Results 1 to 15 of 15
    Nov 2007
    Roval Rim Tape vs Plugs
    So I don't see much in terms of the use of Plugs over the rim strip on our Roval wheels - does anybody have a long-term experience with those?
    I'm with stupid
    Reputation: hitechredneck's Avatar
    The brown tape from specialized sucks. If you are going to stick with tape get some stans. I have a couple sets of those wheels and the brown tape will peel up off the rim when going to change tires. It lacks long term sticky. On my 29er wheelset I went to the plugs. They work well. However if you are trying to mount a really tight tire, it will make it more difficult since it is taking up more room then tape in the drop down section of the wheel. I found stans tape was the happy middle ground.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Is that "brown tape" tape? I thought it was a plastic strip without any adhesive. When new and aligned properly it works OK but I've seen it get misaligned and cause leaking. Agree Stan's or similar would be better. I use Kapton. I have no experience with plugs.
    Do the math.
    I'm with stupid
    Guess it is called a strip instead of tape.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Aug 2015
    Ive had better luck with Orange seal tape in terms of shelf life.
    Sent from my SM-G930V using Tapatalk
    Reputation: sfer1's Avatar
    Schwalbe's and DT Swiss' tapes are way better and come in more widths than Stan's.
    Mar 2016
    Stan's tape is awful, relatively speaking.
    West Chester, PA
    Those plugs are air tight?
    Mar 2017
    Plugs are sealant and air tight. I have 3 sets of Roval carbon rims. One with the plugs and the other two with the Spesh tape, multiple tire changes on all and no problem with any of them. I even had some spokes replaced on one rear wheel and used the same strip without any issues. I see no problem or benefit from either and both work just fine.
    Huh, those plugs are nifty. Wish my rim bed were flat enough to take them! And i can see them causing problems with tight tires. Still an easier solution than tape...
    West Chester, PA
    Must... have... plugs...
    Hmmm. Not on the website. Will call the local spech shop tomorrow.
    West Chester, PA
    Local dealer says the plugs are no longer available. Spech ditched them for the reusable rim strips.
    Reputation: ewarnerusa's Avatar
    My Roval Traverse brown tubeless rim strips were no longer functional so I decided to try the plugs which came with the wheels. Easy to install and the tire went on and inflated fine. I added plenty of the new Slime tubeless sealant. One tire held air OK with a slow leak, I didn't do much trouble shooting to find out why. The other tire leaked like crazy from the valve stem and went flat within minutes, despite a quick ride around the drive way plus shake and spin efforts to distribute sealant. By the next day the slow leaker was flat, too. With each plug being a potential source of leakage into the rim cavity that ultimately escapes through the valve stem, I scrapped the experiment and went back to ol' reliable strapping tape. Wheel one held air overnight without even adding any sealant. Wheel two is tonight's project.
    Reputation: coke's Avatar
    I bought a set of Roval Traverse SL Fattie wheels around 2 years ago and used the plugs. Extremely simple to install.
    I've moved the wheels between 5 different bikes, have done countless tire changes, and would guess they have 1,500-2,000 miles on them.
    I haven't had a single issue with the plugs.
    Does anyone know if the Roval rim plugs are reusable?
  1. Roval tubeless wheel plugs with plus tires?
    By Tjaard in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 10-21-2016, 09:44 PM
  2. Roval Fattie SL Rim Plugs in Other Wheels?
    By mopes in forum Specialized
    Last Post: 12-14-2015, 05:54 PM
  3. Specialized Roval tubeless rim plugs on Enve rims?
    By Leprechaun in forum Wheels and Tires
    Last Post: 11-10-2014, 08:08 PM
  4. Best tape solution for Roval wheels?
    By Alias530 in forum Specialized
    Last Post: 05-27-2014, 01:45 PM
  5. Gorilla tape OVER Roval tape?
    By freeriderB in forum Wheels and Tires
    Last Post: 03-19-2013, 05:54 AM
Members who have read this thread: 69
