Maxxis Flyweight 330, Maxxis Ignitor & Continental Explorer Supersonic- Mtbr.com
Results 1 to 5 of 5
    I can't seem to get much info about the above mentioned tyres and would appreciate your experience about these tyres such as it's grip, durability, performance in mud, road, gravel etc.
    Thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by 9W6VX
    Thanks.
    Ignitor: I have a ride or two on one (front mounted). All on dry trail, hardpack to loose, some rock. Rode well. Good grip and braking. Washed out hard in one sandy corner. Specs on my Site.
    Explorer Supersonic: Race tire. Wears quickly. Less flat resistance than the Pro version. Otherwise performs the same.
    mtbtires.com
    Quote Originally Posted by shiggy©®™
    Any info or experience/feedback on the Maxxis Flyweight 330's?
    Thanks. Will check out your website later.
    I use Flyweight
    Very good tires. Light. Thin. Low spikes. Easy to ride. Easy to puncture. I use them mostly for asphalt. If you want to swim in mud -- I do not think they will be good.
    You are correct mate.
    The Flyweight 330's puncture easily, the casing seems too soft but they roll superbly and are very light. Use a flyweight tube of about 100grams and the total weight per wheel is only 330+100grams=430 grams.
    Very sweet!
    Unfortunately I fel that the negatives outweighed its positive attributes.
  1. Continental Supersonic Explorer vs. Vertical Pro? DIFFERENCES?
    By SCHUMACHER in forum General Discussion
    Last Post: 01-13-2004, 02:42 PM
