Mavic Crossmax- Mtbr.com
Results 1 to 5 of 5
Thread: Mavic Crossmax
    Mavic Crossmax
    I picked up a used bike cheap. The rear rim (Mavic 317) took a good hit and I need to take it to the LBS and see if it's able to be trued. The front rim is an older Mavic CrossMax with the flat bladed spokes. From what I've read, the Mavic rear hubs are problematic and require a lot of maintenance, but not too many reports of issues with the fronts. I'm trying to decide which way to go with this. The rear rim may need to be replaced, so it would make sense to pick up another CrossMax for the rear. I'm kind of anal about having matching rims. What would you do?
    Reputation: 4slomo's Avatar
    Consider replacing the rear wheel with a new wheel, and maybe a matching rim for rebuilding the front to coordinate, if that makes you feel better. If you have the budget, consider a new wheelset from BWW, or wherever you can get the best deal.
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    Quote Originally Posted by pcmark View Post
    Mavic hubs are fine the maintaince takes about 5 minutes to do...
    Work with the LBS you will probably get a quick cheap fix...
    If not buy new....consider mavic and others
    Take Chances
    Reputation: cadmanrjm's Avatar
    Dec 2005
    crossmax
    I have a pair from 2008 that I am thinking of getting rid of. I replaced the bearings and the cassette hub in 2010 then shelved them when I got a pair of Easton Havens.. QR front and rear.
    let me know if your interested, $300
    Cadmanrjm
    Quote Originally Posted by cadmanrjm View Post
    I'll keep that in mind. I really only need a rear though.
