Results 1 to 5 of 5
    Jan 2017
    Rekon 27.5 x 2.8 Opinions..
    I picked up one for the rear of my Spec. Enduro 2017 27.5..
    I received the tire today and it notes on the tag a min. inner diameter rim of 39mm. That is my concern I have Roval Traverse carbon rims w internal diameter of 30mm. So for those who are in the know... should this tire work just fine or is there a risk that makes it not worth trying....
    I will also be using a Vittora air liner with this tire...
    Thanks in advance..
    Dec 2017
    I have a friend who runs 3" tires on 25mm rims. You'll be fine, it's just not ideal. Are you sure it'll fit the frame?
    You can get more performance out of some high volume rounded profile 2.35 tires on your rim and use the 2.8 on a wider rim for your front. If you put it on the 30 you'll need to run it at higher pressure than a 2.35. Low pressure for the 2.35 gets you a bigger more conforming footprint.
    Jan 2017
    it will fit the frame on the rear (Bike magazine measured the actual tire at 2.65" the bike is designed for 2.6 which is on there now and have plenty of room in the back, already a tight squeeze up front.
    Thank you for the responses. I was concerned about the bead getting a good seal..
    Jan 2017
    Quote Originally Posted by eb1888 View Post
    I have a 29r with 2.35s, so looking for something different for this ride.
  1. Is Recon Gold a stiffer spring that Recon Silver
    By Fargo1 in forum 29er Components
    Last Post: 02-18-2014, 11:36 AM
  2. 2011 rockshox recon gold solo air internals into a 2008 recon 351?
    By mobile chernobyl in forum Shocks and Suspension
    Last Post: 07-08-2013, 11:59 AM
  3. 2010 Recon Race 120 vs 2011 Recon Gold RL 120
    By mmckechnie in forum SRAM
    Last Post: 03-27-2012, 05:20 AM
  4. Recon 335 SLite vs Recon Silver TK
    By tavorh1 in forum Shocks and Suspension
    Last Post: 09-03-2011, 08:01 PM
  5. 2010 Recon Race 120 vs 2011 Recon Gold RL 120
    By mmckechnie in forum Shocks and Suspension
    Last Post: 06-17-2011, 02:12 AM
Members who have read this thread: 34
