Stans Flow MK3 to EX3 - can I reuse spokes?- Mtbr.com
    Jun 2013
    I currently have a Flow MK3 that is due for replacement. ERD for 29er MK3 is 605 mm. If I wanted to lace up a EX3 (ERD 602 mm), could I get away with reusing my current spokes or will I need a different length?
    Reputation: PuddleDuck's Avatar
    If the ERD's measured the same (vs stated in specs...which aren't always accurate), then if your current spokes aren't that old or haven't had much usage, you could re-use your current spokes.
    Given the stated ERD difference, I very much doubt it.
    If those numbers are good, you can reuse the spokes, but change the nipples to squorx. That also assumes your current spokes arent too long or short.
    Jan 2009
    Based on personal experience, I would not waste your time. I once tried to build a wheel based on the manufacturer's listed ERD. I got 75% into the build before realizing that I was never going to get the nipples to fully and safely engage the spokes. Sure enough, I measured the rim myself and it was 3_4mm bigger than what the manufacturer listed. Had to throw out all the mangled spokes and buy a new set that were 2mm longer.
  1. Replies: 2
    Last Post: 02-02-2019, 07:23 PM
  2. Replies: 4
    Last Post: 09-28-2016, 02:37 PM
  3. Replies: 2
    Last Post: 09-05-2016, 04:25 PM
  4. Mavic xa elite wheels or stans flow mk3
    By jrgand in forum Wheels and Tires
    Last Post: 08-27-2016, 09:21 AM
  5. DT XM481 vs WTB ASYM 129 vs Easton Arc vs Stans Flow MK3
    By olibluegoat in forum Wheels and Tires
    Last Post: 07-12-2016, 05:40 AM
Members who have read this thread: 4
