wet days- Mtbr.com
Results 1 to 18 of 18
Thread: wet days
    Oct 2017
    wet days
    I am buying a new set of wheels for rainy and wet weather. Some mud, wet rocks and roots.
    What tires should i put on?
    I was thinking (29ers):
    Option 1 Magic mary front and back (2.35)
    Option 2 Minion dhf 2.5 WT front and forekaster 2.35 back
    Anything better? Nothing slower rolling than a minion please.
    Dec 2017
    Magic mary soft sucks on wet rocks and roots
    Oct 2017
    What about the E13 TSR?
    Reputation: Curveball's Avatar
    Aug 2015
    I'm having good luck with a WTB Vigilante on the front. Rear is a Spec. Eliminator which is working better than I expected.
    This is in PacNW wet roots and rocks.
    Riding Washington State singletrack since 1986
    hold out for the upcoming wtb verdict wet
    '18 banshee rune
    Reputation: Lone Rager's Avatar
    Dec 2013
    As a general rule, I like more smaller knobs than fewer larger knobs for slippery wet rocks and roots.
    Do the math.
    Oct 2017
    So something like a xr2 or recon would be better?
    Feb 2013
    I've had good luck with Vittoria Barzo in wet, those would be about my 1st choice, because they also do dry well. I may be in the minority, but I also have had good luck with Spec Ground Controls in wet.
    skidding is the signature of the novice; learn how to use your brakes.
    Are you guys really getting good performance on wet roots?
    I've used a lot of tires, and I can honestly say, they've all been terrible on wet roots. Either I hop the root or hit it straight on, or Im just sliding off it. Zero traction. The roots here are mostly large glass-slick redwood roots though. Maybe other roots are substantially different, but chasing traction on roots seems like an uphill battle.
    Dec 2013
    Quote Originally Posted by One Pivot View Post
    Are you guys really getting good performance on wet roots?...
    Good performance on roots means getting a slight amount of traction rather than absolutely none.
    Do the math.
    Aug 2015
    Quote Originally Posted by Lone Rager View Post
    This statement is so true!
    Hans Dampf trail star for front ( I haven't tried Addix), WTB trailboss light/high grip rear. Others that have worked well (meaning better than most), Chunkey monkey/smorgasbord, Vittoria gato, maxxis Beaver, SE2
    My opinion for front tires for wet roots is more smaller knobs, rounder profile, minimize open areas on tread, soft rubber compound. I've found that tires advertised as mud tires are typically not good as wet root tires. Mud tires have tall, spiky knobs for punching into the ground. I find that these squirm on wet roots/rocks.
    Tires like an HR2 in grippy rubber were ok straight line. But the large open area with no tread would slide immediately when leaned over just a bit.
    The downside is that I don't corner as aggressively with my wet root specific tires compared to a dry set of tires where I like to go a little squarer.
    The beaver was the best, but it only came in a very narrow 2.0, so flatted easily or got knocked off line.
    Armature speller
    Sep 2004
    I liked the 2.35 Ikon at 20psi on roots.
    Good compound and suppleness.
    Dhf 3c
    83 Ritchey Everest
    88 Mountain Goat Whiskeytown Racer
    95 Bianchi Mega Tube ti
    2012 Ibis Mojo HD
    2015 Kona Process 153
    Sep 2018
    Quote Originally Posted by davideb87 View Post
    My experience with the Magic Mary soft is completely the opposite - once i changed the tires to MM front and HD in the back (from HD front\RR rear) i got full grip on wet and muddy conditions.
    Someone tried or using the MM as a rear tire? Im wondering how it be will...
    that been said, my next set i will be DHF\DHR2, never tried them and i want to see why everyone rave about them.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    DHF 2.5 WT in a 3C front and rear. Run at least an i30 rim, ideally an i35, drop the psi a bit and thank me later. Maybe a 2.6 DHF 3C up front. Depends how hard you want to push the bike.
    Got a nice pic to attach but mtbr keeps flipping it. This place is getting glitchy. All the delays from the ads/spam, posting issues,.... Sup ??? I'm stuck inside with the flu and cranky.
    Got it. Learned to crop it a hair. Somehow that "resets" something.
    May 2017
    Last year was a very wet year in PA and I had a lot of luck with the 2.4 wide Maxxis High Roller 2 in a 3c compound. I don't know how it rolls in relation to a DHR/DHF but it is not real fast. I ride lots of roots,rocks, and mud, and this worked best. I am running ONZA IBEX 2.4 now which is also great in mud but the slightly harder compound slips on roots and rocks a little more. I think the soft 3c compound and equivalent is really what helps over tread pattern for rock and root traction.
    Reputation: Gman086's Avatar
    DHF front and rear as others have stated. I prefer the narrower sizes for mud (at least for the rear tire) as the wider ones spin out with more surface area whereas the smaller ones sink in and get traction sooner (why most mud specific tires are actually narrow). DHR2 is a nightmare on wet roots because the longer horizontal knobs slide out. The HR2 sheds mud well but doesn't have aggressive enough knobs to bite good enough. Pacific NW rider so I ride in a lot of wet conditions...
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
  1. How wet is too wet in cold upstate NY?
    By peteer01 in forum New York - New Jersey
    Last Post: 11-27-2013, 02:45 PM
  2. how wet is too wet at bent creek?
    By grodo in forum North & South Carolina
    Last Post: 05-30-2011, 04:03 AM
  3. How wet is too wet?
    By stubecontinued in forum California - Norcal
    Last Post: 01-31-2011, 11:40 AM
  4. Wet, wet, wet
    By langen in forum 29er Bikes
    Last Post: 07-06-2007, 06:12 PM
  5. Marta SLs in wet, wet, WET conditions?
    By tscheezy in forum Brake Time
    Last Post: 07-29-2004, 10:36 PM
Members who have read this thread: 106
