Stan's MK3 Flow rims and 2.8" tire?- Mtbr.com
Results 1 to 12 of 12
    29 mm internal width wide enough to support a 2.8? It's listed as the maximum width on their website. Anybody have any experience with this combination?
    mtbpete
    Reputation: changingleaf's Avatar
    It will work, but it's not optimal. It is about the same tire width / inner rim width ratio as a 2in tire on a 21mm inner width rim which seemed to work fine for a long time.
    Apr 2019
    I'm running those wheels with Schwalbe Magic Mary/Nobby Nic 2.8 and haven't had any problem with them.
    People used to run 3.0's on 19-21mm rims.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    I ran that combo (27.5 2.8 DHF) last year and it was flawless. Lots of Strava trophies, so it worked fine (for me)
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Thrill Bikers Unite!
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by One Pivot View Post
    Who?!
    cmg
    cmg is online now
    passed out in your garden
    Reputation: cmg's Avatar
    Mar 2012
    Quote Originally Posted by Telewacker View Post
    Aren't they 26mm ID?
    Either way ld just do it, l dont think you will die
    Edit: sorry misread, you said Flow, either way my second sentence still stands
    always mad and usually drunk......
    Quote Originally Posted by mikesee View Post
    Who?!
    Everyone who bought a nokian gazzodoli! That was basically the only option back then.
    Out spokin'
    Dec 1999
    shiggy & RedHaze used to run 3" Gazzis BITD... don't know which rims they used but since this was 15-20 years ago, I can't imagine their rims were very wide. Not sure truly wide rims existed back then. Dunno how they optimized those tires -- I never swallowed the 3" Gazzi pill.
    =sParty
    disciplesofdirt.org
    The nokians did suck, so there's that. Just saying they physically fit on those rims and people rode them. A way wider rim will also fit a smaller tire, so 2.8's on flows will work, technically.
    We more settled on tires about 2.3-2.4 on 30mm rims, in general. Some people consider 2.5's to be getting large for 30mm rims.
    While the 2.8s fit, I think you'd get more overall performance and speed with a smaller tire.
    To do it you need pressure to keep the tire sidewall from folding when you have to make a quick line change in a corner, for example. Because of that higher pressure you don't get all the tread footprint you can get with a 40-50mm rim and lower pressure. On the wide rim the sidewall can crinkle down and put more tread on the trail surface. That can be a lot of traction difference at low to medium speeds. High speeds need pressure even on wider rims.
    Aug 2003
    I ran my Gazza's (on snow) on Sun Ringle Doublewide's, Phat Albert's, Snowcats, and Remolino's. Used 'em for roughly 3 years.
    I think the narrowest of those was 44mm internal.
    The only other person I've ever seen running Gazza's was at Whistler, they were 24", and he had them on ~40mm rims.
  1. Stan's Flow rims with a 32c tire. Bad idea?
    By Mr.Ice807 in forum Commuting
    Last Post: 03-16-2015, 12:15 PM
  2. Monarch RT3 MM3 tune aftermarket availability
    By dclxvi in forum Shocks and Suspension
    Last Post: 05-04-2011, 02:31 PM
  3. Stan's Flow rims vs. DT Swiss 5.1 rims
    By qbert2000 in forum Wheels and Tires
    Last Post: 04-13-2011, 12:16 PM
  4. Clearance issues with hope 180 and MM3
    By rjpstoked in forum Shocks and Suspension
    Last Post: 04-10-2005, 09:48 AM
  5. I love my MM3 but....
    Last Post: 03-22-2005, 02:38 PM
Members who have read this thread: 86
