Sram PG980 cassette on AL freehub??- Mtbr.com
Results 1 to 2 of 2
    Dec 2004
    So I've decided to get a set of Sun Ringle Black Flag Pros. Only consistent problem I've read about is cassettes biting into the AL freehub body. It's recommended that you run a full spider cassette like the Sram PG990. I'm currently have a 980 that still in good shape which has only the largest three gears sharing a spider. Will this be enough to avert any major damage to the freehub body? Or do I need to bite the bullet, break the bank, and get a new pg990 while I'm at it too? I'd rather not if I can avoid it, but I also don't want to damage a set of wheels that I'm dropping several hundred dollars on either.
    I have hope hubs with an aluminum body and I use the pg 980 no problem. With that said I've seen the pg 990 on chainlove recently for around $50.
  1. SRAM cassette stuck on freehub
    By wv_bob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-12-2012, 07:52 AM
  2. SRAM PG980 or PG990 Cassette?
    By Frankie Figs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-22-2010, 11:08 PM
  3. Issue Cassette PG980 9sp mtb
    By rick rocket in forum SRAM
    Last Post: 04-20-2009, 01:39 PM
  4. SRAM PG850 cassette with Hadley (Ti) freehub?
    By turbodog in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2009, 09:52 PM
  5. SRAM cassette gouging my freehub splines
    By Appendage in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-28-2005, 09:10 PM
