Park Tool TS-4 vs TS-2.2- Mtbr.com
Results 1 to 9 of 9
    Aug 2019
    I want to but a wheel truer and my head is spinning.
    I have come to realize that the TS-2.2 and the TS-2.2p are the same dimensions, just different finishes.
    My largest wheel is a 4.6" fatbike tire on a 26" wheel.
    I have found a TS-4 for sale which seems like it was sale only for a short period of time before the TS-4.2 was released.
    For even money, the TS-4 seems to be a better buy than the TS-2.2 since it can handle a larger wheel and can also handle through axles with no extra components.
    Is my thinking right?
    Thanks,
    Chris
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    The cost difference is a lot unless you happen across a deal. I wonder how wide a fatbike rim is? I don't own one to make a proper guess If you remove the tire, I'd guess the 4" capacity of the TS-2.2 would be enough...at least that was my thinking before purchasing. I already had a 15mm to QR adapter for the front so all I needed was the 12mm for the rear (like $5-10 off fleabay).
    The fatbike factor would be the only reason to consider just about doubling the cost vs. the TS-2.2. Are fat rims that wide or is it the convenience factor of not removing a tire? Too far outside what I do to give any more of an answer, but hopefully it helps.
    :nono: :thumbsup:
    The parts to do TA's arent very expensive. $10-$15 per standard, its nothing crazy.
    I used to build wheels every day on a cheap modified spin doctor stand. I bought it "just to get started" but all it does is hold a wheel in place while I do all the work.
    Id get whatever fits all the wheels you do, which is most stands these days. Honestly, I think the nicest one is the jobst brant DIY wood stand. If you really cant do woodwork, id consider paying someone who can over buying a park.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have a 2.2 and I built lots of fat wheels on it. I have the adapters for the extra width of the hubs. The calipers handle 100mm rims just fine.
    I want a TS-4 just because it looks badass but I REALLY don't need it. I'm probably gonna get it anyway.
    I like turtles
    And He was Not
    Reputation: Enoch's Avatar
    The TS-4 Is a nice stand. I built a lot of wheels on my 2.2. But I'm way happier using the TS-4. If you can afford the 4, I would defiantly get it.
    The Truth is out there. Here it isThe TRUTH
    Aug 2019
    Quote Originally Posted by Enoch View Post
    Do you have the TS-4 or the TS-4.2? The old model is in my budget, the new one is not.
    Thanks,
    Chris
    Jul 2016
    I have a 2.2 and a ts-4, I ended up building my fatbike wheels this summer, on the 2.2 because it was portable. My ts-4 is mounted to a bench in the garage and I was too hot to go out there. I like the thru axle mounts on the ts-4 and ended up getting the adapter for the 2.2. It all works the way it is supposed to.
    And He was Not
    Mine is a TS-4. I' not sure what changes were made on the 4.2. The main body looks the same. The only thing I see that is a different is handle for the arms.
    And He was Not
    I did some searching and found they re located the caliper swing arm handle back to the middle on the 4.2. I like the offset location just fine on the 4 version. They added a sharper nub to the axle holder, this is a good thing but I rarely use the that feature. Lastly, It looks like the v slots might have got smaller on the vertical arms of the 4.2. the Ones on the 4 version are really deep which I like a lot
  1. any reason to keep the PT TS-2.2 vs TS-4?
    By ehigh in forum Tooltime
    Last Post: 08-30-2017, 09:49 AM
  2. Replies: 3
    Last Post: 10-09-2016, 06:43 PM
  3. What do I need: Park TS-2 or TS-8?
    By bbgobie in forum Wheels and Tires
    Last Post: 09-19-2007, 12:45 PM
  4. Park ts-2 versus ts-3
    By pherret in forum Wheels and Tires
    Last Post: 01-13-2005, 01:58 PM
  5. Park ts-2 versus ts-3
    By pherret in forum Tooltime
    Last Post: 01-13-2005, 01:56 PM
Members who have read this thread: 68
