Vittoria Barzo 29x2.6- Mtbr.com
Results 1 to 10 of 10
    Aug 2016
    Noticed that the Barzo 29x2.6 is available from Vittoria: https://www.vittoria.com/us/barzo-cross-country.html
    Has anyone tried these yet? Curious about actual size, weight, etc...
    The “gravel20” coupon on Vittoria’s site applies to these, and they can be had for $53.59/tire.
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    I have a set of the 27.5 versions. They're a true 2.6, about 850 grams.
    Also they're round ish so you want 35mm rims, minimum.
    Aug 2016
    Thank you, much appreciated.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Quote Originally Posted by Schulze View Post
    Good to know. Previously had some issues when the G2.0 versions first came out and sizing of the molds was off. Grabbed a 2.35" and ended up being more like 2.2" at largest. Vittoria was aware and replaced for me easily and without issue.
    Jan 2018
    How do you like them? Would you run them as a front tire for dry trail riding? Or would you run something burlier for a front tire?
    Hitching a ride
    Feb 2007
    When I first got them I was unhappy because the knobs are .5mm shorter than the 2.35 version and I felt gypped. But I had to eventually realize that these are XC tires, and they are very good at that. The large footprint makes up for the shorter knobs and grip is very good. Rolling resistance is very low. I used these at Oak Mountain state park in AL one day when the trails were wet and greasy (when are they not at that place? lol) and had no trouble keeping up with my riding buddies. I started at 18/20 but kept dropping the air pressure until I was at like 13 for the front and 15 in the rear. In the dry they are grippy (for an xc tire) and fast.
    Eventually I took them off because my superlight xc wheelset is only 30mm and that was holding them back a bit. I'm caring less about rolling resistance these days so I'm not sure if I'll build a superlight 35mm wheelset for them or sell them. The xc tires are a lot of fun but we have a ton of rocks around here and I can't trust them for all day riding, and I like more of a burly tire for bombing descents on my trail bike. True, I've never gotten a flat....but I can't trust them. Maybe I should. But no.
    I still run the 2.35 on my xc 29er.
    Jan 2016
    Do you think they can be used on 40mm rims? I have Onza Canis 2.85 on those rims, but I have problems with tubeless setup due to tire not properly gripping to rim bead on DT Swiss rims, so I would like to try them.
    Many thanks in advance,
    Hitching a ride
    Feb 2007
    Yes, they would do well on 40mm rims.
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    Curious about the new Agarro in 2.6
    It's about 100 grams heavier than the Barzo but looks pretty good...
    borrowing the best traits from the popular Martello, Barzo, and Gato models, the Agarro utilizes proven technologies from both the Enduro and XC categories. This combination of performance is ideal for the Trail category, as it provides predictable grip and efficiency in a mix of conditions.
    https://www.vittoria.com/us/agarro-e...and-trail.html
    https://www.youtube.com/watch?v=xKRydIEG-rI
    17 Fuel EX 9.9 (in progress)
    19 FM 279 carbon gravel
    17 Stache 29+
    14 GT Zaskar 100 9r
    https://kettleheadbrewing.com/
    Apr 2015
    Quote Originally Posted by NH Mtbiker View Post
    I am thinking Aggaro front, Barzo rear
    Sent from my SM-G975U using Tapatalk
  1. Weighed: Vittoria Barzo 2.35 TNT
    By westin in forum Wheels and Tires
    Last Post: 06-19-2019, 07:51 AM
  2. Anyone Running Vittoria Barzo's??
    By indebt in forum Wheels and Tires
    Last Post: 06-05-2018, 02:34 PM
  3. Vittoria Barzo & Peyote.....
    By durkind in forum Wheels and Tires
    Last Post: 06-04-2018, 04:36 AM
  4. fast track gripton or vittoria Mezcal or Addix
    By louit32 in forum Wheels and Tires
    Last Post: 09-13-2017, 06:06 AM
  5. Vittoria Barzo 29er mounting
    By seandm in forum Wheels and Tires
    Last Post: 06-18-2015, 04:56 PM
Members who have read this thread: 89
