Results 1 to 9 of 9
    Oct 2013
    Norco Revolver Rear Axle - Too Short?
    Hi all, I'm working on a 2017 Revolver HT 9xx and just installed the rear wheel only to see that the thru axle is too short?
    I have a 7X01 with the quick release axle, not the one in the pics, that is long enough both on the Revolver 27.5 and this 29er as well
    Is that considered "normal"? It doesn't look safe for the threads in that rear triangle. Thanks
    2019 Yeti SB100
    2016 Transition Smuggler
    Jul 2017
    What happens if you remove that spacer from the second pic?
    Oct 2013
    Thought about it but it's there to stay...doesn't come off unless I cut it? I'll take another look.
    2019 Yeti SB100
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    So it's a boost rear with a 142 axle, right?
    May 2005
    Wrong axle...that's the axle they spec for their steel/gravel/road frames.
    Oct 2013
    No, it is 142 rear with the 142 rear axle, definitely looks like it's too short for the job? I bought the frame like that...
    2019 Yeti SB100
    May 2005
    It is too short for the job. Norco has two different thru-axle lengths for 142mm...they sent you the wrong one.
    You have the wrong one. You need a Maxle. Check In the part number from Norco.
    Usualy with the one you got the head is recess in .
    Oct 2013
    Here are the specs for it - https://www.norco.com/downloads/bike...mall-parts.pdf
    And the Maxle is the lightest, I think the SRAM P/N is 00.4318.005.027
    Maxle Stealth Rear Thru Axle: 12x142, 174mm, M12X1.75
    Now I have to measure what I have at home, Woolf Tooth has a nice "how to measure" on their site - https://bit.ly/2CiugPE
    2019 Yeti SB100
  1. Revolver Rear Axle - Too Short?
    By mevnet in forum Norco
    Last Post: 1 Week Ago, 08:47 AM
  2. Replies: 1
    Last Post: 07-27-2018, 12:38 PM
  3. Replies: 8
    Last Post: 01-12-2018, 09:54 PM
  4. Norco Revolver FS Rear Shock Dimensions
    By russmu66 in forum Norco
    Last Post: 03-10-2016, 12:25 PM
  5. DMR Revolver SS Disc 10mm axle 36h (rear hub)
    By jasevr4 in forum Where are the Best Deals?
    Last Post: 04-02-2007, 02:14 PM
Members who have read this thread: 17
