Maxxis Minion DHF 29x2.6"?- Mtbr.com
Results 1 to 48 of 48
    The new Scott Ransom 29er comes stock with DHF 29x2.6 front and rear. These tires are not on the Maxxis website. Does anybody know if they are releasing this and the DHRII in the 2.6 tire size to the public? If so, when? I love the 27.5x2.6 DHF/DHR II combo on my Evil Insurgent and would like to run them on my Orbea Rallon.
    Reputation: noosa2's Avatar
    Oh please, please, please let these be real 2.6" wide tires. I'd love a 29x2.75 or 29x2.8 DHF but if this is a real 2.6 then I'm still going to be happy.
    Kind of hard to tell but it looks like the Specialized SJ on the cover of this months Mountain Bike Action mag is running a 29x2.6 DHF tire up front. Hope they hit the stores soon and as BigJZ74 says above I hope they release a DHRII in the same size.
    Reputation: SikeMo's Avatar
    Mar 2013
    Any updates on the ETA of this thing?
    Moderator Moderator
    Reputation: Harryman's Avatar
    Quote Originally Posted by noosa2 View Post
    Knowing Maxxis, they're probably a true 2.5" with a 2.6" label.....
    Reputation: Streetdoctor's Avatar
    Oct 2011
    I haven't heard of the DHR but a 29x2.6 DHF EXO+ and EXO is on the way. All of my 2.5's measure slightly over 2.5 with a micrometer on a 30mm ID rim as well...
    Denver, CO
    Sep 2014
    IDK what kind of rims some of you run, but every Maxxis Ive mounted in the last couple of years (at least 30) have been right at the size listed when used on the appropriate rim size. Including a bunch of 2.5 and 2.6 tires, both 27.5 and 29.
    Ibis Ripmo V2
    Ibis Ripley V4
    Ibis Mojo HD5
    Pivot Mach 4SL
    Pivot LES SS
    A road bike
    SPECIALizED
    Reputation: UPSed's Avatar
    Dec 2010
    Quote Originally Posted by BmanInTheD View Post
    Especially if you inflate them to max pressure for 24 hours.
    Mar 2013
    It's here! Worldwide Cyclery has them. It's showing 1015g and 120 TPI. Probably pretty thin, so I would only run it on the front. Sounds perfect to me.
    WNC Native
    Reputation: nitrousjunky's Avatar
    Quote Originally Posted by SikeMo View Post
    Will be very interested to see how these actually measure on a proper rim.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Mar 2013
    Quote Originally Posted by nitrousjunky View Post
    I've got a 36mm internal Nox Kitsuma. Will mount it sometime after Wednesday and measure.
    SPECIALizED
    Dec 2010
    I'm sure it's a different casing but my 29x2.6 Rekon measures 2.6 on a 34mm internal width rim.
    Mar 2013
    Mounted it up to a 36mm internal width rim at 30psi.
    Measured 2.533 in. Maybe it will stretch out overnight.
    Weight was 1003g, which is surprisingly light!
    Thanks for taking the time to measure, weigh and update us. I'd be interested in seeing what it measures in a week or two.
    Just Heard from a vendor for Maxxis that the DHRII 29x2.6 is in the pipeline but due to arrive mid march.
    Hey SikeMo, did it's stretch at all after a week?
    Mar 2013
    I'll check it in a couple more days. Didn't look like it, last I checked.
    Mar 2013
    Just measured it after my first long ride on it. It's now at 2.56in. Still a great tire, if a little smaller than advertised.
    WNC Native
    Not horrible. The sad thing, the original non-WT 29x2.5 DHF measured 2.6 across the knobs.
    Did u let it stretch with it inflated to Max PSI?
    Thanks.
    Perpetual Hack
    Reputation: mykel's Avatar
    Quote Originally Posted by BigJZ74 View Post
    Good tip.
    Going a bit OT....
    I learned years ago from a pro mech to air them up at full pressure and let them sit for a few hours / overnight to stretch out the carcass. Was told that it lets the tire stretch out in a static environment which minimizes problems later. As well any soft spot / bulge may start to show. There is a higher possibility for problems if the tire is stretching when in hard and heavy use.
    Over the decades you get into a bit of a routine... mine is...
    (when time allows, emergency situations do not count)
    Mount the tire and air it up to seat the bead.
    If it gives you a problem throw a tube in it.
    If you don't have a tube, or are pressed for time. Rope it.
    You put a rope around the tire. going around the circumference with the tread.
    Tighten the rope until it forces the bead into the rim channel, then hit it with air.
    If it seats and the beads and seems to hold a bit o'air for a few seconds...
    Split the bead, or pull the valve core
    Add tire spooge.
    Reseat the bead and air it up.
    Do the Spin and Wobble dance to get the entire inside coated
    (don't forget to do the tire / rim interface.
    Check pressure.
    Rinse and repeat until it holds air.
    Air it up to max pressure and walk away overnight.
    Next day
    Check pressure and do the tubeless dance if required.
    or
    Pull the tube.
    Reseat the bead and don't forget the tire spooge.
    Air it up.
    Check pressure.
    If anal, measure width. Publish to EmptyBeer
    Air down to riding pressure, mount wheels and go ride.
    Hatched in '64
    A Dirtbag since '69
    A Knomer since '07
    Knolly Fugitive
    Knolly Podium
    Knolly Endorphin
    Knolly Delirium
    Reputation: LyNx's Avatar
    Curious, is this measurement taken at the casing or widest knobs? Also curious as oithers asked, did you inflate to max PSI and let sit at least overnight to grow?
    Thanks for that info, looking to pick up one to run on the rear of my rigid to see if it can take enough of the edge off and give enough cush and drop some weight over running a 29x3".
    Quote Originally Posted by UPSed View Post
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    SPECIALizED
    Dec 2010
    @LyNx my measurement was taken at the widest section of knobs and as with all Maxxis tires I install I inflated it to max psi and let it sit over night.
    Mar 2013
    Alright, @ 40psi overnight it's now 2.65" casing width and 2.54" knob to knob. I'm somewhat shocked what a difference it made. After deflating to 21psi, it's 2.59" and 2.49 ", respectively.
    Oh yeah, tyres can grow by a little bit or some grow a whole lot, so much so when you first mount them up and try them they fit with room to spare, then after letting them sit aired up for a few days and try re-installing, they're then a no-go
    Well that grew a bit so once my 2.6 Butcher dies I'll probably pick up a 2.6 DHF...or I see world wide cyclery now has the DHR II in 29x2.6 so that may also be an option. https://www.worldwidecyclery.com/pro...17080308007034
    I've been running 27.5x2.6 DHF/DHRII on my Evil for a year, Definitely 2.6 when stretched first. On my Rallon, I had 2.6" Butcher/Purgatory combo. Hated the drag on the Butcher so I cut Ramps into all the squared off center knobs which helped a lot. Was gonna order DHF/DHR 2.6's but I just swapped to DHF/aggressor 2.5's cuz I had them sitting in my parts bin. To me they roll so much better. Will wait for the 2.6WT swap when the 2.5's wear out. On Maxxis, stretching at max psi is a must. When I have the time, I'll let them stretch for a few days.
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    For dry, rocky, raw terrain, what do you prefer between the 2.6 DHF/DHR2 combo, and the 2.5 DHF/Aggressor combo? I assume the former since it sounds like that is where you are going once the 2.5s wear out. Any comments/thoughts would be most appreciated.
    Mar 2013
    I like the Aggressor better than the DHRII overall. The DHRII is better in the wet and has better braking traction, however it's not exactly snappy when it comes to pedaling uphill. I'd put the DHRII on in the PNW or on an enduro bike that I occasionally shuttle up to the top. The Aggressor pedals better and is great in dry, rocky terrain.
    As far as size goes, it's all about rim width and personal preference. The drier and more sandy the trail, the wider the tire for me. I ride in Northern California, where it's dry 80% of the time, and a lot of the trails are super sandy by August. The 2.6 DHF and 2.5 Aggressor combo is what I have chosen. That said, sometimes I wish I had a Forekaster or DHRII on in the wet winter months.
    Aug 2013
    I'll have to agree.I was out riding in UCSC on Wednesday and hit some wet leave with an Aggressor and went sideways so fast I didn't even have time to react.Swapped it out for a 2.6 Forekaster and am pretty happy with it as a trail tire but will stick a DHF 2.5 WT on the rear for any serious terrain.
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    New tire day. Looks beefy.
    Weight 1009g
    29 x 2.6 120tpi 3c exo
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Quote Originally Posted by alexbn921 View Post
    Weight 1009g
    that is a full pound lighter than my normal tire. Let us know hoe tough and grippy they are.
    Mar 2016
    Quote Originally Posted by mykel View Post
    Good tip.
    Going a bit OT....
    Add tire spooge.
    Check pressure.
    Next day
    or
    Pull the tube.
    Air it up.
    Check pressure.
    This is excellent advice. Since I started allowing my (Maxxis) tires to stretch for at least 48 hours at/near max inflation I have had far fewer problems. Previously, I had some problems with Continental tires and gave up on them. Probably didn't help that I didn't allow them to stretch prior to riding them. Given that tires are the contact point between you and the ground, it is well worth the effort to set them up properly.
    Sep 2017
    Got one ride in on my 2.6 DHF (27.5 version) mounted up front. After stretching at 40psi for two nights it measures exactly 2.6. Compared with with the Magic Mary Addix soft it replaced, the DHF is definitely more predictable on loose over hard. Never felt like the front was gonna wash out on me. Rolling resistance is similar Id say.
    Rocks belong
    Im confused on why Maxxis has 2.5WT and 2.6 DHFs?
    However, Im excited for the 29x2.6 DHR2!
    Feb 2018
    Quote Originally Posted by 06HokieMTB View Post
    Good point, and why wouldn't they be 2.6WT
    DHF breakdown on 30mm internal rims. 29er of course. Both at 30 psi
    2.5 old
    Cassing 61mm
    Square knobs 65.5mm. to center large 10mm
    L knobs 62.5mm. to center large 7mm
    Center small gap 5mm Edge to edge 21.8mm
    Center Large gap 4mm Edge to edge 29.8mm
    2.6 brand new
    Cassing 64mm
    Square knobs 64.5mm. to center large 9mm
    L knobs 63.5mm. to center large 7mm
    Center small gap 5mm Edge to edge 23mm
    Center Large gap 5mm Edge to edge 30.3mm
    2.5 Square blocks are angled out from the tire.
    2.6 blocks are slightly bigger 1mm ish and spacing that gives better more consistant angle. Casing is much bigger.
    Ran the 2.6 at the same 19psi as the 2.5 and it seemed to have better grip.
    Profile of the 2.6 looks slightly more round. Difference is very small.
    2.6 is 8mm taller than the 2.5. probably only 6mm taller vs a brand new tire.
    Updated with better measurements.
    Is that on a new WT 2.5" or the old version 2.5"? Far as I understand, with WT they modified the knob pattern to work better with wider rims. Would be interesting to see comparison photos if you still have both mounted, sounds like some pretty obvious differences in the tread block design.
    DHF breakdown on 30mm internal rims. 29er of course. Both at 30 psi.............good info
    Guest
    The casings feel much different with the 2.6 having quite a bit more volume and lighter with 120tpi. I tried a pair F&R on my Sentinel in EXO on 29mm iw rims, weights were right around 980grams each. My takeaway is these would work great as a trail tire on a short travel or hardtail bike. They're very comfortable, roll very fast and have pretty good grip until pushed hard, then they felt a bit unpredictable to me. I burped the bead off the rear rim in a berm at 19psi so I don't think I'd run them under 21, 22 which takes away some of their advantages. At higher pressures they lost some trail feel at speed, didn't feel stuck to the trail and confidence went down.
    Maybe the EXO plus version would work better but with the additional weight I'd just stick to a beefier casing, DD or E13 Apex TRS which I put back on.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I like the rope idea. Thanks.
    jrm
    jrm is offline
    2.5 DHF & 2.3 Aggressor on 30mm rims.
    When I first put the the 27.5x 2.6 DHF/DHR II's on my Insurgent a year ago, I spoke to the guys Maxxis and was told the the 2.6's were still WT even though they don't have the WT designation. I was gonna put them on some Flow EX's (25.4mm id) but they recommended a wider rim, so I built up some Sentry's w 32mm id. Currently running 2.5wt DHF/AGG on my 29er Rallon until they wear out then 2.6's get installed. For a big guy, Traction on the 2.6's is confidence inspiring.
    My 2.5 are WT. I updated all my measurements on my previous post.
    Mar 2016
    Quote Originally Posted by bob-o View Post
    EDIT: I'd sell these tires for half of what I paid, they have 2 rides on them and no more than 30 miles. PM if interested.
    A wider rim (around 35mm IW) helps with the stability/predictability and allows lower pressures to be run with less tire performance loss. I also run 2.4's EXO on 30mm IW wheels on a trail bike and would expect some loss of stability/predictability if running larger tires, especially at 120tpi. It's a fine line but very noticeable when pushing the bike hard.
    Sep 2018
    Dhf/she actual width
    The 29x3 dhf and dhrs actually come out to almost exactly 29x2.75 on my 35 mm rims
    Mar 2011
    Shot you a PM
    Reputation: Nomadllc's Avatar
    Nov 2012
    Kind of wish I would have seen this thread before ordering and mounting my new 29x2.6 DHF. The 29x2.5WT I moved from the front to the rear is considerably bigger with a better profile. These are mounted to 34id Reynolds wheels. I guess I'll see how they ride and report back with pictures.
  1. Maxxis Minion 29x3.00 Minion DHF 3C
    By bonesetter2004 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-19-2019, 07:45 PM
  2. Replies: 9
    Last Post: 02-13-2018, 02:06 PM
  3. Maxxis Minion DHF 3C/EXO/TR 2.3" vs 2.5" Experiences?
    By Scottyman in forum Wheels and Tires
    Last Post: 05-09-2017, 02:34 PM
  4. Replies: 4
    Last Post: 03-21-2017, 10:06 AM
  5. Minion DHF/DHF or DHF/DHR for Downieville?
    By Taz8 in forum California - Norcal
    Last Post: 07-13-2007, 02:22 PM
Members who have read this thread: 66
