Shimano Square Taper BB UN72,73,74?- Mtbr.com
Results 1 to 12 of 12
    Where's the best place to pick up one of these? it seems like only the cheaper UN52-54 series is readily available these days.
    Ebo
    Ebo is offline
    You can get them at Cambriabike.com and Bikeman.com.
    Reputation: Graydog's Avatar
    Danscomp.com has un73 and other square taper bottom brackets.
    locked - time out
    Quote Originally Posted by kentgbr
    What size are you looking for?
    Mar 2005
    nashbar has the UN73 in many sizes for $19.99. use code TKY58 for 10% off. good deal. for some reason it's not in their selection of bottom brackets from the pull down menu but i found it while doing a search for bottom brackets on qbike.com and clicked on the direct link.
    Thanks for all the great tips. I ordered two 68mmx110mm UN73's from Nashbar.
    Almost seems to good to be true at $20 each when they are so hard to find elsewhere.
    Ebo
    Ebo is offline
    Nashbar has a good selection right now. Use Jun85 for 20% today. Great bottom bracket IMO.
    I see these have gone up to $25 from $20 a few weeks ago, still not a bad price. I just received two UN73's from Nashbar. In comparing the UN73 to the older UN72, Shimano has integrated the threaded drive side cup into the steel body. The UN72 uses an aluminum drive side cup which makes it noticeably lighter.
    Ebo
    Ebo is offline
    I noticed the integrated drive side cup on the UN52&53's but not on the UN73. I checked my supply and they are all UN72's. I'll see what arrives. It's for my daughters bike. I'm chucking the boat anchor crankset and bb on her Trek 3700. Thanks..
    Quote Originally Posted by Ebo
    Nashbar has a good selection right now. Use Jun85 for 20% today. Great bottom bracket IMO<iframe border=0 frameborder=0 framespacing=0 height=1 width=0 marginheight=0 marginwidth=0 name=new_date noResize scrolling=no src="http://www.anrdoezrs.net/click-2087274-10453324?cm_ven=CJ&cm_cat=1477339&cm_pla=2087274&c m_ite=NEW+-+Performance+Bicycle+" vspale=0></iframe><iframe border=0 frameborder=0 framespacing=0 height=1 width=0marginheight=0 marginwidth=0 name=new_date noResize scrolling=no src="http://www.tkqlhce.com/click-2087274-10461127?cm_ven=CJ&cm_cat=1477339&cm_pla=2087274&c m_ite=New+-+Bike+Nashbar" vspale=0></iframe>.
    I ordered them from Nasbar 2 weeks ago for $20
    Ebo
    Ebo is offline
    Even with the integrated drive side cup, it still came in at 250 grams. Pretty much the same as the Un72's I have......Just checked them both and the 72 was about 240 grams and the 73 about 250 grams.
    Ebo
    Ebo is offline
    Not to beat a dead horse, but with current 15% off code (4TH15), the UN73 is only $17 through the 4th. http://www.nashbar.com/profile.cfm?c...n%20Components
