Maxxis Forekaster 2.6 & Ardent Race Tyre pressure- Mtbr.com
Results 1 to 9 of 9
    o27
    o27 is offline
    Apr 2016
    Just got a Forekaster 29x2.6 and 29x2,35 Ardent Race for my SC TB3, weighing in around 200lbs/90 kg with Camelbak - what kind of tyre pressure should i aim for on 29mm IW Carbon wheelset?
    Feb 2018
    I'm about the same weight and ran 22lbs up front on the forekaster.
    Reputation: jeremy3220's Avatar
    Jul 2017
    The 2.6 is going to be more sensitive to getting the pressure right. Basically run it as low as possible without getting rim strikes or squirm.
    always licking the glass
    Reputation: stripes's Avatar
    Sep 2016
    I run my 2.6 forekaster between 20-22 psi.
    Guerrilla Gravity BAMF, Colorado Front Range
    https://classifieds.mtbr.com/showpro...product=116154
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by o27 View Post
    I'd be looking for tips on the Ardent.....Rekon may be better suited.
    Ripley V1 XC/Gravel Adventure rig
    Marin Hawk Hill 2.5
    o27
    o27 is offline
    Apr 2016
    The Forekaster 2.6 is not that much wider than the 2.35 AR, so would recon the pressure should be fairly similar.
    I ran 2.6 DHR and 2.6 AR in 27,5 on my old bike with 29iw rims, and ran at 16 PSI front and 18 PSI rear.
    o27
    o27 is offline
    Apr 2016
    Just had a few rounds on the local single track and tried out 21 PSI front and 23 PSI rear, its not 100% dialed in but not far off. Can it be right I can comfortably ride 23 PSI rear?
    Demon Cleaner
    Reputation: Structure's Avatar
    Im comfortable at 20-21 in my Forekaster in front. I have to run closer to 25-26 to avoid rim strikes in the rear with an Ardent Race. Im 180 lbs riding weight. Using 30 iw carbon rims.
    Bicycling is politics by other means.
    o27
    o27 is offline
    Apr 2016
    Appreciated
  1. Maxxis Ardent / Forekaster - Which one front & rear?
    By Ulairi in forum Wheels and Tires
    Last Post: 11-15-2019, 07:12 PM
  2. Maxxis Ardent race 2.35 and Ardent 2.4 size difference if any?
    By Biohazard74 in forum Wheels and Tires
    Last Post: 03-16-2019, 01:54 PM
  3. Replies: 0
    Last Post: 04-12-2018, 10:27 AM
  4. Tyre Pressure & Front Suspension Pressure on 2009 Badboy
    By fumi in forum General Discussion
    Last Post: 07-05-2013, 10:30 AM
  5. UR tyre pressure - weight - tyre size - ride type
    By John Lazzara in forum Wheels and Tires
    Last Post: 02-22-2013, 09:14 PM
Members who have read this thread: 55
