SB66c & Reynolds Carbon AM Wheelset Compatibility Issue- Mtbr.com
Results 1 to 2 of 2
    Reputation: ameybrook's Avatar
    Hello all,
    I searched and found nothing, so hopefully someone has come across and solved this problem before. I just acquired an NOS '13 SB66c. I planned to use my existing wheelset, which is a '12 Reynolds carbon AM with a 142/12 rear thru axle. Problem I'm having is the Shimano thru axle around which the frame is designed wont fit all the way through the hub. The "solid" part of the axle gets caught on the drive side hub cap, so it won't thread into the nut on the outside of the dropout.
    Anyone come across this before? Thanks!
    Why would you own 100 Yugos when you could own 1 Porsche? - Rumpfy
    Tribe Member
    Reputation: yetirich's Avatar
    I'm using the Reynolds AM wheels on a 13 SB66A and have had no issues. It's the stock rear axle that came with the bike. Can you take pics of the issue?
    Proud Tribe member since 1992 - looking for better singletrack to be ridden year round
  1. Reynolds Carbon wheelset experience
    By StumpyElite2010 in forum Cannondale
    Last Post: 05-02-2014, 10:15 AM
  2. Reynolds AM Carbon Wheelset
    By MarkMass in forum Wheels and Tires
    Last Post: 11-11-2013, 08:30 AM
  3. Reynolds 2012 XC Carbon Wheelset...
    By cohenfive in forum Wheels and Tires
    Last Post: 11-05-2012, 12:25 PM
  4. $999 Reynolds carbon 29er wheelset
    By danK in forum Where are the Best Deals?
    Last Post: 05-28-2012, 08:28 PM
  5. Reynolds carbon wheelset for $700
    By CCPHammer in forum Wheels and Tires
    Last Post: 01-19-2011, 03:56 PM
