Nokian NBX 2.0 Lites too small for a big guy?- Mtbr.com
Results 1 to 10 of 10
    My name is Steve and I'm a weight weenie. At 6'3" and 195lbs I currently ride Mythos 2.10 tires, primarily in hardpack/dusty/SoCal conditions and do about six races per year. To save weight and benefit from less rolling resistance, I am seriously considering switching to the Nokian NBX 2.0 Lites. My concern is that I am a fairly big guy, as bike racers go, and perhaps this is too small a tire for me. Does anyone have any negative experience with the Nokian's, or other suggestions for someone my size? Should I go with the 2.2's as an alternative? Thanks.
    ol'guy who says hi &waves
    Reputation: fred-da-trog's Avatar
    Oct 2003
    Hi Steve.....
    Quote Originally Posted by Dirt Pilot
    ...I'm Fred at 195 with a little lower center of gravity than you.. Been running NBX 2.0 @ 40psi off and on since Dec in Norcal. Haven't had any problems, but I'm not a really agressive rider. Anything over a 2ft drop and I'm walking. Ran them on FS at Sea Otter(hardpack and sandy s-track) and on my SS a few weeks ago in somewhat rocky conditions a they worked great. I just replaced the worn out rear. I think they're fine under certain conditions.
    I may not have the best of everything, but I have the best everything that matters.
    Quote Originally Posted by fred-da-trog
    Fred,
    Thanks for the insight. Sounds like you have had no problems with them. Where did you buy them?
    No personal exp. but a good friend who's a pretty competitive Expert XC guy had a pair and didn't really care for them. They're real skinny, like a 1.85....
    I'm more interested in the new 2.2 or 2.3 Lite version thats supposed to be coming out.
    Anybody have info on these???
    BTW - My buddy is only 150lbs.....
    I'm 200 and 6'5", and seeing some size inspires one's confidence.
    Just my 2 bits....
    Reputation: KMan's Avatar
    The 2.2 lites
    "should" be available per Nokian in about 30 days.
    I have been running the 2.1 lites, I'm 185 lbs and have no problems with them for their intended use.
    KMan
    Quote Originally Posted by DMFT
    Just my 2 bits....
    Thanks Kman, those 2.2's will be getting put on the "want list" at the shop.
    Just passing through....
    Reputation: DaFireMedic's Avatar
    If the Nokians don't work out for you, look at the Kenda Karma DTC's. They weigh roughly the same, usually in the 460-480 range, and are fast rolling with good grip. They are also a surprisingly big, large volume tire, larger than many if not most 2.1's. I weigh 185 and they have been working out great.
    I am also looking forward to trying the larger NBX lite when it comes out.
    If you want to play with electricity, more power to ya......
    Just my 2 bits....
    Are they really that skinny? Can anyone else confirm this? Thanks!
    Reputation: craig's Avatar
    Yes, they are that skinny. When I set them next to my Python AirLite 2.0, they look tiny. They are also "low-volume", ie not tall.
    On the plus side, they roll fast and grip well in most conditions. However, my rear tire is wearing down after about 600 miles. I will probably have to replace it before the year is over. Oh well, you pay for performance.
    Oct 2003
    On vacation
    Fred,
    sorry long to respond. Well not that sorry. I just spent 8 days roaming Sierra trails from Downieville to Bear Valley CA. Here's where I've found the best deals so far http://aebike.com/site/page.cfm?PageID=30&SKU=TR1177
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Send me your "used" Nokian NBX Lites
    By Chester in forum Weight Weenies
    Last Post: 06-11-2004, 02:31 PM
  3. Nokian NBX lite 2.0 vs Schwalbe Jimy Lite 2.1's
    By KMan in forum Weight Weenies
    Last Post: 05-11-2004, 12:25 PM
  4. Mounting UST Nokian NBX Lites on Crossmax
    By nathasm in forum Wheels and Tires
    Last Post: 04-26-2004, 08:40 AM
  5. Nokian NBX Lite 2.0 + Stan's = OK?
    By fred-da-trog in forum Wheels and Tires
    Last Post: 03-11-2004, 10:24 AM
