Tire inserts with tubes (Nukeproof ARD/Cushcore/ etc.) ?- Mtbr.com
Results 1 to 7 of 7
    New question here. Tire inserts with tubes (Nukeproof ARD/Cushcore/ etc.) ?
    Hi all!
    I'm a die hard tube guy (don't want to mess with sealant), and while I don't flat often (once every year or 2), I'd still like the added security of tire inserts. Looking at their shape, I'm thinking that the Nukeproof ARD or Cushcore could potentially work well with tubes, as opposed to Huck Norris or similar since those ones don't sit in the rim's bed much. I'm not interested by the Tannus since I feel that the thick foam underneath the tread would feel weird.
    Does any of you run inserts with tubes ? If so, what's your experience ?
    Aug 2019
    I just picked up some Nukeproof ARD. I don't see how you could run 'em with tubes. I've switched over to tubeless and never going back to tubes unless it's to hobble back home.
    If you aren't flatting tubes often, then you probably are a poor candidate for tire inserts to begin with in my opinion.
    theoretically this could be done using a tube with a long valve stem that would go through the foam insert and sit between the tire tread and the insert. I have heard of people successFully doing this to ride out after a flat. I ride with this in the case I get a flat.
    One issue I would see happening is that the tire bead may not seat properly with the tube not being up against the bead and rim.
    I'm interested in your results if you give it a shot.
    RSD Ambassador
    RSD Middlechild
    RSD The Mayor V4
    Giant TCX
    Giant TCR Advanced
    Slow and steady
    If you want a combine a tube and an insert, the best option is the Tannus Armour since they are designed exactly for that purpose. Blister gave them a pretty positive review.
    Tire inserts with tubes (Nukeproof ARD/Cushcore/ etc.) ?-armour-cross-section_1800x1800.jpg
    Apr 2005
    ARD stretch over time. It cause pinging sound on the rim. There a few YouTube videos that mentioned this issue.
    Sent from my SM-G965W using Tapatalk
    Oct 2018
    Quote Originally Posted by guim View Post
    Hi all!
    Added protection against what exactly?
    Rim inserts typically prevent pinch flats or rim damage (from what I know about them).
    If you run an insert with a tube, the tube could still become pinched, just on/against the insert instead of the rim.
    Inserts do not prevent punctures so that wouldn't be helpful if you want protection from thorns, etc.
  1. Nukeproof ARD inserts
    By ehfour in forum Wheels and Tires
    Last Post: 11-14-2019, 11:17 AM
  2. Leadville 100: To Use Tire Inserts or Not To Use Tire Inserts?
    By Pegleg81 in forum Endurance XC Racing
    Last Post: 05-30-2019, 11:32 AM
  3. Cushcore inserts for big guys
    By ucsbwsr in forum Clydesdales/Tall Riders
    Last Post: 08-17-2018, 02:06 PM
  4. Replies: 82
    Last Post: 06-06-2018, 03:17 PM
  5. Cushcore inserts 29"
    By Redeye in forum Classifieds
    Last Post: 08-02-2017, 09:56 AM
Members who have read this thread: 59
