Mavic CrossMax SX 20mm to 15mm end cap adapters??? Please help???- Mtbr.com
Results 1 to 8 of 8
    Feb 2010
    I have a pair of Mavic CrossMax SX's from 2008. They are set up for 20mm thru axle but i was hoping to mount them on my 2009 enduro which sports a 2010 Float with a 15mm qr thruaxle. I have done a fair amount of research and it seems there is a lot of mixed info regarding if this front hub can be converted from 20mm to 15mm. As it can convert from 20mm to 9mmQR, i do not understand the reasoning on why there is no mavic conversion from 20 to 15mm. I have found some old post http://www.mtbr.com/cat/suspension/2...0_6513crx.aspx where people ordered machined end caps from Risse Racing in Redding...seems the company is closed down. Any other advice on finding someone who is able to machine this part???? Please Help
    Rob
    H2o-Bar
    Mar 2006
    Did you get the 9mm end cap's with your wheelset?
    If so it's pretty straight forward. Just check out this thread.
    http://forums.mtbr.com/showthread.php?t=467294
    No so sure whats available thru Mavic but this worked for me. Good luck.
    I got some of those from risse like two months ago... They work perfect. Web site is still up...
    http://www.risseracing.com/
    I think $20'plus 5 for shipping...
    Reputation: Steamer19's Avatar
    Nov 2006
    I assume that in order to fit 20mm, there must be a plug that inserts and extends the width to the 110mm standard for 20mm. When these plugs are removed, the plug for the QR is shorter to allow it to fit in a 100mm fork drop out?
    Nov 2006
    Will the 15mm end caps from the 2012 SX wheelset work on the 2011 SX front wheel?
    Bump for a answer .
    Will the newer adapotors fit the older wheels ?
    I'm also not sure what year my wheels are they're white hubs , grey rims sx's of course
    I'm looking for similar adapters as well
    Just wanted to reiterate interest in these types of parts from Mavic (or someone else).
    I've got a pair of ~2004 deemax wheels that are not being used that I'd like to convert to 15mm. They're currently setup using 20mm and I have the adapters for 9mm. I sent an email to Risse, but have not heard back.
    Got the adaptor . Ended up using a 20mm fork instead .
    But the Risse adaptor fit with ease
