Ok, I have done close to 1000 spoke calcs in 25 years- Mtbr.com
Results 1 to 5 of 5
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    I need a second opinion
    Stan's Crest 650b
    Hope Pro II 6 bolt, 20mm
    3 cross
    32 spokes
    12mm nipples
    What do you get?
    Custom Wheelbuilder
    Reputation: Zen Cyclery's Avatar
    I get 272mm for the disc side and 274mm for the non disc, that is, assuming that I used the correct hub dimensions. Here's the ones I found.
    Front:
    Flange Diameter - 56(L) 54(R)
    Offset (center-to-flange) - 19.5(L) 34(R)
    spoke hole diameter - 2.6
    Check out www.zencyclery.com for fully customizable, handbuilt wheels.
    www.facebook.com/zencyclerywheels
    Humor me...I got 170 and 171.
    Have the hope dims changed?
    Just for giggles, what do you get if you calc the non disc side 2 cross?
    I have relaced this wheel 3 times, I am beyond frustrated....
    Have you checked the ERD of the rims? I have had 29er Crests that were off the number that Notubes states on their site by 3-4 mm.
    On the Hope site (somewhere..), there is a table with old Pro2 dimensions and one with new dimensions, but they do not differ that much that you get in trouble with spoke lengths.
    Custom Wheelbuilder
    Quote Originally Posted by rideit View Post
    Sounds like an ERD issue to me. What is the ERD that you are using?
