WT Maxxis Tires on 25.5mm inner width rims?- Mtbr.com
Results 1 to 3 of 3
    Reputation: R1ggs's Avatar
    Apr 2018
    New question here. WT Maxxis Tires on 25.5mm inner width rims?
    This question has been going around some threads here, but I haven't seen definite answers so far, especially for the case of my rims and terrain type, particularly.
    I have Stan's Flow Ex 25.5 inner width rims on the front, and SunRinglé Inferno 25.5 inner width rims on the rear.
    The terrain pattern in my local trails is mostly gravel/loose/loose over hard and a few rocky parts.
    So I am looking for lower pressures in order to get a better grip and traction.
    I currently use a Minion DHF 2.3 up front and Michelin Wild Grip 2.35 in the back, but as they are getting worn I'm planning to switch to DHR II 2.4 WT rear and DHF 2.5 WT front.
    Will these rims be a bottleneck for the performance of these tires? Will I be able to ride just fine with them at lower pressures? I'm 5'11, 170 lbs btw, if that matters for this.
    Reputation: kevin267's Avatar
    Mar 2011
    I think they're fine, I ran 2.5 dhfs on Dt Swiss ex471 (25mm internal width I think?) and liked it!
    Reputation: MSU Alum's Avatar
    I'd say get them and try them. If you want to spend the money and take the weight hit, you can always get some cushcore inserts and run really low pressure. My understanding is that the inserts also help prevent fold over at low pressures in addition to protecting rims.
  1. Maxxis WT tires on 29 inner width rims?
    By garcia in forum Wheels and Tires
    Last Post: 04-18-2018, 05:35 PM
  2. Replies: 11
    Last Post: 05-29-2016, 08:20 PM
  3. Replies: 4
    Last Post: 02-10-2016, 07:54 AM
  4. Max reasonable tire width for 25mm inner rim width?
    By noobbiker888 in forum Wheels and Tires
    Last Post: 07-31-2015, 06:21 PM
  5. wiiiide inner width rims? What's out there?
    By 300hp in forum Downhill - Freeride
    Last Post: 10-08-2012, 02:10 AM
Members who have read this thread: 33
