is it true that the 54t ratchets come with stiffer springs?- Mtbr.com
Results 1 to 3 of 3
    Reputation: S.D.M.F.'s Avatar
    Jul 2018
    I didn't change out the springs when I put the 54t in.
    Sep 2019
    No, the springs are the same in all ratchet kits.
    Ole
    Ole is online now
    You can always stretch the springs out a bit to get more preload and thus stronger engagement between the two ratchet rings. More preload means grease and debris will be less able to keep the rings from engaging properly. But you'll also get a bit more noise and drag.
  1. Are the Chinese DT Swiss star ratchets any good?
    By S.D.M.F. in forum Wheels and Tires
    Last Post: 09-09-2019, 12:04 AM
  2. POV - Engaging DT Swiss with 54 ratchets
    By Neogen in forum Videos and POV Cameras
    Last Post: 05-26-2019, 01:57 AM
  3. Bontrager 54T Ratchet using a 3 pawl design?
    By Hewittalfred in forum Wheels and Tires
    Last Post: 10-17-2015, 05:11 PM
  4. Cost increase DT Swiss 36 Star Ratchets
    By Dagonger in forum Wheels and Tires
    Last Post: 04-30-2014, 11:44 AM
  5. Grease for Hugi 240 ratchets?
    By eman2 in forum Wheels and Tires
    Last Post: 08-10-2006, 07:15 PM
Members who have read this thread: 89
