Rim Offset? - Need different hub?- Mtbr.com
    Jun 2005
    Sorry for such a newb question, but...
    My kid blew out his rear wheel. I started looking at a new rim (RaceFace ARC 30 HD) and it is offset. I would imagine i don't need a special rear hub for this and I can just have the rim built around his Hope EVO Pro 2 hub correct?
    There isn't like some special rear hub i have to get is there?
    Sorry, i know nothing about offset wheels apart from i have read they make it stronger i guess.
    Thanks for any input.
    Jan 2009
    you don't need a special hub, but you need to include the rim offset in spoke length calculations. the offset rim means that the "bracing angle" of the spokes as they come out of the hub is closer to equal on each side, which should make a stronger wheel.
    Jun 2005
    Quote Originally Posted by mack_turtle View Post
    Cool, thanks. I kinda figured that with the spokes. I can lace MX wheels, i suck at MTB wheels. LBS will be doing this one.
    Jan 2009
    if you can lace a MX wheel, you can lace a MTB wheel. believe in yourself! also, if your LBS is anything like the ones around here, they are swamped with labor due to the pandemic and will take weeks go get that wheel done.
  1. Ai offset with an offset rim
    By Some1callthekomsquad in forum Wheels and Tires
    Last Post: 09-23-2017, 08:35 AM
  2. Do Different Brakes Need Different Mounts?
    By Moosey in forum Downhill - Freeride
    Last Post: 09-02-2011, 10:53 PM
  3. Replies: 5
    Last Post: 11-01-2004, 11:46 PM
  4. Replies: 12
    Last Post: 08-30-2004, 02:21 PM
  5. asymmetrical offset rear rim vs. non-offset rear rim
    By ashwinearl in forum Wheels and Tires
    Last Post: 07-22-2004, 12:10 PM
Members who have read this thread: 18
