Shimano Freehub replacement- Mtbr.com
Results 1 to 8 of 8
    Reputation: Tribble Me's Avatar
    I have a Shimano Freehub (10spd) that I am trying to replace. FH-M785 which I'm going to replace with a compatible FH-M770. From everything I've been able to find online I should be able to use a 14 mm allen wrench to remove the freehub fixing bolt. I have a 14 mm allen but it won't go into the fixing bolt.
    I'm looking for ideas. Do I need a special tool or should I try a different 14 mm allen?
    Aug 2017
    Don’t they just twist off?
    Jun 2016
    Wait until tonight. I'll tell if my experiment with my tool will work. Maybe you just have an out-of-spec tool, maybe you need a special/modified tool.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Did you try a 12 mm?
    Why are you replacing it?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: Wombat's Avatar
    Did you pull the axle out first from the non-drive side? The service instructions do say a 14mm allen key will remove it: https://si.shimano.com/pdfs/si/SI-3TG0A-002-ENG.pdf
    Tim
    I've got the axel out and the 14 mm allen is just the tiniest bit too big. (I've tried two different ones.)
    I'm replacing it because it is binding up as I try to spin it. The wheel would lock up and not spin at times. I figure that the pawls are jamming.
    It's an older wheel and I want to use it on a spare bike, so I don't really want to buy a new hub/wheel. Although I probably should have bought a new one at this point for all the time and parts.
    Just to complete the thread and in case anyone else ever has the same problem.
    I feel pretty stupid. I finally took the wheel to the LBS and the tech told me he'd seen this before. He took my 14 mm allen and a hammer and tapped it into the Freebody fixing bolt. He had to take a smaller allen from the non drive side to knock the 14 mm allen back out once we had the new Freewheel body on.
    All done in less than 5 minutes.
    Magically Delicious
    Bottom line is that you got it done and learned something through the experience.
  1. Replies: 8
    Last Post: 07-29-2019, 10:37 PM
  2. XD freehub to Shimano style freehub question
    By bpnic in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-26-2015, 11:05 AM
  3. Shimano XT freehub replacement?
    By BobbyWilliams in forum Wheels and Tires
    Last Post: 04-18-2014, 05:00 PM
  4. X9 freehub replacement…compatible with any other freehub?
    By t-stormy in forum Wheels and Tires
    Last Post: 10-01-2012, 08:27 AM
  5. Replies: 0
    Last Post: 06-28-2008, 04:55 AM
Members who have read this thread: 44
