New wheel fit- Mtbr.com
Results 1 to 5 of 5
Thread: New wheel fit
    Jul 2018
    New wheel fit
    I just received a new set of fat carbon wheels from Light Bicycle with Onyx hubs and new rotors. I've installed both and noticed that the rear caliper needs adjustment due to rotor rubbing. The front wheel needed no adjustment. Is this to be expected with a different wheel set?
    This is the first time I've owned a second set of wheels.
    Reputation: Myers005's Avatar
    Jan 2011
    New wheel fit
    Yes, I usually have to readjust brake calipers when switching wheels. Seems normal to me
    Reputation: PuddleDuck's Avatar
    Quote Originally Posted by Mark K View Post
    If you're using 6 bolt hubs, you can use spacers from Syntace to space out the narrower hub, so you don't need to adjust your caliper when you swap wheels
    https://www.universalcycles.com/shop...s.php?id=52017
    https://bikerumor.com/2015/11/11/jus...otor-shim-kit/
    Reputation: upstateSC-rider's Avatar
    Totally normal, sometimes shifting changes a little also and you have to adjust shift cable tension or high/low limits.
    Niner Jet 9 RDO, Scalpel 29, XTC 650b, 04 Stumpjumper FSR Pro, Trek Rigid SS - No suspension, no gears....no problem
    Jul 2018
    New wheel fit
    Those will solve my problem, thanks for the link!
  1. would this wheel cover fit a 29er wheel?
    By Philphine in forum 29er Components
    Last Post: 12-28-2015, 08:45 AM
  2. Replies: 1
    Last Post: 09-23-2013, 04:41 PM
  3. Replies: 3
    Last Post: 07-29-2008, 03:59 PM
  4. Any way to modify a rear disk wheel to fit as a front wheel ?
    By th3crack3r in forum General Discussion
    Last Post: 04-05-2007, 05:43 PM
  5. Fit...Fit...Fit questions (bike fit, that is!)
    By Alan in forum General Discussion
    Last Post: 04-02-2007, 07:06 AM
Members who have read this thread: 26
