I have a set of Mavic Crossmax SL SSC wheels I've used with standard 9MM QR fittings and looking to use them with 15mm x 100mm thruaxle.
Having a hell of time locating correct adapter, and it looks like there are quite a few different ones, - (mostly because I've have these a while and can't locate the OE #). The label on the wheel does not come up on website.
Whatever they are, just looking to determine what Mavic adapter# to chase down to use as with 15m thru axle.
Here's what I know:
26" wheel
id label - 60382573
24 spoke, 2x, and silver
axle in hub 100mm and fits in bearings with 17mm id
id of wheel bore is 30mm
depth of bearing to outside lip 6mm.
any help appreciated - TIA!
Mavic Crossmax SL SSC what adapter to 15mm axle?-img_20191107_102500519.jpgMavic Crossmax SL SSC what adapter to 15mm axle?-img_20191107_101956834.jpgMavic Crossmax SL SSC what adapter to 15mm axle?-img_20191107_101929588_hdr.jpgMavic Crossmax SL SSC what adapter to 15mm axle?-img_20191107_101909203_hdr.jpgMavic Crossmax SL SSC what adapter to 15mm axle?-img_20191107_101838919.jpg
