WTB Asym i29 VS KOM Tough i29 ?- Mtbr.com
Results 1 to 11 of 11
    New question here. WTB Asym i29 VS KOM Tough i29 ?
    Hi all!
    I am currently using WTB Asym i29 rims, which I love, but WTB just released a new KOM Tough rim. The profile seems stronger (i-beam in the center), but the spoke holes are centered, VS the Asym rim which does't have the ibeam, but the spoke holes are offset, giving the spokes more even tension. The KOM Tough is even a bit lighter than the Asym, probably because it has no eyelets.
    Which one would make for a stronger wheel ? Stronger rim or more even tension ? Thanks!
    What? There's more?
    Reputation: tyrebyter's Avatar
    The KOM Tough is not an I-beam according to WTB, but has two ribs. It's also 45 grams lighter than the Async. You should try it and let us know how it works out.
    I should have written I-beams since they now have two beams instead of one (like my old Laserdisc FRs). From their website : "Our legendary I-Beam construction has evolved to further reinforce the rim with dual support beams that provide increased strength and stiffness for the world’s most aggressive riders. " That must be their strongest rim, but a few manufacturers are switching to offset spoke holes for their dh/enduro rims/wheels to get more even tension/stronger wheelbuild.
    I've had great luck with the Asyms, but I'll ask WTB to see what's their take on those. I'll probably try the KOM Tough on my next wheelbuild and will report back though. Cheers!
    Reputation: LyNx's Avatar
    I don't know about the "vs" part, but I can tell you for sure, that id you want a pretty damn bomb proof rim, the Asym is definitely it. I've built up 2 sets of wheels for myself using them and 3 sets for other guys and I haven't gotten back any reports from them onany issues. I like the Asym for the dishless build and not needing to have multiple spoke lengths. Just ordered a e13 TRS+ rim to try as a lighter alternative for my rigid which is currently running a Dually45, also for a better bead seat (price was too good to pass on), first non WTB rim I'll be using for a build in over 6 years.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Are the WTB rims pinned, sleeved or welded? I am interested in the KOM Tough. My MK3's are beat to hell & honestly do not care about weight.
    What? There's more?
    I think all WTBs are sleeved.
    WTB states that they are sleeved. All the WTB rims I've used so far have all definitely not been welded and I've never had an issue with any of them in any regards.
    Quote Originally Posted by ttchad View Post
    Rocks belong
    If the KOM Tough is truly ~50g lighter than the Asym, that's commendable. Agreed that the Asym is a reliable rim, so the KOM Tough has promise!
    Although, I've always wondered if the I-Beam really provides what it promises? When I kill rims, it's always at the sidewall (where the I-beams don't really support much). I typically ding them so bad that the rim sidewall is compromised (cracks when you try to bend it back out) or the rim flat spots on that side.
    I like 'em long, low, slack and playful
    Yeah, I was comparing the different rims yesterday from WTB and noticed that as well and w3as kind of dubious as to if they could be as strong as the Asym with the extra internal ribs taking material away from elsewhere on the rim and being lighter by 50g. If you compare the KOM Tough i45, it's actually lighter than the Scraper as well, really hoping someone who's ridden the Asym and Scraper builds and rides these new KOM Toughs and reports back.
    Quote Originally Posted by 06HokieMTB View Post
    Class Clown
    Reputation: dundundata's Avatar
    anymore thoughts on this?
    I have some i29 asym which are great and now looking at i35 asym or the tough rims
    I ended up buying a KOM Tough i29 for my new front wheel, and I'm still using the same Asym i29 on my rear wheel. I've never had to re-true or re-tension the Asym and it has survived pretty rough terrain at speed without a hiccup on a bike that had no place on those trails haha.
    I don't expect anything less from the KOM Tough but it's on the front wheel so it sees less strain. Building-wise, since it had no eyelets, I decided to use Sapim nipple washers under the brass nipples, but there is a lot of material where the spoke holes are drilled so I don't see any problem not running washers. The wheel built up really nicely and round like all the WTB rims I've used and ended up with even tension all around.
    The only slight annoyance is that they always have a slight hump at the joint, which can not be corrected. I've had 3 Asym i29 with this and my KOM Tough i29 has the same thing. It's mostly visual, but I wish the joint would be more subtle.
  1. WTB Asym i29 - unable to remove tyres
    By snoopy20 in forum Wheels and Tires
    Last Post: 09-07-2017, 11:49 AM
  2. Stans Flow MK3 VS WTB Asym i29 (29er)
    By pulsepro in forum Wheels and Tires
    Last Post: 09-06-2017, 04:00 PM
  3. Spoke length for WTB Asym i29 Rims
    Last Post: 08-24-2017, 04:39 PM
  4. optimal tire width to WTB asym i29?
    By Amit Ifrach in forum Wheels and Tires
    Last Post: 11-15-2016, 01:50 PM
  5. Stans flow mk3 or wtb asym i29
    By kikoraa in forum Wheels and Tires
    Last Post: 10-28-2016, 11:37 PM
Members who have read this thread: 40
