Fox 32sc Rebound Knob (removable?)- Mtbr.com
Results 1 to 6 of 6
    bike rider
    Reputation: Lelandjt's Avatar
    On a lot of Rockshox forks the rebound knob is only held in by an o-ring and can be pulled off. Is that the case with the 32sc or is it bolted in place? It feels wiggly but I didn't want to pull too hard.
    Keep the Country country.
    I haven't worked on a Fox fork in a long time but last time I did, the rebound knob was secured with a small grub screw.
    Jul 2016
    Just FYI I have the same fork and mine was wiggling then fell off, had to send my fork to Fox for warranty new rebound shaft
    bike rider
    I called Fox and they said it threads into the rebound shaft. I was hoping it pops in and out so I could take it off once my setting is dialed. No dice cuz you'd then be in the full fast setting after unscrewing it.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    It's held on by a small bolt, 2mm or 2.5, can't remember which. You could take it off if you wanted, it wouldn't hurt anything. The knob is quite flimsy. The bolt won't affect the rebound as long as you hold the knob while you undo the bolt. This is kind of important to know because this is how you get at the lowers to do the oil-bath change, which is required fairly frequently with fox forks.
    bike rider
    Ah, I see it down there. The Fox rep made it sound like the knob threads into the rod. When I get the fork dialed I'll take it off. More weight savings!
    Edit: It's only 6g.
  1. Deleted
    By Lelandjt in forum Vacations & Destinations
    Last Post: 06-11-2017, 11:06 PM
  2. Replies: 1
    Last Post: 04-23-2013, 01:39 PM
  3. Stuck Rebound Knob - Fox Vanilla RLC
    By shopcat_cycles in forum Shocks and Suspension
    Last Post: 05-25-2012, 06:16 AM
  4. Fox rebound slow..adj knob wont turn?
    By Magnum Ti in forum Shocks and Suspension
    Last Post: 09-16-2011, 09:37 AM
  5. Fox DHX 4.0 Air rebound knob Jammed/Stuck
    By xjrides in forum Shocks and Suspension
    Last Post: 07-09-2011, 10:59 AM
Members who have read this thread: 4
