What is needed to convert 12x142 torch hubs to 12x148?- Mtbr.com
Results 1 to 5 of 5
    I have 12x142 i9 torch hubs. i bought these end caps
    https://www.fanatikbike.com/products...t=401913118723
    The drive side endcap fits fine.
    the brake side endcap doesnt seat all the way to the hub body. The hub does fit a boost frame. What is supposed to go between the end cap and the hub body? Some kits have brake rotor spacers, but this is never mentioned for this particular kit.
    What do I need to do to close the gap?
    I converted my Torch using a different kit (below). Looks like you purchased replacement 148mm end caps not a conversion kit. Kit w/ 6mm disc spacer requires a wheel re-dish. There are more generic 3 piece kits that do not require re-dish but change the cassette spacing inboard by 3mm.
    https://www.wolftoothcomponents.com/...nt=18214666885
    Quote Originally Posted by keen View Post
    I converted my Torch using a different kit (below). Looks like you purchased replacement 148mm end caps not a conversion kit. Kit w/ 6mm disc spacer requires a wheel re-dish. There are more generic 3 piece kits that do not require re-dish but change the cassette spacing outboard by 3mm.
    Im building my wheelset so the redish is ok. I need to get the hubs set right, then will build the wheel.
    Is the boostinator the best kit?
    The Boostinator doesn’t have loose spacers like the generic sets.
    what do you mean "loose spacer". Is having loose spacers good or bad?
    Anyway I bought the boostinator.
  1. 12x148 axle options for 2018 sworks enduro
    By brotheronwheel in forum Specialized
    Last Post: 01-26-2019, 09:40 AM
  2. Rear axle 12x148 2017 Stumpjumper
    By rakerdeal in forum Specialized
    Last Post: 07-19-2018, 04:54 AM
  3. Replies: 4
    Last Post: 04-10-2018, 11:57 AM
  4. Shimano boost thru axle 12X148
    By mtnbikerdude in forum Yeti
    Last Post: 11-18-2016, 11:08 PM
  5. Replies: 2
    Last Post: 01-30-2015, 03:11 PM
Members who have read this thread: 42
