Which tires are easier to slip over the rim?- Mtbr.com
Results 1 to 11 of 11
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    My Sun-Ringle thread has me asking this new question.
    In your experience, which UST or Tubeless-ready tires are easiest to mount over a tight rim?
    (Yes, I tried teh Google machine.)
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Thatshowiroll View Post
    None. By design UST and TR tires have a slightly smaller BSD. Not intended to be used on Notubes type rims.
    The Black Flag rims use the Notubes rim design which has a significantly larger BSD than ISO or UST spec.
    mtbtires.com
    Jan 2009
    Quote Originally Posted by shiggy View Post
    That's a helpful point.
    So, with Stan's rims, would "normal" bead tires be best?
    Tire God Shiggy can correct me if I'm wrong on this, but, weren't NoTubes rims designed specifically to run standard (non tubeless or TLR) tires?
    Wasn't that their whole marketing thing?
    Lead by my Lefty............... right down the trail, no brakes.
    West Chester, PA
    Not an answer to the question, but I can tell you that putting on a pair of mechanics gloves (or your full fingered biking gloves) makes a world of difference when trying to mount tight tires.
    Reputation: 7daysaweek's Avatar
    Didn't know this (about Stans rims) but makes perfect sense. I recently tried mounting up a tubeless python tire to a stans crest and it did not go well... resulted in lots of foul language and the same tire I had before being reinstalled.
    Reputation: Bike Whisperer's Avatar
    Stans BST design was/is for converting standard tires to tubeless. So yes, standard tires would be easier to mount than tubeless ready. The Sun/Ringle wheels use the first generation BST which is a little more tubeless ready tire friendly than the second generation on Stans newer rims. I ran 2Bliss tires on my Chargers with very good success, though they mount much easier on my current TCS rims. I also ran CST (Maxxis) folding bead tires on my Chargers with good success. Some standard tires seem to work well, some don't...that's the YMMV element to the Stans system.
    Jan 2009
    Thanks for the info guys.
    I was using UST to make it easier to set up tubeless, but I think I'm going to try some normal bead tires.
    Perhaps a set of Maxxis Ikons.
    Jan 2009
    I took your advice on the Maxxis. Got a pair of Ikons and no problem slipping over the rim.
    Hopefully they're easy to convert to tubeless.
    Reputation: MSU Alum's Avatar
    I put some 26x2.35 Ikon TRs on and they held air pretty well without any sealant at all in them, on Haven carbon rims.
    Reputation: J.B. Weld's Avatar
    Tires that "slip easily over the rim" + tubeless doesn't seem like a desirable combination to me.
  1. Chain Slip
    By XDR in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-10-2014, 02:54 PM
  2. Slip Slidin Away...
    By evandy in forum Fat bikes
    Last Post: 12-10-2013, 09:30 AM
  3. Carve SL BB Slip??
    By sandbox in forum Specialized
    Last Post: 09-10-2013, 11:56 AM
  4. Tifosi Slip
    By CabinDweller in forum Apparel and Protection
    Last Post: 01-17-2012, 08:35 PM
  5. Chain slip
    By keene1 in forum Singlespeed
    Last Post: 02-23-2011, 05:58 PM
