Results 1 to 13 of 13
    Sem
    Nov 2018
    What thru axle do I need?
    Hi, I am currently building a bike and I do not have a thru axle to measure the threads by. My frame is a cube reaction with the 12*142mm hub spacing. The dropout is a cube 2090 AXH SRAM spec. Does anybody know what thru axel I need with what threads? I was thinking a DT swiss RWS E-thru.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    If it's a Cube I'm 99% sure that you need a Syntace X12 compatible thru axle.
    damned rocks...
    Dec 2014
    Forgot to add that you if you look at your NDS dropout it will be conical on the outside if it's a Syntace X12 system.
    Sem
    Nov 2018
    Quote Originally Posted by Aglo View Post
    That's great thanks for your help, I'm not sure what you mean by "NDS" and "conical". I'm new to learning to build a bike and learn all the parts it's my first time
    Sent from my Moto G (5) using Mtbr.com Forums
    damned rocks...
    Dec 2014
    DS = drive side = the side where you chainring and cassette are.
    NDS = non drive side = the side where the cassette and chainring are not .
    If you look at the picture below you will see that the side that contact your NDS dropout is conical/tapered, instead of flat. This is unique to the Syntace X12 system.
    The X12 uses an M12x1.0 thread.
    Sem
    Nov 2018
    Ok great, where did you see that it should be x-12, somewhere I think I saw e thru 1.5 thread. But I'll have to look around and ill use your info thanks
    Sem
    Nov 2018
    No wait I am wrong, the story Swiss rws was for the front fork not the frame, that wraps things up then. Thanks for your help I'll have to look into x-12 thru axles. Also saw an x-12 axel sold by cube themselves.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    What year cube reaction?
    Sem
    Nov 2018
    Quote Originally Posted by Schulze View Post
    I'm not entirely sure mate, this one:
    https://www.bike-discount.de/en/buy/...lashred-581008
    Sem
    Nov 2018
    I also replaced the derailleur hanger with a SRAM cube 2090 AXH drop out
    Barely in control
    Feb 2007
    It says X12 rear axle in the description. If your sram hangar is not x12 you're boned.
    Sem
    Nov 2018
    Oh yeah I never saw that, thanks for your help. It should be, there is a link to the hanger I have on the same site, and it is cube and everything, hopefully it's all good. Thanks for help
    Sem
    Nov 2018
    Ah yeah the hanger says x-12 aswell. Posting on the forum wasn't a waste of time though because I didn't even know about any of the axel standards!
  1. Quick release vs 10MM thru vs 12MM thru axle
    By ScabFace in forum General Discussion
    Last Post: 08-25-2013, 11:36 AM
  2. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
  3. Replies: 4
    Last Post: 06-19-2012, 04:52 PM
  4. Maxle vs DT Swiss thru-bolt or thru-axle?
    By fire_strom in forum Niner Bikes
    Last Post: 09-11-2011, 09:31 AM
  5. Replies: 0
    Last Post: 09-02-2008, 06:57 AM
Members who have read this thread: 25
