SB100
    #2. If you ride a bunch of stuff, and also race XC, you should consider the SB100
  85. #85
    your chance to go build both bikes and share your impressions!
  86. #86
    Mar 2011
    more than happy to when my frame finally comes in...
  87. #87
    Any more direct comparisons to the 4.5? Looking to decide how much Iíll gain for endurance racing over the 4.5.
  88. #88
    alh
    alh is offline
    Aug 2016
    Beautiful build, wooly! I'm picking up a black X01 build this weekend and was thinking about changing to XX1 for the bling. Your pics are convincing to pull that trigger!
    My LBS is going to demo the 321 hubs. How do you like them? Silent and good engagement?
  89. #89
    Quote Originally Posted by alh View Post
    Thanks! My backordered Kashima dropper is now installed. Looks awesome. I need to take a pic to post an update.
    The wheels are great. Not as quiet as Onyx hubs which Iíve had but I canít hear them while on the trail. Engagement is awesome and the finish is great. Loving the wheels.
  90. #90
    alh
    alh is offline
    Aug 2016
    Yes, I'm getting Kashima dropper, too. Really ties in the look.
    LBS tells me the hubs are from a team that is an offshoot from I9. Know if their engagement is similar (which I thin is phenomenal).
  91. #91
    Has a cycling disorder
    Reputation: fishboy2807's Avatar
    Frameskin for SB100
    I've developed a Frameskin kit for SB100 in Medium and Large frame sizes. Here are a series of detail images. Man, it is a very nicely resolved frame design.
    Yeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_3.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_16.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_17.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_18.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_19.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_20.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_21.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_22.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_23.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_15.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_14.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_13.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_4.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_6.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_7.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_8.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_9.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_10.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_11.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_12.jpgYeti SB100 Discussion, Performance and build-2019_yeti_sb100_c_24.jpg
    Frameskinô Bike Protection Film
    www.frameskin.com
    Dirtsurferô Custom mudguards
    www.dirtsurfer.com.au
  92. #92
    Jul 2013
    Quote Originally Posted by fishboy2807 View Post
    I've gotta get one. Especially since I just got my first scrapes
  93. #93
    Mar 2011
    I just wish it didn't cost so much or there were like smaller kits available. Like maybe just the top tube, down tube and outer chainstays. Frameskin is the best as I've tried others and am not impressed. But I remember paying sub 100 us which was doable...
  94. #94
    We offer partial kits too though this is done offline. Situations where this is helpful can be 1. where a main or rear triangle has failed (for whatever reason) and is being replaced.
    2. You've had a tumble while riding and you want to replace one or more of the decals that have borne the brunt of the stack so the whole kit looks sharp
    3. You just want minimum coverage, or
    4. You know you are a chronic boot scuffer and want to double up protection just on the stays etc.
    Send me a pm and we can sort it.
    www.frameskin.com
  95. #95
    They're online now mate.
    www.frameskin.com
  96. #96
    alh
    alh is offline
    Aug 2016
    Size small coming for the SB100?
  97. #97
    Mar 2011
    Sent PM! Thanks man that sounds great. I'm really just looking for the one piece for top tube, the bottom of the downtube and outer chainstay and seatstay. That's cool that you do partials as haven't found anything better than Frameskin yet. Other brands I have tried are more susceptible to scuff marks from boots etc. and they DO NOT COME OUT so I begin to wonder what's the point right? as the scuffs would just rub off the paint, but for some reason with some frame films it's like a permanent scuff that you can't get out...
  98. #98
    Jul 2013
    Got my new Power2Max installed on the SB100 and did one of my usual loops. Some very interesting data.
    Obviously there will be some differences between the Stages and the P2M, but both units have gotten good accuracy scores from DCRM so I figured this data would be useful with the caveat that it's really difficult to do exact 1:1 tests on dirt. I'm also about 3 pounds heavier in the SB100 tests since I'm carrying around a bit of water weight.
    Paved climb (.4 miles) to trailhead where I usually just spin
    Hei Hei: 4:05 @ 258w
    SB100: 4:03 @ 246w
    Dirt climb, 7%, .8 miles
    Hei Hei: 8:56 @ 230w
    SB100: 8:46 @217w
    Dirt climb, 10%, .4 miles
    Hei Hei: 5:01 @ 236w
    SB100: 4:53 @ 230w
    This says a few things to me:
    #1. The Stages reads a bit higher than the P2M
    #2. The SB100 is probably more efficient than the Hei Hei, potentially even making up the difference in weight.
  99. #99
    SB100: 4:03 @ 246w
    SB100: 8:46 @217w
    SB100: 4:53 @ 230w
    Same tires?
    The scientific researcher in me says this would need to be repeated numerous times with the same power meter to prove any statistical difference between the two bikes but it is likely to be at least as efficient as the HH. I think Iím pretty much sold on the 100 being the replacement for my 4.5 for endurance events. The question is whether or not to keep the 4.5
  100. #100
    Is anyone looking for a more trail oriented bike and not concerned about weight thinking about running this bike with a 130 Fox 34? (And yes I know Nate Hills is running his Pike at 130)
  101. #101
    Mar 2015
    Quote Originally Posted by KineticFear View Post
    Iím definitely thinking about it. Havenít ordered my frame yet, but hope to in the next week or two. I already have a newíish Pike that I plan to use. It has the 120 air shaft in it now. But it came stock as a 130 and I still have that one. Iíll probably start at 120 and go from there.
  102. #102
    I would like to have an SB100.
  103. #103
    Sep 2017
    Fwiw my local bike shop just told me they built an SB100 for a client which came in at 23.5 lbs including pedals and 150mm dropper. XO1 build, Enve M525 wheels with DT240 hubs, DHF/Aggressor. Not sure if heíd been smoking something but thought Iíd share.
  104. #104
    Sep 2012
    I read my SB100 at the old cabin classic race last weekend, and was very impressed. This is the bike that climbs exceptionally well which I expected, but most importantly itís still fun on the down hills. My friends on hard tails were pretty miserable with the washboard flat sections along the coast. I didnít even notice them the bike pedal beautifully, when locked out it has Hardtail efficiency but I ran in trail or open the whole race. Itís easily as capable as an ibis Ripley, itís not going to replace a 140 mm trail or call mountain bike, but for most of the trails in the bay area itís a great, id even say a spectacular bike.
    Now here are my gripes:
    Hype or not I was a little annoyed that the step cast 34 in the 44 mm offset that is specd on yetis build Isnít available after market as I wouldíve much preferred to build a frame up. I even called Fox and it sounds like itís possible they may release a version later this year but they wouldnít officially tell me anything. So basically to get the fork the bike was designed around i had to get the full bike, I went with the Xo1 build. I donít love the XT brakes but theyíre a little better now that theyíre bedded in. They are better than the sram guide R but no where near the quality of the guide ultimates. I also find it a little annoying buying a bike labeled as an x01 build and finding it with a GX Eagle shifter. I probably should have read item by item but thatís what an X01 eagle build comes with, not a mistake. I much prefer how the X01 shifts to the gx shifter. Finally the DHF and aggressor are definitely overkill on this bike. I love the mixing of genres, but the minion is practically a downhill tire and the aggressor is suitable but also can never be confuse for cross country tire. These are two of my favorite tires for my High tower LT so I donít mind having an extra set around. I ended up putting a maxes icon on the rear and A Nobby Nic in front, both 2.35. This combo worked spectacularly on the loose over hard at wilder ranch for the old cabin. Bike seems to roll endlessly compared to what Iím used to.
  105. #105
    Jul 2013
    Agreed, I hate that most brands do this. I know that people see the rear derailleur and think thats the reason why shifting is better, but in reality, a nicer shifter is what makes a bigger difference.
    This is why on my custom build I have it reversed (GX mech, X01 shifter). There is only 15grams difference between the GX and X01 mechs.
  106. #106
    Hype or not I was a little annoyed that the step cast 34 in the 46 mm offset that is specd on yetis build Isnít available after market as I wouldíve much preferred to build a frame up. I even called Fox and it sounds like itís possible they may release a version later this year but they wouldnít officially tell me anything. So basically to get the fork the bike was designed around i had to get the full bike, I went with the Xo1 build. I donít love the XT brakes but theyíre a little better now that theyíre bedded in. They are better than the sram guide R but no where near the quality of the guide ultimates. I also find it a little annoying buying a bike labeled as an x01 build and finding it with a GX Eagle shifter. I probably should have read item by item but thatís what an X01 eagle build comes with, not a mistake. I much prefer how the X01 shifts to the gx shifter. Finally the DHF and aggressor are definitely overkill on this bike. I love the mixing of genres, but the minion is practically a downhill tire and the aggressor is suitable but also can never be confuse for cross country tire. These are two of my favorite tires for my High tower LT so I donít mind having an extra set around. I ended up putting a maxes icon on the rear and A Nobby Nic in front, both 2.35. This combo worked spectacularly on the loose over hard at wilder ranch for the old cabin. Bike seems to roll endlessly compared to what Iím used to.
    what pisses me off even more is the cassette! pure marketing scheme to sell lower priced bike and call a higer priced build! the x01 build is really the one they called x01 race build, another marketing naming scheme!
    btw, interesting about the fox 34 sc, Iíve been seeing some 44mm offset 36s for sale, mostly marked for the ripmo. I thought fox was releasing the 34 sc 44 and 51 at the same time, such a bummer for those who like to custom build from frame up!
  107. #107
    Mar 2011
    hmmm I have a fox 34 SC with 44mm offset on order... have you checked with your local shops?
  108. #108
    Sep 2012
    let me know what your shop says, because I called the Scotts valley office for fox since I live I live in the area and have ordered from them directly. They said the fox 34 stepcast is only available to yeti as a special run. The 51mm is being released later this month. He had no way to even order a 44mm in their system. It will be pretty annoying if I got the fox employee that didnít know their shit. Maybe your shop has a relationship with yeti and got the fork from them, id double check with your shop if you really want the 44. Since the stack is kinda high I have the stem all the way down, and feel I found the climbing sweet spot. I donít think I would want a 51mm offset fork as I think Iíd get a lot of front wheel wantering on steep climbs. Let me know what your shop says.
  109. #109
    Feb 2013
    51mm should ship this month from Fox. as for the 44mm offset this is what I got from Fox.
    just got information in our Friday meeting that we are adding a 44mm offset option for the 29 34 SC. This will not be available for a couple of months though, and I do not have a part number for the product yet.
  110. #110
    Mar 2011
    Quote Originally Posted by Noah Williams View Post
    Ya, pretty pissed overall. Found out last night Apparently Yeti has the rights to the first production run exclusively on the 44mm stepcast 34 so they are basically screwing everyone that doesn't want a complete bike. I might have thought about a complete bike if the sb100 wasn't spec'ed like a friggen enduro bike with 100mm of travel. It boggles my mind that FOX would put one of the best trail forks to come out in a while in a contract to where they can't sell to their customers for months till they fulfill yeti's orders... Guess I won't have a race bike at all this season, or I"ll have to look for a cheap hardtail to race in the meantime.
  111. #111
    Oct 2013
    Here's a dirty SB100 @ Allegrippis trails, semi custom X01, LOVE it!
    Yeti SB100
  112. #112
    Sep 2012
    Yeah lame right. I do t think itís a bad spec just not what Iíd choose. The only reason I can see this being an advantage for them is they can control the user experience with specifics like big tires (which I took off anyway), maybe their profit margin con components is bigger than I think. Great bike, kinda lame customer experience for anyone really particular about their gear
  113. #113
    Reputation: Dogboy's Avatar
    Or they could be like Pivot with the new 429 and not even offer a frame only option. I'm a frame buyer as well and if I was in the market for a SB100 I would wait until the 44mm offset SC34 was available.
  114. #114
    Jul 2013
    Quote Originally Posted by Dogboy View Post
    I'm happily riding my 51mm offset fork on my SB100. Handles great. I'll demo one with a 44 offset fork eventually but I'm in no hurry.
  115. #115
    Apr 2015
    Yeti makes more money selling a complete bike than a frame only. It's their way to keep their profits up.
  116. #116
    ejj
    ejj is offline
    Any thoughts on the 6K build vs the 7K build? Seems the extra $1000 gets you:
    Turq vs Carbon frame
    Factory vs Performance Suspension
    Carbon Bar
    Lighter Crank--X01 vs X1. Both carbon--X1 is their cheaper OEM only carbon crank.
    Save a pound in the frame/crank probably. Worth it? The Suspension upgrades are not that huge IMO.
  117. #117
    May 2016
    Does the 44mm offset SC34 give the bike a more slack riding position? I'm not familiar with how this offset changes the riding characteristics but certainly want to learn.
    I test rode the SB last weekend and I felt like I was riding over the handlebars the entire time and didn't feel like I was in the cockpit. It was the right size build, as I own other Yeti Mediums and that is what the SB was. What does the 44mm offset do?
    Chib
  118. #118
    Oct 2013
    Quote Originally Posted by ejj View Post
    Carbon Bar
    Are you going to fully enjoy the $5999 carbon or always think 'Wish I got the X01..." It's probably all that matters.
    Yeti SB100
  119. #119
    the 44mm has a part no. so look out for it later this year
    Explore 34 Step-Cast Bike Forks | FOX
  120. #120
    Mar 2011
    Quote Originally Posted by givemefive View Post
    if you actually go through the filter to pick the fork in question it only lists a 51mm offset part #. As soon as you pick "factory" and then "29" inch wheel, it blanks out the 44mm and only the 51mm option is available. So, technically no, this 44mm offset stepcast 34 does not have a part # on their website
  121. #121
    Jul 2013
    Just picked up my SB100, went for a quick spin...
    And Wow! Love it so far!!
  122. #122
    Quote Originally Posted by DUBIRLMTB View Post
    Looks great with the tan sidewall tires
  123. #123
    Jul 2013
    Looks great with the tan sidewalk tires
    Yea they look great with the Turq colour...
  124. #124
    Jul 2013
    I always get buyer's remorse when I see the Turq! Even though I love the matte black that I have.
  125. #125
    Jun 2010
    Not sure if this has been posted yet(i)... but, wow:
    If that is not a proper bike release video, I donít know what is. Short on time, watch Neer XC his way down a trail at the 6m mark.
  126. #126
    Handmade in Switzerland
    Reputation: maettu's Avatar
    According the Yeti website, the SB100 has a 190x37.5 metric shock. Would it be possible to add a 190x45 shock and have 120mm rear wheel travel?
  127. #127
    Quote Originally Posted by maettu View Post
    I don't see any 190x37.5 Monarchs anywhere...
  128. #128
    On his SB5 he used a Super Deluxe shock with a little more stroke (200x57) instead of the classic RockShox Monarch Plus (200x51), and so gets 140 mm instead of 127 mm travel out of the rear end.
    Quote Originally Posted by trailerpup View Post
    I wonder what size Monarch Nate Hills is running on his Enduro build. I don't see any 190x37.5 Monarchs anywhere...
  129. #129
    Mar 2011
    Welp... shes a bit portly but hoping shes fast enough to make up that lb vs other bikes in the cat. Now if there was only a fork available that was meant for this bike...
    Sent from my SM-G950U using Tapatalk
  130. #130
    Nh sb100.
    Attached Thumbnails Attached Thumbnails Yeti SB100 Discussion, Performance and build-img_1305.jpg
  131. #131
    Reputation: smartyiak's Avatar
    I have to say, the complete builds, out in the wild, are a damn fine looking bicycle!!!
  132. #132
    Oct 2013
    That is a 190x40 metric shock with a reducer spacer inside. If you want to test the limits that would be my first step, removing that travel reducer spacer.
    Yeti SB100
  133. #133
    Quote Originally Posted by k/dv View Post
    4.5 killer?!?
  134. #134
    manchvegas, Is that a large frame?
  135. #135
    Had mine for a few weeks and starting to get my fit and suspension dialed. Iím 5í10.5Ē and got a medium. Started with a 70mm stem but am down to a 60. Feels really good now. Couldnít imagine being on a large. Here she is post ride.
  136. #136
    Mar 2011
    Quote Originally Posted by wfl3 View Post
    Medium. As you can see have der hanger, axle with cardboard booty, and seatclamp installed.
  137. #137
    Aug 2015
    What size are the nobby nics you have on there? Beautiful bike and build!
  138. #138
    Quote Originally Posted by bnlv View Post
    2.35ís on We Are One Insider rims
  139. #139
    Jul 2013
    Did you get a professional fit or are you just tinkering with positions?
    I'm 5'11 riding a large and got my fit done yesterday. 50mm stem with 770mm bars was the recommendation after getting saddle position and height correct (although I'll prob go with a 55mm and 760mm bars).
  140. #140
    alh
    alh is offline
    Aug 2016
    Stunning, wooly88! I have a black as well, but ultimately didn't get all the XX1 group like you did. I may just get the cassette and chain for the bling factor.
    Looks sharp!
  141. #141
    Jul 2013
    I messaged him to see if I can get an answer.
  142. #142
    No, no professional fit but I know how I like my bikes to feel. With Yeti and most manufacturers I fall right on the cusp of being a Large. Iíve had numerous yetis and theyíve all been larges. I sold them all for various reasons but one common one was the bikes just didnít feel as nimble as I liked. Iím glad I went with the medium as the large with 29er wheels wouldnít have felt like I prefer.
    Regarding the fit tweaks I made on the sb100 I had my saddle pushed pretty far forward on the rails to keep the effective seat angle steeper. But this caused too much weight on the bars and was uncomfortable. I had to move the saddle on my last two bikes (Pivot 5.5 and 429 Trail). Prior to todayís ride I swapped the stem to a 20 and moved my saddle back about 5mm. Weighting feels so much better. And I didnít see any negative effects on climbing so Iím happy. The bike is a lot of fun. More capable than I expected but when I know Iíll be riding in some rough stuff I always have my Evil Wreckoning to party on.
  143. #143
    Reputation: Rom3n's Avatar
    Jan 2014
    Nice looking setup
  144. #144
    ejj
    ejj is offline
    That is a great looking bike.
  145. #145
    Jul 2013
    4.5 killer?!?
    Well, currently not missing my 4.5, the 100 is just so sharp and responsive, don't feel I need more suspension or anything slacker...
  146. #146
    Apr 2018
    If you wanted XX1 for your build, why would you not get the XX1 build from Yeit? In other words, what don't you like on the XX1 build offered?
  147. #147
    Thanks Udyr.
  148. #148
    Oct 2013
    Without trying too hard, Medium frames, with 300g pedals, custom X01 build, with wheels that are 100g heavier than the stock DT, and with tires in the 650-675g tubeless.
    Yeti SB100
  149. #149
    Mar 2011
    have a pic of the complete bike? Dropper? What fork? etc etc... thanks
  150. #150
    alh
    alh is offline
    Aug 2016
    Yes, I'd be interested as well. I have a small and pretty much stock everything and I'm coming in at 27.1lbs.
  151. #151
    Oct 2013
    This is base X01 with 34SC fork, 150mm FOX Performance dropper and Wolf Tooth remote, Schwalbe RoRo and TB tires. Maybe is the tires where the biggest difference is? Mine are 645g TB and 675 for RoRo, wheels with tape and valves are 1900g.
    Can't seem to be able to upload photos right now for some reason...#$#^%&%*
    Post #111 is the bike with different tires.
    Yeti SB100
  152. #152
    Mar 2011
    thanks for the info! My plan is to be running a 1400g wheelset on race day with 650g tires, carbon cranks etc.. so I'm hoping to be right at 24 or under. If I took the dropper off then definitely would be under.
  153. #153
    Oct 2013
    100%, dropper is over 600g alone, you can shave a pound off those wheels a well. But bike feels different with the skimpy tires (as you know), like it better with something beefier, but definitely not DHF like, this is not the bike for those tires.
    Yeti SB100
  154. #154
    Jul 2013
    Anyone have opinions on the Level brakes? (if they came on your build)
    I'm on XT m8000s and I'm just not a fan of them. The old XTs were way better.
  155. #155
    ejj
    ejj is offline
    Ha. I'm hoping to order my bike today--but I'm trying to decide between the lower builds--Carbon vs Turq. Both come with XT. I saw that as a decent choice over the Levels.
    Most people don't seem that excited about the Levels.
  156. #156
    Jul 2013
    Itís not that they are ďbadĒ. Itís just that the old XT were much better and more consistent. I loved my older Guide RS set until the calipers stuck in on a hot day.
    Doesnít seem like there are any XC options that people are really stoked about.
  157. #157
    I prefer the guide brakes over Shimano. The Shimano XTís are too grabby for my taste.
  158. #158
    ejj
    ejj is offline
    New XTR?
  159. #159
    Jul 2013
    I got an answer and Nate said that he was running the stock size. He probably worked with Rockshox directly to get the right size and tune.
  160. #160
    yes, he used to run a lyrik on his 4.5 at 140, that RS made for him.
  161. #161
    Jul 2013
    Have the SB100 a few days now and been out on it (almost)every day since!
    It's much more than its weight or amount of travel, Yeti have hit it out of the ballpark with this one!
  162. #162
    ejj
    ejj is offline
    Anyone been on the GX comp model yet? I just ordered mine. Kinda thinking about the next kit up with the Turq frame.
  163. #163
    Apr 2015
    Please tell us more.
  164. #164
    Jul 2013
    Good job!
    What dya wanna know?
    Well, anyways day 4, loving every minute of being on the 100, I may have to retire the 4.5 now! I've come from an SB75, a 5C and now to my favorite Yeti so far..
    The 100 is sharp, precise, I don't feel undergunned on the downhills or rooty rocky stuff, the 100/120 is perfect for the kinda trails I ride here. I wouldn't define the bike by the amount of suspension it has, it just rocks!
    I've a fairly basic build on it now, i.e. the wheels, brakes, forks are from my 4.5 before the upgrades so can't wait to get a set of lighter wheels, stepcast forks, and maybe a nice set of Hope brakes.
    Got back on a brand new 5C briefly during the week and I wouldn't swap the 100 for it at all!
    Though would like to add a 5C to the 100 and 45 collection soon!
  165. #165
    Apr 2015
    In my area, I ride east coast rooty Ricky stuff with a fair amount of techy puncy climbs and downs. We don't have any drops and they are less than 18 inches. Rock gardens with successive rocks really less that 10 inches. Some log overs. What do you think?
  166. #166
    Jul 2013
    In my cash, I ride east coast rooty Ricky stuff with a fair amount of techy puncy climbs and downs. We don't have any drops and they are less than 18 inches. Rock gardens with successive rocks really less that 10 inches. Some log overs. What do you think?
    Go for the SB5.5! ;-)
    No, the 100 will eat up the techy climbs, and cut through the techy downs, the 29er wheels make it easier getting through rock gardens, I think the smaller wheels(on a 5 or 6C) would require more upper body work! I have 2.4 Ardents on the 100.
    The grip on rocky/loose climbs is amazing and i'm no Cat 1 racer for sure! Lovin' all the PR's i'm getting on Strava in the last few days!
  167. #167
    Apr 2015
    No, the 100 will eat up the techy climbs, and cut through the techy downs, the 29er wheels(on a 5 or 6C)make it easier getting through rock gardens, I think the smaller wheels would require more upper body work! I have 2.4 Ardents on the 100.
    How does the suspension do with successive rock hits and packing up?
  168. #168
    Jul 2013
    Honestly feels more than 100mm... I've had a couple of Giant Anthems where you'd really feel like you were limited with the 100mm but not on the Yeti... Feels precise and more controllable with the Switch infinity of the 100...
  169. #169
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    I wanted to tune into this thread, so I'll jump in by adding....
    Had a recent 4 day trial in Moab on the Yeti 5.5. The SI susension feel was no joke. Aside from stiffening under braking it felt amazing, even with an air shock. I'm sure Yeti can mod the SI's feel from bike to bike but I've been on other Yeti's with the SI and they are similar. Super smooth off the top and perfectly progressive on hard hits, snappy under pedaling. Does all that carry over to the sb100, don't know, but I'd sure like to find out.
  170. #170
    Jul 2013
    Quote Originally Posted by Miker J View Post
    Had a recent 4 day trial in Moab on the Yeti 5.5. Does all that carry over to the sb100, don't know, but I'd sure like to find out.
    The SI is the reason I go for the Yeti, just like how it feels, haven't yet been on a 5.5 and would like one for higher rocky longer descents(with full or partial uplifts)...
    But for all day riding, XC Marathons with techy climbs and descents it would be hard to beat the 100...
  171. #171
    May 2016
    Just ordered an XX1 in large. All my other yetiís Have been mediums but for some reason the Medium Sb felt odd, but with a large I felt right at home. Will post pics when it comes in.
  172. #172
    Jul 2016
    My Super Bike 100 Build
    First ride day. Jazzed to spin and pump it. Heading to Santa Cruz. Will take some trail pics.
    24.4 lbs
  173. #173
    aka...appBLING72
    Reputation: aappling72's Avatar
    Hey man. I have a HTLT that i feel is a little more bike than I need for 85% of my riding. I'm seriously considering pulling the trigger on the SB100 since I'm starting to do more endurance type events. Love the HTLT, but I think I'd have more fun overall and be faster on the SB100. Your thoughts between the two? Obviously horses for courses, but it doesn't seem like people are giving up much on the SB, unless of course you're riding super chunky stuff all the time. Which I'm not. THx
  174. #174
    aka...appBLING72
    Hey Wooly what is your inseam? I'm 5'11 and typically try to ride mediums, but was on the fence about a large in this bike to give it a little longer wheelbase for stability at speed and run a shorter stem. What are your thoughts?
  175. #175
    Quote Originally Posted by aappling72 View Post
    32 inseam. Iím a tweener on most manufacturers sizing and am glad I went medium on the SB. I like a more nimble handling bike. Iíve had a large yeti sb5+ and sb5c and prefer the medium. If you prefer a more stable bike then go large. Iím running a 60mm stem with my saddle a tad forward on the rails.
  176. #176
    aka...appBLING72
    32 inseam. Iím a tweeter on most manufacturers sizing and am glad I went medium on the SB. I like a more nimble handling bike. Iíve had a large yeti sb5+ and sb5c and prefer the medium. If you prefer a more stable bike then go large. Iím running a 60mm stem with my saddle a tad forward on the rails.
    Thx for the input. awesome looking ride btw
  177. #177
    Quote Originally Posted by jpzeroday View Post
    24.4 lbs
    Nice ride. Curious what size youíre riding and how you got the weight down to 24 lbs. Iíve got a medium with all eagle and was 26 lbs and change. What wheels and what size tires are you running? Thatís the only area where I see a possible area to drop but canít imagine getting close to two pounds off. Iím running 2.35 Nobby Nics so thatís about a pound heavier than the 2.25 Aspens your running. My We Are One Insider wheels are about 1600 grams. Canít imagine lopping off 400 grams there. Maybe 200 with some XC type carbon hoops.
  178. #178
    Formerly of Kent
    Post every part on your bike. I can probably knock a pound off without a tire swap.
    Death from Below.
  179. #179
    Mar 2011
    Got her built up didnt bother weighing yet as Im running a pike 130 in it right now as the 34 SC is unavailable to us meer mortals. Havent been able to ride yet but the feel of the suspension is great... feels nice and firm. Running a med Im 5 10 with 31ish inseam and feel like the 50mm stem is too short. Thinking of going 60mm with 0 rise instead of the 50 with 6*. But unsure how the 34 SC will change the cockpit feel as my pike is 130mm with 51mm offset...
  180. #180
    Jul 2015
    ^^^Are the wheels Nox Teo's or Farlow's?
  181. #181
    Mar 2011
    Neither... older xcr-29s which is basically a teo. Ill be building a 1400g set of nox skylines for race day with some lightweight tires. These are more my trail wheels prolly 1500g plus 800g trail tires
    Quote Originally Posted by Chicane32 View Post
  182. #182
    Jul 2016
    Enve 525s
  183. #183
    Jul 2016
    Enve 525s
    Size medium.
    Key parts, in addition to wheels:
    Revive Dropper 185
    Enve Cockpit
    XTR Race Brakes
    Syncros 1.0 Carbon Saddle
    Aspen 2.25s
    XX1 Quarq Crankset
    ODI Vapor Grips (love these)
    Iím riding a ton this week. Will give feedback HTLT v this. I got it to pedal a ton. Backcountry is right. I have a HT LT and a Nomad 4. Probably selling the HTLT and making N4+SB100+Slate my quiver.
  184. #184
    17j
    17j is offline
    What is the main reason people are going with Yeti vs blur ( blur with added 120 fork)
    Seems the blur will cost less even with a second fork and weigh a pound less with equal tires and the 120 fork. (level playing and less weight and paying) If sounds combative, it's not, sincerely curious.
  185. #185
    Jun 2010
    ^ Suspension platform?
  186. #186
    I just jumped on this bike in the parking lot!! Holly shit!!!!! Getting one!!!!
  187. #187
    ejj
    ejj is offline
    Quote Originally Posted by 17j View Post
    As built, the Blur comes with a 32 fork, XC tires, lockouts, no dropper. All of these are things I would want to change.
    TBH, I think this bikes competes more with the Tallboy as a stout short travel bike. But I like the build kits better on the SB 100.
    But the biggest thing is the SI. I rode the 4.5 last summer and loved it.
  188. #188
    Quote Originally Posted by dgw7000 View Post
    Demo or friendís? And whoís Holly???
  189. #189
    Mar 2011
    Cuz I wanted a bike that would be fun as an every day trail bike and could swap tires and do an xc race. The blur with 120mm fork might be cool but is that recommended? What would the geo be? Just rode my sb100 for the first time and love the stiff feel of the rear suspension and also really liked how it sprinted up hills standing up (not much squat compared to asr).
  190. #190
    17j
    17j is offline
    what did you ride before and do you race at all xc?
  191. #191
    17j
    17j is offline
    Just as an FYI - 120 fork = same HT as sb100, acceptable by Santa Cruz per their site. The seat tube would be 73 vs 74 - Thanks for all the input.
  192. #192
    17j
    17j is offline
    All great input...curious how many plan to xc race vs spirited trail riders
  193. #193
    Mar 2011
    I do race xc and plan on racing the sb100 as well. I had an ASRC and won 2 sport master class championships last year on it. But, the asrc wasnt alot of fun on the trails I like to ride so I built up a pivot 429 trail. The sb100 is replacing both the 429 and my asrc and I will just have 2 wheelsets one with trail tires and the other with xc race tires (and obviously be a lightweight wheelset). Gonna give the sb100 a shot and see how it goes. Im just kinds bummed as feel my fitness is not as it was last year
  194. #194
    Jul 2013
    Plan to race the 100, but am more of a fatlete than an athlete...! :-)
    2018 - Yeti SB100
    2019 - Yeti SB150
    Previous bikes:
    SB75
    SB5
    SB4.5
  195. #195
    How about a little more 4.5 vs 100 comparison DUBIRLMTB
  196. #196
    Jul 2013
    I haven't been on the 4.5 since I got the 100!
    My local trails are generally not very high, like maybe 500 or 600m, plenty of draggy climbs, short descents, open loamy mountains, again not massive peaks..
    The 100 has pushed me to get some PR's on regular segments, it's such a brilliant climber, stiff responsive frame, even with fairly basic alu DT swiss wheels, and the standard Fox 34's..
    On the downhill sections it's sharp and responsive, again my downhill segments are short and snappy, 5 mins or so, rooty, loamy, don't feel undergunned at all...
    Maybe needs a bit more rider input on the rougher stuff, but who cares, you got to the top of the trail quicker!
    The standover height is much improved over the 4.5, means you can get lower on it when needed.
    Definitely think the 120mm is enough on the front, I will have no spacers under the stem to keep the front low..
    Got on a new 5C recently, felt smaller, bit softer, definitely like the 4.5 and 100 more..
    Must get back on the 4.5 soon, before I forget completely how it rides!
    2018 - Yeti SB100
    2019 - Yeti SB150
    Previous bikes:
    SB75
    SB5
    SB4.5
  197. #197
    Apr 2018
    So Yeti will allow my local non-yeti shop the opportunity to purchase a full bike, frame, or frame and fork for me. Now I'm just trying to decide if I should just get the bike with a build kit or build one from the frame up? I'd like it to be as light as possible, as I plan to race. Any thoughts/component suggestions would be appreciated. I'm considering the XX1 build with the XRC 1200 wheels. Thanks.
  198. #198
    ejj
    ejj is offline
    Those are some sweet wheels. Very light. Different rubber will save some weight for sure. Maybe a lighter dropper or no dropper.
  199. #199
    Apr 2018
    I'm guessing theres no saving money by building it up with XX1, and trying to better the bars, stem, dropper, and wheels that come on that XX1 build from them.
  200. #200
    ejj
    ejj is offline
    Some people go with light saddle, foam grips, Aspen or similar tires, Syntace Post or Lev Carbon dropper.
Page 1 of 12 1234511 ... LastLast
  1. Yeti SB 5.5c discussion
    By skinnybex in forum Yeti
    Last Post: 3 Days Ago, 10:09 AM
  2. Replies: 274
    Last Post: 11-21-2019, 07:33 PM
  3. Fox 36 Performance vs Performance Elite?
    By arm121 in forum Shocks and Suspension
    Last Post: 07-25-2019, 06:05 AM
  4. Dual beam, Twin XM-L New Cycle light from SPARK: SB100
    By Skyraider59 in forum Lights and Night Riding
    Last Post: 04-13-2014, 03:58 PM
  5. A Discussion of Tire Width, Weight, and Performance
    By The Boz in forum Wheels and Tires
    Last Post: 01-04-2012, 02:13 PM
Members who have read this thread: 368
