• 01-18-2004
    Steve-O
    Wheelbuilding on a Sunday afternoon
    NOTE - Warning blatant 700c content.
    I've been planning a new wheelbuild for a Ti road bike I picked up over Christmas. After hassling Bianchi4me about rims and spokes over several phone calls I placed an order and began plotting for a spare 4 hours to build up the wheels. Fortune came this afternoon when the wife picked up a copy of the DaVinci Code and the kid visited a family friend. First I consulted the dog-eared guides I had used in the past.
    <img src=https://gallery.consumerreview.com/webcrossing/images/builddirections.jpg>
    Next I started prepping out my tools on the kitchen island (Mike T. you'll appreciate the glob of anti-sieze). I'm a pretty simple guy so I use a couple of old spokes to put the nipples in the rim. A stripped q-tip works to apply the anti-sieze to the threads. Finally a stanley screwdriver does the job to turn the nipples.
    <img src=https://gallery.consumerreview.com/webcrossing/images/buildtools.jpg>
    Not sure if anyone else does this but I typically mark my spoke holes to help guide the build. I have gotten to the point where I really don't need to do this anymore but it gives me a little added security against mistakes. They talk about this in the Barnett's manual.
    <img src=https://gallery.consumerreview.com/webcrossing/images/markingwheels.jpg>
    Everything starts going together once I figure out the key spoke. The Corian countertop holds up pretty well to this kind of abuse (good thing Mrs. Steve-O is in the other room).
    <img src=https://gallery.consumerreview.com/webcrossing/images/build1.jpg>
    Now things are coming together. The front wheel is a Hugi 240 with Wheelsmith AE15 bladed spokes laced 2x.
    <img src=https://gallery.consumerreview.com/webcrossing/images/build3.jpg>
    The rear hub is a Hugi 240 with the AE15's 2x on the NDS and Wheelsmith DB14's 3x on the DS. My wife passes though about this point and sees the wheels prior to being tensioned and comments on how funky they look...
    <img src=https://gallery.consumerreview.com/webcrossing/images/build4.jpg>
    The finished product after getting trued and tensioned. Gotta love the Airborne Ti skewers. Not bad for $15...
    <img src=https://gallery.consumerreview.com/webcrossing/images/build5.jpg>
    Here's the rear where you can see the 2x / 3x pattern. This seems to make the tension a little more balanced...
    <img src=https://gallery.consumerreview.com/webcrossing/images/build6.jpg>
    The finished product ready for a spin!
    <img src=https://gallery.consumerreview.com/webcrossing/images/Guru.jpg>
    Here's the specs:
    Hubs: Hugi 240 28h front, 32h rear
    Rims: Velocity Aerohead front, Fusion rear (no stickers for the stealth look)
    spokes: Wheelsmith AE15's, DB14's
    nipples: Sapim aluminum
    Estimated weight on our crappy, non-digital kitchen scale. Front wheel no skewer 750 grams, Rear wheel no skewer 1000 grams.
    Thanks for viewing....
  • 01-18-2004
    fonseca
    Nice pictoral walkthrough.
    For your next build you can pick up some copper anti-seize, and "color code" your different spoke lengths before you build, one length silver and the other copper.
    That's what I like to do anyway, it's an easy way to double check that I am lacing everything correctly, and I can grab a spoke without having to measure it should the need arise.
  • 01-19-2004
    thebronze
    style points
    I love the way black rim silver spokes black hubs look,
    I got the same hookup with dt xr4 and hope bulbs.
  • 01-20-2004
    Ricko
    Dude, you're inspiring me....
    Here's the specs:
    You'v got me thinking that I should go ahead and build my MTB wheelset instead of having B4me do the honors :D I can't wait to see that new crotch rocket of yours, sounds sweet as he!!.
    Me and Derek enjoyed our Sunday afternoon climbing some snow hills at Imagination Glen. It was a bit nippy out there but it was good to get out of the house into the fresh air :)
  • 01-22-2004
    ŽandyA
    AWESOME Steve-O... and a ?
    ... I just downloaded the Barnett Chapter on wheels & I PDF'd the Wheelbuilding page from Sheldon, but what is the doc in between those two in your pic?
    I've been messing around with the idea of building my first set of wheels for my CX (Carpe Diem but I've had to put that off since I bought my house early last year. I'm currently running a set of custom wheels I bought from Wrenchscience - Mavic MA3's with Campy Centuar hubs & 14g (straight) DT spokes and am looking to go up a bit to Mavic T520's & Chorus hubs - to more handle my interest in off road riding with the Carpe. Your post really re-ignited my interest again.
    Thanks,
    Randy
  • 01-22-2004
    Steve-O
    The middle one...
    The middle one is from our own Mike T. You can get it <a href=http://www.execulink.com/~dtierney/wmc/faq.htm#WTQ1>here</a>. Good luck on the CX wheels. T520's should be plenty strong... I've used MA3's offroad with good luck too.
  • 01-22-2004
    ŽandyA
    I shoulda known! I have his site bookmarked, I haven't gotten around to PDF'ing it, so I'll do that now. Thanks Steve.
    Randy
  • 03-24-2004
    Mike T.
    Niiiiiiiiiice glob of anti-sieze! Suuuuu-weeeeet.
  • 03-24-2004
    TeamTwentyFour
    A tip for all wheelbuilders
    Use boiled linseed oil on spoke threads. It works as a great lube during assembly and will thicken up over time (like the exposed ketchup crust on the ketchup bottle), which will prevent spoke nipples from loosening. It will never harden up to the point where you can't easily turn the nipples for future truing/ tensioning.
    Whatever you do, DON'T use Loctite or that Spoke Prep crap on your hi- dollar wheels!!! If thats the case, you may as well weld everything together, because you will never be able to turn the nipples for future service if you use that stuff.
    <hr><a href="http://www.teamtwentyfour.com">
    <img src="http://www.teamtwentyfour.com/!html_email/email_files/clock_new1.gif" border="0"></a>
    <font size="1"><i>Racing 'Round the Clock</i>
    <a href="http://www.teamtwentyfour.com">www.teamtwentyfour.com</a></font>
  • 03-24-2004
    Mike T.
    Use boiled linseed oil on spoke threads..............which will prevent spoke nipples from loosening.
    B-b-b-b-b-but sufficient tension is enough to stop nipples from loosening!
  • 03-24-2004
    TeamTwentyFour
    Usually, yes.....but not always.
  • 03-24-2004
    Mike T.
    That's not been my experience over 42 years of wheelbuilding. Maybe there's time yet for it to happen though.
  • 03-24-2004
    mtnpedaler.com
    Oh no?
    I guess you better stop using anti-sieze Mike.
  • 03-24-2004
    toad
    Hey Teamtwentyfour
    That linseed oil, do you boil it yourself? If so, do you do just enough for the wheelset your building, or can you store it after its boiled? Also, what about thickened linseed oil I have seen in Art stores, any experiences there? I believe that a well built wheelset may not need somethin to keep'em from loosening, but I'm talkin about wheelsets built by ME! I'm still building with my learner's permit. Also, if it can't hurt, why not? I agree that ws spokeprep sucks, though, and expensive! -t
  • 03-25-2004
    toad
    ignore (bump)
    bump it up
