What is the maximum spoke tension for the Duroc 50?- Mtbr.com
Results 1 to 15 of 15
    Reputation: huckleberry hound's Avatar
    Feb 2015
    Anybody know what the maximum spoke tension for Duroc 50's are? It's not listed on Sun Ringle's web site.
    Thanks in advance.
    Change begins by doing something different.
    Reputation: J.B. Weld's Avatar
    I don't know but ime 120 kgf is always a pretty safe bet.
    I brake for stinkbugs
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ that's what I use irrespective of rim.
    Do the math.
    Tighten until the spoke nipples round off, then back it off half a turn.
    Feb 2015
    Thanks for the guesses but nobody wins a cigar. Sun-Ringle emailed me back today. Here is their response.
    Max tension is 100-110kgf.
    Eric
    Technical Support l Hayes Bicycle
    Phone 888-686-3472
    Hayes Performance Systems l 5800 W Donges Bay Rd Mequon WI 53092 United States.
    I had it set at 120kgf according to my Park Tool tension meter. About seven of them did this.
    Dang, I have my WTB kom's @150 kfg, no problems.
    Dec 2013
    Quote Originally Posted by J.B. Weld View Post
    kfg = kilo effing grams?
    Do the math.
    Quote Originally Posted by Lone Rager View Post
    Damn straight, I don't f- around.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by huckleberry hound View Post
    The Park tensio is good for relative numbers but not so much for absolutes.
    Quote Originally Posted by mikesee View Post
    I was in the market for a tensio meter and was looking @ the park unit. I asked a local builder (experienced) what he thought of the Park unit " it has numbers and maybe you can get numbers similar but what they actually relate to..." I think he was telling me it wasn't that accurate.
    Reputation: LyNx's Avatar
    As Mike said, it's good to check the relative tensions of the spokes to each other on a build, but not sure I really trust it - I have 2, they both read different. I bought it when I first started building and fixing my own and friends wheels about 11 years ago, haven't actually used it but to check relative tension sometimes of spokes to each other, set actual tension by feel, once I do my hard de-tensioning when it feels like it's up to proper tension and get no/maybe 1 pops/pings, then I'm right where I need to be for a strong wheel.
    Quote Originally Posted by keen View Post
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Doh!
    that's what internet opinions will do fer ya, unfortunately.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Quote Originally Posted by aerius View Post
    You can actually do that ONCE, since youll only round off two corners.
    Feb 2015
    I'm also wondering if my choice of spokes could have contributed to the rim cracking around the spoke holes. I used Sapim Strong which are a single butted spoke with 13g head and elbows then straight 14g the rest of the way. I weigh 250-260# with hydration pack. This was the rear wheel. I just replaced the rim but re-used the same spokes. I'm wondering if I should change the spokes to Sapim Race DB spokes.
    When I rebuilt the wheel I did set the tension at 107kg/f with my park tool tension meter. Am I over thinking this and will I be fine with the current spokes or should I change them? I see that Nobl wheels says not to use 14g straight gauge spokes because it will cause the to crack and it will void their warranty if you use them.
    Dec 2013
    Yeah. IMO, skinny spokes are more elastic so help distribute loads among themselves when a rim deflects. Since the large majority of spoke breakage is at the nipple, head, or bend, rims crack at the nipple, and hub flanges break, straight gauge spokes are addling material where it is actually counterproductive for spoke, rim and hub longevity.
    Do the math.
  1. SunRingle Duroc 29+ Rims
    By nitrousjunky in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 01-30-2019, 07:38 AM
  2. Crazy high spoke tension, or tension meter off?
    By tuvok in forum Wheels and Tires
    Last Post: 04-25-2016, 05:25 PM
  3. Replies: 1
    Last Post: 06-08-2015, 12:48 PM
  4. What does max spoke tension for your rim mean? Average tension?
    By happyriding in forum Wheels and Tires
    Last Post: 03-23-2014, 11:03 AM
  5. Replies: 3
    Last Post: 12-09-2012, 02:49 PM
Members who have read this thread: 65
