Tubeless tires rotation..........- Mtbr.com
Results 1 to 2 of 2
    I have tubeless tires, same tire front and rear (MAXXIS MINIONS DHF 2.5). I love the tires but they are quite heavy.
    My rear tire is more worn out than my front one. If I want to rotate them, do I need to buy or add more sealant or the one already in the tire is enough?
    I don't want to keep these tires, for that reason I want to get as much as I can from both tires before buying new tires.
    Former Bike Wrench
    You should not rotate a rear tire to the front unless you like less cornering traction and crashing. Rotating tire on bicycles (road or mtb) when both tires are the same goes like this...replace front, old front goes to rear, old rear goes in the trash or recycling.
