Vitus Nucleus VR tires- Mtbr.com
Results 1 to 2 of 2
    Jun 2020
    Hi,
    Does anyone know what are the widest tires I can use for the Vitus VR 27 and 29 models?
    WTB ST i30 rim for both those bikes. 30mm inner rim width.
    I would run a XR Team 2.35 at as low pressure as you can until you get rim hits in your trails rocky segments.
    This tire is designed with a more rounded tread profile and high volume. That design is specifically for wide rims. When you use low pressure the footprint gets flattened somewhat. This gives you a bigger contact patch for more traction. You can also run the 2.6 versions. You may not be able to get the most out of that tire unless you have a 40mm rim. You can tune it by lowering the pressure until you get squirm or rim hits. Front tire pressure for me is usually about 4 psi less than rear. Rim inserts can help you run less pressure to get a bigger footprint.
  1. Tubeless tires for my Vitus Nucleus
    By GSRswapandslow in forum Wheels and Tires
    Last Post: 05-21-2020, 12:44 PM
  2. Replies: 4
    Last Post: 06-07-2019, 10:41 AM
  3. Anyone have the 2019 Vitus Nucleus 24?
    By marx68 in forum Families and Riding with Kids
    Last Post: 01-25-2019, 08:22 PM
  4. Vitus Nucleus 29 size question
    By lnc0321 in forum 29er Bikes
    Last Post: 05-17-2018, 07:54 AM
  5. Begginer: Vitus Nucleus 275 VR. Good enough?
    By povilasand in forum Beginner's Corner
    Last Post: 06-25-2015, 01:58 AM
Members who have read this thread: 19
