Specialized Butcher and Slaughter 27.5 x 2.6- Mtbr.com
Results 1 to 33 of 33
    Jun 2010
    I couldn't find much online yet on the new 2.6 tires from Specialized for fit. Here is my experience today.
    It fits in NON boost spacing forks:
    - Marzocchi 350CR and
    - Marzocchi double crown 888CR
    It also fits handily on my NS Soda EVO frame which already claimed to take tires up to 2.6 which was weird since that was an uncommon size when I got the bike a few years ago.
    350CR
    888
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I cannot wait to see more on these. Are they the same size as the DHF 2.5? Knobs bigger then the 2.3? I know the Butcher control/grid had shorter knobs then the DH casing. So I wonder about these as well.
    Reputation: RS VR6's Avatar
    Curious to know the actual size.
    Yeah, actual width would be really sweet to know.
    I'm really curious about the Slaughter 2.6. Art's is listing 2/21 availability, so I assume most Spesh dealers can get them in now too.
    What rim width do you think is too narrow for these? I assume my 24m internals are probably closer to "silly idea" territory than "adequate but sub-optimal". Thoughts?
    Quote Originally Posted by lazarus2405 View Post
    New No tubes Flow3 are very good, 29 mm id, and would consider 2,6" to be widest to fit to them, without compromising benefits of wider rim.
    Nov 2006
    Several Specialized shops near me now have them in stock. I saw a set mounted up on 30mm ID rims and they looked huge! Almost like a plus tire, but not quite. Definitely larger than a 2.5 DHF WT. I didn't put a caliper on either tire but eyeballing they looked pretty true to size. I was considering putting a set on my Nomad 3 but after seeing them I'm not sure if the Slaughter would fit in the rear.
    Jun 2010
    I'm using 29mm internal width rims
    Jan 2016
    Quote Originally Posted by hans2vt View Post
    Do you have a tire height measurement? Ground to top of tire tread. Thanks in advance!!
    my butcher 2.6 on wtb asym 29 rim is 2.5" casing and 2.44 tread. So, casing is slightly wider than tread. its side knob profile is like that on the control/grid models, not the DH model, unfortunately. However, overall the knobs are a bit bigger than the 2.3's (which measure 2.2 casing and tread on wtb i25 rim.) My DHF on 29 mm rim is 2.45 tread 2.35 casing, if i remember correctly.
    The butcher, however, is a bit taller than the dhf. The dhf has 1/4" clearance in my fork, the butcher has a hair over 1/8" clearance. But, the mrp stage has tighter clearance than most forks I think. dont think i could really fit a butcher 2.8 in their.
    The butcher rides good, Im leaving it on for now. Running 20 psi at 210 lb, ran 24 in the DHF. But i am a bit disappointed, I was hopeing for a more aggressive side knob profile.
    '18 banshee rune
    Jan 2016
    Quote Originally Posted by dwyooaj View Post
    awesome info! Looking for height though, ground to top of tire. Going to try to swing an almost plus tire in a 29er. Hoping for 28 1/4".
    Sep 2015
    Based on that it sounds like the Spesh 2.6s measure up more or less identical to the Schwalbe 2.6s. And the DHF WT measures up about the same as a Magic Mary 2.35.
    I'm loving this tyre size, fitting them in my non-plus fork and frame is an awesome bonus.
    So that's the same size as the 2.35 magic mary on an i29 rim. I wonder if they will stretch any more? Kind of funny that I might have to go to a 2.8 minion to get a true 2.6" tire (though predictable, I suppose).
    Jun 2010
    Quote Originally Posted by 52766 View Post
    On NS Fundamental rims about 29mm inner
    Butcher front 28 1/4"
    Slaughter rear 28 1/8"
    Jan 2016
    YOU ROCK!!! Thank you
    Wow, your 210lbs and ur running 20psi front? I'm running 24PSI on a 30mm and I'm 175lbs and likely 180-185lbs riding weight. I'm running them front and rear, rolling resistance is pretty high in the rear as the side knobs are touching if I run anything lower than 24 psi in the rear on my '17 Enduro 650b.
    What type of terrain u riding? I'm thinking maybe 22psi up front and 25PSI in the rear.
    May 2016
    I've been running Butchers 2.8 on the front and Slaughter 2.6 since mid Dec. For my weight + gear (155) find 18 front and 22 rear works extremely well on 35mm internal diameter rims.
    Sep 2015
    Hans, do you happen to have a tread\casing width for the 2.6 Slaughter? Trying to decide if it will fit in the rear of my Norco Sight.
    For what it's worth, I mounted a 2.6 Purgatory on Flow Mk III yesterday. Hasn't sat tubeless long and will probably stretch, but it is currently sitting at 62.5 mm (2.46 in) casing and 60.5 mm (2.38 in) tread.
    Love that the slaughter rear seems to be not as tall, but the width may get me.
    -Nate
    Jun 2010
    slaughter width
    slaughter 2.6 width - I don't have calipers, but with my tape measure I get between...
    (tread width... casing doesn't look much different)
    2 3/8ths to 2 7/16th
    or
    2.37500 to 2.4375
    not sure what I expected, that's what I get
    Dec 2014
    Quote Originally Posted by LithiumMetalman View Post
    What bike are you running them on?
    Rocks belong
    Quote Originally Posted by hitechredneck View Post
    Yes
    I like 'em long, low, slack and playful
    May 2016
    @irck
    Kona Process 111, converted into plus mode for fun days
    Feb 2006
    Any rubbing issues on those 350's on hard cornering ? I'm running a hans dampf and there doesn't seem to be much more with space , but tons more for volume
    Jun 2010
    Quote Originally Posted by maclgallant View Post
    i didn't have any rubbing issues with the CR 350. currently for the summer i'm using my 888 fork and the height on that is barely tall enough but the only rub I get is when a little piece of gravel gets stuck in the tread.
    Feb 2006
    Thanks for the reply ... I'm debating going DHF 2.5wt , 2.6 or MagicMary 2.35
    Feb 2016
    Anyone tried mounting the 2.6's on a 40mm ID rim?
    I wouldn't. Casing is already wider than tread on a 29 mm rim
    Feb 2006
    Thread bump, any one try any other 2.6" tires on this fork? (DHF 2.6" MM/NN 2.6" etc)
    Tantrumcycles #1
    Reputation: Gunnar Westholm's Avatar
    Any one who knows how much bigger in radius a Slaughter 2.6 is compared to a 2.3?
    More then 10mm?
    www.tantrumcycles.com
    Jun 2010
    I took off my 2.6 Slaughter moved to Maxxis Minnion DHF 2.5 WT. with frame and wheel flex my 2.6 was contacting my brake cable routed on inside of triangle but with 2.5 is not.
    I don't have any width measurements though
    Sep 2019
    I am curious as to how the Slaughter (or other semislicks) handle in steep sandy/gravely downhill sections? Do the side knobs dig in when breaking or do you just skid around on the small center knobs?
    After testing a "2.6" (<2.4'') Rekon I started to take interest in lower profile tread rear tires for the non-wet season. I only need loads of rear traction in 2 conditions: (wet) rock slabs and gravel downhill chutes. 2.6'' tires and low profile tires in general are great on rocks but are semi-slicks any good on loose gravel?
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    The slaughter gives up traction but does not get better rolling resistance. There is no point to it, really.
    Seeing this thread reminded me of the stack of Spec tires I have in my closet that I have zero interest in ever riding again - all 2018 models, 2.6 Purg, Butcher, Slaughter, 2.8 Slaughter and Butcher.
    Sep 2019
    Quote Originally Posted by Schulze View Post
    compared to.... ?? And why don't you like the Butcher? I test drove a 29x2.6'' Butch/Purge combo for a couple of laps on my buddy's Stumpjumper and didn't really find anything major to be disappointed with.
    Hitching a ride
    Feb 2007
    Compared to the Butcher or Purg. Or any tire that has some meat in the center.
    What I didn't like is that these tires didn't fulfill the purpose they claimed to fill. If I want an aggressive 2.6, then I want a 2.6 tire with tall, stiff cornering knobs. The Spec tires are undersized and their side knobs aren't as stiff. I found other tires that did everything better.
    If you want a fast all mountain semislick, the Morsa is what you want. It just came out in 2.6 also. If you're giving up some traction you need to get some speed in return.
    I found the XR5, which isn't even billed as an enduro/am tire, to be better at that than the Butcher.
  1. Nobby Nic 2.35 vs Butcher/Slaughter 2.3?
    By jgusta in forum Wheels and Tires
    Last Post: 08-24-2019, 10:35 AM
  2. Specialized 2.8 Butcher and 2.6 Slaughter photos!
    By artnshel in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-03-2017, 10:18 AM
  3. Butcher/Slaughter or DHF/SS Combo?
    By blaklabl in forum Wheels and Tires
    Last Post: 03-29-2017, 01:41 PM
  4. New Specialized Slaughter
    By Chuch in forum Wheels and Tires
    Last Post: 03-24-2016, 02:40 PM
  5. Specialized Slaughter
    By IPunchCholla in forum New Mexico
    Last Post: 07-08-2015, 08:34 AM
Members who have read this thread: 32
