Results 1 to 3 of 3
    Aug 2015
    Wheel/tire width
    How narrow of a wheel can I put 26 x 4 tires on?
    mtbpete
    Reputation: changingleaf's Avatar
    In terms of function, any rim you can fit it on,. In terms of more optimal function I would recommend staying between 60 and 90mm internal rim width. It also depends on the tire your using and the terrain. You could go skinnier than 60, but you will just have to add more air pressure and loose some performance.
    Aug 2015
    I ended up going with these
    https://www.thebikelane.com/product/...atalogTypeId=1
    that's for the front, found the rear for $10 more than the front. Should be a good wheelset and help shed some weight
  1. Replies: 7
    Last Post: 09-18-2017, 02:35 PM
  2. Replies: 12
    Last Post: 09-17-2017, 05:44 AM
  3. Replies: 17
    Last Post: 08-17-2013, 10:58 PM
  4. Wheel width VS tire width
    By Fox Fire in forum Wheels and Tires
    Last Post: 12-30-2012, 01:03 PM
  5. rim width, tire width
    By kimbroughhg in forum General Discussion
    Last Post: 05-01-2011, 06:41 PM
Members who have read this thread: 45
© Copyright 2018 VerticalScope Inc. All rights reserved.
