• 02-24-2014
    oldranger
    Wide Rims? Don't believe the hype...
    Hi Folks,
    After researching the subject of rim specs for DH wheels, I find that wider rims are becoming increasing popular. News Flash, right? No, not really, but I have begun to wonder just how much of this is simply hype. Let's be honest and see if there are some facts we can look at before I even give my opinion:
    1) Many of the most popular tires with consistently good reviews (i.e. Maxxis Minion DHF) have casings that were designed before manufacturers were building these 'wide' rims with >25mm internal width.
    2) Many of the top racers use rims with less than 25mm internal width.
    Really? You mean the really fast guys don't ride on wide rims? Why not? I know from personal experience that 'wide' rims feel different, but honestly I don't know if they make me faster. So: I think it is all hype. My guess is that the ideal rim width for DH tires on the market today is 23mm - 25mm of internal width.
    2013 winning riders
    1. Steve Smith Easton Havoc 23mm
    2. Greg Minnaar - Enve DH 21mm (30mm external)
    3. Aaron Gwin DT FR600 24.9mm
    Ive ridden these rims on Freeride, DH Racing and DS:
    1. Crossmax SX 21mm
    2. Atomlab Standard Issue 21mm
    3. Atomlab Pimp2 26mm
    4. Specialized Roval DH 23mm
    Unrelated, but Ive ridden DT Swiss m480 for All Mountain
    DT m480 19.6mm
    My opinion: I notice a different feel when moving from 21mm to 23mm rims (internal width) and I up the psi a bit on the rearbut I don't know if it is actually better traction or just a different feel. My experience is far from a controlled experiment. I don't even really notice the different from 23mm to 26mm.
  • 02-24-2014
    bholwell
    A greater difference will be felt when running thinner, AM or XC tires at lower pressures.
    Yes, I designed the DHR2 and the HR2 on a 23mm internal width rim, but the difference in profile going from 23mm to 28mm internal isn't much.
  • 02-24-2014
    nvphatty
    we are not all racers or wanna be racers but mere plain recreational riders by in large so much of what you posted does not apply nor will effect the vast majority.
  • 02-24-2014
    meltingfeather
    that's a broad proclamation on a pretty weak basis.
    here's an idea: why not ride what you like and what works for you, regardless of what Smith and Minnaar are riding?
  • 02-24-2014
    FastBanana
    I can tell the difference between a 21 and a 30.
    However, for I run 21mm on my AM bike. Its does just fine with beefy tires, but i could run a lighter tire on a wider rim. DH is much different than trail riding. They run much stronger but heavier tires that really dont care what rims they are on. Also, going very wide can squared out the profile of the tire, which is a bad thing when you lean the bike 60+ degrees
    Sent from my LG-LS995 using Tapatalk
  • 02-24-2014
    edubfromktown
    We all have different objectives so whatever works...
    I noticed a difference between running 19mm (Stan's 355) and 21.?mm (Stan's Crest) internal width rims with the same tires mounted on them.
    I have 3 sets of "28mm" rims (~23 ish mm internal width) as well and do not notice as much of a difference with the same tire mounted on them as compared to the Crest's. All of them are setup tubeless.
    I even run a 3.0 Knard 120 tpi front tire mounted on a "28mm" rim (rigid single speed 36x18). It makes the rim look like a road wheel with all the tire volume. Quite effective cushion (@ ~12 psi with a bit of added weight and +2-3 cog teeth to pedal it on the climbs I was doing with a 2.4 front tire/15t cog).
  • 02-24-2014
    mtnzj
    Originally Posted by oldranger View Post
    2013 winning riders
    Don't forget these guys have to run their sponsor's equipment, and many of the mainstream manufacturers have not gone to the wider rims (partially due to old rim safety specifications).
    Additionally, the world's top pro riders would kick ass on most any bike/setup you stick under them.
  • 02-24-2014
    evasive
    I've never seen anyone claim that wide rims are faster, so I don't see the relevance. The benefit most often cited is the more traction through the use of lower pressures. I doubt any DH racers are willing to risk using lower pressures. On the odd occasion I enter an enduro race, I definitely add pressure to my tires.
  • 02-24-2014
    oldranger
    Thanks bholwell! This is the kind of information I was hoping to get out of this thread!
    Note: I didn't intend this to be a discussion on what 'I liked to run' or what 'is fun for me' since that doesn't really matter to you (folks). I hoped to initiate (or instigate) a debate on the actual performance value of wider rims. I haven't found (anywhere) where an engineer or product team has substantianted that a rim wider than 23mm (internal) helps improve riding or how a tire provides traction. On the flip side I see that wider rims increase material and weight, or they require expensive materials....all of which are a drawback in my mind.
  • 02-24-2014
    oldranger
    I totally agree. But I was honestly surprised when I researched what they are riding - and learned they are NOT running the trendy wide rims.
    Look folks. My bike is not spec'd with what the racers are using simply because it is what they are using. I have Atomlab wheels, a Marz 888 fork, low-end cranks, a heavy-a## seat, and the list goes on...but if I am going to spend money on improving my bike it seemed like wheels were the way to go. So I started looking at what credible riders are winning on.
  • 02-24-2014
    FastBanana
    Re: Wide Rims? Don't believe the hype...
    Wide rims dont directly provide traction, they enable lower pressures that provide more traction.
    Do you really notice 50g in a rim? Tire choice is almost infinitely more important.
  • 02-24-2014
    oldranger
    Thanks for your points on how rim width can influence psi (and traction). I don't recall mentioning 50g, but for the sake of discussion:
    I run a 630 gram Atomlab Pimp2 rim because I was encouraged to build a wide, tough rim for DH. If I go with a smaller rim profile I can get closer to 500g. The top end Norco, Devinci and Specialized DH bikes are spec'd with rims that weigh about 500g and are close to 23mm internal width. (I think; just picking from some brands)
  • 02-24-2014
    Berkeley Mike
    This has been said about many "advancements" in bike technology. The challenge is that measuring it's effect is elusive. Its sort of like taking 20 grams off of a derailleur; an incremental step I may not even feel. Add to that I'm just trying to stay upright most of the time.
    But, when you take a look at an entire Groupo the weight difference adds up. And, seen from my 1988 Rigid 6 Speed Rockhopper with cantis, all those incremental steps add up, too.
  • 02-24-2014
    FastBanana
    Thats the difference between an Arch and a Flow rim.
    630g rim is just plain overkill. There is a reason those bikes are spec'ed with 500g rims. Its a great balance point, and 23mm is by no means a thin rim. At that weight/width, you have a very strong wheel.
  • 02-24-2014
    Deerhill
    I find rims over @23-25mm internal width start to take a heck of a lot more hits on rocky trails (from the volume and also dings to the finish)
  • 02-24-2014
    deerock
    love what is said here. this forum consists of recreational riders...not many pros if any. Though it's great these guys do so well, etc. I couldn't give a wild smelly crap about who rides what. I want good wheels that feel great on my ride....and I'm a damned good rider. But I don't pretend to be a pro or anything similar.
  • 02-24-2014
    Bike Whisperer
    I ride a full rigid, what pro DH and FR riders run means jack schitt to me (and most riders).
    My experience with single ply tires is that big volume tires on narrow rims roll when cornering unless I pump them up harder than I prefer. So I like wider rims with big tires that I can run down to ~18psi for traction and some cushion.
  • 02-24-2014
    MTBMILES
    I personally like wider rims for running lower pressure and getting better traction and less tire squirm.
    Are you going to tell me this is all in my head?
  • 02-24-2014
    blcman
    ^ This! Bike Whisperer wins the prize for best answer!:cool:
  • 02-24-2014
    FastBanana
    Its great for running over chihuahuas
    ....with less tire squirm
  • 02-24-2014
    dirtrider76
    Meh, my wide rims are awesome. I dont care what pro's run, I'm not a pro.
  • 02-24-2014
    oldranger
    I dunno. My hypothesis (for the sake of debate) is that the ideal rim width for standard 2.3-2.5 width DH tires on the market today is 23mm - 25mm of internal width. I looked for any shred of evidence to the contrary, and didn't find any. Maybe when tires are squirming psi is sub-optimal, and addressing it with wider rims doesn't solve the root of the problem.
  • 02-24-2014
    meltingfeather
    lol... when you're leaning your bike over 60(+) degrees... good one. :skep:
    also... tire profiles are round... always.
  • 02-24-2014
    meltingfeather
    That being pros' equipment choices?
    Just out of curiosity, how did you arrive at your claimed optimal rim width?
    And what is sub-optimal about riding a tire pressure that works? Isn't optimum tire pressure totally dependent on the circumstances, including rim width, or have you also figured out optimum tire pressure for everyone on every bike?
  • 02-25-2014
    oldranger
    To your question: I based my hypothesis largely on the observation that the majority of the major manufacturers spec their best DH bikes with 23mm-25mm rims, and many of the DH racing teams use the same. I had no access to wheel manufacturer test data. They do. A hypothesis is a speculative guess that has yet to be tested.
    That said, after a day of interesting comments, Id like to restate my hypothesis because I think some of you missed it: the ideal rim width for DH tires on the market today is 23mm - 25mm of internal width. I started this thread in hopes there would be attempts to prove or disprove itwhich in turn, help me make a good decision on a pair of wheels for my DH bike. I recognize its not a well justified hypothesis, and the word ideal oversimplifies thingsbut the point Im making has not been disproven in this thread. On the contrary, a tire designer seems to (indirectly) support it and that is the only professional opinion so far on the thread. Maybe I should try to elaborate a bit on what I mean by ideal: I mean compatible with, and works optimally in conjunction with a conventional DH tire (2.3-2.5 DH casing) to provide the best possible traction for the rider without adversely impacting speed or durability. Ideal for DH is not: wide enough to enable dramatically low psi so the rider doesnt perceive slip on rocks and roots and such. Or worseso the rider can sit down comfortably.
    Lets not dumb this down. I threw this topic out in a forum dedicated to Wheels & Tires. This discussion isnt about preference, or Recreation vs. Racing, or how something feels. I consider myself a recreational rider. But frankly folks if you are a recreational rider sitting on a $4-8K DH bikeyoure sitting on a sophisticated, carefully specd piece of equipment. And most of you try to go fast (I hope). Me personally: I dont want to ignorantly do the equivalent of throwing a big ass set of Dubs on a BMW M3 just because of some hype around WIDE is BETTER and manufacturers like I9, Atomlab, Spank, etc. wanting to sell us those things. It is a common play to penetrate a market with gimmicky products that owners cant find as OE on some car or truck or gun or bike under the premise it is better.
    Here are the observations I have that seem to contribute to this topic.
    Major Manufacturer DH Bike Spec:
    Trek Session FR600 (24.9mm)
    Devinci Wilson, Norco Aurum LE, Transition TR450 Easton Havoc DH (23mm)
    Specialized Demo 8 Roval 30mm external (usually means about 23mm internal)
    GT Fury E13 LG1+ DH (23mm)
    Giant Glory 0 DT Swiss EX500 (20.7mm)
    Successful Racing Team Rim Choices:
    Steve Smith Easton Havoc (23mm)
    Aaron Gwin DT Swiss FR600 (24.9mm)
  • 02-25-2014
    oldranger
    Absolutely. Tire pressure is the variable that the rider should change based on conditions. No. I haven't made any claims about psi, nor have I stated that I've figured out anything.
  • 02-25-2014
    evasive
    Fine, but your OP wasn't carefully caveated and specific like your last post. It's easy to miss your point when you don't make it. The OP was a broad claim about wide rims being all hype, and used a fairly small sample based on pro DH riders as the supporting evidence.
    Your OP mentions that you're looking at DH rims, but that's the only hint that the discussion of rim width was intended to be limited to that narrow application. Besides, most of the wider is better talk that would be interpreted as hype comes from the trail-AM market where you have Stans and WTB and Syncros playing.
  • 02-25-2014
    MTBMILES
    I have noticed wheel sizes changing and bikes have disc brakes, droppers and FS. I have a feeling rims widths are also evolving.
  • 02-25-2014
    oldranger
    Originally Posted by evasive View Post
    Fine, but your OP wasn't carefully caveated and specific like your last post. It's easy to miss your point...
    Progressive elaboration. And c'mon...the acronym "DH" is in my first sentence. Now do you have something to contribute that disproves my hypothesis Mr. Evasive, or are you just looking to easily increase your post count with a debate? Please do some research.
    OK, I hadn't thought about where the hype was coming from. For what its worth, I bought Stans Flow EX for my son's DH bike...believing the hype applied to DH. The 2.5 Maxxis Minion DHF tire profile on that rim is absolutely different than it is on my Crossmax SX or My Atomlab Standard Issue. Which is better? (I don't know, hence my hypothesis and provocative posts and title)
  • 02-25-2014
    MTBMILES
    Have you not ridden the different widths to come up with a conclusion based on riding?
  • 02-25-2014
    oldranger
    Yes, but as I mentioned in my original post...I couldn't get to any conclusion about what is really faster. I've ridden rims from 21mm 26mm (internal width) in many places across North America, as fast as I can go. But my opinion isn't worth much so I started looking for credible information.
  • 02-25-2014
    MTBMILES
    I think better traction equals more confidence leading to faster times. That is my conclusion based on my riding.
  • 02-25-2014
    meltingfeather
    You know what would be a much better basis for a decision than theoretical arguments on the internet? Finding some wide rims to borrow/demo and see what you think.
    I think you have misinterpreted his comment somewhat.
    Hypotheses are part of the scientific method. You aren't using any scientific methods. You are attempting to confirm your bias by searching out anecdotal evidence that you interpret to support your idea. No isolation. No control. It is meaningless.
    You can't prove whether something is "all hype" or not. First, what does that even mean? Second, you'll never have enough data to say anything statistically significant, and even if you were able to put all that together, it would not tell you what your individual experience is going to be on any given rim width. That's why it makes sense to cut all the BS and just ride some wide rims and see what you think. It would also be a whole lot more fun, unless posting here is more fun to you than riding.
    It started off dumbed down. Why change now? :arf:
    At some point you have to realize that your, from a scientific standpoint, totally hack efforts at really "figuring something out" aren't going anywhere. Riding a bike for the sake of it is about doing what works for you, which riding the bike will tell you. Doing otherwise is posing.
  • 02-25-2014
    oldranger
    Mr. Feather,
    Do you have some objective observations or proposed investigation that constructively adds to this? Do you suggest a specific rim or rim width based on your own observations?
    This is a hypothesis, not a theory, so you can back down on "start doing some science" rant. I don't pose. I'm not a professional I don't have a good opinion. Don't get so easily bent out of shape on how I instigated folks to contribute to this thread
    A hypothesis is defined as: a supposition or proposed explanation made on the basis of limited evidence as a starting point for further investigation.
  • 02-25-2014
    kiloman
    Word. :thumbsup:
    Based on feedback from others and reflection on my personal intended use and preferences I decided on a set of Pacenti TL28 29er rims to replace the stock wheels on my 2009 Giant XTC 29er 1.
    I don't know if I'd go so far as to call it "hype" but I would say they lived up to my expectations based on other users feedback. (IMO WIDE carbon rims are "hype.") The Pacenti TL28 29er are reasonably light. I can run low pressures with them (20psi F and 22psi R on my pump) and haven't pinch flatted on them, with tubes (passed plenty of people in the Shenandoah 100 who did pinch flat on the rocks for whatever reason so I know my setup works for me). And at those pressures they offer good tire stability. But this is only my second set of MTB rims, so I have no valid comparison. All I can say is they work for me, other users experience might be different based on their intended use, riding style, and priorities. So do your research and make an informed decision.
  • 02-25-2014
    oldranger
    OK. Done. I have two seasons of DH racing on a set of Atomlab Pimp2 rims with 2.5 Minion DHF front and rear; sometimes High Rollers. I have not substantially changed my approach to psi while using these rims. These rims have a 26mm (WIDE) internal width
    I have 6 days of sustained riding at Whistler on the same bike, but with rims that had a 23mm internal width.
    I can't tell the difference. Should I stick with a 23mm rim or go with a wider one? if so why? If you want to make this about me (like your attacks on my words in this post)...I'm 190-195lbs riding weight, I ride fast and want to go as fast as I can. What rims should I consider?
  • 02-25-2014
    oldranger
    (This is fun by the way - I do appreciate the responses. There have been some meaningful comments) (Thank you)
  • 02-25-2014
    meltingfeather
    Mr. Feather,
    Yes. Riding will tell you all you need to know about what equipment choice will work for you.
    I know what works for me, which is of no use to you.
    Not at all bent... I just offered my opinion, which is what you asked for. Don't like it? Don't heed my advise.
    Cute. I know what a hypothesis is. I'd say, as others have, that what I ride and for that matter what sponsored pros ride is of little value in determining "optimal" for you.
    Good luck :thumbsup:
  • 02-25-2014
    deerock
    there's too much time on your hands. go ride your bike. ;)
  • 02-25-2014
    HoJo
    Sure seems like oldranger=Traildoc. For those who didn't follow the Az forum Traildoc was an avid rider, trail-builder and troll. Who was temporarily banned from the local Sedona forest and then banned from MTBR. There is way too much good information on this forum let's keep the good exchange and forget the trolls.
    hojo
  • 02-25-2014
    dbabuser
    Bike manufacturers spec bikes to fit the average rider. It's up to you to figure out where you fit in relation to the average. In my experience, being heavier and more aggressive than the average rider, a wider and heavier rear rim lasts longer. Is 600 grams overkill? Not for me (185 lbs, former expert dh racer), unless I want to rebuild the rear wheel 1 or more times per season.
  • 02-25-2014
    oldranger
    hojo
    Still hoping for someone to give specifics on rim widths outside of the 23mm - 25mm range for DH.
    Too funny. Trail doc? Really? I'm just a 42 year (Old) guy who has been a Ranger (Ranger) Old+Ranger = OldRanger. You guys really stink at science and math.
  • 02-25-2014
    oldranger
    Thanks. Do you run a lighter rim in the front? I've considered that option.
  • 02-25-2014
    dbabuser
    I've had good luck w/ 500g front rims on my dh bike.
  • 02-25-2014
    oldranger
    Thanks dbabuser. This is helpful, I haven't tried a 'staggered' setup...but wondered if it would be a good approach for DH riding given the typical weight distribution front/rear the rider has. It's also helpful for me to have your benchmark for a 185 pound rider - that's about where I am. I have seen others with this approach
    For anyone (like me) who may be new to this topic of rim widths, or rim design in general - let me try to elaborate on the relationship between dbabuser's observations on rim weights and rim widths (simple, I know). Generally speaking rims with 21mm internal widths can be built in the 500g range (i.e. DT Swiss EX500). Rims with a 25mm internal width can generally be built in the 600g range (i.e. DT Swiss EX600). I use the DT Swiss example since they are kind enough to put the rim weight in the product name.
    Disclaimer: this doesn't always hold true. One contrast is the Stan's Flow EX which has a 25.5mm inner width, but only weights 500g.
  • 02-25-2014
    92gli
    You keep saying faster. Its not always about "faster" for non-racers. I like the wider trend because the tire is more stable at lower pressures.
  • 02-25-2014
    leeboh
    I don't run 26er downhill tires. I do however run 29er 2.4 tires on 35 mm ID rims and they are awesome at lower pressure and maximum traction. Wider = better for tubeless, YRMV.
  • 02-25-2014
    Ilyam3
    With the modern frames and drive for short chain stains with bigger wheels (27.5) that are sometimes stuffed in smaller frames (HDR ) the width of the rim can be a problem with the fit in the rear. Manufacturers already spec narrow 2.2 tires for tight clearance so going wider might not be an option
    On the other hand I agree with op For modern 2.4 -2.5 tires the internal width of 23-25 mm is optimal for weight and performance. And I can run low pressures on ust rims of that width too , so why carry extra weight for 35-40mm internal big rim. That's unless we go to 2.7 or 3.0 tires , oh wait - that's fat biking :)
  • 02-25-2014
    nvphatty
    no thats not close to fat biking, 3.8 begins fatness. When i build my next full squish AM bike it'll use 35mm blunts with the 26" 2.75 dirt wizards which will equate to 27.5 circumference wise.
  • 02-25-2014
    brimorga
    Carbon rims are lighter than tires. So use a wider rim and a more narrow tire to get a similar effect as a fat tire and a narrow rim for less weight.
    Simple.
  • 02-25-2014
    ryanxj
    Road bikes.
    Motorcycles.
    Cars.
    Zamboni.
    Wheelbarrows.
    Unicycles.
    Wheelchairs.
    Space Shuttles.
    GoKarts.
    Mars rover.
    Trailers.
    Hand trucks.
    Lawnmowers.
    Aircraft.
    Strollers.
    Tractors.
    R/C anything.
    Golf carts.
    Heavy equipment.
    ATV's.
    UTV's.
    Monster trucks.
    DID I MISS ANY?
    NOT ONE of these rubber tire equipped machines utilizes a rim width that is narrower (by much of a margin) than the tire it is supporting... COINCIDENCE?
    Why believe the hype when you can look at the facts?
    Oh, and dont believe the hype, 9ers dont ride faster and suspension will actually slow you down from all the pedal bob....
  • 02-26-2014
    oldranger
    Originally Posted by ryanxj View Post
    DID I MISS ANY?
    Yes, I think you missed one: Motocross. I don't have one, but those machines still use tires with a rim width that is narrower than the tire it is supporting. It looks like the margin is greater on the front. But I'm way out of my knowledge 'base' on this MX comparison.
    But you could also add one to your list: BMX Bikes. Those tires seem to be fairly close to the rim width. Wait, let me clarify: those 20" tires that roll on hard pack or paved dry surfaces have tires with a casing width close to the rim width. Hmmm. I wonder when BMXers will go to full suspension 29ers cause they ride faster?
    Your comments where thought provoking - so thanks for that!
  • 02-26-2014
    oldranger
    Link to another post on here that has some relevance to this subject:
    http://forums.mtbr.com/wheels-tires/...th-756818.html
  • 02-26-2014
    oldranger
    I found some more related posts
    Try this one:
    http://forums.mtbr.com/wheels-tires/...de-882258.html
    A quote from that thread:
    Originally Posted by Norman Clydesdale View Post
    As the rim's interior width increases, you'll see different performance and appearances in your tires. Basically, the same tire will sit and perform differently on a narrower rim vs an even slightly wider rim...On a 25mm inner width rim, the tire sits noticeable squarer and hooks up better in corners in all conditions. I can run it tubeless at 32psi in the front and 36 in the rear and not worry about burping or dinging the rim. If I run just a few psi lower in a tubeless set up on the 25inner width rim, I'll ding and flat spot the rims.
    So, you'll need to factor in PSI, tire size, and rim width in to the equation. Depending on tire choice and preferred PSI, I think you can go too wide in rim width. In my experience,25-23mm inner width seems to be a good spot for many trail tires in the 2.4-2.3 range. Just a few mm increase in inner rim width can produce positive performance results.
  • 02-26-2014
    edubfromktown
    Try this one:
    32 / 36 PSI is quite high pressure for a large percentage of riders ... Norman Clydesdale implies 200+ lb. rider and based on what he stated, there wasn't much room to lower the tire pressure without dinging the rims.
    Some other factors to consider besides PSI, tire size and rim width:
    Tubeless system
    Tire sidewall thickness
    Rider weight
    Riding style
    Terrain
    I am 195 lbs. and ran 20 psi F / 25 psi R "semi-aggressively" on Stan's 355 rims with TLR Schwalbe Racing Ralph tires (2.4 front / 2.25 rear) setup tubeless w/ Stan's goo and rim tape. I manged to burp the front once on a severe down and up that was off camber (with a bit of a turn). That was the only time I've ever burped a tubeless tire in years of riding on them.
    I can run 17 PSI on the front with a wider Stan's Flow rim running with a Schwalbe Nobby Nic snakeskin 2.35 tire. I typically run a Racing Ralph 2.4 a few PSI higher on the front...
    My approach to setting up appropriate tire pressure is:
    Front- start in mid 20's, drop 1 PSI at a time and ride a bit until handling in significant turns becomes squirmy, then add 1-2 psi.
    Rear- start around 30, drop 1 PSI at a time and ride a bit until I detect something close to a rim hit when riding over rocks/roots at a moderate pace, then add 1-2 PSI.
  • 02-26-2014
    Saul Lumikko
    People, you are forgetting one important reason to run wide rims.
    The sheer surface area you get for flashy colors!
  • 02-26-2014
    ryanxj
    What part of 'motorcycles' excludes MX? and I'm not sure on bmx stuff myself, but if they are using narrow rims, i would have to assume that its purely a matter of shaving grams, as is likely @ the top level of dh racing. Not to mention, if assume that the smooth groomed nature of a bmx track allows for highish pressures, lessening the benefits of a wider rim/tire interface...
  • 02-26-2014
    googas7070
    I guess this thread means my Sun Rhyno Lites are back in style!:thumbsup:
  • 02-26-2014
    Bike Whisperer
    Ding, ding, ding...winning
    1994 called and wanted it's wide rims...just need some nice green hubs
    Attachment 872649
  • 02-27-2014
    LB412
    Most of the expansion has to do with the relatively recent tubeless tire trend. Burping will occur more frequently on older rim tire combos because neither were designed for the task. Primarily because a narrow tire base generally leads to a taller thinner tire when inflated. Think narrow at the bottom and wide at the top... Equals more stress on the bead in hard turns or landings. By widening the base you theoretically reduce flex on the tire and therefore the bead. That said we are heading into marketing overkill territory. My 24.9 internal works great.
  • 02-27-2014
    oldranger
    Originally Posted by LB412 View Post
    Most of the expansion has to do with the relatively recent tubeless tire trend...By widening the base you theoretically reduce flex on the tire and therefore the bead.
    Thanks for your contribution.
    This gets me thinking (or wildly speculating as some have written). As bholwell noted early on in this thread - he designed DHR2 and the HR2 on a 23mm internal width rim. He also stated that "going from 23mm to 28mm internal isn't much". I'm pretty sure those tires are 2.4 width; they also have Tubeless Ready casing options. Anyway, I'm just reiterating the point that a tire is designed with a specific rim width that is optimal.
    Taking LB412's point: think about a tubeless rim manufacturer (like Stan's for example). They need to get a majority of the TR tires on the market to simply hold air well...even before they start to analyze how tires function in other ways on their rim. Unless a tubeless rim manufacturer are working together for an ideal tubeless wheel (rim+tire), it's not unreasonable to question whether they are building rims outside of the ideal width of most tire casings...simply to get them to hold air better.
    So I have an idea: let's look at one of the newer DH tires (since the OP is about DH tires). Let's try the new 2014 Schwalbe Magic Mary 26 x 2.35. Does anyone know what rim width that tire was designed to work with?
  • 02-27-2014
    oldranger
    By the way, based on information I've gathered online and input on this thread: for my new set of DH wheels I'm considering a DT Swiss FR600 rim (25mm wide) and trying a tubeless ready tire like the 2.35 width Magic Mary. If I had the courage I would go with an EX500 front rim...
    I'm used to running relatively high pressures. I'm 185lbs without gear and I run 28-30psi front and 32-34 psi rear depending on the track. Last two years I used 26mm wide AtomLab Pimp2's with DT Champion spokes, Minion DHF, and an XC Tube (Heavy!!)
  • 02-27-2014
    Deerhill
    haven't tried magic mary..
    Muddy Marry was one of my fav fronts, good girth and worked great on a 25mm rim. Wouldn't surprise me if some of those Schwalby were designed w/ 25mm or wider rim in mind, casings are nice size
  • 02-27-2014
    changingleaf
    Like bholwell, tire designer said "the difference in profile going from 23mm to 28mm internal isn't much".
    A wider rim should give more lateral stability at the same air pressure because it is increasing the air-volume in the tire.
  • 02-27-2014
    leeboh
    The tire/ rim companies HAVE been working together for several years now. The UST rim profile matches together with tire bead profile. Combines with a butyl ( airtight) tire liner and some stiffer sidewalls, the system works well. Some rims need a rim strip as well and the presta valves have a removable core to add sealant. For me, there is no downside to wider rims, unless you include lower tire pressure for better traction a negative.
  • 02-28-2014
    oldranger
    3 Attachment(s)
    a picture is worth a thousand words
    From Schwalbe's website on their most modern tire designs for the type of riding we are discussing here. Still looks like (by design by Schwalbe) tires are significantly wider than the rims.
    I wonder how wide these rims are?
    Attachment 873033
    Attachment 873034
    This image is from a section where they describe some design elements of the Super Gravity carcass
    Attachment 873035
    Super Gravity: Revolutionary carcass technology for MTBs | Schwalbe North America
  • 02-28-2014
    MTBMILES
    It seems most riders like the wider rims so maybe you should "believe the hype". I do.
  • 02-28-2014
    Bike Whisperer
    Yes, I've rode anywhere from 17mm to 30mm internal with roughly the same width tire. I greatly prefer the 30mm internal. I recently switched from 23mm to 30mm internal on the same tire and prefer the 30mm. There is zero hype here, just my real world on the bike experience...YMMV
    :thumbsup:
  • 02-28-2014
    DethWshBkr
    Typcailly a rear rim width for a 250 2 stroke/450 4 stroke is 2.15" (tire is 110mm or 4.33"), front rim is usually 1.6", (tire 80mm or 3.15").
    Tire width makes a pretty big difference on them regarding turn in capabilities, due to the curvature of the tread.
    Having a much narrower front wheel also allows the bike to "drop" into corners beautifully. Something we don't do on the mountain bikes. We run the same tire widths on the mountain bikes, front or rear, sometimes with a wider tire in the front.....
  • 02-28-2014
    oldranger
    Comment from Syntace Website on their W35 rim
    Per Syntace:
    With a rim width (inner) of 28.4 mm the Syntace W35 will provide the RightTireShape for tyres up to 2.5 tyre width.
    Less pressure, more control
    Less tyre pressure means: more grip, less rolling resistance in rough terrain, higher capability to absorb impacts, higher speed in corners as well as better braking traction. Why can a wider rim be ridden with less air pressure? Because the carcass remains upright better and is in contact with the rim via more air volume. On the wide Syntace W35 MX rims, mountain bike tyres mount wider and more directly on the rim with less bulging than on previous conventional narrow rims with low support width. This significantly reduces the tendency of folding when running low air pressures.
    For everything but downhill
    Meanwhile we are able to confirm from several years of experience: Syntace W-Series wheels can do everything. Apart from deliberately caused pinch flats with a Maxxis Minion or Specialized Butcher (or similar). What we mean, is causing harsh pinch flats using a tyre with knob profile which is unfavourable towards wide rims. This will simply dang up the rim hook. And we will have to help out with a crash replacement ;-)
    Attachment 873084
    Syntace
    So, I guess Syntace would say there is such a thing as a tyre with a knob profile unfavourable towards wide rims. Tires like the Minion or the Butcher.
  • 02-28-2014
    Kronk
    Per Syntace:
    [I]
    IF you get the area between the knobs to align just right. A rim width that matches any narrower tire/rim combo can produce the same result.
  • 02-28-2014
    derby
    With my own designs, and the p35's I ran before, I've noticed the most tire performance improvement in the 2.1 to 2.35 size single-ply tires I've tried with my 650b bike going from narrow 30mm to wider rims.
    By performance improvement, I mean much improved traction and stability, and reduction in rolling resistance on rocky trail. And not to mention a set of my rim's ~300+ gram reduction in measured rim weight compared to p35's, and much stiffer wheels enhancing the feel of traction and stability.
    Bigger tires are certainly improved too, but I think 2.4 and above really need 45mm wide rims for as noticeable a jump in performance gains over the truly hyped so called "wide" 30mm rims available.
    With 2.4 and larger and/or double-ply I think there are diminishing returns in performance improvement with wider rims. Although duel-ply Minion riders on my 29'er x 35mm wide rims "hype" to me and in the forums around the world about their improvement in handling.
    No matter how wide a rim, DH park riders and racers and large huckers need to use pretty high pressures to avoid pinch flats. The wider rim advantage may not be much for DH and FR because of the pressures required. I've also read an interview with a top DH racer who wanted rims that will dent, unlike carbon-fiber rims, when the tire is cased, so they can finish the run without flatting.
    I'm thinking real wide CF rims are more optimum for trail riding, rather than DH, where the much lighter weight is an advantage for climbing and endurance, and for the huge handling advantages at more moderate downhill speeds of public trails of real wide rims stiffening the casing tension under the cornering knobs and running lower pressures.
  • 03-02-2014
    aliikane
    Yeah, I agree. It is not like wider rims are faster, it is that they make the tire wider so the contact area is larger. If anything the grip is better. Will it make a noticeable difference? That is the question for every rider to answer themselves.
    The pros use what company pays them. In the case of all the riders the OP mentioned, all of them are using the widest rims available to them from the company they are sponsored and paid by.
    I think the biggest change to DH racing is gonna be wheel size and that they are gonna start moving to bigger wheels once they strengthen the bigger hoops.
  • 03-02-2014
    manokaiser
    Here is a good article on the subject.
    This should answer a lot of questions here.
    I just build a pair of WTB KOM 23mm internal. I 'll figure out soon what it feels like I guess.
    Ride on...
  • 03-02-2014
    SKullman
    Per Syntace:
    Attachment 873084
    Syntace
    This here is fantastic information, it explains two thing at once, tire tech and rim tech.
  • 03-02-2014
    Dennis
    ''you are wrong friend,,,the more we know about products,,and it gives us better choices,thank you,,,,,
    we buy and use the better we ride
  • 03-02-2014
    gticlay
    I like that a little wider rim is stronger and stays true for a longer period of time. Don't have to get cray cray about it but the old narrow rims weren't as stout. Stan's old Flow ZTR rims is super strong and light. Not sure why they felt the need to put more weight in the newer rims :(
  • 03-02-2014
    lstone84
    Ride on...
    I think part of this discussion involves marketing and selling to the masses. First, the pro riders are all sponsored and mostly ride with gear from major companies, few of which make wide rims. Secondly, carbon has become much more common in the bike world, allowing reasonably light wide rims, which previously was not feasible without affordable carbon. Sure, you could make light wide carbon rims but it would be out of most peoples price range. So there wasn't really an opportunity for companies to make a big profit from this.
  • 03-02-2014
    jdubside
    28 is NOT wide, Try a derby 40mm and then make your opinion.....
    I think everyone needs to try a 40mm carbon derby on the front before making opinions to this thread... game changer.... makes a round xc tire an all mtn monster...
    Hi Folks,
    2013 winning riders
    1. Crossmax SX 21mm
    DT m480 19.6mm
  • 03-02-2014
    Pau11y
    "Trendy wide rims"?
    I've been on D321/EX729 for 10+ years on my DH bikes... Must be the old hawtness thing?!
  • 03-02-2014
    mspohn
    This quote right here shows why you feel a difference, but you're not feeling the advantage of a wider rim. If you move to a wider rim, keeping the tire constant, you are increasing the volume of the tire. Which means you have to LOWER the PSI to compare apples to apples. To make it simple, for the same PSI, increasing volume, makes the tire "harder".
    If you increase tire volume, by increasing inner rim width, you can lower pressure, which will increase your traction - with the added benefit of having a more stable tire with regards to lateral (cornering) forces because of the rounder tire cross section.
    This actually should also decrease rolling resistance, on anything but a smooth surface, because the tire can conform to trail features easily with less energy lost in the tire deformation and rebounding process.
  • 03-02-2014
    Yody
    If you're a casual rider (or ridgid rider) you might like these ultra wide rims (35mm)and big squishy low pressure tires/Casings, but if your pinning it on any kind of DH, its not the ideal setup. These ultra wide rims are a fred phenomenon, and companies love freds with money. (Flamesuit on lol)
  • 03-02-2014
    modifier
    This ^. I like fat tires at lower pressures and I find that with a fat rim they are much more predictable in corners. I think they stick better too. And I'm not talking 25. I like 35. But...that's just me.
  • 03-02-2014
    Yody
    And rock Stikes while turning, thru rocks, with a wide run unprotected because of a stretched out tire with no sidewall bulge. .. is very dangerous at speed
  • 03-02-2014
    roobydoo
    I think that many are not noticing a difference be because they are not going wide enough!
    Ztr Flows ARE my narrow rim.
    The rest of the time I run 47mm as my narrow rim and 80mm as my winter rim. Once on a fatbike, narrow is anything on a normal mtb.
    Now I don't want to turn this into a fatbike vs mtb issue, but my point is. Once tire pressure become as important as it is on a fatbike you learn to try the same on your standard bike. Guess what, I'm hardly trying with guys I used to have to push myself to keep up with.
    For me a narrow Mtb rim is anything less than 25mm inside, I am not fast enough to care about the grams I could save just to loose traction, a better ride, and better handling.
  • 03-02-2014
    colbygee
    Well there is a big difference
    In rim width and performance
    Skinny rims are weeker and flexy and tires are
    Squirmy ! Simple !
  • 03-02-2014
    Surestick Malone
    I've always understood the reason for wider rear tires on motorbikes was traction under power. Apparently they actually handle better with narrower tires.
    On a bicycle, which is way underpowered compared to a motorbike, the danger of loosing the front, which is a guaranteed crash, versus the rear in a turn means fatter tires in the front. Part of this is a lot of bikes have much more clearance in the forks than between the chainstays due to drivetrain requirements.
  • 03-02-2014
    dirtrider76
    Totally planned on it but they dont make 26 rims so I went with Velocity Blunt35's.
  • 03-02-2014
    highdelll
    e.g. is what you wanted; not i.e.
    see more -- Grammar Girl : I.e. Versus E.g. :: Quick and Dirty Tips ?
  • 03-02-2014
    boostin
    Personally, I've found wide rims to be stabilizing. Is that good or bad? For me, I like to keep my bikes loose and flickable. This stabilizing action is not desirable. I have to work harder to get my lean on. I also still ride 26" and have flat pedals.
    I can see where the stabilizing action would be a positive trait for someone else though. I also understand that people like to run narrower tires than 2.4". The wide rims seem to be benefit tires in the 2.0-2.2 range more than than 2.4's.
    And I agree with gticlay, the original Flows were hard to beat
  • 03-02-2014
    hssp
    Last year I was racing enduro in Norway on a not too high level, and I had Syntace W35 rims. They gave super sideways stability, but I had way more pinch flats than before - running tubeless... I had to go for SuperGravity rear for racing and a beefier than before tire for everyday riding. I did the first half of the season om Flow EX, and I hadde no problems on the same tires. When I did the switch, I measured the tires om rims with same tubes and same pressure (digital gauge): the Flow EX gave a 10mm higher and 1mm wider profile on Nobby Nic 2.4"...
    A curiosity is that German Bike mag har a "dream enduro bike" test, where Liteville/Syntace brought a pimped out 301. The where running the narrower, lighter W30 rear with W35 up front in a b6-er config..
    My own conclusion: wide rims good for stability, but not for your tube consumption...
    After the season I sold my W35 wheels and stuck with the Flow EX wheels for harder riding and some Flow sized chinese carbon thingies for everyday riding. Works great for this year I hope.
    I now just wait for the new dual chamber system from Schwalbe, where low pressures and no pinch flats can be a reality..
  • 03-03-2014
    Lelandjt
    Wide rims (26-30mm internal) were popular in DH & FR from 2000ish to 2007ish. Mavic's top DH rim was 29mm internal and was a mainstay on the circuit. This was when the Minion DHF became the standard tire. Narrow rims for DH became popular when Mavic made the 823 its premier rim and riders starting looking to the NoTubes Flow and similar to reduce weight. A lot of riders were never as happy with the narrower profile but appreciate easy tubeless and having DH wheels you can sprint so the trade off was made. Now that carbon is allowing wide, light rims (and they have tubeless friendly profiles) riders are getting the best of both worlds. It's getting popular on the internet faster than on OEM and World Cup bikes because the companies making these rims are smaller and focus on aftermarket sales. Why Enve continues to cheap out and use the same mold for their DH rim and AM rim (same outside shape but more carbon for thicker walls & narrower width) is beyond me but I bet they come out with a wider 2nd gen DH rim soon now that the market is proven. Oh, and I've heard that the Syndicate uses the AM rim for its greater width & lower weight and just swaps them out when they crack.
    I don't feel like re-reading the OP and proof reading mine to see if I covered his points but here's the conversation ender: Ride a set of 26 to 29mm carbon rims and just try not to prefer them to everything else.
    Ultimate DH wheelset: Light Bicycle DH rims, DT 240 hubs, DT Aerolite spokes. Budget version is NoTubes Flow EX rims, Hope hubs, doubled butted spokes. For burly version substitute Mavic 729 rim.
    Edit: On my DH bike I've exclusively used the Minion DHF 2.7" since like 2004. I've tested other tires but always go back to my standard. Keep in mind that the 2.7" Minion measures the same as the 2.5"s from Spesh, Conti, Bontrager, ect. I've used them on rims from 23-30mm and prefer 26-29mm.
  • 03-03-2014
    jdubside
    Everyone on this thread should give a 40mm wide carbon rim a try. It is very different. In my opinion much better than easton carbon, enve carbon, and shanghai carbon, all of them I have tried, 19mm wide 28wide, and 30wide... the 40 crushes them all in handling stiffness and durability PERIOD.
  • 03-03-2014
    Bike Whisperer
    1980 Araya Catalog
    1980 called and wanted its 32mm wide mountain bike rims back...this is the rim (7x) that was spec'd on the original 1982 Stumpjumper.
    Attachment 873902
    Attachment 873907
    I think the hype was the skinny roadie width rims starting in the late 80's
  • 03-03-2014
    thickfog
    Attachment 873902
    Attachment 873907
    Exactly.
    This thread went from dumb to really dumb. People going from 21mm to 23mm, keeping the psi the same and saying they can't feel a difference? Really Einstein?
    I have a feeling too many of the contributions here never tried a proper wide rim. As another said, their flows are not even their wide rim. I couldn't agree more.
    Keep running your roadie crap. Enjoy if that's what you like!
  • 03-03-2014
    oldranger
    Thanks for your on-topic perspective Lelandjt.
    OK - there is opportunity here. I built that exact budget version for my son's Demo 8. Thinking that since he weighs 90 pounds - the lighter spec could hold up for his riding. Next time I'm out riding DH I'll try his ZTR Flow EX/DT Competition wheels on my bike and see how they work. We use Hope hubs on all of our custom wheels.
    Lelandjt - how much riding time do you have on the Light Bicycle DH rims? I am interested in those. I looked at those as I viable option until I decided I didn't believe the hype.
  • 03-03-2014
    oldranger
    This thread has over 16,000 views in 6 days. The only dumb stuff I've seen on this thread are posts from folks trying to change the subject and/or folks that misquote the OP (me). Some of you obviously don't pay attention to details. Which, by the way, is exactly what this thread is about.
  • 03-03-2014
    oldranger
    Checkpoint on the topic - are there carbon DH (Downhill) rim options?
    Are there any major rim manufacturers are making carbon DH rims? I know there have been a lot of good comments regarding the value of wide carbon rims for trail riding and all-mountain-spec bikes, but I'm sticking with the topic of DH.
    There is one reputable manufacturer - Enve that makes a carbon DH rim. Per their website, they designed it for "faster cornering speeds, direct lines, maximum durability, and responsive accelerations". Also according to their website, Enve has been providing this carbon rim for over 4 years, and no other rim manufacturers have followed those footsteps.
    Here are the Enve DH Rim Technical Specs:
    - Hole Counts: 32
    - External Width: 30mm
    - Internal Width: 21mm
    - Depth: 31mm
    - Weight: 475 g
    - Spokes: DT Competition
    ENVE Composites Launches the First All‐Carbon DH Rim - Press Releases - Vital MTB
  • 03-03-2014
    Bike Whisperer
    - Hole Counts: 32
    - Depth: 31mm
    - Weight: 475 g
    Not sure if you consider Light-Bicycle a "major" rim manufactuer, but they have come out with a heavier duty DH version of their 33mm wide carbon rim
    For Downhill version, we add much more carbon fiber to make the rim strong enough. So the weight is heavier than All Mountain version. It is around 460+/-15g.
    Advantages of this newly 33mm wide MTB 26er carbon rim
    *Wider & deeper( 33mm wide and 30mm deep), the strength and stiffness is much improved.
    *Manufactured by our new manufacturing process, making the strength much improved.
    *It is strongly recommended for all rocky mountain bikes like jumping bikes, downhill mountain bikes, all mountain bike.
  • 03-03-2014
    clbaumer
    Just a thought;
    This seems, to me, like it will be the same argument as 26" vs 29", but then eventually will come to an agreement that the middle is realistically the best. I haven't rode on real wide rims yet, but I have a feeling that eventually all will agree in the midrange- 23-30mm ish.
  • 03-03-2014
    Bike Whisperer
    Originally Posted by clbaumer View Post
    Just a thought;
    Who came to an agreement that the middle is best...best for what?
    XC
    SS
    DH
    FR
    AM
    Trail
    Short riders
    Tall riders
    There is no middle and there is no best...different strokes for different folks
  • 03-03-2014
    clbaumer
    XC
    SS
    DH
    FR
    AM
    Trail
    Short riders
    Tall riders
    I didnt say we had come to an agreement, i said eventually will. And there is always a middle, and always a best, at least majority wise. Basically, its will be a bell curve, just like everything.
  • 03-03-2014
    Deerhill
    For rocky trails..
    I do like the wide/light weight 2.4" single ply benefits and plushness at moderate speed, but I agree with this ^^. Even with pressure through the roof, the casing expands and the volume is just not progressive enough to take high speed hits w/o bottoming.. @ 35-40mm internal rim width, a single ply needs a 200g road slick installed inside.
  • 03-03-2014
    Bike Whisperer
    I do not believe there will ever be an agreement, there will always be three wheel sizes from this point on because different wheel sizes work better for different riders, terrain, bikes, etc. We has consensus 15 years ago, now it's gone and it's not coming back.
  • 03-03-2014
    BikeBert
    wider is better :)
    Maybe it looks like marketing BS but I find these images pretty close to what I experienced with my 35mm wide rims.
    Disclaimer: I am not a downhiller but I like riding steep and technical terrain; I call it trail riding, some call it Enduro. Also, I'm quite a heavy rider at ca. 200 lbs, hence I prefer stronger wheels, which doesn't necessarily mean heavier. My set is 1700g. :)
    First off, I was surprised by the low rolling resistance of the tires put on the wider rims. The tires feel more stable while cornering and climb better due to improved grip. Also, braking distances are considerably shorter. All in all, I really like the performance of the wider rims. Nevertheless, what I find beneficial, others may find redundant. It all boils down to personal preference and there is no universal solution for everybody.
    Few weeks ago [when the weather wasn't that inviting] I decided to take some measurements. I installed the same tire [Schwalbe Rock Razor 2.35] on two different rims with 21mm I.D. [DT Swiss EX 5.1 D] and 29mm I.D. [Syntace W35 MX]. In both cases I inflated the tire to 2 bars [29 PSI]. This is what I found.
    Casing width:
    rim DT Swiss EX 5.1D [I.D. 21mm] - 55.80mm | rim Syntace W35 MX [I.D. 29mm] - 58.40mm
    difference: 2.6mm
    Thread width:
    rim DT Swiss EX 5.1D [I.D. 21mm] - 57.55mm | rim Syntace W35 MX [I.D. 29mm] - 57.60mm
    difference: 0.05mm
    practically none
    Findings: with the rim 8mm wider, casing expanded by 2.6mm while the thread width remained virtually the same [which is mathematically correct]. Moreover, the modified profile of a tire - a more gradual arch with more of the tread facing the crown of the tire - makes the transition to the tire's edging tread seamless and is responsible for a better grip as "more" tire contacts the ground.
  • 03-03-2014
    Lelandjt
    I started using them in August. I did National Champs (16th in pro) and several Winter Park races on them. During Nats I heard several rim-to-ground bottom-out impacts but nothing bone crunching that would have caused more than a small dent in normal rims. They look like new. I run 28-29psi front, 32-34psi rear. I got the 430g version as opposed to the 370g layup that is recommended more as a wide AM rim.
    While Hope hubs are nice, you can drop 1/4lb with DT 240s. Bladed spokes like DT Aerolite and Sapim CX-Ray drop another 1/4lb. The Flow EX seems pretty durable but in corners it's noticeably flexier than the Light Bicycles.
  • 03-03-2014
    clbaumer
    i don't disagree with you, there a reasons to ride all different sizes and there will never be just one size that is end all. What I am saying is I believe it will be a bell curve, therefore the median will be the majority. Which would make it 27.5 wheels, with 23-30mm width is what I believe will be the majority going forward.
    I don't think we will see a majority of 26 x 17mm or 29 x 45mm. Make sense?
  • 03-03-2014
    unrooted
    Casing width:
    difference: 2.6mm
    Thread width:
    difference: 0.05mm
    practically none
    Bert,
    Can you take pics of the tire profile-without the calipers in the way?
    Also can you measure the difference in height of the tires? If the tire is being flattened out, then that must mean that the distance between the rim and the top of tread would decrease, right?
    Also, since the argument for wider rims is lower pressures, can you do the same measurements at 20 & 25 psi?
  • 03-03-2014
    Brian Damage
    ENVE Rims... Don't believe the hype!
    Hijacking the thread I know, but hear me out. Enve rims IMHO are all hype at the price tag they get. Why haven't they pushed the industry? Because they don't have to... yet.
    But I digress..
    1. Carbon rims are Stiffer / unit weight. Case in point, I build a pair of LB 30mm external rims to replace a set of Flows (nearly the same dimensions). Both with King hubs, both built by the same builder. The Flow were build up burly (I was 215lbs then). Since have dropped to 185 and build the carbon wheels accordingly. The end result was still a waaaaayyy sriffer and more responsive wheel. 390g/rim vs. 530 on the flows (650B size). BOOM 280 grams of rim alone gone. And those wheels took a beating and held up as good as the Flows.
    2. Since carbon is lighter, it can go places where Al rims have not been able to succeed (wider) without the massive weight penalty.
    3. Light Bicycle, Nextie, and Derby are all making carbon rims in the 35-40mm range. It's only a matter of time before the big guys will take notice. And before Enve may have to drop prices.
    4. Why do the pros ride narrower? Because they are paid to, and breaking an $800 rim on a practice run is no biggie, just grab another out of the support truck.
    Back to the topic... What is the best DH specific rim? I'd say it's a 40mm Derby rim with a fat Minion or your prefered front tire. Maybe go down to a 35 for the rear.
  • 03-03-2014
    Shredman69
    Exactly! This is what a lot of people are just not getting.
  • 03-03-2014
    Lelandjt
    ^While I'm impressed with Derby's rims he doesn't approve them for DH and they aren't available in 26". This leaves LB, Easton, and Enve as the only carbon DH rims. With Enve you pay a lot and get a very narrow profile (remember, their sponsored riders are racing DH on the wider, weaker AM rim). Eastons are also kind of narrow, expensive, have fewer spokes, and questionable hubs (and proprietary spokes and nipples?). I'm no shill for LB but I see no other options at this strength and width without tacking on 150g per rim.
  • 03-03-2014
    Shredman69
    I agree. I use their 33 wide AM with Hope hubs. Mine came out at 1530g for the set. I have punished them and raced on them at Fontana a few weeks ago and they have remained perfectly true. They are way stiffer, lighter, more stable, and they hold a line way better in the turns. I run between 26-28lbs with no tubes and I can push much harder in turns without rolling the tire or burping the bead. Wider is definitely better.
  • 03-03-2014
    hssp
    With Enve you pay a lot and get a very narrow profile (remember, their sponsored riders are racing DH on the narrower, weaker AM rim).
    The AM is actually 24mm ID vs 21mm ID on the DH...
  • 03-03-2014
    Lelandjt
    ^Typo, went back and fixed that.
  • 03-04-2014
    oldranger
    Mr. Dain Bramage,
    You mention 650b wheels. Are you commenting on your experience with DH wheels and downhill riding, or some other kind of riding?
  • 03-04-2014
    SVO
    [CENTER]
    I don't DH, but I do run 35mm rims on my winter set-up. I ride the same loop from home about 50X a year in all conditions. In any hard off-camber contact, the difference is entirely notable and has everything to do with side tire overhang and deformation- just like the picture. With thin-walled XC 2.4s at below 20 PSI I run in snow, it's night and day. Tough to imagine the exact same forces are not at play with stiffer tires and higher speeds/pressures. Just much harder to repeat the exact same line/pace at DH to experience the improvement clearly.
  • 03-05-2014
    beanbag
    Can anybody explain what is this mystery force "C" that reaches across air to try to pull the other bead off the rim? :madman:
  • 03-05-2014
    unrooted
    Beanbag, too me it looks as though force C is coming from the rim pushing into the bead/sidewall due to Force A being directed towards B, which is farther out from the rim in the narrow rim. Makes sense to me. What this tells me is that it reduces burping to have a wider rim, which in my experience isn't quite true. . .
  • 03-05-2014
    SVO
    It is apparently an attempt to simplify the complex forces with the deformation of the tire into a simple geometric comparison between rim widths. The ratio of AB/BC is a lot larger in the narrower rim, if one views the force as a rigid L-shaped lever (green) with fulcrum at point B and application at point D. More lever, easier to pop the bead. Not sure how well that mechanical analogy works in reality, and I haven't read the source page, so it's a guess as to what that depicts. But modeling this stuff with FEA or such would likely be cost prohibitive. So they gave you pretty color pictures instead. Fun!
  • 03-05-2014
    beanbag
    I was being sarcastic. There is no "mystery force C". The only things that exerts force on the bead, are things that actually touch the bead. That would be the tire sidewall. Another interesting fact: a sidewall can only exert a pulling force on the bead in the same direction that the sidewall pulls on the bead. So as you can see from the two diagrams, the narrow rim version actually has more force pulling the bead towards the bead hook, and not away from it.
  • 03-05-2014
    meltingfeather
    It seems to represent the torque caused by the folding tire pulling around the bead. Although the diagram is crude, I don't see a fundamental flaw, since it is not quantitative and is trying to demonstrate a concept.
    The bigger flaw is the lack or corresponding vector on the wide rim diagram.
  • 03-05-2014
    oldranger
    I don't know the original source of those images, but I first saw them on this PinkBike Tech article: Tech Tuesday ? Wider Rims Are Better and Why Tubeless Tires Burp Air - Pinkbike
    The author attempts to explain those images. Thing is, "wide" in that article is 27 mm (exterior). So those images should be considered supporting evidence for going from skinny old-school XC rims to wide rims like the Crossmax they suggest. That rim is 21mm internal.
    From that article:
    "Experience has shown that switching from skinny, 22-millimeter (OD) rims to 27 -millimeter (OD) width versions dramatically increases the lateral stability of a wheel and tire in corners and in technical terrain."
  • 03-05-2014
    beanbag
    Reading that article makes my head hurt and highlights Cunnigham's deep and profound misunderstanding of mechanics.
    One of the correct things is that if there is a sideways force on the tire, then one bead's upwards force will increase, and the other decrease, over the initial value. The effect is larger when the rim is narrower. But so what, if you just look at the diagrams, you will see right away that the wider rim causes higher "bead-pulling-up" forces in the first place, since the sidewalls start off more vertical. Secondly, in this modern age of Stan's bead-overstretching rims and hookless rims, nobody gives a f, nor is worried, about this upwards pulling force anyway.
    Next, there is nothing special about when the contact point moves over the rim's sidewall.
    Thirdly, the article claims that this "magic lever C" tries to pop the bead off towards the rim center channel. One look at the diagram shows that the sidewall is still yanking the bead INTO the hook.
    The way to get the bead to fall into the center channel is if the sidewall exceeds vertical. So the narrow rim system starts off with more sidewall angle preventing this, but at the same time, is floppier so flexes over more easily. Which tire will pop off first for the same side load? It's like that issue of "thin spokes make for a flexier but stronger wheel" of which you are intimately familiar LOL.
  • 03-06-2014
    Deerhill
    Magic lever c might only apply when riding on blacktop with red and green tires
  • 03-06-2014
    Miker J
    Watching.
  • 03-06-2014
    SVO
    Yeah, knew that. You missed my sarcasm.
    What you need to understand is that as the tire is distorted laterally away from centerline, the bike/rider weight load eventually tries to roll the tire off the rim. As lateral force increases, the centerline of the weight moves laterally and if there is enough of it, ultimately, outside the rim. At that point the weight is pushing the tire up along side the rim, rather than into it, and pulling out on the far bead. Narrower rim means less distance for the tire centerline to travel and less sidewall flex to overcome to reach that point. Both factors exacerbate potential problems with squirrelly handling from lots of smaller lateral movements and larger forces that might actually unseat the tire.
  • 03-06-2014
    oldranger
    3 Attachment(s)
    interesting analysis of those images...I just don't see tires deforming like that
    I'm sure these are lots of valid points analyzing how forces affect a tire casing...I imagine that is a very difficult analysis. I for one appreciate the comments in these most recent posts. But real world pictures don't seem to show gross deformation of the casing like those drawings.
    The first photo below clearly depicts his front wheel drifting/slipping, and we should expect that he is putting substantial pressure on that tire. Bit I don't see anything like behavior those drawings depict. The angle of that picture is almost perfect for this discussion.
    I know - those previous diagrams are just for demonstrating a concept...but I think they might be fundamentally flawed. (aka not relevant)
    Attachment 874928Attachment 874929Attachment 874930
  • 03-06-2014
    meltingfeather
    Downhill riders typically set pressure for hits, so riding on soft terrain, especially while dragging a foot, isn't going to show much tire deformation.
    If you've ever had a rim strike or snake bite or felt the tire squirm sideways, then you'd know the tires are deforming substantially.
  • 03-06-2014
    Miker J
    I've burped plenty of tires with hard cornering.
    Anecdotally, this supports the deformation-squirm theory.
  • 03-06-2014
    oldranger
    I love that. That deserves Caps.
    Deformation Squirm Theory.
  • 03-06-2014
    Saul Lumikko
    The DH rider is in a banked corner. The angle between the tire and surface isn't extreme at all.
    It might really be that wide rims in DH use are not as beneficial as in AM/FR/Enduro type riding, where pressures are lower and tires more compliant.
  • 03-06-2014
    beanbag
    I already said that there is nothing special about any weights or forces or centerlines outside the edge of the rim.
  • 03-06-2014
    Brian Damage
    Hahaha.... Your arguments make me laugh so hard it brings a tear to my eye ;). Thank you!
    The diagrams are meant to show the angle at failure. Your pictures do not show anything close to a failure of any width rim. I'm sure there a many more extreme images out there. Have you ever burped a tire? If not, keep using your skinny rims and keep thinking you are fast of the Dh's. But you started the debate asking the question: 'is wider better for DH'. If you haven't tried both then your opinions are just that... opinions. Let's hear from someone who has tried 'real' wide composite rims (I'm not talking about 25 v 21mm internal width) and compared them to 'narrow' rims in the 25mm range. Just sayin... Try it, you might like it.
  • 03-06-2014
    oldranger
    This is where I'm 'at' on this subject. But, with that said, there has been one experienced DH rider/racer give specific, experience based recommendations that the LightBicycle DH rim offers a better ride for DH racing. I don't think anyone else contributing to this thread has made any specific rim/tire recommendations based on DH experience. Did I miss any?
  • 03-06-2014
    Brian Damage
    Is this relavent enough for you Mr Ranger?
    I like this one
  • 03-06-2014
    pharmaboy
    Lol, that's a ripper of a photo!
    Test theory - put 20 psi in front tyre, go for ride on rough concrete or bitumen path and at slow speed turn sharp.
    THAT noise and nearly coming undone was tyre deformation. One of the reasons that mountain bikes aren't suitable for flying down a mountain road at 10 tenths, because you'll roll the tyre off and die. That there is no witnesses to this exact outcome only goes to prove the point! ;)
    Now, I don't know about the rest of you, but I pretty much have never had bitumen type levels of grip offroad so the point is pretty moot - I'm more likely to burp a tyre sliding down into a rut than anything else, because grip on dirt is very rare for my riding areas.
  • 03-06-2014
    oldranger
    Thanks. I love pictures. What kind of rim is that? Looks old. Perhaps some old school skinny Mavic rim to go with that old fork, and the even older Kenda tire not designed for tubeless. Does that fork have a standard QR axle with IS mounts for a brake?
    Can you find a picture like that from this decade?
  • 03-06-2014
    oldranger
    You picked a winner of a pic Mr. Bramage
    Google tire burp and within 5 seconds I find the source of your pic. This is too good.
    No. It's not relevant.
    Attachment 875036
  • 03-06-2014
    Shredman69
    Attachment 875036
    How is it not relevant? It's a skinny rim with the tire folding and burping under a load. Unlike your pics that show that the bike is not even under a load. Look at the suspension on the pics that you posted, it's not even compressed. Of course their is no deformation, there is no load on the tire. I have used both skinny and wide rims, both tubeless. I've folded and burped the tires on the skinny rims but I've yet to have that happen on my wide rims, even though I run less pressure in my wide rims than I did in my skinny rims. I get better traction and I can rail turns harder and faster than I ever could on my skinny rims. They are LB carbon, 33 wide external and 26 wide internal and 30 deep. It's pretty simple and an easy decision to make. Wider is better for all riding, especially DH.
  • 03-06-2014
    MTBMILES
    Wide Rims? Don't believe the hype...
    old ranger will never change his mind and will always go back to " I am talking about DH", this forum already believes the hype.
  • 03-06-2014
    Shredman69
    LOL, true.
  • 03-06-2014
    pharmaboy
    Not relevant - are you seriously asking why it isn't? That picture is in the middle of a crash - he has landed withthe wheel at an angle to direction - it is not in any way a tyre losing grip in the midst of turning - look where his right knee is FFS.
    It doesn't prove anything, nor disprove anything either - it is however an amusing photo.
    And before you go off at me as well, if I were ordering a set of LB rims I would order wider rather than skinny, but that's on the basis that I don't see anything to lose and maybe something to gain with wider rims, and I certainly wouldn't bother with 18mm internals.
    The other thing I think you are missing is that tyre and rim interface is mostly the cause of burps - if the tyre goes on super easy and is hard to inflate because it's so loose - then that's a tyre that is going to burp easily. A hard cornering friend of mine used to burp all the time - he fixed it when he changed to tyres that were tighter fit.
    If you changed from identical sized rims to wider ones and used the same tyres and burping stopped, I think then you have some evidence. As soon as you change a couple of things at a time, all you have is supposition.
  • 03-07-2014
    beanbag
    2013 winning riders
    1. Steve Smith Easton Havoc 23mm
    2. Greg Minnaar - Enve DH 21mm (30mm external)
    3. Aaron Gwin DT FR600 24.9mm
    I think this is a good point. One of my rules of thumb is: "If you don't know what you are doing, follow other people that do" LOL. I would think that pro downhillers are more interested in winning, than running whatever sub-optimal stuff their sponsors give them. Like maybe if they thought wide rims were so great, then they can buy the rims themselves and peel off the labels.
    But this assumes you also have the same equipment as the pros and your goal is always to go as fast as possible.
    Of the few things that are true and relevant is that wider rims cause tires to feel laterally stiffer, and maybe your chance of bonking the rim is higher.
    This "tire peeling off" stuff is all BS, I mean, how many pro downhillers go around peeling off their tires coz their rims were too narrow? On the other hand, maybe you suck as a rider and don't run the right pressures, in which case, tire peel could be an issue for you. Maybe the real question is:
    Are you GOOD ENOUGH to run narrow rims like the pros? LOL
  • 03-07-2014
    nogod
    If a flat wide profile is desired, why is it that tire manufactures seem to think that a rounded tire is what is best? The logic seems to be that wide rimes are a compensation for a poorly designed tire in order to use low pressure. perhaps a tire with a flatter profile and thicker sidewalls would make more since?
    But then there may be a solution: The dual chamber tire Detail - Schwalbe Professional Bike Tires
    "With the current trend towards wide wheel rims, the trail performance of the tires at low air pressure is improved and has become less "spongy". The risk of snake bites, however, remains the same.
    The solution is an innovative dual chamber system. There is an additional air chamber inside the tire. This inner chamber is filled with high air pressure and effectively prevents the tire hitting the edge of the rim. At the same time, the inner system also secures the tire on the rim and prevents the dreaded "burping", a loss of air of the tubeless system in the case of low pressure. Depending on the situation, the air pressure in the outer chamber can now be reduced to 1 bar (14psi) without running any risk."
    For the record though a tire with more pressure is less likely than a tire with lower pressure to roll over. And if your tire is hard then you can use the tread on the rounded side of the tire. meaning that if you have higher pressure you need a rounder tire profile. Generally speaking downhill bikes have higher pressure. Applied to the average rider it means if for whatever reason you need higher pressure in your tires a narrower rim is better. But if you can can or want to run lower pressure then a wider rim is in order. Or what is more fun just ride what you have and what you want.
  • 03-07-2014
    shiggy
    Because two wheeled vehicles handle like crap on tires with flat treads.
    ALL bicycle tires have round profiles. Any squaring off is relative.
    IME too narrow a tire on too wide a rim is worse for handling than the other way round, and is more prone to pinch flats and sidewall damage.
  • 03-07-2014
    oldranger
    Yes I will, well, maybe after another year...
    Actually, I have been influenced by this thread, just not willing to take advice about how wide, light rims with low psi perform for Trail, AM, and Enduro and apply it to my DH bike spec. (that I race for fun, on my dime)
    I will watch to see how the 26mm internal width LightBicycle DH rims hold up for you folks over the 2014 season. Hadn't thought about carbon - which has been out of my price range.
    Based on contribution to this thread - I have decided that I will build up a set of DT Swiss FR600 rims with DT Comp spokes for my normal DH wheels. The FR600 width falls in to the range the Maxxis tires are said to be designed for.
    My choice to go with FR600 is primarily based on the good balance of width, weight, the tires I intend on using, and the price. I intend on running Maxxis DHF and HR2 tires again this year. The $90/rim FR600s have a relatively wide 24.9mm internal width, a record of durability, and are used by race teams and one of the top riders, and come as OE on one of the top DH bikes available.
    I will put away my heavy Atom Lab Pimp2 rims with Champion spokes and save them for days at Windrock, TN.
    I will also give my set of 2013 Stans ZTR Flow EX wheels a try on my Demo when Im riding DH some day. That will help gauge the benefit of light rims - and see if it might be worth the $$
    Oh, and Id love to ride anyones wide rims that wants me to see the light. :)
    I really appreciate the time each of you has taken to share your observations, facts youve found, and opinions. Its been fun to debate, and this is a great forum for that. There have been some key contributors to this thread that Id like to call out. These folks have offered succinct, specific suggestions based on professional experience, or a noteworthy track record of participation in MTB riding and racing:
    Bholwell, Tire Design & Development Engineer. A greater difference will be felt when running thinner, AM or XC tires at lower pressures. Yes, I designed the DHR2 and the HR2 on a 23mm internal width rim, but the difference in profile going from 23mm to 28mm internal isn't much.
    Lelandjt, DH rider with 10+ years of competition including Pro DH On my DH bike I've exclusively used the Minion DHF 2.7" since like 2004. I've tested other tires but always go back to my standard. Keep in mind that the 2.7" Minion measures the same as the 2.5"s from Spesh, Conti, Bontrager, ect. I've used them on rims from 23-30mm and prefer 26-29mm. Leland recommended the Light Bicycle DH rim (inner 26mm, outer 33mm). This guy has a record of going fast DH.
    Also thanks to Beanbag, for your well-crafted and on-topic contribution when the talk got technical.
    Interesting that there hasnt been a recommendation for using wide aluminum rims like the $1,200 Industry Nine Gravity Rim (33.5mm outer/28.5mm inner width).
  • 03-07-2014
    meltingfeather
    The $1,200 Industry Nine product is an entire wheel.
  • 03-07-2014
    mtnzj
  • 03-08-2014
    meltingfeather
    Looking back at it, C looks like the moment about the bead produced by the force vector AB, which also explains why there is not a corresponding moment in the wide rim diagram... AB is through the bead, thus producing no moment about it.
    Accurate? No comment... :arf:
    The more I look at those diagrams the more I think they are useless.
  • 03-08-2014
    beanbag
    This is a good assessment. Think about this:
    Why is it that the tire is pushed over sideways, yet this mystery force AB is still exactly in the plane of the wheel? The Cunningham mystery lever is an L-shaped device that has the corner at one bead, the top at the tire contact point, and the other end trying to lift the other bead. To operate this mystery lever, you have to push SIDEWAYS at the top, not down. (Doesn't anybody know how to operate a lever these days?) Using this "explanation" (LOL), there is no special threshold point between a wide vs narrow rim.
    BTW, when I did google search on pink bike wide rims, I came across this article:
    To the Point: Bill Shook on Wheels and Wide Rims - Pinkbike
    where American classic says they use 32mm for their XC rims, and 28mm for free-ride, because if they made their freeride rims 32mm, it would be "too heavy to ride uphill". :rolleyes: So by logical extension, that means that DH rims should be 24mm wide.
  • 03-08-2014
    Shredman69
    where American classic says they use 32mm for their XC rims, and 28mm for free-ride, because if they made their freeride rims 32mm, it would be "too heavy to ride uphill". :rolleyes: So by logical extension, that means that DH rims should be 24mm wide.[/QUOTE]
    Obviously a typo. 32 is the FR rim, not XC rim. The lighter narrower rim is the XC rim.
  • 03-08-2014
    TedS123
    The new AC Wide Lightning is 32 mm outside/ 29 mm inside width and is targeted at XC/Trail/AM. It's interesting that AC is pushing wide rims for XC.
    I do mostly XC/trail riding in the rooty, rocky east, with a few races. I've been trying to decide between the LB 22 and 30 mm inside wide hookless, so this thread has been interesting. Was wondering if 30 mm might be too much for my typical 2.2 - 2.35 tires. So the Wide Lightning seems to support the thinking that wide rims are good for xc.
    Sent from my XT907 using Tapatalk
  • 03-09-2014
    oldranger
    This comment from Bill Shook is on the topic:
    "I started these riders with rim widths at 24 millimeters wide, then 26 millimeters, each with reductions in tire casing size and weight, Then I tried 28 millimeters with a subsequent reduction of tire casing size and weight. In watching this progression, I saw that the profile of the tire on the rim (as a unit) was going more and more towards a half-circle shape (hemispherical tire profile). I took it to its conclusion and the sweet spot is at 32 millimeters wide, as it is the maximum lightest casing with the best tire profile. If you go beyond that to, say, 36 millimeters wide, you get negative returns, because the shape of the tire on the rim exceeds the optimum hemispherical shape."
    There is also another watch out when reading that article and interpreting Bill's reference to 'width'. He is referring to outside width, and the rim material is thinner for XC rims. It is typical that for a DH rim, there is a difference of 6-7 mm between the inner and outer width of the rim. (Not 3mm difference like the AC Wide Lightening rim)
    Attachment 875566
  • 03-09-2014
    Surestick Malone
    Attachment 875566
    I read the article. There's no mention of why a hemispherical profile is better or what width tire the magical 32mm wide rim is best with.
    Also, why reduce tire size with increase in rim width? You'd want to try a range of tire sizes with a range of rim widths.
    Not a very informative article, more of an an exercise in marketing.
  • 03-09-2014
    pharmaboy
    The article is a bit like asking the Pope what's wrong with the Catholic Church .
    It seems to me that the main driver of wider rims in xc has been American Classic, and the main opinion site has been pinkbike with similar fervour.
    What the shape of the tyre is on the rim seems a little irrelevant to me unless you are running 50psi. What matters is where the rubber meets the road with an enormous flat spot at 25psi with presumably a change in the bulge depending on rim width. But that change in bulge while it might lead to an efficiency change, also means a less compliant ride over rocks.
    I can't help but wonder that tyre developers would be making tyres to suit the average rim out there and to perform well in that environment. Would schwalbe be designing tyres for xc to work best with a 28mm ID rim?
  • 03-09-2014
    beanbag
    Sissy riders like me would probably benefit from wider rims because they raise the side knobs on the tires and make them engage earlier.
  • 03-09-2014
    meltingfeather
    Wide rims make tires square, which is cool.
  • 03-10-2014
    ca_rider
    Good point, I'll add support for it.
    No moment exists at C because torque cannot be transmitted through the tire sheet. Any torque would be caused by viscous shear from fluid flow within the tire, and as we all know these internal fluid forces are negligible in comparison to other forces within the tire. Also, D is wrong. As we all know, internal pressure acts along the normal to the tire surface but is neglected. D should not be upward (away from the rim seat) but outwards through the rim sidewall.
    The figure is clearly drawn by somebody that does not understand mechanics. E.g. the impinging forces do not sum to the reactive forces, and how does AB cause lateral flex, since it is vertical. The figure should be discounted wholly.
    In my perspective, wider rims do two things:
    i) Provide a harsher cushion of air to ride on for a given pressure. The harshness of the ride will scale positively but less than linearly with the width of the rim. The logic is as follows. It is surely commonly understood that the tire area which supports the rider is the same for constant tire pressure, this follows from the definition of pressure which is approximately constant within a tire. For a wider rim, the width aspect of the support area increases and the circumferencial aspect of support area decreases. Since the circumferencial dimension is less rigid than the width dimension due to fact that tire sheet shear contributes more to balancing forces in this aspect, the ride becomes harder. These two effects allow for achieving stable conditions at lower pressure.
    ii) Reduce tire roundness, which reduces handling as Shiggy mentioned. One way to rationalize this is to imagine the roundness as contributing to a varying tire height as a function of aspect angle. As the bike lays over to one side (i.e. carving), the slope of the change of radius causes the bike to turn. This slope is exactly related to the change in radius as a function of aspect angle. That is, round tires turn better. Square tires don't turn as a function of aspect angle. To lay over a bike with square tires and turn is to use the angle and centripetal forces to balance against the forced turning of the handlebars but fully neglects turn contribution from tire design.
    Lastly, rolling efficiency is characterized by the sum of PV work and mg*delta(h) work whereas heating and other effects are negligible. The PV work is dominated by mg*delta(h) work since fluid redistribution allows impact energy to be stored elastically over the entire fluid volume and tire surface so local fluid pressure spikes are minimized at characteristic timescales. As such, the harsher riding wide rims will be less efficient due to more delta(h), regardless of operating pressure.
    If I get a chance I'll run some simulations regarding this within the next 6 months. After reviewing the literature, I found very little published analysis on the subject.
  • 03-10-2014
    oldranger
    (ca_rider) is referring to the figures from the pinkbike article "Wider Rims are Better..."
    Thank you Sir. I appreciate the effort you put in to your explanation.
    (Though you are bringing back bad memories of how bad I felt when I got a D in Physics because I was too busy rock climbing to go to class)
  • 03-10-2014
    nvphatty
    imma square does it make me cool?
  • 03-10-2014
    Shredman69
    This is a good article on wide tires with lower pressure roll faster and are more efficient than narrow tires with higher pressures. I know it's not about the rims, but they go hand in hand.
    http://www.mtbonline.co.za/downloads...llustrated.pdf
  • 03-10-2014
    HillDancer
    I have wide rims, and I've used narrower rims, the ride is not harsher on the wider rim than with the same tire on a narrower rim; increased volume = increased pneumatic suspension with tire construction being constant.
    Circumference of a tire is constrained by its cords, it does not vary with rim width. A narrow tire, narrow rim, or combination of both, creates a longer contact patch than the same tire on a wide rim, which increases pneumatic trail, and increases slip angle. High pneumatic trail plus wide slip angles slow steering response and encourage understeer.
    Tire shape does not become square with an increase in rim width; square is just a stereotype label used to pigeon hole info. While there is much to disagree with one line with an arrow in the disputed diagram without knowing the illustrator's intent, the outside shape of the tires in the illustration are representative of rim width's effect on casing shape. The narrower rim produces a more obtuse shape surrounding the contact patch when viewed on a coronal/vertical plane. With the tire's center further from the rim's center, slip angle increases. The greater the slip angle, the further the tire lags behind steering input.
  • 03-10-2014
    ca_rider
    5 Attachment(s)
    There is a lot of conjecture in this thread including questionable references and philosophies, anchored with bad diagrams and articles written and illustrated by people not trained to analyze mechanical systems correctly (aka marketing departments). I'll indicate some technical refs here and hope it aids the discussion. My sincere opinion is that a reasonable understanding of the principles outlined for instance in the refs below is necessary to gauge tire and rim design correctly. I question every article linked thus far based on flawed rationale.
    For reference, some captures of tire force distributions are shown below.
    Attachment 875904
    Attachment 875905
    Attachment 875906
    Attachment 875907
    Attachment 875908
    The above captures are from
    http://www.nhtsa.gov/staticfiles/saf...HS-810-561.pdf
    Another good theoretical reference is
    https://archive.org/download/nasa_te...9700007105.pdf
  • 03-10-2014
    ca_rider
    Thank you for your thoughtful comments.
    Sorry, I meant for the constant pressure case.
    I fully agree for a fully inflated tire when cords are at design tension. My understanding of the intent of wide rims is to find stability at less than design pressure.
  • 03-10-2014
    ca_rider
    I wish I read your post before posting my latest diatribe so as to include some of it. I agree with your point about steering input lag, which is captured in 2.46 and to your point about chords defining spanwise profile, and that tires do not become 'more square' at lower pressure, figure 7.38 and chapter 7 in particular pertains to the relevant mechanism and in this case discerns the difference in load distribution as a function of approach to load rating which indicates profile dominance by chords vs external forces (internal pressure vs. road).
  • 03-10-2014
    meltingfeather
    This is not true.
    You have to be very careful when comparing belted radials like the "medium duty truck tires" in the NHTSA study cited above to bicycle tires.
    Apples and oranges.
  • 03-10-2014
    HillDancer
    There is a period of cord elongation and material spread between the weave during the early life of a bicycle tire, after which tire circumference stabilizes, or at least slows considerably. Cotton and Aramid fibers have varying limits, which can produce apples to oranges growth outcomes, rim width however, does not effect this change.
  • 03-10-2014
    Shredman69
    Truck tires on pavement and mountain bike tires ridden offroad can not be compaired. Here is your scientific test data on mountain bike tires.
  • 03-10-2014
    oldranger
    I was resisting, but since you posted the link a second time, I have a question Shredman: which of the grueling test scenarios on that 5.7% grade 460m climb test track is most like the type of riding (shredding) you do? The 'Road', the 'Gravel', or the 'Meadow' scenario?
    I'm guessing the gradual uphill 'Meadow' is most like what you ride, since that is the scenario the PhD student/author/test rider suggests is most beneficial for wide (2.3 - 2.4) tires and very low tyre pressure (21psi)(with a y).
  • 03-10-2014
    MTBMILES
    Old ranger are you saying this test isn't DH so it isn't relevant?
  • 03-10-2014
    Shredman69
    [QUOTE=MTBMILES;11054934]Old ranger are you saying this test isn't DH so it isn't relevant?
    LOL, he doesn't think anything is relevant unless its on skinny rims with DH tires and high pressure.:lol:
  • 03-10-2014
    ridonkulus
    Ok, we are all arguing over theoretical science, I'm not gonna trust any of these until we here from several sources that have actually ridden wide rims, as in 30mm+, and the narrower options out here.
    Your science may very we'll be right but how it translates to real trail riding is what matters
  • 03-10-2014
    Shredman69
    LOL yep mostly open meadows. Here I am on some of them. You can see the tire and rim in action. It's a 2.35 Nevagal on the 26mm int 33mm ext carbon rim tubeless with about 25 psi in the front.
    Rock-It trail in Aliso Woods on my 2013 Intense Uzzi. - YouTube
    1st time down Car Wreck in Aliso Woods - YouTube
    Oh yea, and I got 4th on my last "open meadow" DH race too.
  • 03-11-2014
    Deerhill
    Thought op was referring to 30-40mm internal rims, no?
  • 03-11-2014
    oldranger
    No.
    I've accepted the fact many of the contributors on here want this thread to be about trail (All Mountain, XC, etc.) tires and rims. I'm disappointed about that, but there has still been some good, on topic contribution, I just have to be willing to disregard all the noise.
    That article and the premise of the test is kind of silly. Did you read it? The word 'rim' doesn't show up in the article at all until the last paragraph when the author mentions that is is a factor when setting tyres up.
  • 03-11-2014
    kiloman
    LOL, you guys are still at it, trying to convince oldranger? Haven't you figured out yet that he doesn't want to be convinced? He's just instigating you into continuing to make replies.
  • 03-11-2014
    meltingfeather
    See this thread where former Maxxis tire development engineer bholwell said this (among many other things):
    Originally Posted by bholwell View Post
    Ok. Nylon fabric is elastic in the direction of the threads, and has almost no strength in the direction perpendicular to the threads. This is why two plies are needed at opposing angles (all mountain bike tires are of bias construction).
    Yes the hoop tension at the outermost circumference of the tire will increase as the tire O.D. attempts to increase, and will restrict it to some degree. In my first graph, the section height changes, what, 1mm when going from a 17mm rim to a 27mm rim? Or less than a 3mm change MAX? I would venture to guess that in practice, the section height would change 80-90% of the theoretical.
    Rim width does affect casing height (and therefore tire circumference).
  • 03-11-2014
    HillDancer
    I concede, it is possible there is a minor change in height.
  • 03-11-2014
    oldranger
    Alright kiloman, here is what would convince me that a rim with >25mm internal width could be an optimal choice for a Downhill (DH) rider:
    1) Information that any tire manufacturer is specifically designing a 2-ply DH tire for a rim with an internal width of any single value >25mm. This would be especially convincing.
    2) Information that any one of the top 10 UCI DH Race teams is using a rim with an internal width >25mm. This would show support for theory in practice.
    3) Information that any of the top 10 bike manufacturers are spec'ing a top-of-the-line DH bike with a rim that has an internal width >25mm. This would support the market backs opinion with $$
    4) The opportunity to ride a set of Industry Nine Gravity wheels for a weekend. This would give me an opportunity to form my own opinions objectively without being confronted with the all-to-common propensity to justify a mod you just spent $$ on.
    Frankly, the I9 wheels are so cool, I was hoping someone on this forum would help me with some data that would justify the purchase. No such luck.
  • 03-11-2014
    meltingfeather
    lol pwnt
  • 03-11-2014
    Shredman69
    IKR!!! :lol:
  • 03-11-2014
    oldranger
    OK. Shredman - you should feel good about your accomplishments on those trails, and your race result. It looks like you've got your bike setup just right for that kind of riding.
    What kind of rims are those?
  • 03-11-2014
    beanbag
    Like what kind of "data" are you looking for?
  • 03-11-2014
    Shredman69
    Thanks Ranger. Those are Light Bikes Carbon AM rims. The same ones that lelandjt has, except his are the slightly heavier DH version. Same dimensions though, 33mm ex, 26mm int and 30mm deep. The AM ones are advertised at 370g each, but mine weighed 350 and 360. The 350 is on the front and the 360 on the back. With Hope Pro2 EVO's and DT super comps and alloy nips they came in at 1520g for the set. They're light, stiff, strong, fast and WIDE.;)
  • 03-11-2014
    oldranger
    I dunno, maybe "data" is the wrong word. Perhaps just some theoretical model that passed muster on this forum, or quantitative observations from a consistent athlete (like "my times over xx runs were consistently xx seconds faster"). Or maybe someone credible like bholwell would have said something like "I designed the HR2 or DHF on a 27mm rim" (which he didn't, he indicated it was a 23mm width).
    The debate was fun, though.
  • 03-11-2014
    beanbag
    I once had a theorist tell me, "Don't worry about your data. I can create a model where your results are the correct ones."
    You already have this info from the rims that the winning pros use.
    Probably what he meant was the "roundness" of the profile e.g. how soon the side knobs start to engage. I would think that depends on your riding style. Maybe the "pros" lean their bikes over more and want the side knobs to engage later, hence the narrow rims.
  • 04-09-2014
    Deerhill
    As more and more people start using these 30mm+ high volume/wide carbon rims.. the low pressure/handling feels too good.. only a matter of time till the carbon crunched on rocks photo's will start popping up
  • 04-09-2014
    dirtrider76
    I have been on wide rims for awhile now. 32mm and 35mm alloys with no dinged wheels.
  • 04-09-2014
    Brian Damage
    ENVE & IBIS both jumping on the wider is better bandwagon?
    Some interesting developments / new products in the past weeks that pertain to this debate:
    Ibis released new wide carbon rims. 41 outer / 35 inner. Yes, these aren't DH specific or 26", but this is a bike manufacturer endorsing the wider is better theme.
    Enve just released a new line of rims that are wider than their previous offerings.
    M70 26" = 32 outer / 25 inner (intended for 70% DH)
    M90 26" = 34 outer / 25 inner (intended for 90% DH)
    Older Enve 26 DH are 30 out / 21 inner?
    The trend is IMO pushing for wider accross the board. Where is the optimum for each category of riding? I think in the next few years the market will dictate as more major manufacturers get onboard.
  • 04-09-2014
    jazzanova
    Just to make it whole.
    ENVE AM are 30 outer / 24 inner.
  • 04-09-2014
    Brian Damage
    Yes. I was referring to the ENVE DH rim:
    http://enve.com/products/wheels/26-dh-26dh/
    Since ranger doesn't think it applies if it's not DH.
    Doesn't specifically callout the inner width (just the 30 outer), but on pinkbike they talked about it being 21?? not sure of the exact dimensions. But if this is correct, Enve put the extra material on the outside to provide DH strength (over the AM version) this time around instead of the inside so as to maintain the same inner width. Further evidence of the wider theme?
  • 04-09-2014
    Shredman69
    Envy has new rims this year, the M series. The AM rim is 32 wide 24 inside and the DH rim is 34 outside and 24 inside.
    Hot Product: ENVE launches new MSERIES rims, wheelsets | Mountain Bike Review
  • 04-12-2014
    oldranger
    So...Enve goes bigger on their DH carbon rim, but not bigger than 25mm internal...seems yet another data point that supports the position it doesn't make sense to go wider than that.
  • 04-12-2014
    MTBMILES
    You're too funny!
  • 04-24-2014
    ticketchecker
    Originally Posted by nvphatty View Post
    no thats not close to fat biking, 3.8 begins fatness. When i build my next full squish AM bike it'll use 35mm blunts with the 26" 2.75 dirt wizards which will equate to 27.5 circumference wise.
    Kinda where I'm thinking. 27.5 frame with 26+ wheelset
  • 05-14-2014
    slowride454
    I loved when I switched to 23mm rims....on my road bike. Lower pressures and lots more comfort with 25c tires. I love my P35s and 29x2.4s and will be looking into a 40-50mm wide rim for my next wheel build. I run 25f/28r with tubes, ZERO pinch flats and lots of traction.
  • 11-26-2014
    ENSANE
    Originally Posted by Deerhill View Post
    I find rims over @23-25mm internal width start to take a heck of a lot more hits on rocky trails (from the volume and also dings to the finish)
    That's the main concern for me going wide carbon, one rock could kill a rim. Plus I've seen these internal 35mm at the shop mounted up with 2.4 minions on them, and they don't look right at all. The tires look like they could use an extra tread line on the left and right side of the tire.
  • 11-26-2014
    Shredman69
    You both couldn't be any more wrong. You don't "take more hits on rocky trails" because you have more volume. It's just the opposite. Because there is more volume with a wide rim, there is more cushion. And because there is more volume, you can run lower pressures and have a larger contact patch with more traction for turning, braking and acceleration. Also, tires don't roll or burp in hard corners on a wide rim like they do on a skinny rim. And if your talking about rocks hitting the sidewalls of the rim, that's a non issue. I've had plenty hit the side wall of my carbon rims with no issues. Once you try wide carbon rims, you'll. never go back. They are that good.
  • 11-26-2014
    ENSANE
    You talking 30mm internal with or 35mm?
  • 11-26-2014
    Shredman69
    I have 2 pair of LB 33mm wide and 1 pair of LB 38mm wide carbon wheelsets. The 33's are 27 internal and the 38's are 32mm internal. I'm running a 2.5 front and a 2.35 rear on the 33's and 2.5's front and rear on the 38's and the tire profile is perfect on both. If you use too small of a tire then the profile can get a little flat, but running a small tire on a wide rim defeats the purpose of having high volume lower pressures wheels. Larger tires and lower pressures roll over rough terrain more efficiently and provide more traction in all conditions.
