Tire Inflation Survey- Mtbr.com
Results 1 to 22 of 22
    Apr 2015
    We are three high school engineering students attempting to create a new, more efficient solution to inflate bike tires on the go. We would sincerely appreciate it if you would answer all questions to the best of your ability to help with the justification of our proposed problem.
    Thank you!
    - Matthew, Griffin, and Noah
    https://docs.google.com/forms/d/e/1F...rm?usp=sf_link
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Cavermatthew View Post
    We are three high school engineering students attempting to create a new, more efficient solution to inflate bike tires. We would sincerely appreciate it if you would answer all questions to the best of your ability to help with the justification of our proposed problem.
    Thank you!
    Something wrong with the survey. Google returned a "Resource Unavailable" message.
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    Says I need permission.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I'd like to see more solutions with combustibles.
    Hitching a ride
    Feb 2007
    I've used gasoline in the past and posted about it. It works!
    Apr 2015
    I'm so sorry the link didn't work. It looked like it was only restricted to people within our high school by default. It should be good to go now with this link
    Thanks again,
    Matthew
    Meatbomb
    Reputation: Phillbo's Avatar
    Done
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Do the Q's regarding 'portable' refer to on-bike type mini pumps or garage/car floor pumps as well?
    At any rate I did the Q/A assuming you are referring to mini-pumps only.
    Jun 2016
    Done.
    Professional Crastinator
    Reputation: Fleas's Avatar
    If you can balance cost, size, speed, and reliability, you'll be famous. Don't forget about low-pressure, high-volume fatbike tires; and road bikes, which are the opposite.
    Good luck!
    -F
    It's never easier - you just go faster.
    Apr 2015
    Eatdrinkride, we are talking about mini pumps. We've changed the verbiage to be clearer. Thanks for the feedback!
    -Matthew
    Maromero
    Reputation: doccoraje's Avatar
    Done
    Combustibles are too slow, flammables are much quicker.
    Done...not sure how you're going to improve on a pump..but i'm interested to see.
    Hitching a ride
    Feb 2007
    Maybe a small pressure vessel combustion chamber that injects fuel-air reaction mass into the tire. Since frames have to be stiff anyway, it could be integrated into the down tube with little weight penalty.
    Perpetual Hack
    Reputation: mykel's Avatar
    Quote Originally Posted by Schulze View Post
    Actually I'm surprised somebody has not built an air-tank into a downtube, kind of like the pressurized air chamber pumps. Weirder crap has been tried in the past...
    Hatched in '64
    A Dirtbag since '69
    A Knomer since '07
    Knolly Fugitive
    Knolly Podium
    Knolly Endorphin
    Knolly Delirium
    Quote Originally Posted by mykel View Post
    Trapped moisture would be an issue...even more so when continuously repressurized.
    Sent from my SM-G930V using Tapatalk
    Oct 2019
    Interesting. The laws of physics dictate the use of a pump. A shock pump makes a poor tire pump, and a tire pump makes a poor shock pump, though they can look very similar to each other.
    I vote we all start using NO2 cartridges instead of CO2, and when we wreck and break ourselves we can just huff the contents of our tubes and kill the pain briefly.
    Nov 2016
    Quote Originally Posted by Crazy 8s View Post
    A pressure vessel that holds a sufficient number of moles would negate the need for a pump to be present.
    Sent from my SM-N975U1 using Tapatalk
    Oct 2019
    Quote Originally Posted by tuckerjt07 View Post
    Can moles chew through aluminum?
    Nov 2016
    Yep, gotta use that mole resistant carbon
    Oaktown Honkey on Strava
    Why dont you just make the bottom of the dropper post a pump? If you get a flat, sit on your bike, and pump your seat up and down 100 times, alone in the woods, looking like a pervert. Hahaha. Crack myself up.
  1. Replies: 6
    Last Post: 04-24-2012, 09:31 AM
  2. Automatic tire inflation/pressure monitor system
    By skiahh in forum Wheels and Tires
    Last Post: 04-23-2012, 01:54 PM
  3. trailside tire inflation-what do you use?
    By awesomeame in forum General Discussion
    Last Post: 03-27-2011, 08:38 PM
  4. Replies: 0
    Last Post: 11-14-2005, 09:41 AM
Members who have read this thread: 167
