Maxxis Ikon EXO w/ sealant...is there a sealant that willl not bubble these tires.- Mtbr.com
Results 1 to 13 of 13
    Jun 2013
    I have one of the Ikons that I want to use as a rear. It's new and have not used it because of the bubbling issue articulated so many times on the "long term" thread.
    However, I wonder if is related to Stan's or is there another sealant that has more success with this tire, ie Slime, Orange, etc.
    Reputation: bholwell's Avatar
    Oct 2007
    I've ran many Ikons over the years with Stan's sealant and never had a problem (and I still do). Most of the tread separation issues I've seen, though, have been with Stan's. Use Slime Pro, if it gives you some piece of mind.
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Daniel the Dog
    I got bubbles in both my Ikkons but it took nearly a year on both with Stan's sealant.
    Reputation: Gman086's Avatar
    The non-natural latex sealants like Bontrager TLR do NOT contain ammonia and will not bubble tires. Last a lot longer than the natural latex sealants too!
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Reputation: shiggy's Avatar
    Dec 1998
    Maxxis Ikon EXO w/ sealant...is there a sealant that willl not bubble these t...
    Quote Originally Posted by White Bear View Post
    Yes. Butyl rubber. AKA an inner tube.
    mtbtires.com
    Happy Trails
    Reputation: Scott In MD's Avatar
    Stan's. No problems over 1 year on two bikes with Ikons. Also, tubeless is better.
    Reputation: madskatingcow's Avatar
    Quote Originally Posted by Gman086 View Post
    Correct : you can use Caffelatex and Stan's Revo Sealant which are synthetic formulated sealants as well. Caffelatex is the only sealant recommended for usage in Dugast Tubulars.
    Jun 2013
    Looks like it takes a year or so for the migration into the layers. Since this is on a back-up bike, I'll probably just use a tube. Whoever borrows it probably won't care anyway.
    Thanks for the tips on Stan's Revo, which I've not heard of. BTW, do any of the alternatives, such as Caffelatex last any longer? I'm finding that 2 months is the "safe" gap for me. At 3 months, it's marginal, and 4 months is just not effective at sealing a puncture.
    It would really be nice to see a test with the different sealants over time. Like the Stan's video with the ice pick, but conducted at one month intervals.
    From Stan's FAQ page
    I heard there is ammonia in your sealant and it is bad for my tire and or rim?
    Any trace amount of ammonia in Stanís sealant will evaporate soon after it is injected into the tire. We have found no damaging effects from our sealant even after years of use. Any oxidation in your rim will just as likely be caused by riding in wet conditions or the humidity in the air. Although tape may not be necessary to seal your rim, you may add one layer to protect un-anodized or scratched areas of your rim from oxidation due to moisture in the sealant.
    Will using your sealant void the warranty on my tire?
    Using our sealant will void your tire warranty with certain manufacturers. Stanís NoTubes Sealant will not damage your tire.
    Jun 2013
    Quote Originally Posted by drjay9051 View Post
    And the truth shall set you free!
    I made a little typo - it's Continental Revo
    Continental Revo or Caffelatex don't last any longer, I would say about the same. I have done last year some puncture testing myself - sealing bigger holes : the best was Sludge / NoZisch, followed by Caffelatex.
    Caffelatex is easier to remove from the tires and doesn't stick the sidewalls together in case you have a big cut and need to insert a tube.
    Stan's was OK for punctures with nails up to 2mm, while the other two managed punctures up to 5mm.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Tires dont last anywhere close to a year, so I guess I have nothing to worry about.
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    TLR will easily last a year from my experience. I'm in the Pacific NW where we don't get temperature extremes tho so YMMV.
    Have FUN!
    G MAN
  1. Do UST Tires Need Sealant?
    By IntenseMack10 in forum Wheels and Tires
    Last Post: 06-12-2016, 07:05 PM
  2. New tire sealant from Continental, Revo Sealant
    By CrozCountry in forum Wheels and Tires
    Last Post: 02-03-2016, 03:25 PM
  3. Stan's Sealant - trying to seal Maxxis Crossmark
    By StumpjumperUK in forum Wheels and Tires
    Last Post: 09-17-2012, 02:13 PM
  4. Maxxis Ignitor + Stan's sealant + time = blisters
    By 40hills in forum Wheels and Tires
    Last Post: 04-19-2012, 04:29 PM
  5. Schwalbe Tires and Sealant
    By Drth Vadr in forum All Mountain
    Last Post: 01-12-2012, 04:48 AM
