is this taped for tubeless?- Mtbr.com
Results 1 to 7 of 7
    pardon my ignorance, but i bought these from an LBS, with rubber so this is the first i've seen the inside of the rims, and was told the rims were tubeless but needed to be taped for tubeless. this tape looks like it's tubeless ready. plus, since it says 2bliss...i have some tubeless rim tape ready to go, as well as valves, but do i need to uninstall and reinstall??? thanks for the help.
    cheers, j-
    Reputation: watts888's Avatar
    Oct 2012
    looks tubeless taped to me. I wouldn't pull it out unless you wanted more work.
    A real easy way to check is by putting the tire on without tube or sealant and airing it up to seat in the bead. If it holds air decently well (not accounting for any leaking around the valve stem or the bead) it's good.
    "a hundred travel books isn't worth one real trip"
    turtles make me hot
    Reputation: NYrr496's Avatar
    Looks ready to me as well.
    I like turtles
    nvphatty
    Guest
    Quote Originally Posted by NYrr496 View Post
    me 2 me 2
    and it is.
    thanks all. saved me time and extra work.
    cheers, j-
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Throw a valve in and set it up. You're ready to go.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    done did it, got a ride in tonight, held air nice.
    c2l, you still on the 4th floor at dfw?
  1. Replies: 11
    Last Post: 12-10-2014, 10:23 AM
  2. Replies: 15
    Last Post: 07-24-2013, 07:31 AM
  3. Replies: 4
    Last Post: 04-22-2013, 02:24 PM
  4. no riding at FATS - trails are taped off
    By dsquaredmsquared in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 02-28-2013, 08:22 AM
  5. Replies: 2
    Last Post: 02-11-2013, 06:25 PM
