Thoughts on repairing rim ding that's causing sealant weep- Mtbr.com
    New to me used wheelset has a few shallow sidewall dings causing some sealant to leak.
    The sidewalls are as close to straight as I can get them, I just filled the spaces with a very small amounts of RTV silicone (Permatex black) and flattened it with a razor blade. Used a q-tip to make sure the RTV stayed on the damaged lip & not where the bead sits.
    Any guesses if this will work, I'm assuming so.
    Any other alternatives?
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2015 Kona Process 153
    2019 Kona Process 153 CR 29
    Try different tire brand? My dinged rims just get a filing and off to the races.
    Reputation: EatsDirt's Avatar
    Jan 2014
    Guessing itíll work fine. Iíve done something similar, but I buttered a similar sealant at the bead/ding area while the tire was loosely mounted, then inflated.
    Well it worked like a champ. Not even a spec came out. I've used the same stuff on larger tire punctures that bubble out sealant over time.
    83 Ritchey Everest
  1. ring a ding ding WTB
    By wv_bob in forum Vintage, Retro, Classic
    Last Post: 07-14-2013, 06:04 AM
  2. Northeast round three.... DING DING
    By ajd245246 in forum General Discussion
    Last Post: 01-12-2011, 02:25 PM
  3. Weep,weep, sob, sob - SPAM
    By bigdrunk in forum 29er Bikes
    Last Post: 08-17-2005, 09:24 PM
Members who have read this thread: 37
