PSA: Volume of Maxxis Rekon 3c 2.4 vs Ardent DC 2.4, 29er- Mtbr.com
Results 1 to 6 of 6
    I was looking for a similar volume tire to my Ardent which is a DC Exo 29 x 2.4. Figured that the Rekon would be a good match for the front. Bought the Rekon 3c Exo WT version in 29 x 2.4.
    Both mounted to Flow EX which have 25mm internal width. To my surprise the Rekon is significantly lower volume after 24 hours mounted at 40 psi.
    The Dual Compound 2.4 Rekon version may be similar volume but I couldnít find that info online after multiple searches.
    Hope this helps someone avoid a bad purchase.
    Reputation: Lone Rager's Avatar
    Dec 2013
    How did you measure the volume?
    Do the math.
    With my eyes. If you want the numbers...
    Bead to bead of Rekon measured maybe 5mm narrower but donít recall the exact number. Digital caliper shows Ardent being about 3mm wider at sidewalls, 2mm taller casing (not at center knob height) and slightly wider at corner knobs.
    Helpful?
    SPECIALizED
    Reputation: UPSed's Avatar
    Dec 2010
    Not surprised. My 2.35 Ikon was significantly larger than my 2.4 Rekon.
    Sep 2014
    That's weird. I just measured a 2.4 Ardent and a 2.4 Rekon 3C and they were the exact same width, laid flat, edge to edge. And I've used several 2.4 Rekons, both DC and 3C, and all have measured out right at 2.4" after a day or so of stretching. But these were on 30 and 35 rims, which the WT 2.4 Rekon were designed to be used on. But the WT treatment affects corner knob placement more than bag size.
    Ibis Ripmo
    Ibis Ripley V4
    Ibis Mojo HD4
    Pivot Mach 4SL
    Pivot LES SS
    Colnago C60 Disc
    Quote Originally Posted by BmanInTheD View Post
    Interesting. I kind of assumed that the width of the 2.4WT Rekon would increase when mounted to a wide rim but at the same time, Iíd expect the height of the casing to drop. Maybe this Rekon will stretch some more over time?
    For comparison, I have two other Ardents in DC Exo 2.4... one 26er and one 27.5. The apparent size of each seems to be as voluminous as the 29er Ardent, which is to say that theyíre all fat tires for 2.4. Anyway, if things change Iíll post back.
  1. 3C in the front, DC in the rear, or 3C front & rear?
    By zuuds in forum Wheels and Tires
    Last Post: 09-19-2017, 06:22 PM
  2. Maxxis dhf 3c or highroller ii 3c for front?
    By baotuan in forum Wheels and Tires
    Last Post: 08-26-2015, 10:19 AM
  3. Maxxis Minion DHF EXO 3C - No 3C sign on the tire
    By Hokidachi in forum Wheels and Tires
    Last Post: 04-11-2013, 09:37 AM
  4. IKON exc/3c VS exc/3c/EVO (florida)
    By everything motorcycl in forum 29er Components
    Last Post: 12-03-2012, 01:26 PM
  5. Maxxis Ardent 2.6 3C and 2.4 60a - Tested
    By RSutton1223 in forum Downhill - Freeride
    Last Post: 05-29-2008, 09:13 PM
Members who have read this thread: 27
