Results 1 to 7 of 7
    Nov 2016
    Interesting Conundrum - CushCore Tire Wobble
    I just put CushCore in my front and rear wheels. The front with a 2.5 Minion DHF went on with no issue. The rear 2.4 Aggressor was a pain. The front is spinning as true as can be but the rear is showing definite wobble. This is where it gets interesting. I put a pipe cleaner on the seat stays with a clearance of barely anything off of both the wheel and tire on both sides and it never touched but there is a definite shake when spinning the bike in the stand. Is it possible that there is a heavy spot causing it? If so, any ideas on how to correct it? I'm at a loss here. There is sealant in both tires.
    Reputation: life behind bars's Avatar
    May 2014
    Re-seat the offending tire.
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Nov 2016
    Took the tire off tonight. I don't have a trueing stand so can't be 100% certain but the wheel looks true. When running just the insert the wobble is pronounced. Don't know if that's a normal thing or if I got a bum insert.
    Sent from my SM-N950U using Tapatalk
    Reputation: the_joe's Avatar
    Feb 2017
    Do you know that the wobble isnt coming from the tire itself? Thats not uncommon.
    2008 BMC Fourstroke 19-559 ISO (RIP in peace)
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
    Nov 2016
    Quote Originally Posted by the_joe View Post
    Yeah, there wasn't a tire on it tonight when I got the insert to wobble.
    I'd considered that but it wasn't doing it pre-install so double checked.
    Nov 2016
    So, I talked to the guys at Cush Core and they got me sorted. Needed to pull up on the tire and insert before inflating all the way around the rim. Wobble is gone.
    Nov 2017
    I have had to balance mine. There inconsistent
    Li have also pinched the side of its and it was tucked into itself and caused a tire wobble.
    They can be tricky.
  1. Cushcore Kit Review
    By Justin MD in forum Wheels and Tires
    Last Post: 01-04-2019, 10:25 AM
  2. Replies: 82
    Last Post: 06-06-2018, 03:17 PM
  3. Thoughts on tire insert (cushcore) lowering the tire volume
    By legitposter in forum Wheels and Tires
    Last Post: 12-23-2017, 05:11 AM
  4. Cushcore inserts 29"
    By Redeye in forum Classifieds
    Last Post: 08-02-2017, 09:56 AM
  5. snap wobble wobble
    By jeffn5 in forum Clydesdales/Tall Riders
    Last Post: 01-22-2011, 08:52 PM
Members who have read this thread: 49
