Results 1 to 6 of 6
    Reputation: DethWshBkr's Avatar
    Wheelbuilders - question
    Laced up a set of wheels for my CX bike, and was rushing the job a bit, and made a mistake.
    28 hole, 2x build. My mistake, which I discovered when riding the bike, was that I did NOT over/under the leading spoke when lacing. So, the trailing and leading spokes stayed on their respective planes from the hub flange to the rim. The crosses were fine just past the flange, and ~ 2" past the flange, but I just flat forgot to cross the leading spoke under (or over, I forget) the already installed trailing.
    Now, what would that really do? I assume it would weaken the lateral stability of the wheel, or would it?!??
    "Go soothingly in the grease mud, as there lurks the skid demon"
    Aug 2017
    Re-lace them the right way.
    how bad the wrong way is may just be speculation, but not worth to try out to leave it wrong.
    2018 Motobecane Sturgis NX
    2016 Giant Toughroad SLR1
    Already did. I'm just curious.
    Reputation: Lone Rager's Avatar
    Dec 2013
    There are commercial wheels where the cross spokes do not bear on each other. Personally, I don't think it makes any difference.
    Do the math.
    Reputation: life behind bars's Avatar
    May 2014
    It's traditional, like tying and soldering which also does nothing to improve the strength of modern wheels.
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Since the bracing angle is slightly different on alternating spokes, the tension will be slightly different. I built a cx wheelset with no interlacing and rode it for years with no problems. But if I sell that set I'll probably interlace it so the buyer doesn't hassle me about it.
    The theory I've heard is that if one spoke goes a little slack, the tension from the crossing spoke will help it stay tensioned a little bit.
  1. Spoke length question for wheelbuilders out there!!
    By bryanmac in forum Wheels and Tires
    Last Post: 06-26-2018, 08:48 AM
  2. Attn: Wheelbuilders!
    By Cayenne_Pepa in forum Wheels and Tires
    Last Post: 04-19-2011, 11:30 AM
  3. local wheelbuilders gta
    By sm4k in forum Eastern Canada
    Last Post: 03-26-2011, 06:09 PM
  4. Great wheelbuilders?
    By Diggidy in forum Wheels and Tires
    Last Post: 02-03-2011, 04:35 PM
  5. Wheelbuild Question.....??? Calling Wheelbuilders
    By Ottoreni in forum 29er Bikes
    Last Post: 07-31-2008, 09:06 PM
Members who have read this thread: 58
