Newbie tire questions - moving from mtn bike tires to urban tires- Mtbr.com
Results 1 to 3 of 3
    Oct 2013
    Hello,
    I have a 1994 Bridgestone mountain bike (MB-3 frame and MB-4 components) with Ritchey Z-Max tires. The tires are 26x2.1 or 26x2.2 Ė I canít recall exactly.
    Now that I have a new mountain bike Iím going to use the Bridgestone for mostly paved paths (70%) and light-duty gravel or hard-packed trails (30%) with my family. Iím thinking that slicker tires would make the bike quieter, smoother, and more efficient.
    It looks like the Continental Town and Country tire would be a good choice for me. They come in two sizes, 26x2.1 or 26x1.9. Which would be a better choice for me? Would they both fit fine on my rims? Another question Ė would I need or want new inner-tubes when swapping tires? It looks like inner-tubes come in different widths. Thanks for any input!
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Those tyres will both fit your rims. And your existing tubes will be fine. Where you run into trouble with tubes is when you try and fit a large tube (like a 2.1 - 2.35 size) into the likes of a 1" or 1.5" road slick, and end up pinching the tube between the bead and the rim, or run a very narrow tube (like a 1") in a large tyre like a 2.4
    Sizes - the 2.1 will be heavier but let you run softer pressure off road if you want, leading to a bit more grip and cushion. It's common on MTB's to run a larger tyre up front for more steering control and a narrower tyre out back for easy pedalling, especially on hardpacked surfaces.
    A style of tyre that works OK on road and light duty trails is this type - slick centre but with edging knobs for cornering grip off road. Often quite cheap too and of a harder compound to last longer on pavement.
    Kenda Krisp Tire > Components > Tires and Tubes > Tires | Jenson USA Online Bike Shop
    Kenda Kross Plus Tire > Components > Tires and Tubes > Tires | Jenson USA Online Bike Shop
    Less isn't MOAR
    Oct 2013
    Thanks so much! That information really helps!
    Quote Originally Posted by Sideknob View Post
  1. Replies: 4
    Last Post: 07-25-2012, 06:35 AM
  2. Newbie tires/wheel questions
    By kingofZroad in forum Wheels and Tires
    Last Post: 03-06-2012, 09:48 PM
  3. Looking to purchase quality urban tires.
    By ymduhh in forum Urban/DJ/Park
    Last Post: 08-10-2011, 10:06 PM
  4. Tire newbie looking for new tires
    By hogarth in forum Wheels and Tires
    Last Post: 06-05-2011, 07:49 PM
  5. Mtn BIke Tires: Do they have to be the same tire?
    By pantera123 in forum Colorado - Front Range
    Last Post: 03-31-2011, 09:51 AM
